A Practical Guide to Android Custom Views
shenlan9755 发表于 2026/09/13 10:56:14 2026/09/13
【摘要】 A Practical Guide to Android Custom ViewsFrom a blank View to a reusable, interactive component — everything you need to know to build your own custom views in Android. Table of ContentsWhy Custom...
Table of Contents
  1. Why Custom Views?
  2. The Core Lifecycle Methods
  3. Step-by-Step: Building a Circular Progress View
  4. Custom Attributes
  5. Handling Touch Events
  6. Performance Best Practices
  7. Common Pitfalls
  8. Conclusion
The Android SDK ships with a rich set of built-in widgets — TextView, Button, RecyclerView, etc. But sometimes none of them fit your design or interaction needs. That’s where custom views come in.
You should consider writing a custom view when:
  • You need a unique visual appearance that can’t be achieved by composing existing views.
  • You need custom drawing (shapes, charts, graphs, gauges).
  • You need specialized touch handling (gestures, dragging, multi-touch).
  • You want a reusable component shared across projects.
Rule of thumb: If you can achieve the result by composing existing views or using a ShapeableImageView / MaterialCardView, do that first. Reach for a custom view only when composition falls short.
Every custom view revolves around three key overridable methods. Understanding them is non-negotiable.
onMeasure(int widthMeasureSpec, int heightMeasureSpec)
Called when the parent layout asks your view how big it wants to be. The MeasureSpec encodes a size and a mode:
Mode Meaning
EXACTLY The parent has decided an exact size for you (e.g., layout_width="100dp" or match_parent in a constrained parent).
AT_MOST You can be as big as you want up to the given size (e.g., wrap_content in a constrained parent).
UNSPECIFIED No constraints — be as big as you want.
You must call setMeasuredDimension(width, height) before returning.
onSizeChanged(int w, int h, int oldw, int oldh)
Called whenever the view’s size changes. This is the perfect place to cache calculations (center point, radius, scaled bitmap) so you don’t recompute them every frame in onDraw.
onDraw(Canvas canvas)
Where the magic happens. The Canvas is your drawing surface; Paint is your brush. Draw shapes, text, paths, bitmaps here.
Critical: onDraw is called frequently (every animation frame, every invalidation). Keep it lean. Never allocate objects inside onDraw.
Let’s build a reusable circular progress indicator — the kind you see in loading spinners and progress rings.
3.1 Create the class
class CircularProgressView @JvmOverloads constructor(
    context: Context,
    attrs: AttributeSet? = null,
    defStyleAttr: Int = 0
) : View(context, attrs, defStyleAttr) {
    private var progress = 0f          // 0f..1f
    private var strokeWidth = 24f.px   // dp to px
    private var startAngle = -90f      // begin at top
    private val backgroundPaint = Paint(Paint.ANTI_ALIAS_FLAG).apply {
        style = Paint.Style.STROKE
        this.strokeWidth = this@CircularProgressView.strokeWidth
        color = Color.parseColor("#E0E0E0")
    private val progressPaint = Paint(Paint.ANTI_ALIAS_FLAG).apply {
        color = Color.parseColor("#6200EE")
        strokeCap = Paint.Cap.ROUND
    private val bounds = RectF()
A few notes:
  • @JvmOverloads lets you instantiate the view from Java with fewer arguments.
  • Paint.ANTI_ALIAS_FLAG smooths jagged edges.
  • strokeCap = Paint.Cap.ROUND gives the progress arc rounded ends.
  • .px is an extension property: val Float.px get() = this * resources.displayMetrics.density.
3.2 Measure the view
We want a square view by default, but we respect the parent’s constraints:
override fun onMeasure(widthMeasureSpec: Int, heightMeasureSpec: Int) {
    val defaultSize = 200.dp  // preferred size in px
    val width = resolveSize(defaultSize, widthMeasureSpec)
    val height = resolveSize(defaultSize, heightMeasureSpec)
    // Force square: pick the smaller dimension
    val size = minOf(width, height)
    setMeasuredDimension(size, size)
resolveSize handles the MeasureSpec mode logic for you — use it instead of reinventing the wheel.
3.3 Cache geometry on size change
override fun onSizeChanged(w: Int, h: Int, oldw: Int, oldh: Int) {
    super.onSizeChanged(w, h, oldw, oldh)
    val inset = strokeWidth / 2
    bounds.set(inset, inset, w - inset, h - inset)
We inset by half the stroke width so the thick line isn’t clipped at the edges.
3.4 Draw
override fun onDraw(canvas: Canvas) {
    super.onDraw(canvas)
    // Background ring
    canvas.drawArc(bounds, 0f, 360f, false, backgroundPaint)
    // Progress arc
    val sweepAngle = 360f * progress
    canvas.drawArc(bounds, startAngle, sweepAngle, false, progressPaint)
3.5 Expose a public API
fun setProgress(value: Float) {
    progress = value.coerceIn(0f, 1f)
    invalidate()   // trigger a redraw
invalidate() schedules a redraw on the next frame. Call it whenever a property that affects drawing changes.
3.6 Use it in XML
<com.yourpackage.CircularProgressView
    android:id="@+id/progressView"
    android:layout_width="120dp"
    android:layout_height="120dp" />
val progressView = findViewById<CircularProgressView>(R.id.progressView)
progressView.setProgress(0.75f)
Hardcoded colors and sizes are bad practice. Let’s expose them via XML attributes.
