MariaDB源码编译安装(二)
Raymond运维 发表于 2025/09/21 14:47:50 2025/09/21
【摘要】 MariaDB源码编译安装
2.4.4.6 openEuler 22.03 LTS、Kylin Server V10
进入mariadb包解压的目录:
cd mariadb-11.8.3/
安装cmake包:
yum install -y cmake
执行cmake:
cmake . \
-DCMAKE_INSTALL_PREFIX=/apps/mariadb \
-DMYSQL_DATADIR=/data/mariadb/ \
-DSYSCONFDIR=/etc/ \
-DMYSQL_USER=mysql \
-DWITH_INNOBASE_STORAGE_ENGINE=1 \
-DWITH_ARCHIVE_STORAGE_ENGINE=1 \
-DWITH_BLACKHOLE_STORAGE_ENGINE=1 \
-DWITH_PARTITION_STORAGE_ENGINE=1 \
-DWITHOUT_MROONGA_STORAGE_ENGINE=1 \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_ZLIB=system \
-DWITH_PCRE=system \
-DWITH_BOOST=system \
-DWITH_LIBWRAP=0 \
-DENABLED_LOCAL_INFILE=1 \
-DMYSQL_UNIX_ADDR=/data/mariadb/mariadb.sock \
-DDEFAULT_CHARSET=utf8mb4 \
-DDEFAULT_COLLATION=utf8mb4_general_ci \
-DWITH_SYSTEMD=yes
CMake Error: CMake was unable to find a build program corresponding to "Unix Makefiles".  CMAKE_MAKE_PROGRAM is not set.  You probably need to select a different build tool. # 提示,CMake找不到与“Unix Makefiles”对应的构建程序。未设置CMAKE_MAKE_PROGRAM。您可能需要选择不同的构建工具,需要安装make。
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage # 提示,CMake错误:启用语言后未设置CMake_C_COMPILER,需要安装gcc。
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage # 提示,CMake错误:启用语言后未设置CMake_CXX_COMPILER,,需要安装gcc-c++。
-- Configuring incomplete, errors occurred!
安装gcc和gcc-c++包:
yum install -y make gcc gcc-c++
继续执行cmake:
# 再次执行cmake之前先删除“CMakeCache.txt”文件
rm -f CMakeCache.txt
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
CMake Error at cmake/ssl.cmake:150 (MESSAGE):
  Cannot find appropriate system libraries for SSL.  Use WITH_SSL=bundled to
  enable SSL support # 提示,找不到适当的系统库来支持SSL。使用WITH_SSL=bundled来启用SSL支持
Call Stack (most recent call first):
  CMakeLists.txt:425 (MYSQL_CHECK_SSL)
安装openssl-devel包:
yum install -y openssl-devel
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
CMake Error at /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:233 (message):
  Could NOT find Curses (missing: CURSES_LIBRARY CURSES_INCLUDE_PATH) # 提示,找不到 Curses 库。
  /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:603 (_FPHSA_FAILURE_MESSAGE)
  /usr/share/cmake/Modules/FindCurses.cmake:268 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  cmake/readline.cmake:55 (FIND_PACKAGE)
  cmake/readline.cmake:188 (FIND_CURSES)
  CMakeLists.txt:427 (MYSQL_CHECK_READLINE)
安装ncurses-devel:
yum install -y ncurses-devel
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
CMake Error at cmake/systemd.cmake:77 (MESSAGE):
  Requested WITH_SYSTEMD=yes however no dependencies installed/found
Call Stack (most recent call first): # # 请求的WITH_SYSTEMD=是,但未安装/找到依赖项调用堆栈(最近的调用优先)
  CMakeLists.txt:434 (CHECK_SYSTEMD)
See also "/usr/local/src/mariadb-11.8.3/CMakeFiles/CMakeOutput.log".
See also "/usr/local/src/mariadb-11.8.3/CMakeFiles/CMakeError.log".
