821130.
yd_211651640 发表于 2025/04/09 19:10:16 2025/04/09
【摘要】 111
RocketChat上云
1.拷贝安装包到ECS上
使用SFTP工具或SCP拷贝到ECS上
[root@chinaskill ~]# ls
rocketchat-cloud.tar.gz
2.解压安装包
[root@chinaskill ~]# tar -zxvf rocketchat-cloud.tar.gz
rocketchat-cloud  rocketchat-cloud.tar.gz
[root@chinaskill ~]# cd rocketchat-cloud
[root@chinaskill rocketchat-cloud]# ll
total 287584
-rw-r--r-- 1 501 games 162088460 Jul 11  2022 rocket.chat-3.4.1.tgz
-rw-r--r-- 1 501 games 132375089 Jul 31  2022 rocketchat-repo.tar.gz
-rw-r--r-- 1 501 games     13130 Jul 11  2022 setup_12.x
[root@chinaskill rocketchat-cloud]# tar -zxvf rocket.chat-3.4.1.tgz
[root@chinaskill rocketchat-cloud]# tar -zxvf rocketchat-repo.tar.gz
[root@chinaskill rocketchat-cloud]# ls
bundle  rocket.chat-3.4.1.tgz  rocketchat-repo  rocketchat-repo.tar.gz  setup_12.x
[root@chinaskill rocketchat-cloud]# cd bundle
[root@chinaskill bundle]# ls
main.js  programs  README  server  star.json
1.查看依赖
[root@chinaskill bundle]# cd programs
[root@chinaskill programs]# ls
server  web.browser  web.browser.legacy
[root@chinaskill programs]# cd server
[root@chinaskill server]# ls
app      boot.js.map        config.json   mini-files.js      npm-rebuild-args.js      npm-rebuild.js.map  npm-require.js.map   packages        program.json    server-json.js
assets   boot-utils.js      debug.js      mini-files.js.map  npm-rebuild-args.js.map  npm-rebuilds.json   npm-shrinkwrap.json  profile.js      runtime.js      server-json.js.map
boot.js  boot-utils.js.map  debug.js.map  npm                npm-rebuild.js           npm-require.js      package.json         profile.js.map  runtime.js.map
#查看依赖包
#node语言是以package.json控制
#python是以requirement.txt控制
#java是以pom.xml控制
#golang是以go.mod控制
[root@chinaskill server]# cat package.json
  "name": "meteor-dev-bundle",
  "private": true,
  "dependencies": {
    "fibers": "4.0.3",
    "meteor-promise": "0.8.7",
    "promise": "8.0.2",
    "reify": "0.20.12",
    "@babel/parser": "7.9.4",
    "@types/underscore": "1.9.2",
    "underscore": "1.9.1",
    "source-map-support": "https://github.com/meteor/node-source-map-support/tarball/1912478769d76e5df4c365e147f25896aee6375e",
    "@types/semver": "5.4.0",
    "semver": "5.4.1",
    "node-gyp": "6.0.1",
    "node-pre-gyp": "0.14.0"
  "devDependencies": {
    "split2": "2.1.1",
    "multipipe": "1.0.2",
    "chalk": "0.5.1"
  "scripts": {
    "install": "node npm-rebuild.js"
2.查看当前Rocketchat版本需要用到的node版本
[root@chinaskill bundle]# cat star.json
  "format": "site-archive-pre1",
  "builtBy": "Meteor METEOR@1.10.2",
  "programs": [
      "name": "web.browser",
      "arch": "web.browser",
      "path": "programs/web.browser/program.json"
      "name": "web.browser.legacy",
      "arch": "web.browser.legacy",
      "path": "programs/web.browser.legacy/program.json"
      "name": "server",
      "arch": "os",
      "path": "programs/server/boot.js"
  "meteorRelease": "METEOR@1.10.2",
  "nodeVersion": "12.16.1", #node的版本为12.16.1 后面会用到
  "npmVersion": "6.14.0",
  "gitCommitHash": "21157c0c4fe555434bd6b08ee7d7a847a3f8fb15"
3.查看当前版本
[root@chinaskill server]# cd ..
[root@chinaskill programs]# cd ..
[root@chinaskill bundle]# vim README
This is a Meteor application bundle. It has only one external dependency:
Node.js v12.16.1. To run the application: #node版本号
  $ (cd programs/server && npm install)
  $ export MONGO_URL='mongodb://user:password@host:port/databasename'
  $ export ROOT_URL='http://example.com'
  $ export MAIL_URL='smtp://user:password@mailhost:port/'
  $ node main.js
Use the PORT environment variable to set the port where the
application will listen. The default is 80, but that will require
root on most systems.
Find out more about Meteor at meteor.com.
