2022CUDA夏季训练营Day5实践
张辉 发表于 2022/07/12 14:40:41 2022/07/12
【摘要】 CUDA
2022CUDA夏季训练营Day1实践 https://bbs.huaweicloud.cn/blogs/364478
2022CUDA夏季训练营Day2实践 https://bbs.huaweicloud.cn/blogs/364479
2022CUDA夏季训练营Day3实践 https://bbs.huaweicloud.cn/blogs/364480
2022CUDA夏季训练营Day4实践之统一内存 https://bbs.huaweicloud.cn/blogs/364481
2022CUDA夏季训练营Day4实践之原子操作 https://bbs.huaweicloud.cn/blogs/364482
Day4课后作业如下:
其中第一题,在上面的Day4链接中,张小白已经做了。
那么第二题怎么做呢?
老师提供了一个函数是给top k个字段排序的:
__device__ __host__ void insert_value(int* array, int k, int data)
    for (int i = 0; i < k; i++)
        if (array[i] == data)
            return;
    if (data < array[k - 1])
        return;
    for (int i = k - 2; i >= 0; i--)
        if (data > array[i])
            array[i + 1] = array[i];
        else {
            array[i + 1] = data;
            return;
    array[0] = data;
我们求解top10的思路是什么呢?
当然仍然是延续这个万能的框架。
我们来看下求最大值和最小值的框架,只留下最大值的部分:
2_1.cu
#include<stdio.h>
#include<stdint.h>
#include<time.h>     //for time()
#include<stdlib.h>   //for srand()/rand()
#include<sys/time.h> //for gettimeofday()/struct timeval
#include"error.cuh"
#define N 10000000
#define BLOCK_SIZE 256
#define BLOCKS ((N + BLOCK_SIZE - 1) / BLOCK_SIZE)
__managed__ int source[N];               //input data
__managed__ int final_result[2] = {INT_MIN,INT_MAX};   //scalar output
__global__ void _sum_min_or_max(int *input, int count,int *output)
    __shared__ int max_per_block[BLOCK_SIZE];
    int max_temp = INT_MIN;
    for (int idx = threadIdx.x + blockDim.x * blockIdx.x;
         idx < count;
         idx += gridDim.x * blockDim.x
        max_temp = (input[idx] > max_temp) ? input[idx] :max_temp;
    max_per_block[threadIdx.x] = max_temp;  //the per-thread partial max is temp!
    __syncthreads();
    //**********shared memory summation stage***********
    for (int length = BLOCK_SIZE / 2; length >= 1; length /= 2)
        int max_double_kill = -1;
        if (threadIdx.x < length)
            max_double_kill = (max_per_block[threadIdx.x] > max_per_block[threadIdx.x + length]) ? max_per_block[threadIdx.x] : max_per_block[threadIdx.x + length];
        __syncthreads();  //why we need two __syncthreads() here, and,
            max_per_block[threadIdx.x] = max_double_kill;
        __syncthreads();  //....here ?
    } //the per-block partial sum is sum_per_block[0]
    if (blockDim.x * blockIdx.x < count) //in case that our users are naughty
        //the final reduction performed by atomicAdd()
        if (threadIdx.x == 0) atomicMax(&output[0], max_per_block[0]);
int _max_min_cpu(int *ptr, int count, int *max1, int *min1)
    int max = INT_MIN;
    for (int i = 0; i < count; i++)
        max = (ptr[i] > max)? ptr[i]:max;
    //printf(" CPU max = %d\n", max);
    *max1 = max;
    return 0;
void _init(int *ptr, int count)
    uint32_t seed = (uint32_t)time(NULL); //make huan happy
    srand(seed);  //reseeding the random generator
    //filling the buffer with random data
        //ptr[i] = rand() % 100000000;
        ptr[i] = rand() ;
        if (i % 2 == 0) ptr[i] = 0 - ptr[i] ;
double get_time()
    struct timeval tv;
    gettimeofday(&tv, NULL);
    return ((double)tv.tv_usec * 0.000001 + tv.tv_sec);
int main()
    fprintf(stderr, "filling the buffer with %d elements...\n", N);
    _init(source, N);
    //Now we are going to kick start your kernel.