安装systemd-devel包:
yum install -y systemd-devel
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 编译完成后会有类似如下的输出
-- The following OPTIONAL packages have not been found:
 * LibXml2
 * Java (required version >= 1.6)
   Required for the CONNECT_JDBC feature
 * JNI
 * Boost (required version >= 1.40.0)
   Required for the OQGraph storage engine
 * CURL
 * BZip2
 * LZ4 (required version >= 1.6)
 * LibLZMA
 * LZO
 * Snappy
 * BISON (required version >= 2.4)
-- Configuring done
-- Generating done
-- Build files have been written to: /usr/local/src/mariadb-11.8.3
执行make:
make -j $(nproc) && make install
总结编译过程:
# 安装依赖包
yum install -y cmake make gcc gcc-c++ openssl-devel ncurses-devel systemd-devel
# 进入mariadb包解压的目录
cd mariadb-11.8.3/
# 执行cmake
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 执行make
2.4.4.7 UOS Server V20
进入mariadb包解压的目录:
cd mariadb-11.8.3/
安装cmake包:
执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
CMake Error at /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:146 (message):
  /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:393 (_FPHSA_FAILURE_MESSAGE)
  /usr/share/cmake/Modules/FindCurses.cmake:258 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
安装ncurses-devel:
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
Call Stack (most recent call first): # 提示,请求的WITH_SYSTEMD=是,但未安装/找到依赖项调用堆栈(最近的调用优先)
安装systemd-devel包:
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 编译完成后会有类似如下的输出
 * LibXml2
 * JNI
 * CURL
 * BZip2
 * LibLZMA
 * LZO
 * Snappy
-- Configuring done
-- Generating done
执行make:
总结编译过程:
# 安装依赖包
yum install -y cmake ncurses-devel systemd-devel
# 进入mariadb包解压的目录
cd mariadb-11.8.3/
# 执行cmake
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 执行make
2.4.4.8 openSUSE 15
进入mariadb包解压的目录:
cd mariadb-11.8.3/
安装cmake包:
zypper install -y cmake
执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
CMake Error at CMakeLists.txt:40 (PROJECT):
  No CMAKE_C_COMPILER could be found.
  Tell CMake where to find the compiler by setting either the environment
  variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
  the compiler, or to the compiler name if it is in the PATH. # 提示,通过设置环境变量 “CC” 或 CMake 缓存条目CMAKE_C_COMPILER到编译器,或者如果编译器名称在 PATH,需要安装gcc。
  No CMAKE_CXX_COMPILER could be found.
  variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
  to the compiler, or to the compiler name if it is in the PATH. # 提示,通过设置环境变量 “CXX” 或 CMake 缓存条目CMAKE_CXX_COMPILER完整路径添加到编译器,或者添加到编译器名称(如果它在 PATH 中),需要安装gcc-c++。
安装gcc和gcc-c++包:
zypper install -y gcc gcc-c++
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装libopenssl-devel包:
zypper install -y libopenssl-devel
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装ncurses-devel:
zypper install -y ncurses-devel
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
CMake Error at cmake/pcre.cmake:99 (MESSAGE):
  system pcre2-8 library is not found or unusable # 提示,系统pcre2-8库找不到或不可用
  CMakeLists.txt:431 (CHECK_PCRE)
安装pcre2-devel包:
zypper install -y pcre2-devel
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
Call Stack (most recent call first): # 请求的WITH_SYSTEMD=是,但未安装/找到依赖项调用堆栈(最近的调用优先)
安装systemd-devel包:
zypper install -y systemd-devel
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 编译完成后会有类似如下的输出
 * LibXml2
 * JNI
 * GSSAPI
 * CURL
 * BZip2
 * LibLZMA
 * LZO
 * Snappy
-- Configuring done (53.3s)
-- Generating done (0.7s)
执行make:
总结编译过程:
# 安装依赖包
zypper install -y cmake gcc gcc-c++ libopenssl-devel ncurses-devel pcre2-devel systemd-devel
