【数据库使用】 记一次简单sql执行慢问题定位
超人来了 发表于 2025/10/25 17:33:55 2025/10/25
【摘要】 一、问题背景:delete语句执行慢,delete几千条数据,执行要用一分钟,不满足要求。DELETE FROM schema_css.t_call_record_attendee WHERE confuuid in ('xxx','xxx','xxx');表结构:    Column    |          Type           |             Modifiers ...
一、问题背景:
表结构:
    Column    |          Type           |             Modifiers              | Storage  | Stats target | Description
 uuid            | character varying(64)   | not null                           | extended |              |
 confuuid     | character varying(64)   | not null                           | extended |              |
 orguuid      | character varying(128)  |                                    | extended |              |
 logicid        | character varying(128)  |                                    | extended |              |
 roletype      | character varying(16)   | default 'GUEST'::character varying | extended |              |
 displayname  | nvarchar2(512)          |                                    | extended |              |
 terminaltype | character varying(32)   |                                    | extended |              |
 callnumber   | character varying(128)  |                                    | extended |              |
 deptname     | nvarchar2(512)          |                                    | extended |              |
 deptuuid      | character varying(128)  |                                    | extended |              |
 useruuid      | character varying(128)  |                                    | extended |              |
 attribute      | character varying(4096) |                                    | extended |              |
 updatetime  | bigint                  | default 0                          | plain    |              |
 createtime   | bigint                  |                                    | plain    |              |
 deleted        | integer                 | default 0                          | plain    |              |
Indexes:
    "t_call_record_attendee_pkey" PRIMARY KEY, cbtree (uuid, confuuid) TABLESPACE pg_default
    "i_t_call_record_attendee_confuuid" cbtree (confuuid) TABLESPACE pg_default
    "i_t_call_record_attendee_logicid" cbtree (logicid) TABLESPACE pg_default
    "i_t_call_record_attendee_useruuid" cbtree (useruuid) TABLESPACE pg_default
Has OIDs: no
Distribute By: HASH(confuuid)
Location Nodes: ALL DATANODES
Options: orientation=column, enable_hstore_opt=true, enable_binlog=on, binlog_ttl=86400, bucketnums=16384, compression=middle, colversion=2.0, enable_delta=false, enable_hstore=true, enable_turbo_store=true
二、问题定位
1、无锁冲突,无性能瓶颈,执行的是delete的语句,无法打印执行计划;topsql中记录的是fqs,也没有计划。
将delete转化为select语句执行:
select * FROM schema_css.t_call_record_attendee WHERE confuuid in ('xxx','xxx','xxx');
走FQS执行计划,执行很快;关闭fqs后,走了索引,依然很快,未出现慢的情况。
关闭fqs后,打印delete的verbose计划,和select快的计划是一致的,未发现问题。由于FQS计划相当于直连DN执行,因此直连DN打印执行计划,发现也是走了索引的快的计划,性能很快,未能复现。
2、根据等待视图,抓取语句堆栈如下:
postgres=# select * from pgxc_thread_wait_status where query_id in (select query_id from pgxc_stat_activity where query like '%T_CALL_RECORD_ATTENDEE%'  and usename !='Ruby' order by query_start desc limit 1);
  node_name   | db_name |      thread_name       |      query_id      |       tid       |  lwtid  | ptid | tlevel | smpid |           wait_status            | wait_event
 dn_6003_6004 | mms_db  | PostgreSQL JDBC Driver | 145241088536308910 | 139795727430888 | 3127403 |      |      0 |     0 | none                             |
 dn_6009_6010 | mms_db  | PostgreSQL JDBC Driver | 145241088536308910 | 140270667850240 | 4116415 |      |      0 |     0 | none                             |
 dn_6011_6012 | mms_db  | PostgreSQL JDBC Driver | 145241088536308910 | 139655937670760 | 4116416 |      |      0 |     0 | none                             |
 dn_6001_6002 | mms_db  | PostgreSQL JDBC Driver | 145241088536308910 | 139846959760552 | 3127402 |      |      0 |     0 | none                             |
