ABoVE:2018 年阿拉斯加内陆两个热喀斯特湖泊生态系统的甲烷通量
此星光明 发表于 2025/06/23 10:42:31 2025/06/23
【摘要】 ​ ABoVE: Methane Flux across Two Thermokarst Lake Ecosystems, Interior Alaska, 2018简介该数据集提供了从阿拉斯加内陆费尔班克斯北部金溪谷的两个热喀斯特湖泊收集的扩散甲烷 (CH4) 通量。通量收集自沿岸带、邻近海岸线和高地植被。数据收集时间为 2018 年 7 月。测量采用移动式密闭室技术进行,其中室内空气通过...
简介
该数据集提供了从阿拉斯加内陆费尔班克斯北部金溪谷的两个热喀斯特湖泊收集的扩散甲烷 (CH4) 通量。通量收集自沿岸带、邻近海岸线和高地植被。数据收集时间为 2018 年 7 月。测量采用移动式密闭室技术进行,其中室内空气通过洛斯加托斯研究 (LGR) 超便携式腔衰荡光谱仪进行再循环。该密闭室足够大,可以封闭高达 1.5 米的挺水植被和高地植被,从而可以测量植物促进的通量。这些现场测量用于验证美国宇航局下一代机载可见光/红外成像光谱仪 (AVIRIS-NG) 探测到的甲烷通量的空间模式(即随与水距离的指数衰减)。
摘要
Variable Units Description
plot_id Plot ID number
lake_id BTL = Big Trail Lake or GSL = Goldstream Lake
latitude decimal degrees Latitude
longitude decimal degrees Longitude
date YYYY-MM-DD Sampling date
methane mmol CH4 m-2 hr-1 Methane flux: mmol methane/m2/hr
flux_error mmol CH4 m-2 hr-1 Methane flux error: mmol methane/m2/hr. See Section 4 for details.
distance_from_water m Distance from open water to where the measurement was made. “0s” refer to fluxes that were measured over open water surfaces. Other distances from water indicate measurements of vegetation adjacent to a lake and on transects extending radially away from a lake.
distance_error m The uncertainty on the accuracy of the GPS system used to measure the distance from open water.
代码
!pip install leafmap
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="CH4_Fluxes_ThermokarstLakes_AK_1870",
    cloud_hosted=True,
    bounding_box=(-147.85, 64.92, -147.82, 64.92),
    temporal=("2019-07-04", "2019-12-14"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