    cudaDeviceSynchronize(); //steady! ready! go!
    fprintf(stderr, "Running on GPU...\n");
double t0 = get_time();
    _sum_min_or_max<<<BLOCKS, BLOCK_SIZE>>>(source, N,final_result);
    CHECK(cudaGetLastError());  //checking for launch failures
    CHECK(cudaDeviceSynchronize()); //checking for run-time failures
double t1 = get_time();
    fprintf(stderr, " GPU max: %d\n", final_result[0]);
    //Now we are going to exercise your CPU...
    fprintf(stderr, "Running on CPU...\n");
double t2 = get_time();
    int cpu_max=0;
    int cpu_min=0;
    int B = _max_min_cpu(source, N, &cpu_max, &cpu_min);
    printf(" CPU max = %d\n", cpu_max);
    printf(" CPU min = %d\n", cpu_min);
double t3 = get_time();
    //fprintf(stderr, "CPU sum: %u\n", B);
    //******The last judgement**********
    //if ( final_result_max == cpu_max   &&  final_result_min == cpu_min  )
    if ( final_result[0] == cpu_max    )
        fprintf(stderr, "Test Passed!\n");
    else
        fprintf(stderr, "Test failed!\n");
	exit(-1);
    //****and some timing details*******
    fprintf(stderr, "GPU time %.3f ms\n", (t1 - t0) * 1000.0);
    fprintf(stderr, "CPU time %.3f ms\n", (t3 - t2) * 1000.0);
    return 0;
编译运行:
那么,我们继续在这个框架的基础上,把计算top 10的部分加上去。
该怎么加呢?
显然的,需要把上面计算max的部分全部换成计算top10的部分:
我们看到上面两个定义:
int max_temp =0;
max_per_block是存放最大值的,现在要存放topk(k=10)个最大值,所以显然我们需要将max_per_block[BLOCK_SIZE]扩容成 max_per_block[BLOCK_SIZE* topk],
为了对比方便,将max_per_block改为 topk_per_block:
同理,将max_temp扩充为 topk_temp[topk];
第2个地方:根据 inut[idx]计算出 topk_temp:
直接改为
insert_value(topk_temp, TOPK, input[idx]);
第3个地方:根据topk_temp 计算出 topk_per_block[ threadIdx.x * TOPK ]到 topk_per_block[ threadIdx.x * TOPK+TOPK-1 ] :
改为:
for(int i = 0; i< TOPK ; i++)
        topk_per_block[ threadIdx.x * TOPK + i] = topk_temp[i];
第4个地方:
这里原来是取 max_per_block[threadIdx.x] 和 max_per_block[threadIdx.x + length]) 间的最大值,同样换成insert_value函数:
 for(int i=0;i<TOPK ;i++)
     insert_value(topk_temp, TOPK , topk_per_block[  (threadIdx.x + length) * TOPK + i]);
第5个地方:
改为:
     topk_per_block[threadIdx.x *TOPK  + i]= topk_temp[i];
第6个地方:
改为:
         output[TOPK * blockIdx.x +i ] = topk_per_block[i];
注:这里可以更简单的改为:
if (threadIdx.x < TOPK)  output[TOPK * blockIdx.x + threadIdx.x  ] = topk_per_block[threadIdx.x];
这样直接整体并行写入即可,而且还是合并的。
核函数改完之后,调用核函数的地方也做以下改动:
改为
_sum_min_or_max<<<BLOCKS, BLOCK_SIZE>>>(source, N, _1pass_results);
_sum_min_or_max<<<1, BLOCK_SIZE>>>(_1pass_results, TOPK * BLOCKS, final_result);
这里需要解释一下,为啥原来取最大值的时候调用一次核函数就行了,但是取TOPK就需要调用2次呢?