4.1 Define attributes in res/values/attrs.xml
<resources>
    <declare-styleable name="CircularProgressView">
        <attr name="progressColor" format="color" />
        <attr name="trackColor" format="color" />
        <attr name="strokeWidth" format="dimension" />
        <attr name="progress" format="float" />
    </declare-styleable>
</resources>
4.2 Read them in the constructor
init {
    context.obtainStyledAttributes(attrs, R.styleable.CircularProgressView).use { typedArray ->
        progressPaint.color = typedArray.getColor(
            R.styleable.CircularProgressView_progressColor,
        backgroundPaint.color = typedArray.getColor(
            R.styleable.CircularProgressView_trackColor,
        strokeWidth = typedArray.getDimension(
            R.styleable.CircularProgressView_strokeWidth,
            24f.px
        progress = typedArray.getFloat(
            R.styleable.CircularProgressView_progress,
            0f
    backgroundPaint.strokeWidth = strokeWidth
    progressPaint.strokeWidth = strokeWidth
The .use { } extension automatically recycles the TypedArray — always recycle to free native resources.
4.3 Use them in XML
    app:progressColor="#FF4081"
    app:trackColor="#F5F5F5"
    app:strokeWidth="8dp"
    app:progress="0.6" />
To make your view interactive, override onTouchEvent:
override fun onTouchEvent(event: MotionEvent): Boolean {
    when (event.action) {
        MotionEvent.ACTION_DOWN -> {
            // Finger touched the view
            return true   // we want subsequent events
        MotionEvent.ACTION_MOVE -> {
            val x = event.x
            val y = event.y
            // Update state based on touch position
            updateFromTouch(x, y)
            return true
        MotionEvent.ACTION_UP -> {
            // Finger lifted
            performClick()   // accessibility requirement!
            return true
    return super.onTouchEvent(event)
override fun performClick(): Boolean {
    super.performClick()   // handles accessibility
    // handle click logic
    return true
Important: If your view handles ACTION_UP, you must call performClick() to preserve accessibility (TalkBack) behavior. Lint will warn you if you forget.
For complex gestures, delegate to a GestureDetector:
private val gestureDetector = GestureDetector(context, object : GestureDetector.SimpleOnGestureListener() {
    override fun onScroll(e1: MotionEvent, e2: MotionEvent, distanceX: Float, distanceY: Float): Boolean {
        // Handle dragging
        return true
    return gestureDetector.onTouchEvent(event)
Custom views can become performance bottlenecks. Follow these rules:
6.1 Never allocate in onDraw
// BAD — allocates every frame
    val paint = Paint()   // DON'T
    canvas.drawRect(rect, paint)
// GOOD — reuse pre-allocated objects
private val paint = Paint()   // allocated once
6.2 Use hardware layers for animations
When animating a complex view, enable a hardware layer to cache the rendered output:
fun startAnimation() {
    setLayerType(LAYER_TYPE_HARDWARE, null)
    // ... animate ...
    // Disable after animation to free GPU memory
    setLayerType(LAYER_TYPE_NONE, null)
6.3 Avoid invalidate() when postInvalidateOnAnimation() suffices
For smooth 60fps animations, use ValueAnimator and postInvalidateOnAnimation():
fun animateProgress(target: Float) {
    val animator = ValueAnimator.ofFloat(progress, target).apply {
        duration = 300
        interpolator = DecelerateInterpolator()
        addUpdateListener {
            progress = it.animatedValue as Float
    animator.start()
6.4 Profile with GPU rendering
Enable Developer Options → Profile GPU Rendering to spot janky frames. If your view’s bars exceed the green line, you have overdraw or expensive draw calls.
7. Common Pitfalls
Pitfall Fix
View is invisible / zero size You forgot to call setMeasuredDimension() in onMeasure.
Drawing is clipped at edges Inset your RectF/Path by half the stroke width.
wrap_content doesn’t work Implement proper onMeasure logic respecting AT_MOST mode.
Memory leaks Don’t hold Activity/Fragment references; use WeakReference if needed.
Janky scrolling Allocate Paint/Path once; avoid object creation in onDraw.
Accessibility broken Call performClick() in ACTION_UP; set contentDescription.
RTL layout issues Use canvas.save()/canvas.restore() with layoutDirection checks.
8. Conclusion
Custom views are one of the most powerful tools in an Android developer’s toolkit. The key takeaways:
  1. Understand the lifecycle — onMeasure, onSizeChanged, onDraw are your holy trinity.
  2. Respect MeasureSpec — use resolveSize / resolveSizeAndState instead of ignoring constraints.
  3. Keep onDraw allocation-free — pre-create all Paint, Path, and RectF objects.
  4. Expose XML attributes — your view should be configurable from layout files.
  5. Don’t forget accessibility — performClick(), contentDescription, and touch target sizing matter.
Start simple, measure performance early, and iterate. Once you’re comfortable, explore advanced topics like RenderEffect (API 31+), SurfaceView for high-performance rendering, and Compose’s Canvas for the modern toolkit.
Happy drawing!
Written by [Your Name] · Last updated: 2026-08-22