3.安装mongodb
1.配置YUM仓库
[root@chinaskill bundle]# cat > /etc/yum.repos.d/mongodb.repo << EOF
[mongodb-org-4.4]
name=MongoDB Repository
baseurl=https://repo.mongodb.org/yum/redhat/7/mongodb-org/4.4/x86_64/
gpgcheck=0
enabled=1
EOF
2.安装Mongodb
[root@chinaskill bundle]# yum install -y mongodb-org
3.配置主从数据库
[root@chinaskill bundle]# vim /etc/mongod.conf
replication:
  replSetName: rs01
#初始化主从数据库(主节点)
[root@chinaskill bundle]# systemctl enable --now mongod
[root@chinaskill bundle]# mongo
rs.initiate()
> rs.initiate()
        "info2" : "no configuration specified. Using a default configuration for the set",
        "me" : "127.0.0.1:27017",
        "ok" : 1
rs.conf()
rs01:SECONDARY> rs.conf()
        "_id" : "rs01",
        "version" : 1,
        "term" : 1,
        "protocolVersion" : NumberLong(1),
        "writeConcernMajorityJournalDefault" : true,
        "members" : [
                        "_id" : 0,
                        "host" : "127.0.0.1:27017",
                        "arbiterOnly" : false,
                        "buildIndexes" : true,
                        "hidden" : false,
                        "priority" : 1,
                        "tags" : {
                        "slaveDelay" : NumberLong(0),
                        "votes" : 1
        "settings" : {
                "chainingAllowed" : true,
                "heartbeatIntervalMillis" : 2000,
                "heartbeatTimeoutSecs" : 10,
                "electionTimeoutMillis" : 10000,
                "catchUpTimeoutMillis" : -1,
                "catchUpTakeoverDelayMillis" : 30000,
                "getLastErrorModes" : {
                "getLastErrorDefaults" : {
                        "w" : 1,
                        "wtimeout" : 0
                "replicaSetId" : ObjectId("67e4e523d5bd0ad66e191f16")
rs.status() #查看状态
rs01:PRIMARY> rs.status()
        "set" : "rs01",
        "date" : ISODate("2025-03-27T05:44:21.827Z"),
        "myState" : 1,
        "term" : NumberLong(1),
        "syncSourceHost" : "",
        "syncSourceId" : -1,
        "heartbeatIntervalMillis" : NumberLong(2000),
        "majorityVoteCount" : 1,
        "writeMajorityCount" : 1,
        "votingMembersCount" : 1,
        "writableVotingMembersCount" : 1,
        "optimes" : {
                "lastCommittedOpTime" : {
                        "ts" : Timestamp(1743054255, 1),
                        "t" : NumberLong(1)
                "lastCommittedWallTime" : ISODate("2025-03-27T05:44:15.211Z"),
                "readConcernMajorityOpTime" : {
                        "t" : NumberLong(1)
                "readConcernMajorityWallTime" : ISODate("2025-03-27T05:44:15.211Z"),
                "appliedOpTime" : {
                        "t" : NumberLong(1)
                "durableOpTime" : {
                        "t" : NumberLong(1)
                "lastAppliedWallTime" : ISODate("2025-03-27T05:44:15.211Z"),
                "lastDurableWallTime" : ISODate("2025-03-27T05:44:15.211Z")
        "lastStableRecoveryTimestamp" : Timestamp(1743054235, 1),
        "electionCandidateMetrics" : {
                "lastElectionReason" : "electionTimeout",
                "lastElectionDate" : ISODate("2025-03-27T05:41:55.181Z"),
                "electionTerm" : NumberLong(1),
                "lastCommittedOpTimeAtElection" : {
                        "ts" : Timestamp(0, 0),
                        "t" : NumberLong(-1)
                "lastSeenOpTimeAtElection" : {
                        "ts" : Timestamp(1743054115, 1),
                "numVotesNeeded" : 1,
                "priorityAtElection" : 1,
                "electionTimeoutMillis" : NumberLong(10000),
                "newTermStartDate" : ISODate("2025-03-27T05:41:55.200Z"),
                "wMajorityWriteAvailabilityDate" : ISODate("2025-03-27T05:41:55.219Z")
        "members" : [
                        "_id" : 0,
                        "name" : "127.0.0.1:27017",
                        "health" : 1,
                        "state" : 1,
                        "stateStr" : "PRIMARY",
                        "uptime" : 223,
                        "optime" : {
                                "t" : NumberLong(1)
                        "optimeDate" : ISODate("2025-03-27T05:44:15Z"),
                        "lastDurableWallTime" : ISODate("2025-03-27T05:44:15.211Z"),
                        "infoMessage" : "",
                        "electionTime" : Timestamp(1743054115, 2),
                        "electionDate" : ISODate("2025-03-27T05:41:55Z"),
                        "configVersion" : 1,
                        "configTerm" : 1,
                        "self" : true,
                        "lastHeartbeatMessage" : ""
        "ok" : 1,
        "$clusterTime" : {
                "clusterTime" : Timestamp(1743054255, 1),
                "signature" : {
                        "hash" : BinData(0,"AAAAAAAAAAAAAAAAAAAAAAAAAAA="),
                        "keyId" : NumberLong(0)
        "operationTime" : Timestamp(1743054255, 1)
#从节点加入主从数据库(从节点)
rs.add("${IP}",flase)
4.安装node环境
1.安装本次node依赖软件包
[root@chinaskill bundle]# yum install -y npm nodejs gcc make epel-release && sudo yum install -y GraphicsMagick
[root@chinaskill server]# yum groupinstall 'Development Tools' yum install gcc-c++
2.修改node版本
[root@chinaskill bundle]# node -v
v16.20.2
3.安装修改node版本的命令
# 使用nodejs的包管理工具 全局安装n命令
[root@chinaskill bundle]# npm install -g n
# 使用n命令切换nodejs版本
[root@chinaskill bundle]# n v12.16.1
  installing : node-v12.16.1
       mkdir : /usr/local/n/versions/node/12.16.1
       fetch : https://nodejs.org/dist/v12.16.1/node-v12.16.1-linux-x64.tar.xz
     copying : node/12.16.1
   installed : v12.16.1 (with npm 6.13.4)
Note: the node command changed location and the old location may be remembered in your current shell.
