机载数字大气数据系统(DADS)如何记录和呈现飞机的高度、俯仰角和滚转角信息?
此星光明 发表于 2025/04/28 13:33:23 2025/04/28
【摘要】 CARVE: L1 Daily Flight Path Geolocation and Aircraft Position Data, Alaska, 2012-2015简介该数据集为 C-23“夏尔巴”运输机在阿拉斯加和加拿大北极地区上空执行空中任务期间提供高频地理定位、时间、高度、俯仰角、滚转角和航向信息,该任务是北极碳储层脆弱性实验(CARVE)的一部分。数据使用机载数字大气数据系统(...
简介
该数据集为 C-23“夏尔巴”运输机在阿拉斯加和加拿大北极地区上空执行空中任务期间提供高频地理定位、时间、高度、俯仰角、滚转角和航向信息,该任务是北极碳储层脆弱性实验(CARVE)的一部分。数据使用机载数字大气数据系统(DADS)现场收集,并在每次飞行中以 1 秒的间隔呈现。飞行任务于 2012 年至 2015 年 3 月至 11 月期间进行,旨在研究大气气体含量的季节性和年际变化。该数据集中包含的测量值可用于将飞机位置与其他 CARVE 机载仪器收集的科学数据进行匹配。
摘要
Table 1. CARVE file naming convention. Example file name: carve_DADS_L1_b23_20120513_20150621190524.nc
Name element
Example value
Units
Project name
carve
Instrument
DADS
Processing level
L1
Build ID
b23
Flight date
20120513
yyyymmdd
Processing date and time
20150621190524
yyyymmddhhmmss
Data variables
Each file contains 8 geolocation and time variables and an additional 6 science measurement variables described in Table 2.
Table 2. Data variables in each netCDF file. Fill value or missing data were set to -999.9 for all variables.
Variable name
Description
Units
Geolocation measurements
center_lat
latitude of (aircraft sampling) footprint center
Decimal degrees North
center_lat_standard_error
uncertainty of latitude
center_lon
longitude of (aircraft sampling) footprint center
Decimal degrees East
center_lon_standard_error
uncertainty of longitude
geolocation_qc
geolocation status flag
0 = Success, 1 = Error
height
height of aircraft above ground
meters
height_standard_error
uncertainty of height
meters
time
time
seconds since 1980-1-6 0:0:0 UTC
Science Measurements
heading
aircraft heading
degrees
heading_qc
aircraft heading status flag
0 = Valid, 1 = Out of Range, 2 = Error
pitch
aircraft pitch angle
degrees
pitch_qc
aircraft pitch status flag
roll
aircraft roll angle
degrees
roll_qc
aircraft roll status flag
代码
!pip install leafmap
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data/raw/main/nasa_earth_data.tsv"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="CARVE_L1_FlightPath_1425",
    cloud_hosted=True,
    bounding_box=(-168.11, 58.84, -131.75, 71.56),
    temporal=("2012-05-23", "2015-11-13"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
引用
Miller, C.E., Dinardo, S.J. et al. (2012). CARVE: The Carbon in Arctic Reservoirs Vulnerability Experiment., 2012 IEEE Aerospace Conference. http://dx.doi.org/10.1109/AERO.2012.6187026
