《仿盒马》app开发技术分享-- 新人专享券(2)
yd_215151764 发表于 2025/06/30 09:56:25 2025/06/30
【摘要】 ​技术栈Appgallery connect开发准备上一篇文章中我们实现了项目端云一体化的升级,我们的数据后期就要从云侧的数据库去获取了,现在我们从头开始对项目进行端云一体化的改造。我们在首页已经把新人专享券抽离为公共组件现在我们继续进行功能开发,把这个组建的本地数据展示修改为端侧获取。功能分析我们把之前实现的首页功能拿出改造一下。​我们在首页实现了新用户领券中心,数据结构就是 模块的标题、...
技术栈
Appgallery connect
开发准备
功能分析
我们把之前实现的首页功能拿出改造一下。​我们在首页实现了新用户领券中心,数据结构就是 模块的标题、说明、优惠券列表,列表包含优惠券的金额、类型,同时我们还要给券添加一些其他参数,比如领取时间,领取用户等,这时候就又延伸出一个功能,当我们用户没有登录的时候,我们点击立即领取,是需要跳转到用户登录页面的。
因为云数据库不支持外键,所以我们通过多插入id字段来进行数据查询。
代码实现
首先我们进行表的创建。
home_new_people_coupon 这是首页活动模块的表
  "objectTypeName": "home_new_people_coupon",
  "fields": [
    {"fieldName": "activity_id", "fieldType": "Integer", "notNull": true, "belongPrimaryKey": true},
    {"fieldName": "title", "fieldType": "String", "notNull": true, "defaultValue": 0},
    {"fieldName": "msg", "fieldType": "String"},
    {"fieldName": "home_coupon_activity_id", "fieldType": "Integer"},
    {"fieldName": "router", "fieldType": "String"},
    {"fieldName": "activity_time", "fieldType": "String"}
  "indexes": [
    {"indexName": "home_coupon_activity_id_index", "indexList": [{"fieldName":"home_coupon_activity_id","sortType":"ASC"}]}
  "permissions": [
    {"role": "World", "rights": ["Read"]},
    {"role": "Authenticated", "rights": ["Read", "Upsert"]},
    {"role": "Creator", "rights": ["Read", "Upsert", "Delete"]},
    {"role": "Administrator", "rights": ["Read", "Upsert", "Delete"]}
然后我们创建对应的活动id下的优惠券列表表
coupon_info
  "objectTypeName": "coupon_info",
  "fields": [
    {"fieldName": "coupon_id", "fieldType": "Integer", "notNull": true, "belongPrimaryKey": true},
    {"fieldName": "home_coupon_activity_id", "fieldType": "Integer", "notNull": true, "defaultValue": 0},
    {"fieldName": "price", "fieldType": "String"},
    {"fieldName": "type", "fieldType": "String"},
    {"fieldName": "get_time", "fieldType": "String"},
    {"fieldName": "limit_amount", "fieldType": "Integer"},
    {"fieldName": "txt", "fieldType": "String"},
    {"fieldName": "activity_id", "fieldType": "Integer"}
  "indexes": [
    {"indexName": "couponIdIndex", "indexList": [{"fieldName":"coupon_id","sortType":"ASC"}]}
  "permissions": [
完成之后我们插入数据
  "cloudDBZoneName": "default",
  "objects": [
      "activity_id": 10,
      "title": "新人活动",
      "msg": "前三单免运费",
      "home_coupon_activity_id": 10,
      "router": "路由",
      "activity_time": "2025-4-3"
  "objects": [
      "coupon_id": 10,
      "price": "10",
      "type": "新人专享",
      "get_time": "2025-3-18",
      "limit_amount": 30,
      "txt": "string1",
      "activity_id": 1
      "coupon_id": 20,
      "price": "string2",
      "type": "string2",
      "get_time": "string2",
      "limit_amount": 20,
      "txt": "string2",
      "activity_id": 1
      "coupon_id": 30,
      "price": "string1",
      "type": "string1",
      "get_time": "string1",
      "limit_amount": 10,
      "txt": "string1",
      "activity_id": 1
      "coupon_id": 40,
      "price": "string2",
      "type": "string2",
      "limit_amount": 20,
      "txt": "string2",
      "activity_id": 1
数据都插入完之后,我们把内容同步到云端数据库,然后client model 、server model 创建对应的类
都执行完之后我们就可以直接在index 页面进行数据的查询了
首先创建接收数据的对象
@State home_new_people_coupon:homeNewPeopleCoupon|null=null
@State couponList:couponInfo[]=[]
然后进行查询
let databaseZone = cloudDatabase.zone('default');
let condition = new cloudDatabase.DatabaseQuery(home_new_people_coupon);
let condition1 = new cloudDatabase.DatabaseQuery(coupon_info);
let listData = await databaseZone.query(condition);
let json = JSON.stringify(listData)
let data:homeNewPeopleCoupon= JSON.parse(json)
this.home_new_people_coupon=data;
let listData1 = await databaseZone.query(condition1);
condition1.equalTo("home_coupon_activity_id",data.home_coupon_activity_id)
let json1 = JSON.stringify(listData1)
let data1:couponInfo[]= JSON.parse(json1)
this.couponList=data1
可以看到我们的云端数据已经查出来了
我们把数据修改一下提交到云端
  "objects": [
      "coupon_id": 10,
      "price": "10",
      "type": "新人专享",
      "limit_amount": 30,
      "txt": "string1",
      "activity_id": 1
      "coupon_id": 20,
      "price": "15",
      "type": "新人专享",
      "limit_amount": 20,
      "txt": "string2",
      "activity_id": 1
      "coupon_id": 30,
      "price": "20",
      "type": "新人专享",
      "limit_amount": 10,
      "txt": "string1",
      "activity_id": 1
      "coupon_id": 40,
      "price": "30",
      "type": "新人专享",
      "limit_amount": 20,
      "txt": "string2",
      "activity_id": 1
然后修改我们之间创建的新人活动的组件
import { couponInfo } from "../entity/couponInfo"
import { homeNewPeopleCoupon } from "../entity/homeNewPeopleCoupon"
@Component
@Preview
export struct CouponComponent {
  @Link home_activity:homeNewPeopleCoupon|null
  @Link couponList:couponInfo[]
  build() {
    Column() {
      Row() {
        Text(this.home_activity?.title)
          .fontSize(20)
          .fontColor('#FF0000')
        Text(this.home_activity?.msg)
          .fontSize(14)
          .fontColor('#888888')
          .margin({left:10})
      .width('100%')
      .padding(16)
      List({ space: 10 }) {
        ForEach(this.couponList, (item:couponInfo) => {
          ListItem() {
            Column() {
              Text(item.price)
                .fontSize(22)
                .fontColor('#FF4444')
                .margin({ bottom: 8 })
              Text(item.type)
                .fontSize(12)
            .padding(10)
            .backgroundColor("#ffffff")
            .borderRadius(8)
      .margin({left:50})
      .listDirection(Axis.Horizontal)
      .width('100%')
      .height(80)
      Button('立即领取', { type: ButtonType.Normal })
        .width(240)
        .height(40)
        .backgroundColor('#FF0000')
        .fontColor(Color.White)
        .borderRadius(20)
        .margin({ bottom: 16 })
        .onClick(()=>{
          console.log(`"router"`)
    .backgroundColor("#fffce2be")
    .width('95%')
    .margin({top:20})
    .borderRadius(20)
首页调用组件进行参数的传入
CouponComponent({home_activity:this.home_new_people_coupon,couponList:this.couponList})
到这里我们的新人活动就完成了
