用户和数据库权限知识总结
ftruezzq 发表于 2025/12/29 22:39:05 2025/12/29
【摘要】 1、 查看用户user1和数据库的相关权限,要求显示数据库名、用户名、数据库的权限select datname,(aclexplode(datacl)).grantee as grantee,(aclexplode(datacl)).privilege_type as pri_t from pg_database where datname not like 'template%'; sel...
select a.datname,b.rolname,string_agg(a.pri_t,',') from
(select datname
,(aclexplode(COALESCE(datacl, acldefault('d'::"char",datdba)))).grantee as grantee
,(aclexplode(COALESCE(datacl, acldefault('d'::"char", datdba)))).privilege_type as pri_t
from pg_database where datname not like 'template%') a,pg_roles b where (a.grantee=b.oid or a.grantee=0) and b.rolname='shenglu' group by a.datname,b.rolname;
--aclexplode(datacl) 一共有四个属性,分别是grantor(授权人)、grantee(被授权人)、privilege_type(权限类型)、is_grantable(是否拥有该权限)