         old : /usr/bin/node
         new : /usr/local/bin/node
If "node --version" shows the old version then start a new shell, or reset the location hash with:
hash -r  (for bash, zsh, ash, dash, and ksh)
rehash   (for csh and tcsh)
1.安装好退出重进
重新连接ECS云服务器
2.查看版本
[root@chinaskill ~]# node -v
v12.16.1
4.下载所有node依赖包
[root@chinaskill ~]# cd /root/rocketchat-cloud/bundle/programs/server
# 使用node的包管理工具npm来自动解决依赖
# 会基于当前路径下的package.json来安装一系列的依赖包
[root@chinaskill server]# npm i
5.启动服务
1.查看启动方式
[root@chinaskill bundle]# cat README
  $ node main.js
2.添加启动参数
export MONGO_URL='mongodb://127.0.0.1:27017/rocketchat'
export ROOT_URL='http://1.94.162.248:3000'
export PORT=3000
export MONGO_OPLOG_URL=mongodb://127.0.0.1:27017/local?replicaSet=rs01
3.启动服务
[root@chinaskill bundle]# node main.js
LocalStore: store created at
Setting default file store to GridFS
{"line":"120","file":"migrations.js","message":"Migrations: Not migrating, already at version 197","time":{"$date":1743058808696},"level":"info"}
Loaded the Apps Framework and loaded a total of 0 Apps!
Using GridFS for custom sounds storage
Using GridFS for custom emoji storage
Browserslist: caniuse-lite is outdated. Please run next command `npm update`
Updating process.env.MAIL_URL
(node:30615) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
➔ System ➔ startup
➔ |                  SERVER RUNNING                 |
➔ |  Rocket.Chat Version: 3.4.1                     |
➔ |       NodeJS Version: 12.16.1 - x64             |
➔ |      MongoDB Version: 4.4.29                    |
➔ |       MongoDB Engine: wiredTiger                |
➔ |             Platform: linux                     |
➔ |         Process Port: 3000                      |
➔ |             Site URL: http://1.94.162.248:3000  |
➔ |     ReplicaSet OpLog: Enabled                   |
➔ |          Commit Hash: 21157c0c4f                |
➔ |        Commit Branch: HEAD                      |
6.无法访问解决
  • 检查服务启动状态
  • 检查安全组是否放通3000端口
公有云CCE集群
1.云容器引擎管理
创建一个 x86 架构集群,具体要求如下:
(1)集群名称:kcloud;
(2)集群版本:v1.21;
(3)地域:上海一;
(4)集群管理规模:50 节点;
(5)控制节点数:3;
(6)节点使用子网:intnetX-server;
(7)Pod 实例上限:64;
(8)容器网段:10.10.0.0/16。
节点配置信息要求如下:
(1)节点名称:kcloud-server;
(2)节点规格:c6s.xlarge.2
(3)节点:EulerOS 2.9
2.云容器管理
使用插件管理在kcloud容器集群中安装dashboard可视化监控界面。
3.使用kubectl操作集群
在 kcloud 集群中安装 kubectl 命令,使用 kubectl 命令管理 kcloud 集群。
# kubectl命令默认读取-/.kube/config文件作为集群的配置文件
# 在自行搭建的k8s集群中config文件默认在/etc/kubernetes/admin.conf
# 由于我们使用的是一键安装的命令所以拷贝config文件的操作是脚本帮我们执行
# config文件中指定了我们连接的api-server地址以及一些ca证书的信息,我们使用用户的信息
# 就如同我们openstack中的admin-openrc.sh
4.云硬盘存储卷
购买云硬盘存储卷,具体配置如下:
(1)名称为:kcloud-disk;
(2)集群:kcloud;
(3)容量:30G;
(4)类型:高 I/O;
5.工作负载
使用容器镜像服务作为镜像仓库,将提供的httpd-2.4.33和httpd-2.4.35镜像上传至服务中。在kcloud集群中创建一个Deployment,使用所上传的httpd-2.4.33容器镜像,配置使其可以通过外部公网进行访问。
6.创建存活探针
在kcloud集群中使用k8s集群创建名为liveness-http和liveness-tcp的pod,并分别设置http探针和tcp探针监控pod状态。
  • 存活检查(健康检查)
    对于我们的应用(httpd)来说他是否是能够对外提供服务,是评判这个服务健康的标准
  • 就绪检查
    我们容器启动后是否能够正常对外提供服务,就需要做一系列的就绪检查
1.探测的一些参数
  • 延迟时间
允许应用有一个启动时间,过了延迟时间之后基于探测周期开始探测
  • 探测周期
每个固定的时间周期来进行一次探测
  • 最大失败次数
允许的最大失败次数
  • 超时时间
配置请求的超时时间
  • 成功次数
请求成功后多少次判定探测为true 即截止
2.创建http存活探针
在kcloud集群中使用k8s集群创建名为liveness-http的pod,设置http探针监控pod状态,探针初始延迟时间为15秒,探测失败1次后重启容器。
1.创建模板并修改
[root@kcloud-server ~]# kubectl apply -f pod.yaml
[root@kcloud-server ~]# kubectl get pod -w
[root@kcloud-server ~]# kubectl describe pod liveness-http
[root@kcloud-server ~]# kubectl edit pod liveness-http
[root@kcloud-server ~]# kubectl run --image=httpd --port 80 --dry-run -oyaml liveness-http > pod.yaml
[root@kcloud-server ~]# kubectl explain pod.spec
