【HarmonyOS NEXT】如何读取Raw下的JSON文件内容
GeorgePanda 发表于 2025/03/28 21:25:18 2025/03/28
【摘要】 【HarmonyOS NEXT】如何读取Raw下的JSON文件内容 一、问题背景:读取工程中/resources下json文件,json文件推荐放在rawfile路径下,通过getRawFileContent接口访问。但是通过该接口拿到的是Uint8Array类型数据,那怎么拿到JSON的文本内容? 二、解决方案:1.首先通过getRawFileContent拿到文件的字节流内容。 ge...
一、问题背景:
二、解决方案:
  getContext().resourceManager.getRawFileContent("vibration.json")
2.通过util.TextDecoder设置编码,解析字节流内容转化为string文本。
import { util, buffer } from '@kit.ArkTS';
        let decoder = util.TextDecoder.create('utf-8');
        let json = decoder.decodeToString(rawFile);
三、源码示例:
JSONTestPage.ets
import { BusinessError } from '@kit.BasicServicesKit';
@Entry
@Component
struct JSONTestPage {
  private TAG: string = "JSONTestPage";
  @State showText: string = "";
  aboutToAppear(): void {
    this.getRawJson();
   * 获取JSON
  private getRawJson(){
    try {
      getContext().resourceManager.getRawFileContent("vibration.json").then((value: Uint8Array) => {
        let rawFile = value;
        console.info(this.TAG, "json: " + json);
        this.showText = json;
      }).catch((error: BusinessError) => {
        console.error("getRawFileContent promise error is " + error);
    } catch (error) {
      let code = (error as BusinessError).code;
      let message = (error as BusinessError).message;
      console.error(`promise getRawFileContent failed, error code: ${code}, message: ${message}.`);
  build() {
    Scroll(){
      Row() {
        Text(this.showText)
          .fontSize(50)
          .fontWeight(FontWeight.Bold)
    .height('100%')
    .width('100%')
vibration.json
  "MetaData": {
    "Create": "2023-01-09",
    "Description": "a haptic case",
    "Version": 1.0,
    "ChannelNumber": 1
  "Channels": [
      "Parameters": {
        "Index": 0
      "Pattern": [
          "Event": {
            "Type": "transient",
            "StartTime": 0,
            "Parameters": {
              "Frequency": 31,
              "Intensity": 100
          "Event": {
            "Type": "continuous",
            "StartTime": 40,
            "Duration": 54,
            "Parameters": {
              "Frequency": 30,
              "Intensity": 38,
              "Curve": [
                  "Time": 0,
                  "Frequency": 0,
                  "Intensity": 0
                  "Time": 1,
                  "Frequency": 15,
                  "Intensity": 0.5
                  "Time": 40,
                  "Frequency": -8,
                  "Intensity": 1.0
                  "Time": 54,
                  "Frequency": 0,
                  "Intensity": 0
