WRF-STILT模型输入的气象站数据
此星光明 发表于 2025/05/07 10:32:54 2025/05/07
【摘要】 CARVE: L4 Gridded Particle Trajectories for WRF-STILT model, 2012-2016简介该数据集为位于北极碳库脆弱性实验 (CARVE) 飞行路径(2012 - 2015 年)沿线位置的粒子接收器以及阿拉斯加和加拿大北极地区的各个气象站提供天气研究与预报 (WRF) 随机时间倒置拉格朗日传输 (STILT) 模型输入。每个产品包含多个 ...
简介
该数据集为位于北极碳库脆弱性实验 (CARVE) 飞行路径(2012 - 2015 年)沿线位置的粒子接收器以及阿拉斯加和加拿大北极地区的各个气象站提供天气研究与预报 (WRF) 随机时间倒置拉格朗日传输 (STILT) 模型输入。每个产品包含多个 NetCDF 文件,打包为一个 TAR/GZIP 文件。这些数据对应于同样由 CARVE 科学团队生成的 WRF-STILT 模型足迹数据。
该数据集包含 72 个 TAR/GZIP 文件,其中包含 NetCDF 格式的 WRF-STILT 粒子文件。
摘要
Table 1. Naming convention for NetCDF files generated by WRF-STILT.
Example file name: foot2013x06x25x04x00x65.1330Nx147.4539Wx00003.nc
Name element Example value Units
Year 2013 YYYY
Month 06 MM
Day 25 DD
Hour 04 hh (UTC)
Minute 00 mm (UTC)
Latitude 65.1330N decimal degrees
Longitude 127.4539W decimal degrees
Height A.G.L. 00003 m
For example, the above file contains the modeled particle footprints for June 25, 2013 at 4:00 UTC. The observation was taken at 65.1330N, 127.4539W at 3 m above ground level.
Data Variables
Table 2. Data variables in each NetCDF file. Fill values or missing data were set to -1.0E34 for all variables.
Variable name
Units
Description
checkbasic
basic output from Trajeccheck()
checkbasicnames
names for checkbasic 1D array
checksum
checksum array
checksumdate
days since 2000-01-01 00:00:00 UTC
checksum date
checksumnames
column names for checksum array
endpts
stilt particle location array thinned to retain rows containing trajectory endpts
endptsdate
end points date
endptsnames
column names for particle array ‘endpts’
foot1
ppm per (umol m-2 s-1)
gridded STILT footprint
foot1date
date of foot1
foot1hr
hours
hours back from STILT start time
foot1lat
degrees_north
degrees latitude of center of grid cells
foot1lon
degrees_east
degrees longitude of center of grid cells
footnearfield1
footnearfield1date
date for 'footnearfield1'
footnearfield1hr
hours
hours back from STILT start time for 'footnearfield1'
footnearfield1lat
degrees_north
footnearfield1lon
degrees_east
ident
identifier string
nchar
numeric identifier
origagl
meters
original receptor height above ground before rounding for STILT
origlat
degrees_north
original receptor latitude
origlon
degrees_east
original receptor longitude
origutctime
UTC time
original receptor time
origutctimeformat
original receptor time format
part3d
stilt particle location array thinned to retain rows approximately every so many hours
part3ddate
date of part3d
part3dnames
column names for particle array ‘part3d’
partfoot
stilt particle location array thinned to retain rows where foot > 0
partfootdate
date of partfoot
partfootnames
column names for particle array ‘partfoot’
代码
!pip install leafmap
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="CARVE_L4_WRF-STILT_Particle_1430",
    cloud_hosted=True,
    bounding_box=(-180.0, 30.0, 180.0, 90.0),
    temporal=("2012-01-01", "2016-04-28"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
引用
CARVE Science Team. 2017. CARVE: L4 Gridded Particle Trajectories for WRF-STILT model, 2012-2016. ORNL DAAC, Oak Ridge, Tennessee, USA.