[root@kcloud-server ~]# kubectl explain pod.spec | grep live -i
[root@kcloud-server ~]# kubectl explain pod.spec.containers | grep live -i
[root@kcloud-server ~]# kubectl explain pod.spec.containers.livenessProbe
[root@kcloud-server ~]# kubectl explain pod.spec.containers.livenessProbe.httpGet.port
[root@kcloud-server ~]# cat pod.yaml
[root@kcloud-server ~]# vim pod.yaml
[root@kcloud-server ~]# kubectl delete -f pod.yaml
apiVersion: v1
kind: Pod
metadata:
  creationTimestamp: null
  labels:
    run: 1iveness-http
spec:
  containers:
  - image: httpd
    ports:
    - containerPort: 80
    livenessProbe:
      httpGet:
        port: 80
      initialDelaySeconds: 15
      failureThreshold: 1
  dnsPolicy: ClusterFirst
  restartPolicy: Always
3.创建tcp存活探针
在kcloud集群中使用k8s集群创建名为liveness-tcp的pod,设置tcp探针监控pod状态,探针每15秒探测一次容器,探测容器超时时间为2秒。完成后提交连接kcloud集群节点的用户名、密码和公网IP地址到答题框。
[root@kcloud-server ~]# cat liveness-tcp.yaml
[root@kcloud-server ~]# vim liveness-tcp.yaml
apiVersion: v1
kind: Pod
metadata:
  labels:
    run: 1iveness-tcp
spec:
  containers:
  - image: httpd
    ports:
    - containerPort: 80
    livenessProbe:
      tcpSocket:
        port: 80
        #initialDelaySeconds: 15
        #failureThreshold: 1
      timeoutSeconds: 2
      periodSeconds: 15
7.Namespace管理
在 kcloud 集群节点/root 目录下编写 YAML 文件 my-namespace.yaml,具体要求如下:
(1)Namespace 名称:test。
[root@kcloud-server ~]# kubectl create ns test --dr-run -oyaml > my-namespace.yaml
[root@kcloud-server ~]# kubectl apply -f my-namespace.yaml
[root@kcloud-server ~]# kubectl get ns
8.Service管理--ClusterIP
在kcloud集群节点/root目录下编写YAML文件service-clusterip.yaml,具体要求如下:
(1)Servie名称:service-clusterip:
(2)命名空间:default;
(3)集群内部访问端口:80;targetPort:81;
(4)Service类型:NodePort
[root@kcloud-server ~]# kubectl create service clusterip service-clusterip --tcp 80:81 -- dry-run -oyaml > service-clusterip.yaml
[root@kcloud-server ~]# vim service-clusterip.yaml
[root@kcloud-server ~]# kubectl apply -f service-clusterip.yaml
9.Service管理--NodePort
在kcloud集群节点/root目录下编写YAML文件service-nodeport.yaml,具体要求如下:
(1)Servie名称:service-nodeport:
(2)命名空间:default;
(3)集群内部访问端口:80;对外暴露端口:30001;
[root@kcloud-server ~]# kubectl create service nodeport service-nodeport --tcp 80:30001 -- dry-run -oyaml > service-nodeport.yaml
[root@kcloud-server ~]# cat service-nodeport.yaml
apiVersion: v1
kind: Service
metadata:
  labels:
    app: service-nodeport
spec:
  ports:
  - name: 80-30001
    port: 80
    portocol: TCP
    targetPort: 30001
    nodePort: 30001
  selector:
  type: NodePort
status:
  loadBalancer: {}
[root@kcloud-server ~]# kubectl apply -f service-nodeport.yaml
10.Secrets管理--Opaque
在master节点/root目录下编写YAML文件secret.yaml,具体要求如下:
(1)Secret名称:mysecret:
(2)命名空间:default;
(3)类型:Opaque;
(4)username=YWRtaW4=;password=MWYYZDFIMmU2N2Rm。
1.将参数写入文件
将被加密后的字符串解码写入env文件中
[root@kcloud-server ~]# echo YWRtaW4= | base64 -d
admin[root@kcloud-server ~]# vim env-file.txt
[root@kcloud-server ~]# echo MWYYZDFIMmU2N2Rm | base64 -d
1f2dle2e67df[root@kcloud-server ~]# vim env-file.txt
[root@kcloud-server ~]# cat env-file.txt
username=admin
password=1f2dle2e67df
2.基于文件创建secret
[root@kcloud-server ~]# kubectl create secret generic --from-env-file env-file.txt mysecret --dry-run -oyaml > secret.yaml
[root@kcloud-server ~]# vim secret.yaml apiVersion: v1
data:
  password: MWYyZDFlMmU2N2Rm
  username: YWRtaW4=
kind: Secret
metadata:
11.NetworkPolicy管理--deny
在master节点/root目录下编写YAML文件network-policy-deny.yaml,具体要求如下:
(1)NetworkPolicy名称:default-deny:
(2)命名空间:default;
(3)默认禁止所有Pod流量;
