Elasticsearch 6.0.0本地单机16核32G压测报告
岳涛 发表于 2026/10/31 08:32:54 2026/10/31
【摘要】 Pip:10.0.1 from pip (python 3.6)
环境配置
注:这套环境配置为本文验证通过的环境配置及版本,避免踩坑请尽量按照环境配置里提到的配置及版本
Esrally客户端环境
版本
Linux环境:Centos 7.9
Python:3.6.7
Java:openjdk version 1.8.0_302 (build 1.8.0_302-b08)
Git:2.7.5
Esrally:2.3.0
配置
内存:32G
硬盘:SSD云硬盘 100GB
CPU个数:1
CPU核心数:16
Elasticsearch服务端环境
版本
Linux环境:Centos 7.2
Java:openjdk version 11.0.9.1-ga (build 11.0.9.1-ga+1, mixed mode)
Elasticsearch版本:7.10.1(Elasticsearch 白金版)
配置
节点数量:3
内存:16G
硬盘:SSD云硬盘 1TB
CPU个数:1
CPU核心数:4
CPU型号:AMD EPYC 7K62 48-Core Processor
背景
在大数据时代的今天,业务量越来越大,每天动辄都会产生上百GB、上TB的数据,所以拥有一个性能强劲的Elasticsearch集群就显得尤为重要。我们需要模拟大量网络日志、用户行为日志的读写动作,衡量各性能的指标,找出集群瓶颈所在,以确认我们需要怎样的硬件配置以及业务优化,才能满足现有的业务量,这就是我们在业务上线前所必要做的。
压测指令
esrally --distribution-version=6.0.0
压测报告
    _______             __   _____
   / ____(_)___  ____ _/ /  / ___/_________  ________
  / /_  / / __ \/ __ `/ /   \__ \/ ___/ __ \/ ___/ _ \
 / __/ / / / / / /_/ / /   ___/ / /__/ /_/ / /  /  __/
/_/   /_/_/ /_/\__,_/_/   /____/\___/\____/_/   \___/
|                                                         Metric |                   Task |     Value |    Unit |
|                     Cumulative indexing time of primary shards |                        |   31.9571 |     min |
|             Min cumulative indexing time across primary shards |                        |     6.318 |     min |
|          Median cumulative indexing time across primary shards |                        |    6.3739 |     min |
|             Max cumulative indexing time across primary shards |                        |   6.54167 |     min |
|            Cumulative indexing throttle time of primary shards |                        |         0 |     min |
|    Min cumulative indexing throttle time across primary shards |                        |         0 |     min |
| Median cumulative indexing throttle time across primary shards |                        |         0 |     min |
|    Max cumulative indexing throttle time across primary shards |                        |         0 |     min |
|                        Cumulative merge time of primary shards |                        |    8.4722 |     min |
|                       Cumulative merge count of primary shards |                        |       254 |         |
|                Min cumulative merge time across primary shards |                        |   1.43585 |     min |
|             Median cumulative merge time across primary shards |                        |   1.70052 |     min |
|                Max cumulative merge time across primary shards |                        |   1.90262 |     min |
|               Cumulative merge throttle time of primary shards |                        |   1.41052 |     min |
|       Min cumulative merge throttle time across primary shards |                        |   0.19385 |     min |
|    Median cumulative merge throttle time across primary shards |                        |   0.28705 |     min |
|       Max cumulative merge throttle time across primary shards |                        |   0.33705 |     min |
|                      Cumulative refresh time of primary shards |                        |   1.22168 |     min |
|                     Cumulative refresh count of primary shards |                        |       402 |         |
|              Min cumulative refresh time across primary shards |                        |   0.19125 |     min |
|           Median cumulative refresh time across primary shards |                        |  0.227717 |     min |
|              Max cumulative refresh time across primary shards |                        |  0.307067 |     min |
|                        Cumulative flush time of primary shards |                        |  0.865717 |     min |
|                       Cumulative flush count of primary shards |                        |        10 |         |
|                Min cumulative flush time across primary shards |                        |  0.170633 |     min |
|             Median cumulative flush time across primary shards |                        |    0.1722 |     min |
|                Max cumulative flush time across primary shards |                        |  0.176117 |     min |
|                                             Total Young Gen GC |                        |    18.509 |       s |
|                                               Total Old Gen GC |                        |     4.205 |       s |
|                                                     Store size |                        |   3.26041 |      GB |
|                                                  Translog size |                        |   2.68671 |      GB |
|                                         Heap used for segments |                        |    19.758 |      MB |
|                                       Heap used for doc values |                        | 0.0497627 |      MB |
|                                            Heap used for terms |                        |   18.5803 |      MB |
|                                            Heap used for norms |                        | 0.0792847 |      MB |
|                                           Heap used for points |                        |  0.278255 |      MB |
|                                    Heap used for stored fields |                        |  0.770416 |      MB |
|                                                  Segment count |                        |       103 |         |
