Small Cloud Server Daily Checks: Disk, Logs, Backups
yd_292978551 发表于 2026/11/05 10:16:18 2026/11/05
【摘要】 A small cloud server usually fails quietly. Disk space fills up, a service stops after a restart, or a backup turns out to be empty when it is needed. A short daily check catches most of these prob...
A small cloud server usually fails quietly. Disk space fills up, a service stops after a restart, or a backup turns out to be empty when it is needed. A short daily check catches most of these problems before they become an outage.
1. Disk and inodes first. Check free space and inode use, not just total disk size. A full disk can stop logging, updates, and database writes at the same time. If space is low, look for growing logs, old package caches, and unrotated application logs before deleting anything. Never delete a log or database file that is still open without understanding what depends on it.
2. Services and listening ports next. Confirm the services you expect are actually running, and that they survived the last reboot. A service that starts by hand but is not enabled will look fine until the next restart. Check the listening ports for the web service and SSH, and confirm the firewall or security group still matches the intended exposure.
3. Logs with a time window. Read the last day of system and application logs, not just the last few lines. Look for repeated authentication failures, out-of-memory messages, failed scheduled jobs, and certificate warnings. A single error is often noise; the same error every hour is a pattern.
4. Verify a backup, do not just trust that it ran. A backup job can report success while producing an incomplete archive. Once a week, restore a small test file or a database dump to a temporary directory and confirm it opens. Keep at least one copy outside the server itself, for example in object storage, so a server failure does not take the backup with it.
5. Certificates, updates, and scheduled jobs last. Note the expiry date of any TLS certificate, apply security updates in a planned window, and confirm scheduled jobs actually ran. A missed backup job or a missed renewal is easy to overlook until it causes downtime.
This routine takes only a few minutes on a small server, and it is much cheaper than recovering from a full disk, a failed restore, or an expired certificate.
