- 预审中
- 预审通过
- 3 已采纳
- 4 已实现
【产品缺陷】【AI Shell】Failed to clone repository 已采纳 编辑 删除
- 华为云码道(CodeArts)代码智能体
- 软件开发生产线 CodeArts
来源: GitCode Issue #273 by 李尚昱 (https://gitcode.com/developer-skill/vod-skill/issues/273)
描述问题 (Description)
复现步骤 (To Reproduce)
用户在AI Shell中运行安装命令,尝试从GitHub克隆huaweicloud-skills仓库时失败
预期行为 (Expected behavior)
成功克隆仓库并完成skills安装
错误堆栈 (Stack Trace)
``` Failed to clone https://github.com/huaweicloud/huaweicloud-skills.git: Cloning into '/tmp/skills-Z6Lzvi'... error: RPC failed; curl 16 Error in the HTTP2 framing layer fatal: expected flush after ref listing Tip: use the --yes (-y) and --global (-g) flags to install without prompts. Installation failed ```
yd_235587802
发布于 2026-07-10 18:00:06
2026-07-10
5949 1
删除建议
全部评论(1)
评论(1)
