flyway报错Caused by: java.lang.NoSuchMethodError: org.flywaydb.cor
刘大猫 发表于 2025/09/08 21:16:19 2025/09/08
【摘要】 flyway报错Caused by: java.lang.NoSuchMethodError: org.flywaydb.core.api.configuration.FluentConfigurat
详情错误日志
  .   ____          _            __ _ _
 /\\ / ___'_ __ _ _(_)_ __  __ _ \ \ \ \
( ( )\___ | '_ | '_| | '_ \/ _` | \ \ \ \
 \\/  ___)| |_)| | | | | || (_| |  ) ) ) )
  '  |____| .__|_| |_|_| |_\__, | / / / /
 =========|_|==============|___/=/_/_/_/
 :: Spring Boot ::                (v2.6.3)
2022-11-01 16:38:17.063  INFO 18260 --- [           main] com.flyway.FlaywayApplication            : Starting FlaywayApplication using Java 1.8.0_71 on HYT211145187-01 with PID 18260 (G:\WorkSpace\springboot-test\flyway-test\target\classes started by 211145187 in G:\WorkSpace\springboot-test)
2022-11-01 16:38:17.064  INFO 18260 --- [           main] com.flyway.FlaywayApplication            : No active profile set, falling back to default profiles: default
2022-11-01 16:38:18.093  INFO 18260 --- [           main] o.s.b.w.embedded.tomcat.TomcatWebServer  : Tomcat initialized with port(s): 8015 (http)
2022-11-01 16:38:18.126  INFO 18260 --- [           main] o.apache.catalina.core.StandardService   : Starting service [Tomcat]
2022-11-01 16:38:18.126  INFO 18260 --- [           main] org.apache.catalina.core.StandardEngine  : Starting Servlet engine: [Apache Tomcat/9.0.56]
2022-11-01 16:38:18.215  INFO 18260 --- [           main] o.a.c.c.C.[Tomcat].[localhost].[/]       : Initializing Spring embedded WebApplicationContext
2022-11-01 16:38:18.215  INFO 18260 --- [           main] w.s.c.ServletWebServerApplicationContext : Root WebApplicationContext: initialization completed in 1101 ms
2022-11-01 16:38:18.597  WARN 18260 --- [           main] ConfigServletWebServerApplicationContext : Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'flyway' defined in class path resource [org/springframework/boot/autoconfigure/flyway/FlywayAutoConfiguration$FlywayConfiguration.class]: Bean instantiation via factory method failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.flywaydb.core.Flyway]: Factory method 'flyway' threw exception; nested exception is java.lang.BootstrapMethodError: java.lang.NoSuchMethodError: org.flywaydb.core.api.configuration.FluentConfiguration.ignoreMissingMigrations(Z)Lorg/flywaydb/core/api/configuration/FluentConfiguration;
2022-11-01 16:38:18.602  INFO 18260 --- [           main] o.apache.catalina.core.StandardService   : Stopping service [Tomcat]
2022-11-01 16:38:18.609  INFO 18260 --- [           main] ConditionEvaluationReportLoggingListener :
Error starting ApplicationContext. To display the conditions report re-run your application with 'debug' enabled.
