LBA-ECO CD-06 巴西吉巴拉那河流域水量平衡:1995-1996
此星光明 发表于 2025/06/02 18:14:37 2025/06/02
【摘要】 ​ LBA-ECO CD-06 Water Balance of the Ji-Parana River Basin, Brazil: 1995-1996简介本数据集提供了巴西朗多尼亚州吉-帕拉纳河流域模拟的最小、平均和最大月降雨量、潜在蒸散量、缺水量和盈余量。Thornthwaite-Mather 气候模型集成到地理信息系统(GIS)中,用于模拟水通量,模型输入包括先进甚高分辨率雷达(AV...
简介
本数据集提供了巴西朗多尼亚州吉-帕拉纳河流域模拟的最小、平均和最大月降雨量、潜在蒸散量、缺水量和盈余量。Thornthwaite-Mather 气候模型集成到地理信息系统(GIS)中,用于模拟水通量,模型输入包括先进甚高分辨率雷达(AVHRR)图像的温度、流域内外水位计的降雨量、土壤剖面和土地覆盖图。模拟了吉-帕拉纳河流域从 1995 年 2 月到 1996 年 12 月的月水量平衡。
吉-帕拉纳子流域站还提供了流域总降雨量、流域流量和流域蒸散量的数据。这些数据用于检验水量平衡模型的结果。该数据集包含两个逗号分隔的数据文件。
摘要
File #1: CD06_Modeled_Water_Balance_JiParana.csv
Data description: Ji-Parana, Rondonia, Modeled Water Balance, February 1995 - December 1996
Column Heading Units/format Description
1 Date yyyymmdd Date (yyyymmdd)
2 P_min mm Monthly minimum basin rainfall (P) in millimeters (mm)
3 P_med mm Monthly average basin rainfall (P) in millimeters (mm)
4 P_max mm Monthly maximum basin rainfall (P) in millimeters (mm)
5 PET_min mm Monthly minimum basin potential evapotranspiration (PET) in millimeters (mm)
6 PET_med mm Monthly average basin potential evapotranspiration (PET) in millimeters (mm)
7 PET_max mm Monthly maximum basin potential evapotranspiration (PET) in millimeters (mm)
8 ET_min mm Monthly minimum basin evapotranspiration (ET) in millimeters (mm)
9 ET_med mm Monthly average basin evapotranspiration (ET) in millimeters (mm)
10 ET_max mm Monthly maximum basin evapotranspiration (ET) in millimeters (mm)
11 DEF_min mm Monthly minimum basin water deficit (DEF) in millimeters (mm)
12 DEF_med mm Monthly average basin water deficit (DEF) in millimeters (mm)
13 DEF_max mm Monthly maximum basin water deficit (DEF) in millimeters (mm)
14 SUR_min mm Monthly minimum basin water surplus (SUR) in millimeters (mm)
15 SUR_med mm Monthly average basin water surplus (SUR) in millimeters (mm)
16 SUR_max mm Monthly maximum basin water surplus (SUR) in millimeters (mm)
File #2: CD06_Water_Mass_Balance_Ji_Parana.csv
Data description: Water mass balance for 10 sub-basins on the Ji-Parana (Rondonia) basin for September 1995 to August 1996. This data was used to check the results of a simple water balance model based on Thorthwaite-Mather water balance, spatially distributed. This data is from Table 1 in the related paper (Victoria, D., et al. 2007).
1 Sub_basin Ji-Parana sub-basin, defined by the Brazilian national water agency, ANA
2 Station_code Fluviometric station code assigned by ANA
3 Basin_area km2 Drainage basin area in square kilometers (km2)
4 Rainfall mm/yr Total basin rainfall in millimeters per year (mm year-1)  between September 1995 to August 1996, calculated by interpolating rain gauge data from ANA, interpolation method: spline with tension.
5 Discharge mm/yr Total basin discharge in millimeters per year (mm year-1)  for the period: September 1995 to August 1996, measured at ANA fluviometric station
6 ET mm/yr Total basin evapotranspiration in millimeters per year (mm year-1) calculated as the difference from rainfall and discharge over a water year (September 1995 to August 1996)
代码
!pip install leafmap
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="CD06_Water_Balance_JiParana_1132",
    cloud_hosted=True,
    bounding_box=(-63.42, -12.93, -60.01, -8.03),
    temporal=("1995-10-01", "1996-08-31"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