# 进入mariadb包解压的目录
cd mariadb-11.8.3/
# 执行cmake
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 执行make
2.4.4.9 Ubuntu Server 20.04/22.04/24.04 LTS、Debian 11/12/13
进入mariadb包解压的目录:
cd mariadb-11.8.3/
安装cmake包:
apt update
apt install -y cmake
执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装g++包:
apt install -y g++
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装libssl-dev包:
apt install -y libssl-dev
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装libncurses5-dev包:
apt install -y libncurses5-dev
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装libpcre2-dev包:
apt install -y libpcre2-dev
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装libsystemd-dev包:
apt install -y libsystemd-dev
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 编译完成后会有类似如下的输出
 * ZLIB
 * LibXml2
 * JNI
 * GSSAPI
 * CURL
 * BZip2
 * LibLZMA
 * LZO
 * Snappy
-- Configuring done (66.3s)
执行make:
总结编译过程:
# 安装依赖包
apt update
apt install -y cmake g++ libssl-dev libncurses5-dev libpcre2-dev libsystemd-dev
# 进入mariadb包解压的目录
cd mariadb-11.8.3/
# 执行cmake
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 执行make
2.4.4.10 Ubuntu Server 18.04 LTS
进入mariadb包解压的目录:
cd mariadb-11.8.3/
安装cmake包:
apt update
执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
CMake Error at CMakeLists.txt:17 (CMAKE_MINIMUM_REQUIRED):
  CMake 3.12.0 or higher is required.  You are running version 3.10.2 # 需要CMake 3.12.0或更高版本。您运行的是3.10.2版本
安装cmake:
去“https://cmake.org/download/”网址下载cmake二进制包,如图12所示。
图12 下载cmake二进制包
# 卸载cmake
apt remove -y cmake
cd ..
# github下载地址:
wget https://github.com/Kitware/CMake/releases/download/v3.31.7/cmake-3.31.7-linux-x86_64.tar.gz
# 国内下载地址:
wget https://cmake.org/files/v3.31/cmake-3.31.7-linux-x86_64.tar.gz
tar xf cmake-3.31.7-linux-x86_64.tar.gz -C /usr/local/
ln -s /usr/local/cmake-3.31.7-linux-x86_64/bin/cmake /usr/bin/
root@ubuntu1804:/usr/local/src# cmake --version
cmake version 3.31.7
CMake suite maintained and supported by Kitware (kitware.com/cmake).
再次进入mariadb包解压的目录:
cd mariadb-10.11.14/
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装g++包:
apt install -y g++
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装libssl-dev包:
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装libncurses5-dev包:
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装libpcre2-dev包:
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
安装libsystemd-dev包:
继续执行cmake:
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 编译完成后会有类似如下的输出
 * ZLIB
 * LibXml2
 * JNI
 * GSSAPI
 * CURL
 * BZip2
 * LibLZMA
 * LZO
 * Snappy
执行make:
总结编译过程:
# 安装依赖包
apt update
apt install -y g++ libssl-dev libncurses5-dev libpcre2-dev libsystemd-dev
# 安装cmake
# 进入mariadb包解压的目录
cd mariadb-11.8.3/
# 执行cmake
cmake . \
-DWITH_DEBUG=0 \
-DWITH_READLINE=1 \
-DWITH_SSL=system \
-DWITH_LIBWRAP=0 \
-DWITH_SYSTEMD=yes
# 执行make
2.4.5 准备环境变量
echo 'PATH=/apps/mariadb/bin:$PATH' > /etc/profile.d/mariadb.sh
. /etc/profile.d/mariadb.sh
chown -R mysql:mysql /apps/mariadb/
2.4.6 生成数据库文件
# 这里必须先要进入/apps/mariadb/目录,在执行下面命令
cd /apps/mariadb/
./scripts/mariadb-install-db --datadir=/data/mariadb/ --user=mysql
2.4.7 准备配置文件
cat > /etc/my.cnf <<EOF
[mariadb]
basedir=/apps/mariadb/
port=3306
socket=/data/mariadb/mariadb.sock
pid-file=/data/mariadb/mariadb.pid
log-error=/data/mariadb/mariadb.log
[client]
port=3306
EOF
2.4.8 准备启动脚本并启动服务
# Rocky、Almalinux、CentOS、openEuler、AnolisOS、OpenCloudOS、 Kylin Server、UOS Server、openSUSE
cp /apps/mariadb/support-files/systemd/mariadb.service /usr/lib/systemd/system/
