HarmonyOS NEXT 长时任务的学习和总结
水滴石轩 发表于 2025/03/09 16:46:04 2025/03/09
【摘要】 想要使用鸿蒙的长时任务需要配置权限:ohos.permission.KEEP_BACKGROUND_RUNNING并在module.json5中配置需要处理的长时任务类型,此处以定位为例: { ... "backgroundModes": [ // 长时任务类型的配置项 "location" ] ...
          // 长时任务类型的配置项
          "location"
然后再合适的地方调用startBackgroundRunning方法开启长时任务,通过调用stopBackgroundRunning方法关闭长时任务
具体代码如下:
import { common, wantAgent, WantAgent } from '@kit.AbilityKit';
import { BusinessError } from '@kit.BasicServicesKit';
import { CSLogger } from './CSLogger';
const TAG: string = 'CSBackgroundTask';
export function startContinuousTask(context: common.UIAbilityContext) {
  let wantAgentInfo: wantAgent.WantAgentInfo = {
    // 点击通知后,将要执行的动作列表
    // 添加需要被拉起应用的bundleName和abilityName
    wants: [
        bundleName: "com.example.csharmonyosdemo",
        abilityName: "EntryAbility"
    // 指定点击通知栏消息后的动作是拉起ability
    actionType: wantAgent.OperationType.START_ABILITY,
    // 使用者自定义的一个私有值
    requestCode: 0,
    // 点击通知后,动作执行属性
    actionFlags: [wantAgent.WantAgentFlags.UPDATE_PRESENT_FLAG]
  try {
    // 通过wantAgent模块下getWantAgent方法获取WantAgent对象
    wantAgent.getWantAgent(wantAgentInfo).then((wantAgentObj: WantAgent) => {
      try {
        let list: Array<string> = ["location"];
        backgroundTaskManager.startBackgroundRunning(context, list, wantAgentObj).then((res: backgroundTaskManager.ContinuousTaskNotification) => {
          CSLogger.info(TAG, "Operation startBackgroundRunning succeeded");
          // 此处执行具体的长时任务逻辑,如录音,录制等。
          setInterval(() => {
            CSLogger.info(TAG, "backgroundRunning task continue");
          }, 1000*60);
        }).catch((error: BusinessError) => {
          CSLogger.info(TAG, `Failed to Operation startBackgroundRunning. code is ${error.code} message is ${error.message}`);
      } catch (error) {
        CSLogger.info(TAG, `Failed to Operation startBackgroundRunning. code is ${(error as BusinessError).code} message is ${(error as BusinessError).message}`);
  } catch (error) {
    CSLogger.info(TAG, `Failed to Operation getWantAgent. code is ${(error as BusinessError).code} message is ${(error as BusinessError).message}`);
export function stopContinuousTask(context: common.UIAbilityContext) {
  backgroundTaskManager.stopBackgroundRunning(context).then(() => {
    CSLogger.info(TAG, `Succeeded in operationing stopBackgroundRunning.`);
  }).catch((err: BusinessError) => {
    CSLogger.info(TAG, `Failed to operation stopBackgroundRunning. Code is ${err.code}, message is ${err.message}`);
此处CSLogger是自定义日志工具,详情可以查看我的其他文章
----------------- end ---------------
后面会继续补充不足之处。
