sigar获取机器部分负载信息方法及问题解决
刘大猫 发表于 2025/09/23 20:30:05 2025/09/23
【摘要】 sigar获取机器部分负载信息方法及问题解决
@[TOC]
一、获取负载信息部分:
结果部分数据展示:
相关代码如下:
pojo
import java.util.Date;
import com.geespace.microservices.calculate.execute.engine.bean.ModelField;
import lombok.Data;
import lombok.EqualsAndHashCode;
import lombok.ToString;
 * ResourInformation
 * @Author: liudz
 * @Date: 2019-11-07
@Data
@EqualsAndHashCode(callSuper = false)
@ToString(callSuper = true)
public class MachineResourceInfo {
     * cpuLoadDetails
    @ModelField(name = "CPU负载详情信息", comment = "CPU负载详情信息", size = "500", required = false)
    String cpuLoadDetails;
     * memoryLoadTotalUsePercent
    @ModelField(name = "内存总使用百分比", comment = "内存总使用百分比", size = "500", required = false)
    String memoryLoadTotalUsePercent;
     * memoryLoadTotal
    @ModelField(name = "内存总量", comment = "内存总量", size = "500", required = false)
    String memoryLoadTotal;
     * memoryLoadUsed
    @ModelField(name = "当前内存使用量", comment = "当前内存使用量", size = "500", required = false)
    String memoryLoadUsed;
     * memoryLoadFree
    @ModelField(name = "当前内存剩余量", comment = "当前内存剩余量", size = "500", required = false)
    String memoryLoadFree;
     * memoryExchangeTotal
    @ModelField(name = "内存交换区总量", comment = "内存交换区总量", size = "500", required = false)
    String memoryExchangeTotal;
     * memoryExchangeUsed
    @ModelField(name = "内存当前交换区使用量", comment = "内存当前交换区使用量", size = "500", required = false)
    String memoryExchangeUsed;
     * memoryExchangeFree
    @ModelField(name = "内存当前交换区剩余量", comment = "内存当前交换区剩余量", size = "500", required = false)
    String memoryExchangeFree;
     * diskLoad
    @ModelField(name = "磁盘使用情况", comment = "磁盘使用情况", size = "500", required = false)
    String diskLoad;
     * diskReadOrWrite
    @ModelField(name = "磁盘读写", comment = "磁盘读写", size = "500", required = false)
    String diskReadOrWrite;
     * jvmHeapMemoryMax
    @ModelField(name = "JVM堆内存信息Max", comment = "JVM堆内存信息Max", size = "500", required = false)
    String jvmHeapMemoryMax;
     * jvmHeapMemoryInit
    @ModelField(name = "JVM堆内存信息Init", comment = "JVM堆内存信息Init", size = "500", required = false)
    String jvmHeapMemoryInit;
     * jvmHeapMemoryCommitted
    @ModelField(name = "JVM堆内存信息Committed", comment = "JVM堆内存信息Committed", size = "500", required = false)
    String jvmHeapMemoryCommitted;
     * jvmHeapMemoryUsed
    @ModelField(name = "JVM堆内存信息Used", comment = "JVM堆内存信息Used", size = "500", required = false)
    String jvmHeapMemoryUsed;
     * jvmNonHeapMemoryMax
    @ModelField(name = "JVM非堆内存信息Max", comment = "JVM非堆内存信息Max", size = "500", required = false)
    String jvmNonHeapMemoryMax;
     * jvmNonHeapMemoryInit
    @ModelField(name = "JVM非堆内存信息Init", comment = "JVM非堆内存信息Init", size = "500", required = false)
    String jvmNonHeapMemoryInit;
     * jvmNonHeapMemoryCommitted
    @ModelField(name = "JVM非堆内存信息Committed", comment = "JVM非堆内存信息Committed", size = "500", required = false)
    String jvmNonHeapMemoryCommitted;
     * jvmNonHeapMemoryUsed
    @ModelField(name = "JVM非堆内存信息Used", comment = "JVM非堆内存信息Used", size = "500", required = false)
    String jvmNonHeapMemoryUsed;
     * jvmTotalMemory
    @ModelField(name = "JVM已申请的内存量", comment = "JVM已申请的内存量", size = "500", required = false)
    String jvmTotalMemory;
     * jvmFreeMemory
    @ModelField(name = "JVM空闲的内存量", comment = "JVM空闲的内存量", size = "500", required = false)
    String jvmFreeMemory;
     * jvmMaxMemory
    @ModelField(name = "JVM最大可使用的内存量", comment = "JVM最大可使用的内存量", size = "500", required = false)
    String jvmMaxMemory;
     * 数据产生时间
    private Date createTime;
接口
     * 获取机器资源信息
     * @return MachineResourInformation 结果
     * @author: liudz
     * @date: 2020/4/25 16:45
    MachineResourceInfo getMachineResourceInfo();
接口实现类
     * 向ES写机器负载信息,并返回给前端