因为并没有一个同时处理TOPK个元素替换的原子操作(但是有很多替换1个元素的原子操作)
当然,比较CPU和GPU的地方也做相应的改动(这点看下面的代码就行了)
修改完的代码如下:
2_1.cu
#include<stdio.h>
#include<stdint.h>
#include"error.cuh"
#define N 10000000
#define TOPK 10
__managed__ int final_result[TOPK] = {INT_MIN};   //scalar output
__managed__ int _1pass_results[TOPK * BLOCKS];
            return;
        return;
        else {
            return;
    array[0] = data;
    //__shared__ int max_per_block[BLOCK_SIZE];
    __shared__ int topk_per_block[BLOCK_SIZE * TOPK];
    //int max_temp = INT_MIN;
    int topk_temp [TOPK];
    for(int i=0;i<TOPK;i++) topk_temp[i] = INT_MIN;
         idx < count;
        //max_temp = (input[idx] > max_temp) ? input[idx] :max_temp;
    //max_per_block[threadIdx.x] = max_temp;  //the per-thread partial max is temp!
    __syncthreads();
        //int max_double_kill = -1;
            //max_double_kill = (max_per_block[threadIdx.x] > max_per_block[threadIdx.x + length]) ? max_per_block[threadIdx.x] : max_per_block[threadIdx.x + length];
            //max_per_block[threadIdx.x] = max_double_kill;
                 topk_per_block[threadIdx.x * TOPK  + i]= topk_temp[i];
        // if (threadIdx.x == 0) atomicMax(&output[0], max_per_block[0]);
    int max = INT_MIN;
    *max1 = max;
    return 0;
void cpu_result_topk(int* input, int count, int* output)
    /*for (int i = 0; i < TOPK; i++)
        output[i] = INT_MIN;
        insert_value(output, TOPK, input[i]);
        ptr[i] = rand() ;
double get_time()
    struct timeval tv;
int main()
    cudaEvent_t start, stop;
    CHECK(cudaEventCreate(&start));
    CHECK(cudaEventCreate(&stop));
    _init(source, N);
    CHECK(cudaEventRecord(start));
    // _sum_min_or_max<<<BLOCKS, BLOCK_SIZE>>>(source, N,final_result);
    CHECK(cudaEventRecord(stop));
    CHECK(cudaEventSynchronize(stop));
        fprintf(stderr, " GPU max[%d]: %d\n", i,final_result[i]);
    int cpu_result[TOPK] = { 0 };
    //int cpu_max=0;
    //int cpu_min=0;
    //int B = _max_min_cpu(source, N, &cpu_max, &cpu_min);
    cpu_result_topk(source, N, cpu_result);
    //printf(" CPU max = %d\n", cpu_max);
    int ok = 1;
    for (int i = 0; i < TOPK; ++i)
        printf("cpu top%d: %d; gpu top%d: %d \n", i + 1, cpu_result[i], i + 1, final_result[i]);
        if (fabs(cpu_result[i] - final_result[i]) > (1.0e-10))
            ok = 0;
    if (ok)
        printf("Pass!!!\n");
    else
        printf("Error!!!\n");
    else
	exit(-1);
    return 0;
我们来运行一下:
这样下去,算top5,top20,top50应该都是可以的吧?
top5:
top20:
top50:
LOL,张小白想得太美好了~~
只好改为top40看看:貌似算得有点慢了,但是还能出个结果:
那到底有什么好的计算方式呢?
还有,现有方式还能提速吗?
这个萧敬腾的天气,又给张小白创造了好几个难题。。。。
看来还得好好学习啊。。。
另外,张小白忘记自己还有个Jetson AGX Orin了。让我们看看它能不能突破下极限:
仍然用top40计算。
确实比Nano快很多(但是仍然跑不过CPU)
改成top50:
额,还是编译不过去。4G内存和32G内存的设备,看来shared memory是一样大的??
