在线教育项目之专业信息功能
人工智能-张晨光 发表于 2025/09/19 11:26:52 2025/09/19
【摘要】 智慧教育管理系统介绍和部署适用人群1. 在校学生,小白用户,想学习知识的2. 有点基础,想要通过项目实操提高自己的开发能力的3. 找不到完整项目跟着练的4. 网上项目比较大,会提供资料,太大了,吃不了它可以学习到的技能1. 学会常用技术栈的使用2. 独立开发项目3. 学会前端的开发流程4. 学会后端的开发流程5. 学会数据库的设计6. 学会前后端接口调用方式7. 学会多模块之间的关联
新增功能
Entity
TypeScript
package com.example.entity;
import lombok.Data;
@Data
public class Speciality {
private Integer id;
private String name;
private Integer collegeId;
前端
Manager.vue
修改Manager.vue,添加专业信息导航
XML
<el-menu-item index="/speciality">
<el-icon><School /></el-icon>
<span>专业信息</span>
</el-menu-item>
路由
添加speciality路由
TypeScript
{ path: 'speciality', component: () => import('@/views/manager/Speciality.vue')},
Speciality.vue
将资料Speciality.vue添加到views/manager中
[Speciality.vue]
后端
SpecialityController
Java
package com.example.controller;
* 专业信息前端请求的接口入口
@RestController
@RequestMapping("/speciality")
public class SpecialityController {
@Resource
private SpecialityService specialityService;
* 新增
@PostMapping("/add")
public Result add(@RequestBody Speciality speciality) {
specialityService.add(speciality);
return Result.success();
SpecialityService
TypeScript
package com.example.service;
import com.example.entity.Speciality;
public interface SpecialityService {
void add(Speciality speciality);
SpecialityServiceImpl
Java
package com.example.service.impl;
@Service
public class SpecialityServiceImpl implements SpecialityService {
@Resource
private SpecialityMapper specialityMapper;
@Override
public void add(Speciality speciality) {
specialityMapper.insert(speciality);
SpecialityMapper
Java
package com.example.mapper;
public interface SpecialityMapper {
@Insert("insert into speciality(name, college_id) values(#{name}, #{collegeId})")
void insert(Speciality speciality);
分页查询和条件查询
Speciality
添加院校名称字段,在页面显示
TypeScript
// 学院名称
private String collegeName;
TypeScript
* 分页查询
@GetMapping("/selectPage")
public Result selectPage(String name,
@RequestParam(defaultValue = "1") Integer pageNum,
@RequestParam(defaultValue = "5") Integer pageSize) {
PageInfo<Speciality> pageInfo = specialityService.selectPage(name, pageNum, pageSize);
return Result.success(pageInfo);
TypeScript
@Override
public PageInfo<Speciality> selectPage(String name, Integer pageNum, Integer pageSize) {
List<Speciality> list;
PageHelper.startPage(pageNum, pageSize);
if (ObjectUtil.isNotEmpty(name)) {
list = specialityMapper.selectByName(name);
list = specialityMapper.selectAll();
return PageInfo.of(list);
SpecialityMapper
Java
@Select("SELECT s.*,c.`name` collegeName FROM speciality s " +
"LEFT JOIN college c ON s.college_id = c.id " +
"WHERE s.`name` LIKE CONCAT('%',#{name},'%')")
List<Speciality> selectByName(String name);
"LEFT JOIN college c ON s.college_id = c.id")
List<Speciality> selectAll();
查询所有功能
完善新增或编辑教师时的专业信息显示
TypeScript
* 查询所有
@GetMapping("/selectAll")
public Result selectAll() {
List<Speciality> list = specialityService.selectAll();
return Result.success(list);
TypeScript
@Override
public List<Speciality> selectAll() {
return specialityMapper.selectAll();
更新功能
SQL
* 更新
@PutMapping("/update")
public Result update(@RequestBody Speciality speciality) {
specialityService.updateById(speciality);
TypeScript
@Override
public void updateById(Speciality speciality) {
specialityMapper.updateById(speciality);
SpecialityMapper
TypeScript
@Update("update speciality set name = #{name}, college_id = #{collegeId} where id = #{id}")
void updateById(Speciality speciality);
删除功能
SQL
* 根据id删除
@DeleteMapping("/deleteById/{id}")
public Result deleteById(@PathVariable Integer id) {
specialityService.deleteById(id);
TypeScript
@Override
public void deleteById(Integer id) {
specialityMapper.deleteById(id);
SpecialityMapper
TypeScript
@Delete("delete from speciality where id = #{id}")
void deleteById(Integer id);
