CodeArts Crash Course Micro-Certification: How I Scored 92
Yesterday I passed the CodeArts Practical Crash Course micro-certification (CodeArts 实战速成微认证) with 92 out of 100 — 22 of the 24 questions correct. The pass mark is 70, the exam has 24 questions, and the time limit is 45 minutes. Here is exactly how I prepared, and what I would focus on if I took it again.
The exam at a glance
- 24 questions, 45 minutes, pass mark 70/100
- My result: 92/100 (22 correct, 2 wrong)
How I prepared
1. Finished the companion course — 100%
I worked through the full companion course before the exam and completed it to 100%, without skipping chapters. That gave me a solid base to work from on exam day.
2. Used the Chapter 8 self-test (5 questions) as a checkpoint
In Chapter 8 I took the 5-question self-test and treated it as a checkpoint, not a formality. Any question I got wrong or had to guess at told me which part of that chapter I had not really understood, so I went back to that section before moving on.
3. Reviewed the weak spots, then stopped
In the end I got two questions wrong, and they matched the areas I had been least sure about during preparation. If I had one more day, I would have re-read exactly those sections instead of re-reading everything.
Exam tips
- Pace yourself: 45 minutes for 24 questions is under two minutes per question. Read each question once, answer it, and move on. Do not let one hard question eat the time for three easy ones.
- Trust the course. If you finished the course to 100% and worked the chapter self-tests honestly, you have already covered the ground the exam tests.
- Use the self-tests as diagnostics. A wrong answer in a self-test is cheap; the same gap in the exam costs points. Go back to the source section for every question you miss or guess.
- Do the Chapter 8 self-test last. It is a good final check that the earlier chapters stuck.
Result
92/100 — 22 of 24 correct, against a pass mark of 70. The preparation that paid off most was simply finishing the course completely and using the Chapter 8 self-test to find my weak spots before exam day.
If you are preparing for the same micro-certification, start with the course, finish it to 100%, and let the self-tests tell you where to review. Good luck!
