打破 OS 壁垒:Java 跨平台硬件信息采集的“终极方案”
兮动人 发表于 2026/01/15 01:14:19 2026/01/15
【摘要】 在开发资产管理、安全审计或分布式系统监控时,获取终端设备的唯一标识(如 MAC 地址、磁盘序列号、CPU ID)是一项基础且关键的需求。然而,不同操作系统的查询命令各异,且 Java 原生 API 在某些场景下受限。
Java 实现一套跨平台、高可靠的系统信息采集方案。
跨平台终端信息采集
SystemInfoCollector 提供了一套优雅的解决方案:“Java 原生优先 + 系统命令兜底”。
  • 代码如下:
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.net.InetAddress;
import java.net.NetworkInterface;
import java.util.Enumeration;
import java.util.function.Function;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
 * 终端信息采集工具类
 * localIp本地IP、mac地址、pcName字段信息优先使用Java方式获取
 * 失败则使用命令方式获取
 * @author xdr630
 * @since 2.0.0 2025/12/24
public final class SystemInfoCollector {
    private static final Logger LOGGER = LoggerFactory.getLogger(SystemInfoCollector.class);
    private static final String VERSION = "1.6.0";
    private static final String OS_NAME = System.getProperty("os.name").toLowerCase();
    private static final boolean IS_WINDOWS = OS_NAME.contains("win");
    private static final boolean IS_LINUX =
        OS_NAME.contains("linux") || OS_NAME.contains("nix") || OS_NAME.contains("nux") || OS_NAME.contains("aix");
    private static final boolean IS_MAC = OS_NAME.contains("mac");
    private static final String MAC_ADDRESS_PREFIX = "MACAddress=";
    private static final String SERIAL_NUMBER = "SerialNumber";
    private static final String PROCESSOR_ID = "ProcessorId";
    private static final String CPU_SERIAL_ALL_ZERO = "0000000000000000";
    private static final String VOLUME_SERIAL_NUMBER = "VolumeSerialNumber";
    private static final String FILE_SYSTEM = "FileSystem";
    private static final String SIZE = "Size";
    private static final int VOLUME_SERIAL_NUMBER_LENGTH = 8;
    private static final int UUID_LABEL_PARTS_LENGTH = 4;
    private static final String DOT = ".";
    private static final String COLON = ":";
    private static final String HYPHEN = "-";
    private static final Pattern IPV4_PATTERN =
        Pattern.compile("^((25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\\.){3}(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)$");
     * 常见虚拟/容器/桥接/隧道网卡前缀
    private static final String[] VIRTUAL_IFACE_PREFIXES = {
        // VirtualBox
        "vbox",
        // VMware
        "vmnet",
        // 容器虚拟网卡
        "veth",
        // docker bridge
        "br-",
        // docker0 等
        "docker",
        // macOS VPN / tunnel
        "utun",
        // macOS 本地链路
        "llw",
        // macOS AirDrop/WiFi Direct
        "awdl"};
    private SystemInfoCollector() {
     * 获取插件版本-version
     * @return 插件版本
    public static String getVersion() {
        return VERSION;
     * 获取系统名称-systemName
     * @return 系统名称
    public static String getSystemName() {
        return System.getProperty("os.name");
     * 判断网卡名称是否是 虚拟/容器/桥接网卡
    private static boolean isVirtualLikeInterfaceName(String ifaceName) {
        if (ifaceName == null || ifaceName.isEmpty()) {
            return false;
        String name = ifaceName.toLowerCase();
        for (String prefix : VIRTUAL_IFACE_PREFIXES) {
            if (name.startsWith(prefix)) {
                return true;
        return false;
     * 判断网卡是否是一个“合适的网卡”
     * 规则:已启动、非回环、非虚拟、名称不在黑名单,可选要求有 IPv4
    private static boolean isUsableInterface(NetworkInterface iface, boolean requireIpv4) {
        try {
            if (iface == null) {
                return false;
            if (!iface.isUp() || iface.isLoopback() || iface.isVirtual()) {
                return false;
            if (isVirtualLikeInterfaceName(iface.getName())) {
                return false;
            if (!requireIpv4) {
                return true;