2022-11-01 16:38:18.634 ERROR 18260 --- [           main] o.s.boot.SpringApplication               : Application run failed
	at org.springframework.beans.factory.support.ConstructorResolver.instantiate(ConstructorResolver.java:658) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:638) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1352) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1195) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:582) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:542) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:335) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:234) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:333) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:208) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:322) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:953) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:918) ~[spring-context-5.3.15.jar:5.3.15]
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:583) ~[spring-context-5.3.15.jar:5.3.15]
	at org.springframework.boot.web.servlet.context.ServletWebServerApplicationContext.refresh(ServletWebServerApplicationContext.java:145) ~[spring-boot-2.6.3.jar:2.6.3]
	at org.springframework.boot.SpringApplication.refresh(SpringApplication.java:732) [spring-boot-2.6.3.jar:2.6.3]
	at org.springframework.boot.SpringApplication.refreshContext(SpringApplication.java:414) [spring-boot-2.6.3.jar:2.6.3]
	at org.springframework.boot.SpringApplication.run(SpringApplication.java:302) [spring-boot-2.6.3.jar:2.6.3]
	at org.springframework.boot.SpringApplication.run(SpringApplication.java:1303) [spring-boot-2.6.3.jar:2.6.3]
	at org.springframework.boot.SpringApplication.run(SpringApplication.java:1292) [spring-boot-2.6.3.jar:2.6.3]
	at com.flyway.FlaywayApplication.main(FlaywayApplication.java:14) [classes/:na]
Caused by: org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.flywaydb.core.Flyway]: Factory method 'flyway' threw exception; nested exception is java.lang.BootstrapMethodError: java.lang.NoSuchMethodError: org.flywaydb.core.api.configuration.FluentConfiguration.ignoreMissingMigrations(Z)Lorg/flywaydb/core/api/configuration/FluentConfiguration;
	at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:185) ~[spring-beans-5.3.15.jar:5.3.15]
	at org.springframework.beans.factory.support.ConstructorResolver.instantiate(ConstructorResolver.java:653) ~[spring-beans-5.3.15.jar:5.3.15]
	... 21 common frames omitted
Caused by: java.lang.BootstrapMethodError: java.lang.NoSuchMethodError: org.flywaydb.core.api.configuration.FluentConfiguration.ignoreMissingMigrations(Z)Lorg/flywaydb/core/api/configuration/FluentConfiguration;
	at org.springframework.boot.autoconfigure.flyway.FlywayAutoConfiguration$FlywayConfiguration.configureIgnoredMigrations(FlywayAutoConfiguration.java:273) ~[spring-boot-autoconfigure-2.6.3.jar:2.6.3]
	at org.springframework.boot.autoconfigure.flyway.FlywayAutoConfiguration$FlywayConfiguration.configureProperties(FlywayAutoConfiguration.java:213) ~[spring-boot-autoconfigure-2.6.3.jar:2.6.3]
	at org.springframework.boot.autoconfigure.flyway.FlywayAutoConfiguration$FlywayConfiguration.flyway(FlywayAutoConfiguration.java:119) ~[spring-boot-autoconfigure-2.6.3.jar:2.6.3]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_71]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_71]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_71]
	at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_71]
	at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:154) ~[spring-beans-5.3.15.jar:5.3.15]
	... 22 common frames omitted
Caused by: java.lang.NoSuchMethodError: org.flywaydb.core.api.configuration.FluentConfiguration.ignoreMissingMigrations(Z)Lorg/flywaydb/core/api/configuration/FluentConfiguration;
	at java.lang.invoke.MethodHandleNatives.resolve(Native Method) ~[na:1.8.0_71]
	at java.lang.invoke.MemberName$Factory.resolve(MemberName.java:962) ~[na:1.8.0_71]
	at java.lang.invoke.MemberName$Factory.resolveOrFail(MemberName.java:987) ~[na:1.8.0_71]
	at java.lang.invoke.MethodHandles$Lookup.resolveOrFail(MethodHandles.java:1390) ~[na:1.8.0_71]
	at java.lang.invoke.MethodHandles$Lookup.linkMethodHandleConstant(MethodHandles.java:1746) ~[na:1.8.0_71]
	at java.lang.invoke.MethodHandleNatives.linkMethodHandleConstant(MethodHandleNatives.java:477) ~[na:1.8.0_71]
	... 30 common frames omitted
Process finished with exit code 1
错误原因:之前测试flyway-core的版本设置6.5.7就可以正常启动,当使用高版本号比如设置9.6.0时就报如上的错误,感觉就是版本设置高了导致的问题,具体为啥目前不清楚,只要把flyway版本设置成5.2.1或者6.5.7版本以及之间的版本那都是可以运行的。
详情请看我的博客:↓
springboot使用flyway,使用介绍、个人总结及报错场景如何修改