# Ubuntu和Debian
cp /apps/mariadb/support-files/systemd/mariadb.service /lib/systemd/system/
systemctl daemon-reload && systemctl enable --now mariadb
2.4.9 安全初始化
[root@rocky10 mariadb]# mariadb
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 4
Server version: 11.8.3-MariaDB Source distribution
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> status
mariadb from 11.8.3-MariaDB, client 15.2 for Linux (x86_64) using readline 5.1
Connection id:		3
Current database:
Current user:		root@localhost
SSL:			Cipher in use is TLS_AES_256_GCM_SHA384, cert is OK
Current pager:		stdout
Using outfile:		''
Using delimiter:	;
Server:			MariaDB
Protocol version:	10
Connection:		Localhost via UNIX socket
Server characterset:	utf8mb4
Db     characterset:	utf8mb4
Client characterset:	utf8mb4
Conn.  characterset:	utf8mb4
UNIX socket:		/data/mariadb/mariadb.sock
Uptime:			9 sec
Threads: 1  Questions: 4  Slow queries: 0  Opens: 17  Open tables: 10  Queries per second avg: 0.444
MariaDB [(none)]> show databases;
| Database           |
| information_schema |
| mysql              |
| performance_schema |
| sys                |
| test               | # 有test数据库
5 rows in set (0.001 sec)
MariaDB [(none)]> select user,host from mysql.user;
| User        | Host      |
| PUBLIC      |           |
|             | localhost | # 有匿名用户
| mariadb.sys | localhost |
| mysql       | localhost |
| root        | localhost |
|             | rocky10   | # 有远程登陆用户
6 rows in set (0.002 sec)
MariaDB [(none)]> exit
Bye
# 有test数据库、匿名用户和远程登录用户,需要安全初始化
[root@rocky10 mariadb]# mariadb-secure-installation
NOTE: RUNNING ALL PARTS OF THIS SCRIPT IS RECOMMENDED FOR ALL MariaDB
      SERVERS IN PRODUCTION USE!  PLEASE READ EACH STEP CAREFULLY!
In order to log into MariaDB to secure it, we'll need the current
password for the root user. If you've just installed MariaDB, and
haven't set the root password yet, you should just press enter here.
Enter current password for root (enter for none):  # 输入 root 的当前密码(不输入),直接敲回车
OK, successfully used password, moving on...
Setting the root password or using the unix_socket ensures that nobody
can log into the MariaDB root user without the proper authorisation.
You already have your root account protected, so you can safely answer 'n'.
Switch to unix_socket authentication [Y/n] y # 输入y,切换到 unix_socket 身份验证
Enabled successfully!
Reloading privilege tables..
 ... Success!
Change the root password? [Y/n] n # 输入n,不设置root密码
 ... skipping.
By default, a MariaDB installation has an anonymous user, allowing anyone
to log into MariaDB without having to have a user account created for
them.  This is intended only for testing, and to make the installation
go a bit smoother.  You should remove them before moving into a
production environment.
Remove anonymous users? [Y/n] y # 输入y,移除匿名账户
 ... Success!
Normally, root should only be allowed to connect from 'localhost'.  This
ensures that someone cannot guess at the root password from the network.
Disallow root login remotely? [Y/n] y # 输入y,禁止 root 远程登录
 ... Success!
By default, MariaDB comes with a database named 'test' that anyone can
access.  This is also intended only for testing, and should be removed
before moving into a production environment.
Remove test database and access to it? [Y/n] y # 输入y,移除测试库
 - Dropping test database...
 ... Success!
 - Removing privileges on test database...
 ... Success!
Reloading the privilege tables will ensure that all changes made so far
will take effect immediately.