            Enumeration<InetAddress> addresses = iface.getInetAddresses();
            while (addresses.hasMoreElements()) {
                InetAddress addr = addresses.nextElement();
                String ip = addr.getHostAddress();
                if (isValidIp(ip)) {
                    return true;
            return false;
        } catch (Exception e) {
            LOGGER.debug("判断网卡可用性异常: {}", iface, e);
            return false;
     * 获取本地IP-localIp
     * 优先使用Java方式获取,失败则使用命令方式获取
    public static String getLocalIp() {
        String ip = getLocalIpByJava();
        if (ip == null || ip.isEmpty()) {
            LOGGER.warn("Java方式获取IP未获得有效结果,尝试命令方式");
            ip = getLocalIpByCommand();
            LOGGER.error("获取本地IP失败,Java方式与命令方式均未获取到有效IP");
            throw new RuntimeException("Failed to get localIp");
        return ip;
     * 使用Java方式获取本地IP,失败返回 null
    private static String getLocalIpByJava() {
        try {
            // 获取所有网络接口
            Enumeration<NetworkInterface> interfaces = NetworkInterface.getNetworkInterfaces();
            while (interfaces.hasMoreElements()) {
                NetworkInterface iface = interfaces.nextElement();
                // 需要至少有一个 IPv4 的可用网卡
                if (!isUsableInterface(iface, true)) {
                    continue;
                // 获取接口的IP地址
                    // 只返回IPv4地址
                        return ip;
            // 如果没找到,返回本地主机IP
            String fallback = InetAddress.getLocalHost().getHostAddress();
            return isValidIp(fallback) ? fallback : null;
            LOGGER.debug("Java方式获取IP异常", e);
            return null;
     * 使用命令方式获取本地IP,失败返回 null
    private static String getLocalIpByCommand() {
        try {
            if (IS_WINDOWS) {
                // Windows 系统:使用 WMI 查询 IP 地址
                return getWindowsLocalIp();
            } else if (IS_LINUX) {
                // Linux 系统:使用 ifconfig 命令
                return getLinuxLocalIp();
            } else if (IS_MAC) {
                // MacOS 系统:使用 ifconfig 命令
                return getMacLocalIp();
                LOGGER.warn("不支持的操作系统获取IP: {}", OS_NAME);
                return null;
            LOGGER.debug("命令方式获取IP异常", e);
            return null;
     * Windows 系统:获取本地 IP 地址
     * @return 本地 IP 地址
    private static String getWindowsLocalIp() {
        String command = "wmic nicconfig where IPEnabled=true get IPAddress";
        return executeWindowsCommand(command, line -> {
            if (line.contains(DOT)) {
                String[] parts = line.split(",");
                for (String part : parts) {
                    part = part.replaceAll("[{}\"]", "").trim();
                    if (isValidIp(part)) {
                        return part;
            return null;
     * 检查 IP 地址是否有效
     * @param ip IP 地址
     * @return 是否有效
    private static boolean isValidIp(String ip) {
        if (ip == null) {
            return false;
        Matcher matcher = IPV4_PATTERN.matcher(ip);
        return matcher.matches();
     * Linux 系统:获取本地 IP 地址
     * @return 本地 IP 地址
    private static String getLinuxLocalIp() {
        String command =
            "ifconfig | grep -E 'flags=|inet |broadcast ' | grep -i RUNNING -A 1 | grep 'inet ' | grep -m 1 " +
                "'broadcast ' | awk '{print $2}'";
        return executeCommandAndParseOutput(command, line -> line);
     * MacOS 系统:获取本地 IP 地址
     * @return 本地 IP 地址
    private static String getMacLocalIp() {
        String command =
     * 执行 Windows 命令并解析输出
     * @param command         命令
     * @param outputProcessor 输出处理函数
     * @return 处理后的输出结果
