描述符协议实战详解
柠檬🍋 发表于 2026/02/26 20:22:57 2026/02/26
【摘要】 描述符协议实战详解描述符(Descriptor)是Python中实现属性访问控制的核心机制,它支撑着@property、staticmethod、classmethod等特性的实现。本文将深入解析描述符协议及其实战应用。 描述符基础概念描述符是实现了以下任一方法的类:__get__(self, obj, type=None):获取属性值__set__(self, obj, value):设...
描述符协议实战详解
描述符基础概念
描述符是实现了以下任一方法的类:
  • __get__(self, obj, type=None):获取属性值
  • __set__(self, obj, value):设置属性值
  • __delete__(self, obj):删除属性
根据实现的方法,描述符分为:
  • 非数据描述符:仅实现__get__
  • 数据描述符:实现__set__或__delete__
描述符核心实现
Python描述符协议实战详解
包含属性验证、懒加载、类型检查等高级应用
import weakref
from typing import Any, Callable, Optional, Type, Union
from functools import wraps
import time
# ============ 基础描述符示例 ============
class Validator:
    """基础验证描述符"""
    def __init__(self, min_value=None, max_value=None):
        self.min_value = min_value
        self.max_value = max_value
        self.name = None
        self.values = weakref.WeakKeyDictionary()
    def __set_name__(self, owner, name):
        """Python 3.6+ 自动设置属性名"""
        self.name = name
    def __get__(self, obj, objtype=None):
        if obj is None:
            return self
        return self.values.get(obj, None)
    def __set__(self, obj, value):
        self.validate(value)
        self.values[obj] = value
    def validate(self, value):
        """子类重写验证逻辑"""
        pass
class Integer(Validator):
    """整数类型描述符"""
        if not isinstance(value, int):
            raise TypeError(f"{self.name} 必须是整数类型")
        if self.min_value is not None and value < self.min_value:
            raise ValueError(f"{self.name} 必须 >= {self.min_value}")
        if self.max_value is not None and value > self.max_value:
            raise ValueError(f"{self.name} 必须 <= {self.max_value}")
class String(Validator):
    """字符串类型描述符"""
    def __init__(self, min_length=None, max_length=None, pattern=None):
        super().__init__()
        self.min_length = min_length
        self.max_length = max_length
        self.pattern = pattern
        if not isinstance(value, str):
            raise TypeError(f"{self.name} 必须是字符串类型")
        if self.min_length is not None and len(value) < self.min_length:
            raise ValueError(f"{self.name} 长度必须 >= {self.min_length}")
        if self.max_length is not None and len(value) > self.max_length:
            raise ValueError(f"{self.name} 长度必须 <= {self.max_length}")
class Float(Validator):
    """浮点数类型描述符"""
        if not isinstance(value, (int, float)):
            raise TypeError(f"{self.name} 必须是数值类型")
        value = float(value)
# ============ 懒加载描述符 ============
class LazyProperty:
    """懒加载属性描述符"""
    def __init__(self, func):
        self.func = func
        self.name = func.__name__
        if obj is None:
            return self
        if obj not in self.values:
            # 首次访问时计算并缓存
            start_time = time.time()
            value = self.func(obj)
            elapsed = time.time() - start_time
            print(f"[Lazy] {self.name} 计算完成,耗时: {elapsed:.4f}s")
        return self.values[obj]
        raise AttributeError(f"{self.name} 是只读属性")
# ============ 类型检查描述符 ============
class TypedAttribute:
    """类型检查属性描述符"""
    def __init__(self, expected_type: Type):
        self.expected_type = expected_type
        self.name = None
        self.name = name
        if obj is None:
            return self
        return self.values.get(obj)
        if not isinstance(value, self.expected_type):
            raise TypeError(
                f"{self.name} 期望类型 {self.expected_type.__name__}, "
                f"实际类型 {type(value).__name__}"
# ============ 审计日志描述符 ============
class AuditedAttribute:
    """带审计日志的属性描述符"""
    def __init__(self, sensitive=False):
        self.sensitive = sensitive
        self.name = None
        self.audit_log = []
        self.name = name
        if obj is None:
            return self
        value = self.values.get(obj)
        self._log_access("READ", obj, value)
        return value
        old_value = self.values.get(obj)
        self._log_access("WRITE", obj, value, old_value)
    def __delete__(self, obj):
        del self.values[obj]
        self._log_access("DELETE", obj, None, old_value)
    def _log_access(self, operation, obj, value, old_value=None):
        """记录访问日志"""
        display_value = "***" if self.sensitive and value else value
        display_old = "***" if self.sensitive and old_value else old_value
        log_entry = {
            "timestamp": time.strftime("%Y-%m-%d %H:%M:%S"),
            "attribute": self.name,
            "operation": operation,
            "new_value": display_value,
            "old_value": display_old,
            "object_id": id(obj)
        self.audit_log.append(log_entry)
        print(f"[Audit] {operation}: {self.name} = {display_value}")
# ============ 缓存描述符 ============
class CachedProperty:
    """带过期时间的缓存属性"""
    def __init__(self, ttl_seconds: float = 60.0):