Reload privilege tables now? [Y/n] y y # 输入y,重新加载权限表
 ... Success!
Cleaning up...
All done!  If you've completed all of the above steps, your MariaDB
installation should now be secure.
Thanks for using MariaDB!
2.4.10 登录测试
Your MariaDB connection id is 13
Connection id:		3
Current database:
Using outfile:		''
Using delimiter:	;
Server:			MariaDB
Uptime:			9 sec
| Database           |
| mysql              |
| sys                |
4 rows in set (0.001 sec)
# 可以看到已经没有test数据库了
| User        | Host      |
| PUBLIC      |           |
| mysql       | localhost |
| root        | localhost |
# 可以看到已经没有匿名用户和远程登录用户了
Bye
2.4.11 一键安装MariaDB源码编译的脚本
Shell脚本源码地址:
Gitee:https://gitee.com/raymond9/shell
Github:https://github.com/raymond999999/shell
可以去上面的Gitee或Github代码仓库拉取脚本。
[root@rocky10 ~]# cat install_mariadb_source_v2.sh
#!/bin/bash
#Author:        Raymond
#QQ:            88563128
#MP:            Raymond运维
#Date:          2025-09-15
#FileName:      install_mariadb_source_v3.sh
#URL:           https://wx.zsxq.com/group/15555885545422
#Description:   The mariadb source script install supports
#               “Rocky Linux 8, 9 and 10, Almalinux 8, 9 and 10, CentOS 7,
#               CentOS Stream 8, 9 and 10, openEuler 22.03 and 24.03 LTS,
#               AnolisOS 8 and 23, OpencloudOS 8 and 9, Kylin Server v10 and v11,
#               UOS Server v20, Ubuntu Server 18.04, 20.04, 22.04 and 24.04 LTS,
#               Debian 11 , 12 and 13, openSUSE 15“ operating systems.
#Copyright (C): 2025 All rights reserved
COLOR="echo -e \\033[01;31m"
END='\033[0m'
os(){
    . /etc/os-release
    MAIN_NAME=`sed -rn '/^NAME=/s@.*="([[:alpha:]]+).*"$@\1@p' /etc/os-release`
    if [ ${MAIN_NAME} == "Kylin" ];then
        MAIN_VERSION_ID=`sed -rn '/^VERSION_ID=/s@.*="([[:alpha:]]+)(.*)"$@\2@p' /etc/os-release`
    else
        MAIN_VERSION_ID=`sed -rn '/^VERSION_ID=/s@.*="?([0-9]+)\.?.*"?@\1@p' /etc/os-release`
    fi
    if [ ${MAIN_NAME} == "Ubuntu" -o ${MAIN_NAME} == "Debian" ];then
        FULL_NAME="${PRETTY_NAME}"
    elif [ ${MAIN_NAME} == "UOS" ];then
        FULL_NAME="${NAME}"
    else
        FULL_NAME="${NAME} ${VERSION_ID}"
    fi
os
SRC_DIR=/usr/local/src
INSTALL_DIR=/apps/mariadb
DATA_DIR=/data/mariadb
# mariadb 11.8.3包下载地址:"https://mirrors.tuna.tsinghua.edu.cn/mariadb///mariadb-11.8.3/source/mariadb-11.8.3.tar.gz"
# fmt 11.1.4包下载地址:"https://gh-proxy.com/https://github.com/fmtlib/fmt/releases/download/11.1.4/fmt-11.1.4.zip"
# mariadb 10.11.14包下载地址:"https://mirrors.tuna.tsinghua.edu.cn/mariadb/mariadb-10.11.14/source/mariadb-10.11.14.tar.gz"
# fmt 11.0.2包下载地址:"https://gh-proxy.com/https://github.com/fmtlib/fmt/releases/download/11.0.2/fmt-11.0.2.zip"
if [ ${MAIN_NAME} == "CentOS" -a ${MAIN_VERSION_ID} == 7 ];then