    private static String executeWindowsCommand(String command, Function<String, String> outputProcessor) {
        try {
            Process process = Runtime.getRuntime().exec(command);
            try (BufferedReader reader = new BufferedReader(new InputStreamReader(process.getInputStream()))) {
                String line;
                while ((line = reader.readLine()) != null) {
                    String result = outputProcessor.apply(line.trim());
                    if (result != null) {
                        return result;
        } catch (IOException e) {
            throw new RuntimeException("Failed to execute command: " + command, e);
        return null;
     * Linux或MacOS下执行命令并解析输出
     * @param command 命令
     * @return 输出结果
    private static String executeCommandAndParseOutput(String command, Function<String, String> outputProcessor) {
        try {
            Process process = Runtime.getRuntime().exec(new String[]{"sh", "-c", command});
                String line;
                    if (!line.trim().isEmpty()) {
                        String out = outputProcessor.apply(line.trim());
                        if (out != null) {
                            return out;
        return null;
     * 获取本机 MAC 地址-mac
     * 优先使用Java方式获取MAC地址,失败则使用命令方式获取MAC地址
     * @return 本机 MAC 地址
    public static String getMac() {
        String mac = getMacByJava();
        if (mac == null || mac.isEmpty()) {
            LOGGER.warn("Java方式获取MAC未获得有效结果,尝试命令方式");
            mac = getMacByCommand();
            LOGGER.error("获取本机MAC失败,Java方式与命令方式均未获取到有效MAC");
            throw new RuntimeException("Failed to get MAC address");
        return mac;
     * 使用Java方式获取MAC地址,失败返回 null
    private static String getMacByJava() {
        try {
            // 获取第一个非回环的网络接口
                // 要求是一个“有 IPv4 的可用网卡”,避免拿到一些无IP或特殊用途网卡
                    continue;
                // 获取MAC地址
                byte[] macBytes = iface.getHardwareAddress();
                if (macBytes != null && macBytes.length > 0) {
                    return formatMac(macBytes);
            LOGGER.debug("Java方式获取MAC异常", e);
        return null;
     * 使用命令方式获取MAC地址,失败返回 null
    private static String getMacByCommand() {
        try {
            if (IS_WINDOWS) {
                // Windows 系统:使用 WMI 查询 MAC 地址
                return formatMac(getWindowsMac());
                return formatMac(getLinuxMac());
                return formatMac(getMacOsMac());
                LOGGER.warn("不支持的操作系统获取MAC: {}", OS_NAME);
                return null;
            LOGGER.debug("命令方式获取MAC异常", e);
            return null;
     * 格式化 MAC 地址为无分隔符的形式
     * @param mac MAC 地址
     * @return 无分隔符的 MAC 地址
    private static String formatMac(String mac) {
            return null;
        // 移除所有分隔符(如 ":", "-")
        return mac.replaceAll("[:\\-]", "");
     * 格式化MAC地址字节数组为字符串
    private static String formatMac(byte[] macBytes) {
        StringBuilder sb = new StringBuilder();
        for (byte b : macBytes) {
            sb.append(String.format("%02X", b));
        return sb.toString();
     * Windows 系统:获取 MAC 地址
     * @return MAC 地址
    private static String getWindowsMac() {
        // 筛选出物理适配器,并且是已启用的状态
        String command = "wmic nic where \"PhysicalAdapter=True and NetEnabled=True\" get MACAddress /format:value";
            if (line.startsWith(MAC_ADDRESS_PREFIX) && line.length() > MAC_ADDRESS_PREFIX.length()) {
                // 清除前缀
                String macAddress = line.substring(MAC_ADDRESS_PREFIX.length()).trim();
                return macAddress.replace(COLON, HYPHEN);
            return null;
     * Linux 系统:获取 MAC 地址
     * @return MAC 地址