|                                                 Min Throughput |           index-append |   79792.9 |  docs/s |
|                                              Median Throughput |           index-append |   80220.1 |  docs/s |
|                                                 Max Throughput |           index-append |   80462.6 |  docs/s |
|                                        50th percentile latency |           index-append |   431.806 |      ms |
|                                        90th percentile latency |           index-append |   617.963 |      ms |
|                                        99th percentile latency |           index-append |   1409.56 |      ms |
|                                       100th percentile latency |           index-append |   1668.42 |      ms |
|                                   50th percentile service time |           index-append |   431.806 |      ms |
|                                   90th percentile service time |           index-append |   617.963 |      ms |
|                                   99th percentile service time |           index-append |   1409.56 |      ms |
|                                  100th percentile service time |           index-append |   1668.42 |      ms |
|                                                     error rate |           index-append |         0 |       % |
|                                                 Min Throughput |            index-stats |     90.05 |   ops/s |
|                                              Median Throughput |            index-stats |     90.08 |   ops/s |
|                                                 Max Throughput |            index-stats |     90.15 |   ops/s |
|                                        50th percentile latency |            index-stats |   1.15388 |      ms |
|                                        90th percentile latency |            index-stats |   1.44819 |      ms |
|                                        99th percentile latency |            index-stats |   1.68309 |      ms |
|                                      99.9th percentile latency |            index-stats |   6.77088 |      ms |
|                                       100th percentile latency |            index-stats |   10.6119 |      ms |
|                                   50th percentile service time |            index-stats |   1.08615 |      ms |
|                                   90th percentile service time |            index-stats |   1.37542 |      ms |
|                                   99th percentile service time |            index-stats |   1.59919 |      ms |
|                                 99.9th percentile service time |            index-stats |   6.70006 |      ms |
|                                  100th percentile service time |            index-stats |   10.5416 |      ms |
|                                                     error rate |            index-stats |         0 |       % |
|                                                 Min Throughput |             node-stats |     90.07 |   ops/s |
|                                              Median Throughput |             node-stats |     90.13 |   ops/s |
|                                                 Max Throughput |             node-stats |     90.44 |   ops/s |
|                                        50th percentile latency |             node-stats |    1.2836 |      ms |
|                                        90th percentile latency |             node-stats |   1.66455 |      ms |
|                                        99th percentile latency |             node-stats |   2.76618 |      ms |
|                                      99.9th percentile latency |             node-stats |    6.3469 |      ms |
|                                       100th percentile latency |             node-stats |   8.49078 |      ms |
|                                   50th percentile service time |             node-stats |   1.20947 |      ms |
|                                   90th percentile service time |             node-stats |   1.59321 |      ms |
|                                   99th percentile service time |             node-stats |    2.7005 |      ms |
|                                 99.9th percentile service time |             node-stats |   6.27536 |      ms |
|                                  100th percentile service time |             node-stats |   8.42212 |      ms |
|                                                     error rate |             node-stats |         0 |       % |
|                                                 Min Throughput |                default |     50.02 |   ops/s |
|                                              Median Throughput |                default |     50.03 |   ops/s |
|                                                 Max Throughput |                default |     50.06 |   ops/s |
|                                        50th percentile latency |                default |   7.33918 |      ms |
|                                        90th percentile latency |                default |   7.80708 |      ms |
|                                        99th percentile latency |                default |   10.8431 |      ms |
|                                      99.9th percentile latency |                default |   11.3341 |      ms |
|                                       100th percentile latency |                default |   11.3709 |      ms |
