ABoVE:2000-2017 年阿拉斯加和加拿大 MODIS MAIAC 角度校正反射率
此星光明 发表于 2025/07/14 21:27:39 2025/07/14
【摘要】 ​ ABoVE: Angular-corrected MODIS MAIAC Reflectance across Alaska and Canada, 2000-2017简介该数据集提供了 2000 年至 2017 年阿拉斯加和加拿大西部 ABoVE 区域 MODIS 多角度大气校正算法 (MAIAC) 表面反射率的角度校正。使用机器学习方法随机森林 (RF),将原始 MAIAC 反射率数...
简介
该数据集提供了 2000 年至 2017 年阿拉斯加和加拿大西部 ABoVE 区域 MODIS 多角度大气校正算法 (MAIAC) 表面反射率的角度校正。使用机器学习方法随机森林 (RF),将原始 MAIAC 反射率数据校正为一致的视角和照明角度(0 度视角天顶角和 45 度太阳天顶角),以减少由于角度效应造成的伪影和变化。保留了原始 MAIAC 数据的亚日时间分辨率和 1 公里空间分辨率,包括 7 个陆地波段(波段 1-7)和 5 个海洋波段(波段 8-12)。由此产生的表面反射率数据适用于对表面现象的模式、过程和动态进行长期研究。数据涵盖 11 个不同的 Terra 和 Aqua 卫星 MODIS MAIAC 图块。
摘要
Bits Definition
0–2 Cloud Mask
000 = Undefined; 001 = Clear; 010 = Possibly Cloudy (detected by AOT filter);
011 = Cloudy (detected by cloud mask algorithm); 101 = Cloud Shadow;
110 = Hot spot of fire; 111 = Water Sediments
3–4 Land Water Snow/Ice Mask
00 = Land; 01 = Water; 10 = Snow; 11 = Ice
5–7 Adjacency Mask
000 = Normal condition; 001 = Adjacent to cloud;
010 = Surrounded by more than 8 cloudy pixels; 011 = Single cloudy pixel;
100 = Adjacent to snow; 101 = Snow was previously detected on this pixel
8 Aerosol Optical Thickness (AOT) Level
0 = AOT is low (<=0.6); 1 = AOT is high (> 0.6) or undefined
9 Algorithm Initialize Status
0 = Initialized; 1 = Not initialized
10 BRF Retrieved Over Snow (use AOT=0.05)
0 = no; 1 = yes
11 Altitude >3.5km (BRF is retrieved with AOT=0.01)
0 = no; 1 = yes
代码
!pip install leafmap
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="ABoVE_MODIS_MAIAC_Reflectance_1858",
    cloud_hosted=True,
    bounding_box=(-180.0, 44.12, 180.0, 80.81),
    temporal=("2000-02-24", "2017-12-31"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