    private static String getLinuxMac() {
        String command =
            "ifconfig | grep -E 'flags=|inet |broadcast |ether ' | grep -i RUNNING -A 2 | grep -A 1 -E 'broadcast" +
                " " + "|inet ' | grep -m 1 'ether ' | awk '{print $2}'";
     * MacOS 系统:获取 MAC 地址
     * @return MAC 地址
    private static String getMacOsMac() {
        String command =
            "ifconfig | grep -E 'flags=|inet |broadcast |ether ' | grep -i RUNNING -A 2 | grep -B 1 -E 'broadcast" +
     * 获取CPU序列号-cpuSerial
     * @return CPU 序列号
    public static String getCpuSerial() {
        try {
            if (IS_WINDOWS) {
                // Windows 系统:使用 wmic 命令获取 CPU 序列号
                return getWindowsCpuSerial();
                // Linux 系统:使用 dmidecode 命令获取 CPU 序列号
                return getLinuxCpuSerial();
                // macOS 系统:使用 system_profiler 命令获取 CPU 序列号
                return getMacCpuSerial();
                throw new UnsupportedOperationException("Unsupported operating system: " + OS_NAME);
            LOGGER.error("获取CPU序列号失败", e);
            throw new RuntimeException("Failed to get cpuSerial", e);
     * Windows 系统:获取 CPU 序列号
     * @return CPU 序列号
    private static String getWindowsCpuSerial() {
        String command = "wmic cpu get ProcessorId";
            if (!line.isEmpty() && !line.contains(PROCESSOR_ID)) {
                return line;
            return null;
     * Linux 系统:获取 CPU 序列号
     * @return CPU 序列号
    private static String getLinuxCpuSerial() {
        String command = "dmidecode -t 4 | grep -m 1 ID | awk '{print $2$3$4$5$6$7$8$9}'";
        return executeCommandAndParseOutput(command, line -> {
            // 去掉所有空格
            String cpuSerial = line.replaceAll("\\s+", "");
            // 如果 CPU 序列号全为 0,则返回 null
            if (CPU_SERIAL_ALL_ZERO.equals(cpuSerial)) {
                return null;
            return cpuSerial;
     * macOS 系统:获取 CPU 序列号
     * @return CPU 序列号
    private static String getMacCpuSerial() {
        String command = "system_profiler SPHardwareDataType | grep -m 1 'Serial Number' | awk '{print $4}'";
            // 去掉所有空格
            return line.trim().replaceAll("\\s+", "");
     * 获取硬盘序列号-hardSerial
    public static String getHardSerial() {
        try {
            if (IS_WINDOWS) {
                // Windows 系统
                return getWindowsHardSerial();
                // Linux 系统
                return getLinuxHardSerial();
                // macOS 系统
                return getMacHardSerial();
            LOGGER.error("获取硬盘序列号失败", e);
            throw new RuntimeException("Failed to get hardSerial", e);
     * Windows 系统:获取硬盘序列号
     * @return 硬盘序列号,如:6479_A75B_B090_09E0
    private static String getWindowsHardSerial() {
        String command = "wmic diskdrive get serialnumber";
            if (!line.trim().isEmpty() && !line.contains(SERIAL_NUMBER)) {
                // 去掉末尾的点(如果存在)
                return line.trim().endsWith(DOT) ? line.trim().substring(0, line.length() - 1) : line.trim();
            return null;
     * Linux 系统:获取硬盘序列号
     * @return 硬盘序列号,如:ac7b3398-162e-4775-b
    private static String getLinuxHardSerial() {
        // Linux amd 执行后:SERIAL=""
        String command =
            "lsblk -p -P -o NAME,SERIAL,UUID,TYPE,MOUNTPOINT | grep -i boot -B 1 | grep -i disk | awk '{print $2}'";
            String result = line.trim().replace("SERIAL=", "").replace("\"", "");
            // 去掉末尾的点(如果存在)
            if (result.endsWith(DOT)) {
                result = result.substring(0, result.length() - 1);
            // 如果序列号为空,返回 null
            return result.isEmpty() ? null : result;
     * macOS 系统:获取硬盘序列号