|                                   50th percentile service time |                default |   7.26797 |      ms |
|                                   90th percentile service time |                default |   7.73792 |      ms |
|                                   99th percentile service time |                default |   10.7737 |      ms |
|                                 99.9th percentile service time |                default |   11.2504 |      ms |
|                                  100th percentile service time |                default |   11.3026 |      ms |
|                                                     error rate |                default |         0 |       % |
|                                                 Min Throughput |                   term |    100.06 |   ops/s |
|                                              Median Throughput |                   term |    100.09 |   ops/s |
|                                                 Max Throughput |                   term |    100.18 |   ops/s |
|                                        50th percentile latency |                   term |   1.23537 |      ms |
|                                        90th percentile latency |                   term |   1.49826 |      ms |
|                                        99th percentile latency |                   term |   1.64551 |      ms |
|                                      99.9th percentile latency |                   term |    4.5177 |      ms |
|                                       100th percentile latency |                   term |   4.76169 |      ms |
|                                   50th percentile service time |                   term |    1.1639 |      ms |
|                                   90th percentile service time |                   term |   1.42085 |      ms |
|                                   99th percentile service time |                   term |   1.56379 |      ms |
|                                 99.9th percentile service time |                   term |   4.44861 |      ms |
|                                  100th percentile service time |                   term |   4.67859 |      ms |
|                                                     error rate |                   term |         0 |       % |
|                                                 Min Throughput |                 phrase |    110.07 |   ops/s |
|                                              Median Throughput |                 phrase |     110.1 |   ops/s |
|                                                 Max Throughput |                 phrase |    110.18 |   ops/s |
|                                        50th percentile latency |                 phrase |    1.0436 |      ms |
|                                        90th percentile latency |                 phrase |   1.33577 |      ms |
|                                        99th percentile latency |                 phrase |   1.50581 |      ms |
|                                      99.9th percentile latency |                 phrase |   4.61771 |      ms |
|                                       100th percentile latency |                 phrase |   4.68649 |      ms |
|                                   50th percentile service time |                 phrase |  0.970911 |      ms |
|                                   90th percentile service time |                 phrase |   1.25612 |      ms |
|                                   99th percentile service time |                 phrase |   1.43724 |      ms |
|                                 99.9th percentile service time |                 phrase |   4.53463 |      ms |
|                                  100th percentile service time |                 phrase |   4.61535 |      ms |
|                                                     error rate |                 phrase |         0 |       % |
|                                                 Min Throughput |   country_agg_uncached |      3.61 |   ops/s |
|                                              Median Throughput |   country_agg_uncached |      3.61 |   ops/s |
|                                                 Max Throughput |   country_agg_uncached |      3.61 |   ops/s |
|                                        50th percentile latency |   country_agg_uncached |   123.416 |      ms |
|                                        90th percentile latency |   country_agg_uncached |   132.835 |      ms |
|                                        99th percentile latency |   country_agg_uncached |   137.358 |      ms |
|                                       100th percentile latency |   country_agg_uncached |   162.226 |      ms |
|                                   50th percentile service time |   country_agg_uncached |   123.258 |      ms |
|                                   90th percentile service time |   country_agg_uncached |   132.674 |      ms |
|                                   99th percentile service time |   country_agg_uncached |   137.211 |      ms |
|                                  100th percentile service time |   country_agg_uncached |    162.04 |      ms |
|                                                     error rate |   country_agg_uncached |         0 |       % |
|                                                 Min Throughput |     country_agg_cached |    100.05 |   ops/s |
|                                              Median Throughput |     country_agg_cached |    100.06 |   ops/s |
