Elasticsearch索引分片损坏该怎么办?(三)
【摘要】 前面我们学习了 Elasticsearch集群异常状态(RED、YELLOW)原因分析 ……
前面我们学习了 Elasticsearch集群异常状态(RED、YELLOW)原因分析 ,了解到了当集群发生主分片无法上线的情况下,集群状态会变为RED,此时相应的RED索引读写请求都会受到严重的影响。
背景
- 前面我们学习了 Elasticsearch集群异常状态(RED、YELLOW)原因分析 ,了解到了当集群发生主分片无法上线的情况下,集群状态会变为RED,此时相应的RED索引读写请求都会受到严重的影响。
- 这里我们将介绍索引分片损坏这种情况,当索引分片发生损坏时,对应的主分片会无法分配,且状态也会是RED。然而分片的损坏的情况又分为很多种,有些只是表象,可以通过一些手段恢复,但有些则是真实的物理损坏,且无法恢复,只能丢弃部分数据,甚至整块分片。
问题
场景:集群节点文件系统故障引起的分片损坏
这种情况也是比较常见的,一般我们可以通过explain api来确认:
[root@sh ~]# curl -s -XGET localhost:9200/_cluster/allocation/explain?pretty
"index": "d4f811fc-4a43-40ca-a362-ebdaa9f23a720722",
"shard": 5,
"primary": true,
"current_state": "unassigned",
"unassigned_info": {
"reason": "MANUAL_ALLOCATION",
"at": "2021-07-11T03:05: 49.2417",
"details": "failed shand on node[IEW657FYSZiiUn53LjBcuAJ]: shard failure,reason [failed to recover from translog], failure EngineException[failed to recover from translog]; nested:TranslogCorruptedException[translogfrom source [/data2/containers/1620201319003550632/es/data/nodes/0/indices/g2Zz7YV6FRj6xPETjZAzCOg/5/translog/translog-38.tlog] is corrupted, operation size is corrupted must be [0..65615539] but was: 2065851766]; ",
"last_allocation_status ": "no_valid_shard_copy "
"can _allocate": "no_valid_shard_copy",
"allocate_explanation": "cannot allocate because all found copies of the shard are either stale or conrupt",
"node_allocation_decisions": [
"node_id": "OGORzwn5T2CknwuCkHSNHA",
"node_ name": "1617024100001322232",
"transport_address": "9.10.179.196:9300",
"node_attributes": {
"ml.machine_memory": "67211821056",
"rack": "cvm_1_100003",
"xpack.installed": "true",
"set": "100003",
"ip": "9.10.179.196",
"temperature": "warm",
"ml.max_open_jobs": "20",
"region": "1"
"node_decision": "no",
"store": {
"found": false
解决方案
方案一:重试分配上线失败的分片
这是一种乐观的场景,这种情况通常是由于集群压力大,导致的分片无法分配,这里我们尝试重新分配:
[root@sh ~]# curl -s -XPOST localhost:9200/_cluster/reroute?retry_failed=true
"acknowledged": true,
"state": {
"cluster_uuid": "LOk2L8k5RsmCC7eg2y3h8A",
"version": 533752,
"state_uuid": "jVm_8aAIT6ug9NBJazjVig",
"master_node": "kHbBiclxR5-c-rsra2A5Jg",
"blocks": {
"nodes": {
"m5eloUNuTJak4xDRqf3FeA": {
"name": "1625799512002116132",
"ephemeral_id": "dqHmYahLSbuqvSkRXy2IPg",
"transport_address": "9.27.34.96:9300",
"attributes": {
"ml.machine_memory": "134587404288",
"rack": "cvm_33_330002",
"set": "330002",
"transform.node": "true",
"ip": "9.27.34.96",
"temperature": "hot",
"region": "33"
"security_tokens": {
方案二:REOPEN分片
reopen的目的是触发索引分片重新上线,直接调用_close和_open api即可:
[root@sh ~]# curl -s -XPOST localhost:9200/twitter/_close?pretty
[root@sh ~]# curl -s -XPOST localhost:9200/twitter/_open?pretty
"shards_acknowledged": true
方案三:分配陈腐的分片
如果retry_failed和reopen索引都无法使分片上线,则需要考虑使用reroute api分配stale primary。执行这个api之前,我们需要得到一些信息:
- 索引名称和分片ID可以通过explain api直观看到;
- 节点名称可以通过unassigned_info.details得到。
根据这些信息,我们就可以执行reroute api了:
[root@sh ~]# curl -s -H "Content-Type:application/json" -XPOST "localhost:9200/_cluster/reroute?pretty" -d '
"commands": [
"allocate_stale_primary": {
"index": "{索引名称}",
"shard": "{分片ID}",
"node": "{节点名称}",
"accept_data_loss": true
方案四:丢弃部分trasnlog文件
这块无法上线的分片有2GB ,但是提示有一个的translog-38损坏了。登上对应节点的服务器,看了下这个文件有6mb,于是我们把它move走,移到/tmp,然后再次执行方案三,这样allocate_stale_primary操作就可以最大限度的恢复分片数据:
[root@sh ~]# mv /data2/containers/1620201319003550632/es/data/nodes/0/indices/g2Zz7YV6FRj6xPETjZAzCOg/5/translog/translog-38.tlog /tmp
"commands": [
"index": "{索引名称}",
"shard": "{分片ID}",
"node": "{节点名称}",
方案五:丢弃分片(三思!慎用!)
如果以上的所有方案都无法使分片上线,为了不影响索引读写请求,就只能丢弃掉损坏的分片了,这是最糟糕的情况:
"commands" : [
"allocate_empty_primary" : {
"index" : "{索引名称}",
"shard" : "{分片ID}",
"node" : "{节点名称}",
cloudbbs@huaweicloud.com