完成后使用该YAML文件创建NetworkPolicy,并提交master节点的用户名、密码和IP到答题框。
[root@kcloud-server ~]# vim network-policy-deny.yaml
kind: NetworkPolicy
apiVersion: networking.k8s.io/v1
metadata:
  namespace: default
spec:
  policyTypes:
  - Ingress
  podSelector: {}
[root@kcloud-server ~]# kubectl apply -f network-policy-deny.yaml
12.ReplicaSet管理
在kcloud集群节点/root目录下编写YAML文件replicaset.yaml,具体要求如下:
(1)Replicaset名称:nginx:
(2)命名空间:default;
(3)副本数:3;
(4)镜像:nginx
1.基于现有的模板导入
[root@kcloud-server ~]# kubectl get rs -n kube-system coredns-79d6ff7d89 -oyaml > replicaset.yaml
2.修改模板至需要的内容
[root@kcloud-server ~]# vim replicaset.yaml
apiVersion: apps/v1
kind: ReplicaSet
metadata:
  labels:
    app: nginx
spec:
  replicas: 3
  selector:
    matchLabels:
    app: nginx
  template:
    metadata:
      labels:
      app: nginx
    spec:
      containers:
      - image: nginx
        imagePullPolicy: Always
15.HPA管理
基于资源使用率来动态调整Pod的副本,来应对突发的流量。
资源使用率是需要metrics插件来实现,监控
在kcloud集群节点/root目录下编写YAML文件hpa.yaml,具体要求如下:
(1)HPA名称:frontend-scaler;
(2)命名空间:default;
(3)副本数伸缩范围:3--10;
(4)期望每个Pod的CPU使用率为50%
1.创建deploy
创建一个deploy来被伸缩
[root@kcloud-server ~]# kubectl create deploy --image nginx --port 80 nginx --dry-run -oyaml > hpa.yaml
2.基于deploy创建hpa
[root@kcloud-server ~]# kubectl autoscale deploy nginx frontend-scaler --min 3 --max 10 --cpu-percent=50 --dry-run -oyaml >> hpa.yaml
3.修改hpa文件
[root@kcloud-server ~]# vim hpa.yaml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: nginx
spec:
  replicas: 1
  selector:
    matchLabels:
    app: nginx
  strategy: {}
  template:
    metadata:
      labels:
        app:nginx
    spec:
      containers:
      - image: nginx
      ports:
      - containerPort: 80
apiVersion: autoscaling/v1
kind: HorizontalPodAutoscaler
metadata:
spec:
  maxReplicas:10
  minReplicas:3
  scaleTargetRef:
    apiVersion: apps/v1
    kind: Deployment
  targetCPUUtilizationPercentage: 50
4.部署
[root@kcloud-server ~]# kubectl apply -f hpa.yaml
5.观察
Pod由1个副本变成了3个副本(hpa要求的最低副本数量)
如果集群中有监控插件,且Pod的cpu使用率大于了50%那么就会产生一个新的Pod
KubeEdge边缘计算
1.KubeEdge简介
ServiceBus:接收云上服务请求和边缘应用进行http交互
2.KubeEdge云端节点部署
KubeEdge运行依赖Kubernetes环境 需要k8s上层搭建平台
KubeEdge中管理边缘节点就和K8s管理普通节点一般简单
1.基础环境准备
云端K8S需要大于2C4G
在本地创建两台Ubuntu22.04的机器 用于下载本地的部署包 上传至云端节点进行K8s与KubeEdge的部署
Ubuntu操作系统使用ubuntu登录 第一次登录需要修改密码
修改好主机名方便后期辨识
下载软件包
本地Ubuntu操作
2.Cloudcore部署
准备文件
[root@chinaskill-node-1 ~]# unzip kubernetes1.22_kubeedge-1.1.11.zip
Archive:  kubernetes1.22_kubeedge-1.1.11.zip
  inflating: kubernetes_kubeedge/checksum_kubeedge-v1.11.1-linux-amd64.tar.gz.txt
  inflating: kubernetes_kubeedge/keadm-v1.11.1-linux-amd64.tar.gz
  inflating: kubernetes_kubeedge/kubeedge-1.11.1.tar.gz
  inflating: kubernetes_kubeedge/kubeedge-v1.11.1-linux-amd64.tar.gz
[root@chinaskill-node-1 ~]# ll
-rw-r--r-- 1 root root  108923797 Apr  9 14:59 kubernetes1.22_kubeedge-1.1.11.zip
drwxr-xr-x 2 root root       4096 Apr  9 15:32 kubernetes_kubeedge
[root@chinaskill-node-1 ~]# cd kubernetes_kubeedge
[root@chinaskill-node-1 kubernetes_kubeedge]# ll
total 107216
-rw-r--r-- 1 root root      129 Apr 17  2023 checksum_kubeedge-v1.11.1-linux-amd64.tar.gz.txt
-rw-r--r-- 1 root root 20634490 Apr 17  2023 keadm-v1.11.1-linux-amd64.tar.gz
-rw-r--r-- 1 root root 22559484 Apr 17  2023 kubeedge-1.11.1.tar.gz
-rw-r--r-- 1 root root 66587649 Apr 17  2023 kubeedge-v1.11.1-linux-amd64.tar.gz
[root@chinaskill-node-1 kubernetes_kubeedge]# tar -zxvf keadm-v1.11.1-linux-amd64.tar.gz
keadm-v1.11.1-linux-amd64/
keadm-v1.11.1-linux-amd64/keadm/
keadm-v1.11.1-linux-amd64/keadm/keadm
keadm-v1.11.1-linux-amd64/version