|                                                 Max Throughput |     country_agg_cached |    100.09 |   ops/s |
|                                        50th percentile latency |     country_agg_cached |  0.773497 |      ms |
|                                        90th percentile latency |     country_agg_cached |  0.972381 |      ms |
|                                        99th percentile latency |     country_agg_cached |   1.19931 |      ms |
|                                      99.9th percentile latency |     country_agg_cached |   1.63762 |      ms |
|                                       100th percentile latency |     country_agg_cached |   3.01838 |      ms |
|                                   50th percentile service time |     country_agg_cached |   0.69294 |      ms |
|                                   90th percentile service time |     country_agg_cached |  0.888465 |      ms |
|                                   99th percentile service time |     country_agg_cached |   1.11699 |      ms |
|                                 99.9th percentile service time |     country_agg_cached |    1.5571 |      ms |
|                                  100th percentile service time |     country_agg_cached |   2.93895 |      ms |
|                                                     error rate |     country_agg_cached |         0 |       % |
|                                                 Min Throughput |                 scroll |     20.05 | pages/s |
|                                              Median Throughput |                 scroll |     20.06 | pages/s |
|                                                 Max Throughput |                 scroll |     20.08 | pages/s |
|                                        50th percentile latency |                 scroll |   295.173 |      ms |
|                                        90th percentile latency |                 scroll |    301.86 |      ms |
|                                        99th percentile latency |                 scroll |   304.547 |      ms |
|                                       100th percentile latency |                 scroll |   305.208 |      ms |
|                                   50th percentile service time |                 scroll |   294.264 |      ms |
|                                   90th percentile service time |                 scroll |   300.968 |      ms |
|                                   99th percentile service time |                 scroll |   303.718 |      ms |
|                                  100th percentile service time |                 scroll |   304.351 |      ms |
|                                                     error rate |                 scroll |         0 |       % |
|                                                 Min Throughput |             expression |         2 |   ops/s |
|                                              Median Throughput |             expression |         2 |   ops/s |
|                                                 Max Throughput |             expression |         2 |   ops/s |
|                                        50th percentile latency |             expression |   258.146 |      ms |
|                                        90th percentile latency |             expression |   270.362 |      ms |
|                                        99th percentile latency |             expression |   285.048 |      ms |
|                                       100th percentile latency |             expression |   305.866 |      ms |
|                                   50th percentile service time |             expression |   257.889 |      ms |
|                                   90th percentile service time |             expression |   270.114 |      ms |
|                                   99th percentile service time |             expression |   284.788 |      ms |
|                                  100th percentile service time |             expression |   305.616 |      ms |
|                                                     error rate |             expression |         0 |       % |
|                                                 Min Throughput |        painless_static |       1.4 |   ops/s |
|                                              Median Throughput |        painless_static |       1.4 |   ops/s |
|                                                 Max Throughput |        painless_static |       1.4 |   ops/s |
|                                        50th percentile latency |        painless_static |   891.686 |      ms |
|                                        90th percentile latency |        painless_static |   989.863 |      ms |
|                                        99th percentile latency |        painless_static |   1075.74 |      ms |
|                                       100th percentile latency |        painless_static |   1091.99 |      ms |
|                                   50th percentile service time |        painless_static |   705.613 |      ms |
|                                   90th percentile service time |        painless_static |   775.687 |      ms |
|                                   99th percentile service time |        painless_static |   827.929 |      ms |
|                                  100th percentile service time |        painless_static |    835.33 |      ms |
|                                                     error rate |        painless_static |         0 |       % |