     * @return
     * @author: liudz
     * @date: 2020/4/25 16:53
    @Override
    public MachineResourceInfo getMachineResourceInfo() {
        MachineResourceInfo machineResourInfo = null;
        try {
            machineResourInfo = addParameter1();
            MachineResourceInfo finalMachineResourInfo = machineResourInfo;
            esExecutorService.submit(() -> {
                JSONObject params = (JSONObject) JSONObject.toJSON(finalMachineResourInfo);
                ResponseEntity<JSONObject> response = HttpUtils.sendPostRequest(monitorUrl, params);
                if (!response.getStatusCode().equals(HttpStatus.CREATED)) {
                    log.error("spark write ES error:{}", response);
        } catch (SigarException e) {
            log.error("AccessEsLogServiceImpl--getMachineResourInfo--error!");
        return machineResourInfo;
     * addParameter
     * @return 结果
     * @throws SigarException
     *             SigarException
     * @author: liudz
     * @date: 16:52
    public MachineResourceInfo addParameter1() throws SigarException {
        MachineResourceInfo machineResourceInfo = new MachineResourceInfo();
        Sigar sigar = new Sigar();
        CpuInfo[] infos = sigar.getCpuInfoList();
        CpuPerc[] cpuList = null;
        cpuList = sigar.getCpuPercList();
        String cpuLoadDetailsUsed = "";
        for (int i = 0; i < infos.length; i++) {
            cpuLoadDetailsUsed += "第" + (i + 1) + "块CPU总的使用率: " + CpuPerc.format(cpuList[i].getCombined()) + ", ";
        Mem mem = sigar.getMem();
        DecimalFormat df = new DecimalFormat("0.00");
        Swap swap = sigar.getSwap();
        FileSystem[] fslist = sigar.getFileSystemList();
        String diskLoad = "";
        String diskReadOrWrite = "";
        for (int i = 0; i < fslist.length; i++) {
            FileSystem fs = fslist[i];
            FileSystemUsage usage = null;
            usage = sigar.getFileSystemUsage(fs.getDirName());
            double usePercent = usage.getUsePercent() * Double.parseDouble("100D");
            diskLoad += fs.getDevName() + "总大小: " + usage.getTotal() + "KB, " + fs.getDevName() + "已经使用量: "
                + usage.getUsed() + "KB, " + fs.getDevName() + "剩余大小: " + usage.getFree() + "KB, " + fs.getDevName()
                + "资源的利用率: " + usePercent + "%";
            diskReadOrWrite += fs.getDevName() + "读出:" + usage.getDiskReads() + "扇区, " + fs.getDevName() + "写入:"
                + usage.getDiskWrites() + "扇区";
        machineResourceInfo = addParameter2(df, mem, swap, diskLoad, diskReadOrWrite);
        machineResourceInfo.setCpuLoadDetails(cpuLoadDetailsUsed);
        return machineResourceInfo;
     * addParameter2
     * @param df
     *            df
     * @param mem
     *            mem
     * @param swap
     *            swap
     * @param diskLoad
     *            diskLoad
     * @param diskReadOrWrite
     *            diskReadOrWrite
     * @return machineResourceInfo
     * @author: liudz
     * @date: 2020/4/27 10:27
    public MachineResourceInfo addParameter2(DecimalFormat df, Mem mem, Swap swap, String diskLoad,
        String diskReadOrWrite) {
        MemoryMXBean memorymbean = ManagementFactory.getMemoryMXBean();
        machineResourceInfo.setCreateTime(new Date());
        machineResourceInfo.setMemoryLoadTotalUsePercent(
            "内存总使用百分比: " + df.format((float) mem.getUsed() / mem.getTotal() * Integer.parseInt("100")) + "%");
        machineResourceInfo.setMemoryLoadTotal("内存总量:  " + mem.getTotal() / Integer.parseInt("1024") + "K av");
        machineResourceInfo.setMemoryLoadUsed("当前内存使用量:  " + mem.getUsed() / Integer.parseInt("1024") + "K used");
        machineResourceInfo.setMemoryLoadFree("当前内存剩余量:  " + mem.getFree() / Integer.parseInt("1024") + "K free");
