OMPS-NPP L2 NM 气溶胶指数条带轨道 NRT
此星光明 发表于 2025/12/07 01:49:12 2025/12/07
【摘要】 ​OMPS-NPP L2 NM Aerosol Index swath orbital NRT简介OMPS-NPP L2 NM气溶胶指数条带轨道V2近实时数据。标准产品请参见CMR中的OMPS_NPP_NMMIEAI_L2产品。该气溶胶指数由归一化辐射亮度计算得出,使用340 nm和378.5 nm两对波长。此外,该数据产品还包含归一化辐射亮度、反射率、云量和其他辅助变量的测量值。摘要代码!...
简介
摘要
代码
!pip install leafmap
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="NMMIEAI-L2-NRT",
    cloud_hosted=True,
    bounding_box=(-125, 25, -67, 53),
    temporal=("2011-11-07", "2011-11-14"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