total 107220
drwxr-xr-x 3 1001  116     4096 Jul 11  2022 keadm-v1.11.1-linux-amd64
[root@chinaskill-node-1 kubernetes_kubeedge]# cp -r keadm-v1.11.1-linux-amd64/keadm/keadm /usr/local/bin/
[root@chinaskill-node-1 kubernetes_kubeedge]# mkdir /etc/kubeedge
total 107220
[root@chinaskill-node-1 kubernetes_kubeedge]# cp checksum_kubeedge-v1.11.1-linux-amd64.tar.gz.txt kubeedge-1.11.1.tar.gz kubeedge-v1.11.1-linux-amd64.tar.gz /etc/kubeedge
[root@chinaskill-node-1 kubernetes_kubeedge]# tar -zxvf kubeedge-1.11.1.tar.gz
total 107224
drwxrwxr-x 20 root root     4096 Jul 11  2022 kubeedge-1.11.1
[root@chinaskill-node-1 kubernetes_kubeedge]# cp -r kubeedge-1.11.1/build/crds /etc/kubeedge/
安装
[root@chinaskill-node-1 kubeedge]# keadm deprecated init --advertise-address 47.97.171.61 --kubeedge-version 1.11.1 --tarballpath /etc/kubeedge
Kubernetes version verification passed, KubeEdge installation will start...
keadm will install 1.11 CRDs
Expected or Default KubeEdge version 1.11.1 is already downloaded and will checksum for it.
kubeedge-v1.11.1-linux-amd64.tar.gz checksum:
checksum_kubeedge-v1.11.1-linux-amd64.tar.gz.txt content:
Expected or Default checksum file checksum_kubeedge-v1.11.1-linux-amd64.tar.gz.txt is already downloaded.
keadm will download version 1.11 service file
[Run as service] start to download service file for cloudcore
[Run as service] success to download service file for cloudcore
kubeedge-v1.11.1-linux-amd64/
kubeedge-v1.11.1-linux-amd64/edge/
kubeedge-v1.11.1-linux-amd64/edge/edgecore
kubeedge-v1.11.1-linux-amd64/version
kubeedge-v1.11.1-linux-amd64/cloud/
kubeedge-v1.11.1-linux-amd64/cloud/csidriver/
kubeedge-v1.11.1-linux-amd64/cloud/csidriver/csidriver
kubeedge-v1.11.1-linux-amd64/cloud/iptablesmanager/
kubeedge-v1.11.1-linux-amd64/cloud/iptablesmanager/iptablesmanager
kubeedge-v1.11.1-linux-amd64/cloud/cloudcore/
kubeedge-v1.11.1-linux-amd64/cloud/cloudcore/cloudcore
kubeedge-v1.11.1-linux-amd64/cloud/controllermanager/
kubeedge-v1.11.1-linux-amd64/cloud/controllermanager/controllermanager
kubeedge-v1.11.1-linux-amd64/cloud/admission/
kubeedge-v1.11.1-linux-amd64/cloud/admission/admission
KubeEdge cloudcore is running, For logs visit:  /var/log/kubeedge/cloudcore.log
CloudCore started
查看端口是否启动成功
[root@chinaskill-node-1 kubeedge]# netstat -ntpl
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:30080           0.0.0.0:*               LISTEN      9330/kube-proxy
tcp        0      0 0.0.0.0:30081           0.0.0.0:*               LISTEN      9330/kube-proxy
tcp        0      0 0.0.0.0:13379           0.0.0.0:*               LISTEN      9330/kube-proxy
tcp        0      0 127.0.0.1:10248         0.0.0.0:*               LISTEN      8361/kubelet
tcp        0      0 127.0.0.1:10249         0.0.0.0:*               LISTEN      9330/kube-proxy
tcp        0      0 127.0.0.1:35113         0.0.0.0:*               LISTEN      8361/kubelet
tcp        0      0 172.18.64.198:2379      0.0.0.0:*               LISTEN      7984/etcd
tcp        0      0 127.0.0.1:2379          0.0.0.0:*               LISTEN      7984/etcd
tcp        0      0 172.18.64.198:2380      0.0.0.0:*               LISTEN      7984/etcd
tcp        0      0 127.0.0.1:2381          0.0.0.0:*               LISTEN      7984/etcd
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      573/rpcbind
tcp        0      0 0.0.0.0:52885           0.0.0.0:*               LISTEN      9330/kube-proxy
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      4727/sshd