        machineResourceInfo.setMemoryExchangeTotal("内存交换区总量:  " + swap.getTotal() / Integer.parseInt("1024") + "K av");
        machineResourceInfo
            .setMemoryExchangeUsed("内存当前交换区使用量:  " + swap.getUsed() / Integer.parseInt("1024") + "K used");
        machineResourceInfo
            .setMemoryExchangeFree("内存当前交换区剩余量:  " + swap.getFree() / Integer.parseInt("1024") + "K free");
        machineResourceInfo.setDiskLoad(diskLoad);
        machineResourceInfo.setDiskReadOrWrite(diskReadOrWrite);
        machineResourceInfo.setJvmHeapMemoryMax("堆内存信息Max: "
            + memorymbean.getHeapMemoryUsage().getMax() / Integer.parseInt("1024") / Integer.parseInt("1024") + " MB");
        machineResourceInfo.setJvmHeapMemoryInit("堆内存信息Init: "
            + memorymbean.getHeapMemoryUsage().getInit() / Integer.parseInt("1024") / Integer.parseInt("1024") + " MB");
        machineResourceInfo.setJvmHeapMemoryCommitted("堆内存信息Committed: "
            + memorymbean.getHeapMemoryUsage().getCommitted() / Integer.parseInt("1024") / Integer.parseInt("1024")
            + " MB");
        machineResourceInfo.setJvmHeapMemoryUsed("堆内存信息Used: "
            + memorymbean.getHeapMemoryUsage().getUsed() / Integer.parseInt("1024") / Integer.parseInt("1024") + " MB");
        machineResourceInfo.setJvmNonHeapMemoryMax("非堆内存信息Max: "
            + memorymbean.getNonHeapMemoryUsage().getMax() / Integer.parseInt("1024") / Integer.parseInt("1024")
            + " MB");
        machineResourceInfo.setJvmNonHeapMemoryInit("非堆内存信息Init: "
            + memorymbean.getNonHeapMemoryUsage().getInit() / Integer.parseInt("1024") / Integer.parseInt("1024")
            + " MB");
        machineResourceInfo.setJvmNonHeapMemoryCommitted("非堆内存信息Committed: "
            + memorymbean.getNonHeapMemoryUsage().getCommitted() / Integer.parseInt("1024") / Integer.parseInt("1024")
            + " MB");
        machineResourceInfo.setJvmNonHeapMemoryUsed("非堆内存信息Used: "
            + memorymbean.getNonHeapMemoryUsage().getUsed() / Integer.parseInt("1024") / Integer.parseInt("1024")
            + " MB");
        machineResourceInfo.setJvmTotalMemory("JVM已申请的内存量:  "
            + Runtime.getRuntime().totalMemory() / Integer.parseInt("1024") / Integer.parseInt("1024") + " MB");
        machineResourceInfo.setJvmFreeMemory("JVM空闲的内存量:  "
            + Runtime.getRuntime().freeMemory() / Integer.parseInt("1024") / Integer.parseInt("1024") + " MB");
        machineResourceInfo.setJvmMaxMemory("JVM最大可使用的内存量: "
            + Runtime.getRuntime().maxMemory() / Integer.parseInt("1024") / Integer.parseInt("1024") + " MB");
二、使用问题解答
第一种问题:在华为云ARM部署报错:
org.hyperic.sigar.SigarException: no libsigar-aarch64-linux.so in java.libra
解决办法:遇到华为ARM服务器时,需要libsigar-aarch64-linux.so库支持aarch64平台,把“libsigar-aarch64-linux.so”放在linux下的   /usr/lib  和    /usr/lib64   下(都要进行拷贝)
第二种问题:使用该类常常会遇到问题:
java.lang.UnsatisfiedLinkError: org.hyperic.sigar.SysInfo.gather(Lorg/hyperic/sigar/Sigar;)V
org.hyperic.sigar.SysInfo.gather(Native Method)
org.hyperic.sigar.OperatingSystem.getInstance(OperatingSystem.java:90)
com.shuhaiserver.page.servlet.LoginServlet.doLogin(LoginServlet.java:146)
com.shuhaiserver.page.servlet.LoginServlet.doPost(LoginServlet.java:54)
javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
com.shuhaiserver.page.servlet.MyFilter.doFilter(MyFilter.java:82)
第一种办法:此时,需要将libsigar-amd64-linux.so、libsigar-x86-linux.so、sigar-amd64-winnt.dll、sigar-x86-winnt.dll、sigar-x86-winnt.lib文件放在项目的lib文件夹下
第二种办法:将上面的5个文件放在linux下的   /usr/lib  和    /usr/lib64   下(都要进行拷贝)   -----使用场景是linux下启动springboot的jar包 以命令:java -jar xx.jar 运行才会这么做
补充:至于有的水友说的放在tomcat目录或者其他目录,因为我没碰到,需要你们自己测试
还有的朋友说放在java.library.path库下面,我感觉我的/usr/lib或/usr/lib64应该就是这个,具体是不是我不清楚(另外,查看linux下的java.library.path可新建springboot项目,在Application下新建一行打印输出,并打包在linux下以命令 java -jar xx.jar运行即可显示,帖图如下)
解决办法:
三、需要的文件可在我的博客资源下免费下载