    MARIADB_VERSION=10.11.14
    FMT_VERSION=11.0.2
else
    MARIADB_VERSION=11.8.3
    FMT_VERSION=11.1.4
fi
MARIADB_URL="https://mirrors.tuna.tsinghua.edu.cn/mariadb/mariadb-${MARIADB_VERSION}/source/"
MARIADB_FILE="mariadb-${MARIADB_VERSION}.tar.gz"
FMT_URL="https://gh-proxy.com/https://github.com/fmtlib/fmt/releases/download/${FMT_VERSION}/"
FMT_FILE="fmt-${FMT_VERSION}.zip"
CMAKE_URL='https://cmake.org/files/v3.31/'
CMAKE_FILE='cmake-3.31.7-linux-x86_64.tar.gz'
check_mysql_file(){
    if [ ${MAIN_NAME} == "Rocky" -o ${MAIN_NAME} == "AlmaLinux" -o ${MAIN_NAME} == "CentOS" -o ${MAIN_NAME} == "Anolis" -o ${MAIN_NAME} == "OpenCloudOS" -o ${MAIN_NAME} == "Kylin" ];then
        rpm -q wget &> /dev/null || { ${COLOR}"安装wget工具,请稍等......"${END};yum -y install wget &> /dev/null; }
    fi
    if [ ! -e ${MARIADB_FILE} ];then
        ${COLOR}"缺少${MARIADB_FILE}文件!"${END}
        ${COLOR}'开始下载MariaDB源码包......'${END}
        wget ${MARIADB_URL}${MARIADB_FILE} || { ${COLOR}"MariaDB源码包下载失败!"${END}; exit; }
    else
        ${COLOR}"${MARIADB_FILE}文件已准备好!"${END}
    fi
check_fmt_file(){
    if [ ! -e ${FMT_FILE} ];then
        ${COLOR}"缺少${FMT_FILE}文件!"${END}
        ${COLOR}'开始下载fmt包......'${END}
        wget ${FMT_URL}${FMT_FILE} || { ${COLOR}"fmt包下载失败!"${END}; exit; }
    else
        ${COLOR}"${FMT_FILE}相关文件已准备好!"${END}
    fi
check_cmake_file(){
    if [ ! -e ${CMAKE_FILE} ];then
        ${COLOR}"缺少${CMAKE_FILE}文件!"${END}
        ${COLOR}'开始下载cmake二进制包......'${END}
        wget ${CMAKE_URL}${CMAKE_FILE} || { ${COLOR}"cmake二进制包下载失败!"${END}; exit; }
    else
        ${COLOR}"${CMAKE_FILE}相关文件已准备好!"${END}
    fi
check_file(){
    cd  ${SRC_DIR}
    check_mysql_file
    check_fmt_file
        check_cmake_file
    fi
    if [ ${MAIN_NAME} == "Ubuntu" -a ${MAIN_VERSION_ID} == 18 ];then
        check_cmake_file
    fi
install_cmake(){
    ${COLOR}'开始安装cmake,请稍等......'${END}
    tar xf ${CMAKE_FILE} -C /usr/local/
    CMAKE_DIR=`echo ${CMAKE_FILE}| sed -nr 's/^(.*[0-9]).*/\1/p'`
    ln -s /usr/local/${CMAKE_DIR}/bin/cmake /usr/bin/
install_mariadb(){
    [ -d ${INSTALL_DIR} ] && { ${COLOR}"MariaDB数据库已存在,安装失败!"${END};exit; }
    ${COLOR}"开始安装MariaDB数据库......"${END}
    if [ ${MAIN_NAME} == "openSUSE" ];then
        id mysql &> /dev/null || { groupadd -r mysql && useradd -s /sbin/nologin -d ${DATA_DIR} -r -g mysql mysql; ${COLOR}"成功创建mysql用户!"${END}; }
    else
        id mysql &> /dev/null || { useradd -r -s /sbin/nologin -d ${DATA_DIR} mysql ; ${COLOR}"成功创建mysql用户!"${END}; }
    fi
    [ -d ${DATA_DIR} ] || mkdir -p ${DATA_DIR} &> /dev/null
    chown -R mysql:mysql ${DATA_DIR}
