SpringBoot-集成FTP(上传、下载、删除)
林欣 发表于 2025/04/26 21:35:34 2025/04/26
【摘要】 SpringBoot集成FTP实现文件上传、下载、删除在SpringBoot项目中集成FTP功能,可以通过Apache Commons Net库来实现。下面是一个完整的实现方案,包括配置、上传、下载和删除文件的功能。 1. 添加依赖首先,在pom.xml中添加Apache Commons Net依赖:<dependency> <groupId>commons-net</groupId...
1. 添加依赖
<dependency>
    <groupId>commons-net</groupId>
    <artifactId>commons-net</artifactId>
    <version>3.9.0</version>
</dependency>
2. FTP配置类
创建一个FTP配置类,用于存储FTP连接信息:
import org.springframework.boot.context.properties.ConfigurationProperties;
import org.springframework.stereotype.Component;
@Component
@ConfigurationProperties(prefix = "ftp")
public class FtpConfig {
    private String host;
    private int port;
    private String username;
    private String password;
    private String basePath;
    // getters and setters
    public String getHost() {
        return host;
    public void setHost(String host) {
        this.host = host;
    public int getPort() {
        return port;
    public void setPort(int port) {
        this.port = port;
    public String getUsername() {
        return username;
    public void setUsername(String username) {
        this.username = username;
    public String getPassword() {
        return password;
    public void setPassword(String password) {
        this.password = password;
    public String getBasePath() {
        return basePath;
    public void setBasePath(String basePath) {
        this.basePath = basePath;
在application.yml或application.properties中配置FTP信息:
ftp:
  host: 127.0.0.1
  port: 21
  username: your_username
  password: your_password
  basePath: /ftp/files
3. FTP工具类
创建一个FTP工具类,封装上传、下载和删除功能:
import org.apache.commons.net.ftp.FTP;
import org.apache.commons.net.ftp.FTPClient;
import org.apache.commons.net.ftp.FTPFile;
import org.apache.commons.net.ftp.FTPReply;
import org.springframework.beans.factory.annotation.Autowired;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
@Component
public class FtpUtil {
    @Autowired
    private FtpConfig ftpConfig;
     * 连接FTP服务器
    private FTPClient connect() throws IOException {
        FTPClient ftpClient = new FTPClient();
        ftpClient.setControlEncoding("UTF-8");
        ftpClient.connect(ftpConfig.getHost(), ftpConfig.getPort());
        ftpClient.login(ftpConfig.getUsername(), ftpConfig.getPassword());
        ftpClient.setFileType(FTP.BINARY_FILE_TYPE);
        ftpClient.enterLocalPassiveMode();
        ftpClient.setBufferSize(1024 * 1024); // 设置缓冲区大小
        // 检查连接是否成功
        int replyCode = ftpClient.getReplyCode();
        if (!FTPReply.isPositiveCompletion(replyCode)) {
            ftpClient.disconnect();
            throw new IOException("FTP服务器拒绝连接");
        return ftpClient;
     * 上传文件到FTP服务器
     * @param remotePath 远程路径
     * @param fileName 文件名
     * @param inputStream 输入流
     * @return 是否上传成功
    public boolean uploadFile(String remotePath, String fileName, InputStream inputStream) {
        FTPClient ftpClient = null;
        try {
            ftpClient = connect();
            // 切换目录
            if (!ftpClient.changeWorkingDirectory(remotePath)) {
                // 如果目录不存在,则创建
                String[] dirs = remotePath.split("/");
                String tempPath = "";
                for (String dir : dirs) {
                    if (dir.length() > 0) {
                        tempPath += "/" + dir;
                        if (!ftpClient.changeWorkingDirectory(tempPath)) {
                            if (!ftpClient.makeDirectory(tempPath)) {
                                return false;
            // 上传文件
            boolean success = ftpClient.storeFile(fileName, inputStream);
            return success;
        } catch (IOException e) {
            e.printStackTrace();
            return false;
        } finally {
            if (ftpClient != null && ftpClient.isConnected()) {
                try {
                    ftpClient.logout();
     * 从FTP服务器下载文件
     * @param outputStream 输出流
     * @return 是否下载成功
    public boolean downloadFile(String remotePath, String fileName, OutputStream outputStream) {
        try {
            // 切换目录
                return false;
            // 下载文件
            boolean success = ftpClient.retrieveFile(fileName, outputStream);
            return success;
            return false;
        } finally {
                try {
                    ftpClient.logout();
     * 删除FTP服务器上的文件
     * @return 是否删除成功
    public boolean deleteFile(String remotePath, String fileName) {
        try {
            // 切换目录
                return false;
            // 删除文件
            boolean success = ftpClient.deleteFile(fileName);
            return success;
            return false;
        } finally {
                try {
                    ftpClient.logout();
     * 检查文件是否存在
     * @return 文件是否存在
    public boolean fileExists(String remotePath, String fileName) {
        try {
            // 切换目录
                return false;
            FTPFile[] files = ftpClient.listFiles();
            for (FTPFile file : files) {
                if (file.getName().equals(fileName)) {
                    return true;
            return false;
            return false;
        } finally {
                try {
                    ftpClient.logout();
4. 使用示例
创建一个控制器来测试FTP功能:
import org.springframework.web.bind.annotation.*;
import org.springframework.web.multipart.MultipartFile;
import java.io.ByteArrayInputStream;
import java.io.ByteArrayOutputStream;
@RestController
@RequestMapping("/ftp")
public class FtpController {
    @Autowired
    private FtpUtil ftpUtil;
    @PostMapping("/upload")
    public String uploadFile(@RequestParam("file") MultipartFile file) {
        try {
            InputStream inputStream = file.getInputStream();
            boolean success = ftpUtil.uploadFile("/upload", file.getOriginalFilename(), inputStream);
            if (success) {
                return "文件上传成功";
                return "文件上传失败";
            return "文件上传异常";
    @GetMapping("/download")
    public byte[] downloadFile(@RequestParam String fileName) {
        try {
            ByteArrayOutputStream outputStream = new ByteArrayOutputStream();
            boolean success = ftpUtil.downloadFile("/upload", fileName, outputStream);
            if (success) {
                return outputStream.toByteArray();
                return null;
        } catch (Exception e) {
            return null;
    @DeleteMapping("/delete")
    public String deleteFile(@RequestParam String fileName) {
        boolean success = ftpUtil.deleteFile("/upload", fileName);
        if (success) {
            return "文件删除成功";
            return "文件删除失败";
    @GetMapping("/check")
    public String checkFile(@RequestParam String fileName) {
        boolean exists = ftpUtil.fileExists("/upload", fileName);
        if (exists) {
            return "文件存在";
            return "文件不存在";
5. 注意事项
  1. 连接管理:每次操作都新建连接,操作完成后关闭连接。对于高频操作,可以考虑使用连接池。
  2. 异常处理:实际应用中需要更完善的异常处理和日志记录。
  3. 性能优化:对于大文件传输,可以考虑分块上传/下载。
  4. 安全性:确保FTP服务器配置了适当的安全措施,如使用SFTP/FTPS代替普通FTP。
  5. 被动模式:示例中使用的是被动模式(PASV),适用于大多数防火墙/NAT环境。
6. 高级功能扩展
如果需要更高级的功能,可以考虑:
  1. 断点续传:记录已传输的字节位置,支持中断后继续传输
  2. 目录操作:添加创建目录、删除目录、列出目录等功能
  3. 批量操作:支持批量上传/下载/删除
  4. 进度监控:添加传输进度回调接口
以上实现提供了SpringBoot集成FTP的基本功能,可以根据实际需求进行扩展和优化。