     * @return 硬盘序列号
    private static String getMacHardSerial() {
        String command = "system_profiler SPHardwareDataType | grep -m 1 'Hardware UUID' | awk '{print $3}'";
            String result = line.trim();
            // 去掉末尾的点(如果存在)
            return result;
     * 获取系统盘盘符-drive
     * @return 系统盘盘符,如:C 或 /dev/sda1
     * @throws RuntimeException 获取失败时抛出异常
    public static String getDrive() {
        try {
            if (IS_WINDOWS) {
                // Windows 系统
                return getWindowsDrive();
                // Linux 系统
                return getLinuxDrive();
                // macOS 系统
                return getMacDrive();
            LOGGER.error("获取系统盘盘符失败", e);
            throw new RuntimeException("Failed to get drive", e);
     * Windows 系统:获取盘符
     * @return 盘符,如:C
    private static String getWindowsDrive() {
        // 获取系统盘盘符(如 C:)
        String systemDrive = System.getenv("SystemDrive");
        if (systemDrive == null || systemDrive.isEmpty()) {
            LOGGER.error("SystemDrive environment variable is empty");
            return null;
        // 去掉冒号
        return systemDrive.replace(COLON, "");
     * Linux 系统:获取盘符
     * @return 盘符,如:/dev/sda1
    private static String getLinuxDrive() {
        String command =
            "lsblk -p -P -o NAME,PARTUUID,FSTYPE,SIZE,UUID,TYPE,MOUNTPOINT | grep -E '/boot\"$' | grep -i part | " +
                "awk " + "'{print $1,$2,$3,$4}'";
            String[] split = line.split("\"");
            return split.length > 1 ? split[1] : null;
     * macOS 系统:获取盘符
     * @return 盘符
    private static String getMacDrive() {
        String command = "system_profiler SPSoftwareDataType | grep -m 1 'Boot Volume'";
            String[] split = line.split(": ");
     * 获取系统盘分区格式-fileSystem
     * @return 系统盘分区格式,如:NTFS 或 xf4
     * @throws RuntimeException 如果无法获取分区格式
    public static String getFileSystem() {
        try {
            if (IS_WINDOWS) {
                // Windows 系统
                return getWindowsFileSystem();
                // Linux 系统
                return getLinuxFileSystem();
                // macOS 系统
                return getMacFileSystem();
            LOGGER.error("获取系统盘分区格式失败", e);
            throw new RuntimeException("Failed to get fileSystem", e);
     * Windows 系统:获取分区格式
     * @return 分区格式,如:NTFS
    private static String getWindowsFileSystem() {
        // 获取系统盘盘符(如 C:)
            return null;
        // 获取系统盘的分区信息
        String command = "wmic logicaldisk where deviceid='" + systemDrive + "' get filesystem";
            if (!line.isEmpty() && !line.contains(FILE_SYSTEM)) {
                return line;
            return null;
     * Linux 系统:获取分区格式
     * @return 分区格式
    private static String getLinuxFileSystem() {
        String command =
            return split.length > 5 ? split[5] : null;
     * macOS 系统:获取分区格式
     * @return 分区格式
    private static String getMacFileSystem() {
        String command = "system_profiler SPStorageDataType | grep -w -A 5 -B 1 'Mount Point: /'";
            String number = "";
            String[] lines = line.split("\n");
            for (String l : lines) {
                l = l.trim();
                if (l.startsWith("File System:")) {
                    String[] split = l.split(" ");
                    if (split.length > 2) {
                        number = split[2];
            return number.isEmpty() ? null : number;
     * 获取系统盘分区容量
     * @return 系统盘分区容量,如:119G
     * @throws RuntimeException 如果无法获取分区容量
    public static String getPartitionSize() {
        try {
            if (IS_WINDOWS) {
                // Windows 系统