    ${COLOR}'开始安装MariaDB依赖包,请稍等......'${END}
    if [ ${MAIN_NAME} == "Rocky" ];then
        if [ ${MAIN_VERSION_ID} == 8 ];then
            yum install -y cmake gcc gcc-c++ openssl-devel ncurses-devel systemd-devel &> /dev/null
        else
            yum install -y cmake gcc gcc-c++ openssl-devel ncurses-devel pcre2-devel systemd-devel &> /dev/null
        fi
    fi
    if [ ${MAIN_NAME} == "AlmaLinux" ];then
        else
        fi
    fi
    if [ ${MAIN_NAME} == "CentOS" ];then
        if [ ${MAIN_VERSION_ID} == 7 ];then
            yum install -y gcc gcc-c++ openssl-devel ncurses-devel pcre2-devel systemd-devel &> /dev/null
        elif [ ${MAIN_VERSION_ID} == 8 ];then
        else
            yum install -y cmake openssl-devel ncurses-devel pcre2-devel systemd-devel &> /dev/null
        fi
    fi
    if [ ${MAIN_NAME} == "openEuler" ];then
        if [ ${MAIN_VERSION_ID} == 22 ];then
            yum install -y cmake make gcc gcc-c++ openssl-devel ncurses-devel systemd-devel &> /dev/null
        else
            yum install -y cmake make gcc gcc-c++ openssl-devel ncurses-devel pcre2-devel systemd-devel &> /dev/null
        fi
    fi
    if [ ${MAIN_NAME} == "Anolis" ];then
        else
        fi
    fi
    if [ ${MAIN_NAME} == 'OpenCloudOS' ];then
        else
        fi
    fi
        if [ ${MAIN_VERSION_ID} == 10 ];then
        else
        fi
    fi
        if [ ${MAIN_VERSION_ID} == 20 ];then
            yum install -y cmake ncurses-devel systemd-devel &> /dev/null
        fi
    fi
        if [ ${MAIN_VERSION_ID} == 15 ];then
            zypper install -y cmake gcc gcc-c++ libopenssl-devel ncurses-devel pcre2-devel systemd-devel &> /dev/null
        fi
    fi
    if [ ${MAIN_NAME} == "Ubuntu" ];then
        if [ ${MAIN_VERSION_ID} == 18 ];then
            apt update && apt install -y g++ libssl-dev libncurses5-dev libpcre2-dev libsystemd-dev
        else
            apt update && apt install -y cmake g++ libssl-dev libncurses5-dev libpcre2-dev libsystemd-dev
        fi
    fi
    if [ ${MAIN_NAME} == 'Debian' ];then
    fi
        install_cmake
    fi
    if [ ${MAIN_NAME} == 'Ubuntu' -a ${MAIN_VERSION_ID} == 18 ];then
        install_cmake
    fi
    ${COLOR}'开始编译安装MariaDB,请稍等......'${END}
    cd  ${SRC_DIR}
        if [ ${MAIN_VERSION_ID} == 22 -o ${MAIN_VERSION_ID} == 24 ];then
            yum install -y tar &> /dev/null
        fi
    fi
        if [ ${MAIN_VERSION_ID} == 23 ];then
        fi
    fi
    if [ ${MAIN_NAME} == "OpenCloudOS" ];then
        if [ ${MAIN_VERSION_ID} == 9 ];then
        fi
    fi
    tar xf ${MARIADB_FILE}
    MARIADB_DIR=`echo ${MARIADB_FILE}| sed -nr 's/^(.*[0-9]).*/\1/p'`
    mkdir -p /usr/local/src/${MARIADB_DIR}/extra/libfmt/src/