tcp        0      0 0.0.0.0:30776           0.0.0.0:*               LISTEN      9330/kube-proxy
tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      1098/master
tcp        0      0 0.0.0.0:30779           0.0.0.0:*               LISTEN      9330/kube-proxy
tcp6       0      0 :::10250                :::*                    LISTEN      8361/kubelet
tcp6       0      0 :::6443                 :::*                    LISTEN      7921/kube-apiserver
tcp6       0      0 :::111                  :::*                    LISTEN      573/rpcbind
tcp6       0      0 :::10000                :::*                    LISTEN      22141/cloudcore
tcp6       0      0 :::10256                :::*                    LISTEN      9330/kube-proxy
tcp6       0      0 :::10257                :::*                    LISTEN      7879/kube-controlle
tcp6       0      0 :::10002                :::*                    LISTEN      22141/cloudcore
tcp6       0      0 :::10259                :::*                    LISTEN      7920/kube-scheduler
tcp6       0      0 :::22                   :::*                    LISTEN      4727/sshd
tcp6       0      0 ::1:25                  :::*                    LISTEN      1098/master
tcp6       0      0 :::4443                 :::*                    LISTEN      10368/metrics-serve
修改配置文件
[root@chinaskill-node-1 kubeedge]# vim /etc/kubeedge/config/cloudcore.yaml
105 router:
106     address: 0.0.0.0
107     enable: true
停止默认进程
[root@chinaskill-node-1 kubeedge]# pkill cloudcore.service
使用systemctl管理
[root@chinaskill-node-1 kubeedge]# cp cloudcore.service /etc/systemd/system/
[root@chinaskill-node-1 kubeedge]# systemctl enable --now cloudcore.service
Created symlink from /etc/systemd/system/multi-user.target.wants/cloudcore.service to /etc/systemd/system/cloudcore.service.
3.Kubeedge边缘节点部署
安装Docker
1.直接安装(Euler操作系统)
[root@chinaskill-node-1 kubeedge]# yum repolist
[root@chinaskill-node-1 kubeedge]# yum repolist all
[root@chinaskill-node-1 kubeedge]# yum install -y docker
[root@chinaskill-node-1 kubeedge]# docker -v
[root@chinaskill-node-1 kubeedge]# systemctl start docker
2.Yum源安装
[root@chinaskill-node-1 kubeedge]# vi /etc/yum.repos.d/docker.repo
[docker]
name=docker
baseurl=file:///root/yum
gpgcheck=0
enabled=1
#若报错看看是不是有原来的源没删 [root@chinaskill-node-1 kubeedge]# yum makecache
[root@chinaskill-node-1 kubeedge]# yum install -y docker-ce
安装边缘节点
1.找到keadm文件
[root@chinaskill-node-2 bin]# cd /root/kubeedge
[root@chinaskill-node-2 kubeedge]# ll
total 403M
-rw-r--r-- 1 root root  52M Apr 17  2023 cloudcore.tar
-rw-r--r-- 1 root root 191M Apr 17  2023 installation.tar
-rwxr-xr-x 1 1001  116  65M Jul 11  2022 keadm
-rw-r--r-- 1 root root  22M Apr 17  2023 kubeedge-1.11.1.tar.gz
-rw-r--r-- 1 root root  64M Apr 17  2023 kubeedge-v1.11.1-linux-amd64.tar.gz
-rw-r--r-- 1 root root  12M Apr 17  2023 mosquitto.tar
-rw-r--r-- 1 root root 705K Apr 17  2023 pause.tar
[root@chinaskill-node-2 kubeedge]# cp -r keadm /usr/local/bin
2.拉取docker镜像
[root@chinaskill-node-2 kubeedge]# docker load -i mosquitto.tar
9733ccc39513: Loading layer [==================================================>]  5.895MB/5.895MB
10c384d6e3d1: Loading layer [==================================================>]  6.256MB/6.256MB
bf05e19817c3: Loading layer [==================================================>]  2.048kB/2.048kB
Loaded image: eclipse-mosquitto:1.6.15
3.将文件放到指定目录
[root@chinaskill-node-2 kubeedge]# mkdir /etc/kubeedge
total 403M
[root@chinaskill-node-2 kubeedge]# cp checksum_kubeedge-v1.11.1-linux-amd64.tar.gz.txt kubeedge-1.11.1.tar.gz kubeedge-v1.11.1-linux-amd64.tar.gz /etc/kubeedge