                return getWindowsPartitionSize();
                // Linux 系统
                return getLinuxPartitionSize();
                // macOS 系统
                return getMacPartitionSize();
            LOGGER.error("获取系统盘分区容量失败", e);
            throw new RuntimeException("Failed to get partition size", e);
     * Windows 系统:获取分区容量
     * @return 分区容量
    private static String getWindowsPartitionSize() {
        // 获取系统盘盘符(如 C:)
            return null;
        // 获取系统盘的分区信息
        String command = "wmic logicaldisk where deviceid='" + systemDrive + "' get size";
            if (!line.isEmpty() && !line.contains(SIZE)) {
                long sizeBytes = Long.parseLong(line);
                return (sizeBytes / 1024 / 1024 / 1024) + "G";
            return null;
     * Linux 系统:获取分区容量
     * @return 分区容量
    private static String getLinuxPartitionSize() {
        String command =
        return executeCommandAndParseOutput(command, output -> {
            String[] split = output.split("\"");
            return split.length > 7 ? split[7] : null;
     * macOS 系统:获取分区容量
     * @return 分区容量
    private static String getMacPartitionSize() {
            String size = "";
                l = l.trim();
                if (l.startsWith("Capacity:")) {
                        size = split[1] + "G";
            return size;
     * 获取系统盘卷标号-systemDisk
     * @return 系统盘卷标号
    public static String getSystemDisk() {
        try {
            if (IS_WINDOWS) {
                // Windows 系统
                return getWindowsSystemDisk();
                // Linux 系统
                return getLinuxSystemDisk();
                // macOS 系统
                return getMacSystemDisk();
            LOGGER.error("获取系统盘卷标号失败", e);
            throw new RuntimeException("Failed to get systemDisk", e);
     * Windows 系统:获取系统盘卷标号
     * @return 系统盘卷标号,格式为 "XXXX-XXXX",如:8AD0-CC8B
    private static String getWindowsSystemDisk() {
        // 获取系统盘盘符(如 C:)
            return null;
        // 获取系统盘的卷标号
        String command = "wmic logicaldisk where deviceid='" + systemDrive + "' get VolumeSerialNumber";
            if (!line.isEmpty() && !line.contains(VOLUME_SERIAL_NUMBER)) {
                if (line.length() == VOLUME_SERIAL_NUMBER_LENGTH) {
                    // 格式化为 XXXX-XXXX
                    return line.substring(0, 4) + HYPHEN + line.substring(4);
            return null;
     * Linux 系统:获取系统盘卷标号
     * @return 系统盘卷标号
    private static String getLinuxSystemDisk() {
        // 使用 lsblk 命令获取系统盘卷标号
        // Linux amd执行后:UUID="" LABEL=""
        String command =
            "lsblk -p -P -o NAME,UUID,LABEL,TYPE,MOUNTPOINT | grep -i boot -B 1 | grep -i disk | awk '{print $2," +
                "$3}'";
            String[] parts = line.trim().split("\"");
            if (parts.length >= UUID_LABEL_PARTS_LENGTH) {
                // UUID
                String uuid = parts[1];
                // LABEL
                String label = parts[3];
                // 返回 UUID 或 LABEL
                return !uuid.isEmpty() ? uuid : label;
            return null;
     * macOS 系统:获取系统盘卷标号
     * @return 系统盘卷标号
    private static String getMacSystemDisk() {
            String number = "";
                l = l.trim();
                if (l.startsWith("Volume UUID:")) {
                        number = split[2];
     * 获取PC终端设备名称-pcName
     * @return PC终端设备名称
    public static String getPcName() {
        String pcName = getPcNameByJava();
        if (pcName == null || pcName.isEmpty()) {
            LOGGER.warn("Java方式获取PC终端设备名称未获得有效结果,尝试命令方式");
            pcName = getPcNameByCommand();
            LOGGER.error("获取PC终端设备名称失败,Java方式与命令方式均未获取到有效名称");