|                                                 Min Throughput |       painless_dynamic |       1.4 |   ops/s |
|                                              Median Throughput |       painless_dynamic |       1.4 |   ops/s |
|                                                 Max Throughput |       painless_dynamic |       1.4 |   ops/s |
|                                        50th percentile latency |       painless_dynamic |   708.353 |      ms |
|                                        90th percentile latency |       painless_dynamic |   783.711 |      ms |
|                                        99th percentile latency |       painless_dynamic |   852.798 |      ms |
|                                       100th percentile latency |       painless_dynamic |   855.139 |      ms |
|                                   50th percentile service time |       painless_dynamic |   679.176 |      ms |
|                                   90th percentile service time |       painless_dynamic |   752.427 |      ms |
|                                   99th percentile service time |       painless_dynamic |   822.407 |      ms |
|                                  100th percentile service time |       painless_dynamic |   828.349 |      ms |
|                                                     error rate |       painless_dynamic |         0 |       % |
|                                                 Min Throughput |            large_terms |       1.1 |   ops/s |
|                                              Median Throughput |            large_terms |       1.1 |   ops/s |
|                                                 Max Throughput |            large_terms |       1.1 |   ops/s |
|                                        50th percentile latency |            large_terms |    384.18 |      ms |
|                                        90th percentile latency |            large_terms |   392.977 |      ms |
|                                        99th percentile latency |            large_terms |   404.511 |      ms |
|                                       100th percentile latency |            large_terms |   414.145 |      ms |
|                                   50th percentile service time |            large_terms |   383.635 |      ms |
|                                   90th percentile service time |            large_terms |   392.434 |      ms |
|                                   99th percentile service time |            large_terms |   403.958 |      ms |
|                                  100th percentile service time |            large_terms |     413.6 |      ms |
|                                                     error rate |            large_terms |         0 |       % |
|                                                 Min Throughput |   large_filtered_terms |       1.1 |   ops/s |
|                                              Median Throughput |   large_filtered_terms |       1.1 |   ops/s |
|                                                 Max Throughput |   large_filtered_terms |       1.1 |   ops/s |
|                                        50th percentile latency |   large_filtered_terms |   384.729 |      ms |
|                                        90th percentile latency |   large_filtered_terms |   391.508 |      ms |
|                                        99th percentile latency |   large_filtered_terms |   396.777 |      ms |
|                                       100th percentile latency |   large_filtered_terms |   402.892 |      ms |
|                                   50th percentile service time |   large_filtered_terms |   384.253 |      ms |
|                                   90th percentile service time |   large_filtered_terms |   390.981 |      ms |
|                                   99th percentile service time |   large_filtered_terms |   396.297 |      ms |
|                                  100th percentile service time |   large_filtered_terms |   402.423 |      ms |
|                                                     error rate |   large_filtered_terms |         0 |       % |
|                                                 Min Throughput | large_prohibited_terms |       1.1 |   ops/s |
|                                              Median Throughput | large_prohibited_terms |       1.1 |   ops/s |
|                                                 Max Throughput | large_prohibited_terms |       1.1 |   ops/s |
|                                        50th percentile latency | large_prohibited_terms |   383.206 |      ms |
|                                        90th percentile latency | large_prohibited_terms |   390.933 |      ms |
|                                        99th percentile latency | large_prohibited_terms |   394.907 |      ms |
|                                       100th percentile latency | large_prohibited_terms |   399.321 |      ms |
|                                   50th percentile service time | large_prohibited_terms |   382.704 |      ms |
|                                   90th percentile service time | large_prohibited_terms |   390.658 |      ms |
|                                   99th percentile service time | large_prohibited_terms |   394.357 |      ms |
|                                  100th percentile service time | large_prohibited_terms |   398.779 |      ms |
|                                                     error rate | large_prohibited_terms |         0 |       % |
[INFO] SUCCESS (took 2583 seconds)
