LBA-ECO CD-10 CO、CO2 和气象数据,巴西马克萨兰瓜佩
此星光明 发表于 2025/06/10 20:11:10 2025/06/10
【摘要】 ​LBA-ECO CD-10 CO, CO2 and Meteorological Data, Maxaranguape, Brazil简介本数据集报告了 2003 年 1 月 4 日至 2006 年 12 月 27 日期间在巴西东北部马克萨兰瓜佩大气观测站测得的一氧化碳 (CO) 和二氧化碳 (CO2) 浓度、风向、风速和气温。数据为 30 分钟平均值。马克萨兰瓜佩观测到的浓度代表了亚马逊...
简介
本数据集报告了 2003 年 1 月 4 日至 2006 年 12 月 27 日期间在巴西东北部马克萨兰瓜佩大气观测站测得的一氧化碳 (CO) 和二氧化碳 (CO2) 浓度、风向、风速和气温。数据为 30 分钟平均值。马克萨兰瓜佩观测到的浓度代表了亚马逊河流域上游大气边界条件,可与圣塔伦数据和其他数据集结合使用,估算这些气体的区域预算(Kirchhoff 等人,2003)。此数据集包含一个逗号分隔的 ASCII 文本文件。
摘要
File name: CD10_Maxaranguape_CO_CO2_2003-2006.csv
Column  Heading Units/format Description
1 Day_of_year Decimal day of the year with hour indicated by fraction based on UTC (1.5 = noon on Jan 1st)
2 Seq_date_2002 Decimal day since January 1st 2002 based on UTC (local time is GMT-4)
3 Date yyyy/mm/dd Sampling date
4 Hour Hour is the start of the half hourly sampling period on a 24 hour clock on UTC: (local time is GMT -4)
5 Wind_spd m s-1 Mean wind speed in meters per second (m s-1) computed as a vector average on 30 min intervals
6 Wind_dir degrees Mean wind direction in degrees computed as a vector average on 30 min intervals
7 T_air degrees C Mean air temperature in degrees Celsius for the 30 min sampling period
8 Std_dev_T_air degrees C Standard deviation of the mean air temperature
9 CO2_mix_ratio ppmv CO2 mixing ratio in micromoles/mole (ppmv)
10 Std_dev_CO2_ratio ppmv Standard deviation of the calculated mean CO2 ratio
11 Npts_CO2 Number of one minute averages included in the half-hourly reported CO2 ratio
12 CO_mix_ratio ppbv Carbon monoxide (CO) mixing ratio reported in nanomoles/mole (ppbv)
13 Std_dev_CO_ratio ppbv Standard deviation of the calculated mean CO ratio
14 Npts_CO Number of one minute averages included in the half-hourly reported CO ratio. The maximum number will be less than 30 because of the periodic zeroing
Missing data are represented by -999
Site boundaries: (All latitude and longitude given in degrees and fractions)
Site (Region) Westernmost Longitude Easternmost Longitude Northernmost Latitude Southernmost Latitude Geodetic Datum
Rio Grande do Norte - Maxaranguape Atmospheric Observatory (Rio Grande do Norte) -35.2605 -35.2605 -5.496 -5.496 South-American Datum, 1969 (SAD-69)
代码
!pip install leafmap
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="CD10_CO_CO2_Maxaranguape_1012",
    cloud_hosted=True,
    bounding_box=(-55.21, -4.05, -54.91, -2.84),
    temporal=("2003-01-04", "2006-12-27"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
引用
Kirchhoff, V.W.J.H., C.B. Aires, and P.C. Alvala. 2003. An experiment to determine atmospheric CO concentrations of tropical South Atlantic air samples. Quarterly Journal of the Royal Meteorological Society 129(591):1891-1902. doi:10.1256/qj.02.142