            throw new RuntimeException("Failed to get pcName");
        return pcName;
     * 使用Java方式获取PC终端设备名称-pcName
     * @return PC终端设备名称,失败返回 null
    private static String getPcNameByJava() {
        try {
            return InetAddress.getLocalHost().getHostName();
            LOGGER.debug("Java方式获取PC终端设备名称异常", e);
            return null;
     * 使用命令方式获取PC终端设备名称-pcName
    public static String getPcNameByCommand() {
        String command = "hostname";
        try {
            if (IS_WINDOWS) {
                // Windows 系统:使用 hostname 命令获取设备名称
                return executeWindowsCommand(command, line -> line.isEmpty() ? null : line);
                // Linux 系统:使用 hostname 命令获取设备名称
                // MacOS 系统:使用 scutil 命令获取设备名称
                return executeCommandAndParseOutput("scutil --get ComputerName", line -> line);
                LOGGER.warn("不支持的操作系统获取PC终端设备名称: {}", OS_NAME);
                return null;
            LOGGER.debug("命令方式获取PC终端设备名称异常", e);
            return null;
     * 获取PC终端设备序列号(仅 Mac 系统有,其他系统返回 "null")
     * @return PC 终端设备序列号,如果获取失败或非 Mac 系统则返回 "null"
    public static String getPcSerial() {
        if (!IS_MAC) {
            // 非 Mac 系统直接返回 "null"
            return "null";
        try {
            // MacOS 系统:使用 system_profiler 命令获取设备序列号
            String command = "system_profiler SPHardwareDataType | grep -m 1 'Provisioning UDID' | awk '{print $3}'";
            LOGGER.error("获取PC终端设备序列号失败", e);
            throw new RuntimeException("Failed to get pcSerial on MacOS.", e);
核心设计理念
该工具类的核心逻辑遵循以下优先级:
  1. Java 原生 API:跨平台性好,执行效率高,作为首选方案。
  2. 系统原生命令:当 Java API 无法获取深层硬件信息(如磁盘序列号)或执行失败时,根据识别到的操作系统(Windows/Linux/macOS)自动调用底层命令。
主要功能特性
1. 智能的网络接口过滤
获取 IP 或 MAC 地址时,最头疼的就是搜出一堆 vbox、docker 或 utun 等虚拟网卡信息。SystemInfoCollector 内置了黑名单过滤机制:
  • 自动识别虚拟网卡:排除常见容器(Docker)、虚拟机(VMware/VirtualBox)及隧道网卡。
  • 状态校验:仅针对已启动(Up)且非回环(Loopback)的物理网卡进行信息采集。
2. 多维度的硬件识别
工具类不仅能获取基础信息,还能深入挖掘硬件指纹:
  • CPU 序列号:通过 wmic (Win)、dmidecode (Linux) 或 system_profiler (Mac) 获取。
  • 硬盘序列号:精确获取物理硬盘的唯一标识。
  • 系统盘详情:包括盘符、分区格式(NTFS/APFS等)、总容量以及卷标序列号。
3. 强大的跨平台兼容性
代码内部通过 OS_NAME 常量实现了对主流系统的全覆盖:
  • Windows: 利用 wmic 命令进行底层查询。
  • Linux: 结合 lsblk、ifconfig 和 awk 进行文本解析。
  • macOS: 使用特有的 system_profiler 和 scutil 工具。
技术亮点:命令执行与结果解析
为了保证代码的可维护性,工具类采用了一个 函数式接口(Function) 来处理命令输出。这种设计将“执行过程”与“结果过滤”解耦:
// 以 Windows 获取磁盘序列号为例
            return line.trim(); // 具体的过滤逻辑由 Lambda 表达式完成
        return null;
如何使用?
由于所有方法均设计为 static,集成非常简单,无需实例化:
public class SystemInfoCollectorTest {
        System.out.println("version: " + SystemInfoCollector.getVersion());
        System.out.println("systemName: " + SystemInfoCollector.getSystemName());
        System.out.println("localIp: " + SystemInfoCollector.getLocalIp());
        System.out.println("mac: " + SystemInfoCollector.getMac());
        System.out.println("cpuSerial: " + SystemInfoCollector.getCpuSerial());
        System.out.println("hardSerial: " + SystemInfoCollector.getHardSerial());
        System.out.println("drive: " + SystemInfoCollector.getDrive());
        System.out.println("fileSystem: " + SystemInfoCollector.getFileSystem());
        System.out.println("partitionSize: " + SystemInfoCollector.getPartitionSize());
        System.out.println("systemDisk: " + SystemInfoCollector.getSystemDisk());
        System.out.println("pcName: " + SystemInfoCollector.getPcName());
        System.out.println("pcSerial: " + SystemInfoCollector.getPcSerial());
总结与注意事项
SystemInfoCollector 是一个封装严密、容错性强的工具类,非常适合需要快速集成硬件采集功能的 Java 项目。
tips:
  • 在 Linux 环境下,某些硬件命令(如 dmidecode)可能需要 sudo 权限才能获取完整信息。
  • 工具类默认对 IP 地址进行了 IPv4 格式校验,若环境仅支持 IPv6,需微调正则表达式。
