Mybatis入门案例搭建
一颗小谷粒 发表于 2025/03/31 16:35:59 2025/03/31
【摘要】 环境搭建、数据库配置、实体类创建、Mapper 接口与 XML 文件编写以及测试代码1. 项目初始化首先创建一个 Maven 项目,在pom.xml文件里添加 MyBatis 和 MySQL 的依赖:<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLS...
1. 项目初始化
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>com.example</groupId>
    <artifactId>mybatis-demo</artifactId>
    <version>1.0-SNAPSHOT</version>
    <dependencies>
        <!-- MyBatis -->
        <dependency>
            <groupId>org.mybatis</groupId>
            <artifactId>mybatis</artifactId>
            <version>3.5.10</version>
        </dependency>
        <!-- MySQL Connector -->
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
            <version>8.0.26</version>
        </dependency>
    </dependencies>
</project>
2. 数据库准备
创建一个名为test的数据库,并且在其中创建一张users表:
CREATE DATABASE test;
USE test;
CREATE TABLE users (
    id INT PRIMARY KEY AUTO_INCREMENT,
    name VARCHAR(50),
    age INT
3. 创建实体类
在src/main/java目录下创建com.example.entity包,并且在其中创建User类:
package com.example.entity;
public class User {
    private Integer id;
    private String name;
    private Integer age;
    // Getters and Setters
    public Integer getId() {
        return id;
    public void setId(Integer id) {
        this.id = id;
    public String getName() {
        return name;
    public void setName(String name) {
        this.name = name;
    public Integer getAge() {
        return age;
    public void setAge(Integer age) {
        this.age = age;
    @Override
    public String toString() {
        return "User{" +
                "id=" + id +
                ", name='" + name + '\'' +
                ", age=" + age +
4. 创建 Mapper 接口
在src/main/java目录下创建com.example.mapper包,并且在其中创建UserMapper接口:
package com.example.mapper;
import com.example.entity.User;
import java.util.List;
public interface UserMapper {
    List<User> getAllUsers();
5. 创建 Mapper XML 文件
在src/main/resources目录下创建com/example/mapper目录,并且在其中创建UserMapper.xml文件:
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE mapper
        PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
        "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.example.mapper.UserMapper">
    <select id="getAllUsers" resultType="com.example.entity.User">
        SELECT * FROM users
    </select>
</mapper>
6. 配置 MyBatis
在src/main/resources目录下创建mybatis-config.xml文件:
<!DOCTYPE configuration
        PUBLIC "-//mybatis.org//DTD Config 3.0//EN"
        "http://mybatis.org/dtd/mybatis-3-config.dtd">
<configuration>
    <environments default="development">
        <environment id="development">
            <transactionManager type="JDBC"/>
            <dataSource type="POOLED">
                <property name="driver" value="com.mysql.cj.jdbc.Driver"/>
                <property name="url" value="jdbc:mysql://localhost:3306/test?useSSL=false&serverTimezone=UTC"/>
                <property name="username" value="root"/>
                <property name="password" value="your_password"/>
            </dataSource>
        </environment>
    </environments>
    <mappers>
        <mapper resource="com/example/mapper/UserMapper.xml"/>
    </mappers>
</configuration>
7. 编写测试代码
在src/test/java目录下创建com.example.test包,并且在其中创建MyBatisTest类:
package com.example.test;
import com.example.mapper.UserMapper;
import org.apache.ibatis.io.Resources;
import org.apache.ibatis.session.SqlSession;
import org.apache.ibatis.session.SqlSessionFactory;
import org.apache.ibatis.session.SqlSessionFactoryBuilder;
import java.io.InputStream;
public class MyBatisTest {
    public static void main(String[] args) throws Exception {
        // 加载MyBatis配置文件
        String resource = "mybatis-config.xml";
        InputStream inputStream = Resources.getResourceAsStream(resource);
        SqlSessionFactory sqlSessionFactory = new SqlSessionFactoryBuilder().build(inputStream);
        // 获取SqlSession
        try (SqlSession session = sqlSessionFactory.openSession()) {
            // 获取Mapper接口实例
            UserMapper userMapper = session.getMapper(UserMapper.class);
            // 调用Mapper方法
            List<User> users = userMapper.getAllUsers();
            // 输出结果
            for (User user : users) {
                System.out.println(user);