        self.ttl_seconds = ttl_seconds
        self.func = None
        self.name = None
        self.cache = weakref.WeakKeyDictionary()
        self.timestamps = weakref.WeakKeyDictionary()
    def __call__(self, func):
        self.func = func
        return self
        if obj is None:
            return self
        now = time.time()
        cached_time = self.timestamps.get(obj, 0)
        # 检查缓存是否过期
        if obj not in self.cache or (now - cached_time) > self.ttl_seconds:
            self.cache[obj] = self.func(obj)
            self.timestamps[obj] = now
            print(f"[Cache] {self.name} 已更新缓存")
        else:
            remaining = self.ttl_seconds - (now - cached_time)
            print(f"[Cache] {self.name} 使用缓存 (剩余{remaining:.1f}s)")
        return self.cache[obj]
    def invalidate(self, obj):
        """手动使缓存失效"""
        if obj in self.cache:
            del self.cache[obj]
            del self.timestamps[obj]
# ============ 使用描述符的模型类 ============
class User:
    """使用描述符的用户类"""
    # 类型验证描述符
    id = Integer(min_value=1)
    username = String(min_length=3, max_length=20)
    email = String(min_length=5, max_length=100)
    age = Integer(min_value=0, max_value=150)
    score = Float(min_value=0.0, max_value=100.0)
    # 审计日志描述符
    password = AuditedAttribute(sensitive=True)
    # 类型检查描述符
    metadata = TypedAttribute(dict)
    def __init__(self, id, username, email, age=0):
        self.id = id
        self.username = username
        self.email = email
        self.age = age
        self.score = 0.0
        self.metadata = {}
    @LazyProperty
    def profile_completeness(self):
        """计算资料完整度(懒加载)"""
        time.sleep(0.1)  # 模拟耗时计算
        fields = [self.username, self.email, self.age]
        filled = sum(1 for f in fields if f)
        return (filled / len(fields)) * 100
    @CachedProperty(ttl_seconds=5.0)
    def reputation_score(self):
        """计算信誉分数(带缓存)"""
        time.sleep(0.05)
        base_score = self.score * 10
        age_bonus = min(self.age * 0.5, 20)
        return base_score + age_bonus
class Product:
    """产品类 - 展示更多描述符应用"""
    name = String(min_length=1, max_length=100)
    price = Float(min_value=0.01)
    stock = Integer(min_value=0)
    def __init__(self, name, price, stock=0):
        self.name = name
        self.price = price
        self.stock = stock
    @property
    def is_available(self):
        """是否可购买"""
        return self.stock > 0
    @LazyProperty
    def total_value(self):
        """库存总价值"""
        return self.price * self.stock
def main():
    """主函数 - 演示描述符应用"""
    print("="*60)
    print("Python描述符协议实战演示")
    print("="*60)
    # 1. 类型验证演示
    print("\n【类型验证演示】")
    user = User(id=1, username="alice", email="alice@example.com", age=25)
    print(f"创建用户: {user.username}, 年龄: {user.age}")
    # 尝试设置无效值
    try:
        user.age = -5
    except ValueError as e:
        print(f"验证错误: {e}")
    try:
        user.username = "ab"  # 太短
        print(f"验证错误: {e}")
    # 2. 懒加载演示
    print("\n【懒加载演示】")
    print("首次访问 profile_completeness:")
    completeness = user.profile_completeness
    print(f"资料完整度: {completeness:.1f}%")
    print("\n再次访问 profile_completeness(使用缓存):")
    # 3. 审计日志演示
    print("\n【审计日志演示】")
    user.password = "secret123"
    _ = user.password  # 读取
    # 4. 缓存属性演示
    print("\n【缓存属性演示】")
    user.score = 8.5
    print(f"信誉分数: {user.reputation_score:.2f}")
    print(f"信誉分数(缓存): {user.reputation_score:.2f}")
    time.sleep(6)  # 等待缓存过期
    print(f"信誉分数(过期后重新计算): {user.reputation_score:.2f}")
    # 5. 产品类演示
    print("\n【产品类演示】")
    product = Product(name="Laptop", price=999.99, stock=50)
    print(f"产品: {product.name}, 价格: ${product.price}")
    print(f"库存价值: ${product.total_value:.2f}")
    print(f"是否可购买: {product.is_available}")
    # 6. 类型检查演示
    print("\n【类型检查演示】")
    user.metadata = {"role": "admin", "department": "IT"}
    print(f"用户元数据: {user.metadata}")
    try:
        user.metadata = "invalid"  # 类型错误
    except TypeError as e:
        print(f"类型错误: {e}")
    print("\n" + "="*60)
    print("描述符应用总结")
    print("="*60)
    print("1. 数据验证: 自动验证属性值的类型和范围")
    print("2. 懒加载: 延迟计算属性值,提高启动性能")
    print("3. 审计日志: 记录属性的访问和修改历史")
    print("4. 缓存机制: 缓存计算结果,减少重复计算")
    print("5. 类型检查: 运行时类型验证")
    print("="*60)
if __name__ == "__main__":
    main()
描述符查找流程图
是
否
是
否
数据描述符
非数据描述符
否
是
否
访问obj.attr
attr在实例__dict__?
返回实例属性值
attr在类中?
attr是描述符?
AttributeError
调用__get__方法
attr在实例__dict__?
返回类属性值
调用__get__方法
返回描述符计算值
返回结果
描述符优先级规则
属性访问优先级
1. 数据描述符
__get__+__set__
2. 实例字典
obj.__dict__
3. 非数据描述符
仅__get__
4. 类字典
cls.__dict__
5. 父类
MRO查找
关键要点
  1. 数据描述符优先:同时实现__get__和__set__的描述符优先级最高
  2. 实例属性次之:如果属性存在于实例的__dict__中,会覆盖非数据描述符
  3. 内存管理:使用weakref.WeakKeyDictionary避免循环引用
  4. Python 3.6+特性:__set_name__自动获取属性名
  5. 应用场景:ORM字段、属性验证、懒加载、缓存、审计日志
描述符是Python属性系统的基石,掌握描述符协议可以编写出更加优雅、高效的代码。
