黑海高分辨率海表温度 L4 分析,分辨率 0.0625 度
此星光明 发表于 2026/05/18 14:47:21 2026/05/18
【摘要】 Black Sea High Resolution SST L4 Analysis 0.0625 deg Resolution简介CNR MED 海表温度提供黑海每日无缝隙(L4)地图,水平分辨率为 0.0625 度 x 0.0625 度。数据来源于卫星辐射计收集的红外测量数据和统计插值。它是 CMEMS 黑海海表温度的标称业务产品。摘要代码!pip install leafmap!pip ...
简介
摘要
代码
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data/raw/main/nasa_earth_data.tsv"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="OISST_HR_NRT-GOS-L4-BLK-v2.0",
    cloud_hosted=True,
    bounding_box=(-165.68, 34.59, -98.1, 71.28),
    temporal=("2017-07-20", "2017-08-08"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
