- 预审中
- 2 预审不通过
【用户体验】Agent's quite useless. 预审不通过 编辑 删除
- 图像搜索 ImageSearch
- 智能体 iCity
- 智能问答机器人
- 网络智能体
- 图像搜索服务
- 云地图服务 KooMap
- 开天aPaaS
- 对话机器人服务
场景描述:Sorry I'm using a business PC without Chinese typing. I've tried creating one agent to analyse what areas each installation company covers so that when I give a postcode the agent can suggest which installer I can go to.
The agent spent a lot of time analysing. However, it can't read PDF properly. I had to manually convert them to docx. And then it can't read pictures. 10 minutes' gone and nothing's done. Then I tried Claude and within seconds it analysed all the PDFs and listed each installation company's covered areas and suggested which didn't specify.
建议方案:
The agent should be able to equip with plug-ins in real time to deal with any task. And the speed should increase. It's far from being an agent now.
yd_211116208
发布于 2026-04-06 18:14:59
2026-04-06
44 1
删除建议
全部评论(1)
评论(1)
Thank you for your feedback. To better understand your feedback, please provide the name of the cloud service involved and a detailed description of the issue, and attach screenshots and links. This will help us verify and resolve the issue as soon as possible. Thank you for your support of Huawei Cloud.