[root@chinaskill-node-2 kubeedge]# tar -zxvf kubeedge-1.11.1.tar.gz
[root@chinaskill-node-2 kubeedge]# cp -r kubeedge-1.11.1/build/crds /etc/kubeedge
4.云端节点获取token
[root@chinaskill-node-1 kubeedge]# keadm gettoken
5dd5d8a8c6155c66586c6fb9cd3791c55537d8e2924659296d46b5a486205c41.eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE3NDQyNzM5MTB9.-WxJHfhey0rpuktweFqupOYA6LcWSkKkVRJ8ciWjwTs
5.边缘节点加入
[root@chinaskill-node-1 kubeedge]# keadm deprecated join --cloudcore-ipport 47.97.171.61:10000 --kubeedge-version 1.11.1 --token 5dd5d8a8c6155c66586c6fb9cd3791c55537d8e2924659296d46b5a486205c41.eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE3NDQyNzYyNDB9.S8P6IaiY22Q14Tr5HyR9g2GTMJ3uVlwcYULxEFq5PX8 --image-repository docker.io
install MQTT service successfully.
[Run as service] service file already exisits in /etc/kubeedge//edgecore.service, skip download
6.查看状态
[root@chinaskill-node-2 kubeedge]# systemctl status edgecore
● edgecore.service
   Loaded: loaded (/etc/systemd/system/edgecore.service; enabled; vendor preset: disabled)
   Active: active (running) since Wed 2025-04-09 17:14:24 CST; 4min 42s ago
 Main PID: 6701 (edgecore)
    Tasks: 11
   Memory: 26.6M
   CGroup: /system.slice/edgecore.service
           └─6701 /usr/local/bin/edgecore
Apr 09 17:18:50 chinaskill-node-2 edgecore[6701]: I0409 17:18:50.206996    6701 record.go:24] Warning FailedCreatePodSandBox Failed to create pod sandbox: rpc error: code = Unkn...
Apr 09 17:18:50 chinaskill-node-2 edgecore[6701]: E0409 17:18:50.207070    6701 edged.go:1011] worker [0] handle pod addition item [kube-flannel-ds-jztzf] failed: sync...sandbox fo
Apr 09 17:18:55 chinaskill-node-2 edgecore[6701]: W0409 17:18:55.592459    6701 context_channel.go:159] Get bad anonName:ac40112e-d11b-4f77-a260-a4058e6fff26 when send...do nothing
Apr 09 17:19:00 chinaskill-node-2 edgecore[6701]: I0409 17:19:00.200356    6701 edged.go:992] worker [1] get pod addition item [kube-proxy-4j5b8]
Apr 09 17:19:00 chinaskill-node-2 edgecore[6701]: E0409 17:19:00.200421    6701 edged.go:995] consume pod addition backoff: Back-off consume pod [kube-proxy-4j5b8] add...f: [2m40s]
Apr 09 17:19:00 chinaskill-node-2 edgecore[6701]: I0409 17:19:00.200466    6701 edged.go:997] worker [1] backoff pod addition item [kube-proxy-4j5b8] failed, re-add to queue
Apr 09 17:19:00 chinaskill-node-2 edgecore[6701]: I0409 17:19:00.207521    6701 edged.go:992] worker [2] get pod addition item [kube-flannel-ds-jztzf]
Apr 09 17:19:00 chinaskill-node-2 edgecore[6701]: E0409 17:19:00.207549    6701 edged.go:995] consume pod addition backoff: Back-off consume pod [kube-flannel-ds-jztzf...f: [2m40s]
Apr 09 17:19:00 chinaskill-node-2 edgecore[6701]: I0409 17:19:00.207599    6701 edged.go:997] worker [2] backoff pod addition item [kube-flannel-ds-jztzf] failed, re-add to queue
Apr 09 17:19:05 chinaskill-node-2 edgecore[6701]: W0409 17:19:05.618416    6701 context_channel.go:159] Get bad anonName:c4bc73a8-ef1d-4ada-8700-c186bbd26117 when send...do nothing
Hint: Some lines were ellipsized, use -l to show in full.
7.云端节点检验
[root@chinaskill-node-1 kubeedge]# kubectl get nodes
NAME                STATUS   ROLES                         AGE    VERSION
default-edge-node   Ready    agent,edge                    2m7s   v1.22.6-kubeedge-v1.11.1
k8s-master-node1    Ready    control-plane,master,worker   128m   v1.22.1
8.可能报错的解决方案
vi /etc/docker/daemon.json
"exec-opts": ["native.cgroupdriver=cgroupfs"]
systemctl daemon-reload
systemctl restart docker