 dn_6007_6008 | mms_db  | PostgreSQL JDBC Driver | 145241088536308910 | 140166692434008 |  370635 |      |      0 |     0 | none                             |
 dn_6005_6006 | mms_db  | PostgreSQL JDBC Driver | 145241088536308910 | 139766594408728 |  370634 |      |      0 |     0 | none                             |
 cn_5002      | mms_db  | PostgreSQL JDBC Driver | 145241088536308910 | 139761117827248 | 2735702 |      |      0 |     0 | wait node(total 6): dn_6011_6012 |
3、dn抓堆栈
postgres=# SELECT * FROM gs_stack('dn_6001_6002',139846959760552);
       tid       |  lwtid  |        stack
 139846959760552 | 3127402 | texteq(FunctionCallInfoData*) + 0x2
                 |         | ExecEvalScalarArrayOp(ScalarArrayOpExprState*, ExprContext*, bool*, ExprDoneCond*) + 0x41c
                 |         | ExecQual(List*, ExprContext*, bool) + 0x98
                 |         | ExecResult(ResultState*) + 0x7a
                 |         | TupleTableSlot* ExecProcNodeT<false, false, false, false, (NodeTag)201>(PlanState*) + 0x8c
                 |         | ExecRowToVecTupleMode(RowToVecState*) + 0x51
                 |         | VectorEngine(PlanState*) + 0x14a
                 |         | FetchRows(VecModifyTableState*, EState*, CmdType&, PlanState*, PlanState*, JunkFilter*, RelationData*, void*, tagVecModifyTableFuncSet const*, bool) + 0x245
                 |         | ExecVecModifyTable(VecModifyTableState*) + 0x1ed
                 |         | ExecVecToRow(VecToRowState*) + 0xda
                 |         | TupleTableSlot* ExecProcNodeT<false, false, false, false, (NodeTag)2000>(PlanState*) + 0x8c
                 |         | standard_ExecutorRun(QueryDesc*, ScanDirection, long) + 0x649
                 |         | ExecutorRun(QueryDesc*, ScanDirection, long) + 0x375
                 |         | ProcessQuery(PlannedStmt*, char const*, ParamListInfoData*, _DestReceiver*, char*) + 0xc9
                 |         | PortalRunMulti(PortalData*, bool, _DestReceiver*, _DestReceiver*, char*) + 0x287
                 |         | PortalRun(PortalData*, long, bool, _DestReceiver*, _DestReceiver*, char*, bool) + 0x583
                 |         | exec_execute_message(char const*, long) + 0x342
                 |         | PostgresMain(int, char**, char const*, char const*) + 0x15e4
                 |         | SubPostmasterMain(tag_gs_thread_args*) + 0x1209
                 |         | MainStarterThreadFunc(void*) + 0x3f
                 |         | ThreadStarterFunc(void*) + 0x40
                 |         | 0x7f323d8dc67a
                 |         | 0x7f323d95f160
(1 row)
发现堆栈和快的计划对不上,快的计划走了索引,而堆栈中走了全表扫描。
4、继续对比复现语句和客户实际业务语句发下,慢的情况是PBE(Prepare-Bind-Execute 预编译)后,参数是通过变量的方式传到条件里的,而复现问题时,条件都是直接写好的。
客户的业务语句是通过JDBC绑定变量的方式执行的,形如:
DELETE FROM schema_css.t_call_record_attendee WHERE confuuid in ($1, $2, $3);
而在复现时,将其中的$1等变量内容替换成了实际常量:
DELETE FROM schema_css.t_call_record_attendee WHERE confuuid in (1234, 1235, 1236);
怀疑是PBE场景导致的执行计划差异。
使用PBE方式直连DN模拟PBE的FQS计划,发现执行计划和抓到的堆栈匹配,问题复现,确认和PBE有关。
prepare p1(text,text) as select * FROM schema_css.t_call_record_attendee a WHERE confuuid in( $1, $2);
explain verbose execute p1('SFyuC4xX3X7yQHzXqAQxv8md3MHgfoWq','MUZASKbhpDBQwK1A2faPpRzw58qRvV2Z');
关闭FQS后,在CN上执行,生成了索引计划,执行性能较快,因此可将关闭FQS作为规避方案
set enable_fast_query_shipping=off;
5、用户级修改参数
alter user xxx set enable_fast_query_shipping=off;
中间有一个小插曲是,用户级修改参数后,新建连接立即生效,不需要重启,但是老连接不生效,因此需要用户新建连接测试规避方案是否有效。
可以通过审计日志查看用户登入登出时间,确保在参数调整后新建连接:
select * from pgxc_query_audit('2025-08-15 00:00:00','2025-08-15 06:30:00') where session_id like '%对应的pid%' and detail_info not in ('START TRANSACTION','ROLLBACK','COMMIT') and operation_type ='login_logout' order by begintime;
修改参数生效后,验证问题得到解决。
三、问题根因
通过PBE的方式执行,array用法在PBE场景下不支持向量化,in条件会被转化为array,直接执行时,走的FQS计划,导致走了全表扫描,再走行存过滤表达式,性能差。关闭FQS后,变量在CN上被替换,替换后支持向量化,因此可以生成索引扫描计划,性能快。
规避方法:
(1)通过hint关闭fqs : /*+ set global(enable_fast_query_shipping off) */,仅影响当前语句
(2)用户级关闭参数: alter user xxx set enable_fast_query_shipping=off;  仅影响当前用户,一般不会产生其他副作用