    mv ${FMT_FILE} /usr/local/src/${MARIADB_DIR}/extra/libfmt/src/
    cd ${MARIADB_DIR}
    cmake . \
    -DCMAKE_INSTALL_PREFIX=${INSTALL_DIR} \
    -DMYSQL_DATADIR=${DATA_DIR}/ \
    -DWITH_DEBUG=0 \
    -DWITH_READLINE=1 \
    -DWITH_SSL=system \
    -DWITH_LIBWRAP=0 \
    -DMYSQL_UNIX_ADDR=${DATA_DIR}/mariadb.sock \
    -DWITH_SYSTEMD=yes
    [ $? -eq 0 ] && ${COLOR}"MariaDB编译安装成功"${END} ||  { ${COLOR}"MariaDB编译安装失败,退出!"${END};exit; }
	echo 'PATH='${INSTALL_DIR}'/bin:$PATH' > /etc/profile.d/mariadb.sh
    chown -R mysql:mysql ${INSTALL_DIR}
    cd ${INSTALL_DIR}
    ./scripts/mysql_install_db --datadir=${DATA_DIR} --user=mysql
    cat > /etc/my.cnf <<-EOF
[mariadb]
basedir=${INSTALL_DIR}/
datadir=${DATA_DIR}
port=3306
socket=${DATA_DIR}/mariadb.sock
pid-file=${DATA_DIR}/mariadb.pid
log-error=${DATA_DIR}/mariadb.log
[client]
port=3306
EOF
        cp ${INSTALL_DIR}/support-files/systemd/mariadb.service /lib/systemd/system/
    else
        cp ${INSTALL_DIR}/support-files/systemd/mariadb.service /usr/lib/systemd/system/
    fi
    systemctl daemon-reload && systemctl enable --now mariadb &> /dev/null
    [ $? -ne 0 ] && { ${COLOR}"数据库启动失败,退出!"${END};exit; }
mariadb_secure(){
    ${INSTALL_DIR}/bin/mariadb-secure-installation <<EOF
y
n
y
y
y
y
EOF
    ${COLOR}"${FULL_NAME}操作系统,MariaDB数据库安装完成!"${END}
main(){
    check_file
    install_mariadb
    mariadb_secure
    if [ ${MAIN_VERSION_ID} == 8 -o ${MAIN_VERSION_ID} == 9 -o ${MAIN_VERSION_ID} == 10 ];then
        main
    fi
elif [ ${MAIN_NAME} == "AlmaLinux" ];then
        main
    fi
elif [ ${MAIN_NAME} == "CentOS" ];then
    if [ ${MAIN_VERSION_ID} == 7 -o ${MAIN_VERSION_ID} == 8 -o ${MAIN_VERSION_ID} == 9 -o ${MAIN_VERSION_ID} == 10 ];then
        main
    fi
elif [ ${MAIN_NAME} == "openEuler" ];then
        main
    fi
elif [ ${MAIN_NAME} == "Anolis" ];then
    if [ ${MAIN_VERSION_ID} == 8 -o ${MAIN_VERSION_ID} == 23 ];then
        main
    fi
elif [ ${MAIN_NAME} == 'OpenCloudOS' ];then
    if [ ${MAIN_VERSION_ID} == 8 -o ${MAIN_VERSION_ID} == 9 ];then
        main
    fi
elif [ ${MAIN_NAME} == "Kylin" ];then
    if [ ${MAIN_VERSION_ID} == 10 -o ${MAIN_VERSION_ID} == 11 ];then
        main
    fi
        main
    fi
elif [ ${MAIN_NAME} == "openSUSE" ];then
        main
    fi
elif [ ${MAIN_NAME} == "Ubuntu" ];then
    if [ ${MAIN_VERSION_ID} == 18 -o ${MAIN_VERSION_ID} == 20 -o ${MAIN_VERSION_ID} == 22 -o ${MAIN_VERSION_ID} == 24 ];then
        main
    fi
elif [ ${MAIN_NAME} == 'Debian' ];then
    if [ ${MAIN_VERSION_ID} == 11 -o ${MAIN_VERSION_ID} == 12 -o ${MAIN_VERSION_ID} == 13 ];then
        main
    fi
else
    ${COLOR}"此脚本不支持${FULL_NAME}操作系统!"${END}
fi