张小白默默看了下定义:
当然是的。一个block最多能用48kB。也就是说,如果BLOCK_SIZE设置成前面代码中的256的话,那么TOPK为50的时候,256X50X4已经超过48K了。(1个int占用4个字节)。所以樊老师说了,BLOCK_SIZE=256的时候,TOPK最大能到48。
我们试试:
#define TOPK 48
Nano的表现:
改成TOP49,果然不可以编译:
那只有一种办法了,就是降低BLOCK_SIZE,比如说改为128。根据前面的算法,128X4X96等于48K。以此类推,可以算到64,32时候的TOPN最大数量。
我们也就不一一截图了,直接用表格填入结果:
只贴一个:
表格如下:
TOPN BLOCK_SIZE Nano CPU(ms) NanoGPU(ms) Orin CPU(ms) Orin GPU(ms)
5 256 433.401 252.809 131.366 44.420
10 256 107.692 777.333 240.604 99.995
20 256 476.221 3414.480 511.257 256.927
40 256 765.036 29736.022 1079.476 1576.126
48 256 845.735 40406.832 1259.630 224.732
50 256 编译错 编译错
50 128 882.799 34380.985 1355.741 1512.643
100 64 1575.113 94527.526 2709.505 1940.573
96 128 1513 138183.392 2576.214 5307.144
97 128 编译错 编译错
192 64 2831.961 653679.935 5193.001 6091.511
193 64 编译错 编译错
384 32 太长不算了 太长不算了 70072.332 10363.466
385 32 编译错 编译错
48 128 859.618 32778.153 1293.652 1194.083
48 64 853.534 21058.578 1293.964 926.699
48 32 845.070 15701.802 1292.892 997.095
注:上述结果仅为一次测量结果。不排除多次测量会出现抖动或者差异很大的情况。
以上的结果确认了几个事情:
1.共享内存最大确实只有48K,多一毛都没有。想挤牙膏很难。
2.目前的这种reduce算法还是存在很大的局限性的,它在TOPN较小的时候较为高效。
3.对于TOPN较大,还不如直接调用cublas或者thrust做完全排序(不过这个张小白因为不考试——所以没好好学。。LOL。。下次补上)
4.减小BLOCKSIZE确实可以计算,但是BLOCKSIZE越小,SN占有率就越小。一个SM最多可以驻留2048(或者少一点)的线程,在BLOCKSIZE=128时,占有率为 6.25%;BLOCKSIZE=64时,占有率为 3.125%;BLOCKSIZE=32时,占有率为 1.5625%。从上面的结果也可以看出,BLOCKSIZE变化确实会引起性能较大的变化。
如TOP48:
Orin从BLOCK 256-》128-》64》32分别是 224ms-》1194ms-》926ms-》997ms。后面几个差距不大(因为存在预热),但是256到128发生巨变,说明最佳值在256这里。
Nano从BLOCK 256-》128-》64》32分别是40s-》32s-》32s-》15s。反而是BLOCK越小速度越快。当然这个并不能说明有这个正比关系。只能说明Nano设备并不是运行TOP48的最佳机选。
所以,下次考试,如果可以换成Orin集群。。那大家考试将会多爽啊~~~
在最终开发CUDA程序的时候,是从整个程序的角度发力,如果一个地方并不是关键的,那没有必要优化到极致。用什么算法都可以。先应该花力气解决最关键的部分。
注:往TOPK个元素中插入TOPK个元素,并最终保留TOPK个元素(就是只留下TOPK个元素),如果使用插入法,时间复杂度为O(n^2)的。随着K的扩大,比如从10个变成100个的情况下,算法时间的变大将是灾难性的。这点其实在张小白的测试中也可以略微看出。
其实有训练营的童鞋提出了线性的解决方案,比如双指针法,又比如bucket法,可以将两组TOPK个元素组合成1组按高低排序的K个元素,这个时候的算法时间复杂度是O(n)。另外,针对随机数本身的分布特性,还可以快速求出TOPK。这点,张小白只好留做一个问题,将来再研究了。。。
(未完待续)
