探索极地奥秘:Pre-IceBridge ATM L1B Qfit Elevation and Return Strength
此星光明 发表于 2025/02/27 13:53:05 2025/02/27
【摘要】 ​Pre-IceBridge ATM L1B Qfit Elevation and Return Strength V001简介Pre-IceBridge ATM L1B Qfit Elevation and Return Strength V001数据集包含了由美国国家航空航天局(NASA)在冰桥任务(IceBridge)之前使用大气透明计量(ATM)雷达收集的数据。该数据集提供了大气透明...
简介
Pre-IceBridge ATM L1B Qfit Elevation and Return Strength V001数据集包含了由美国国家航空航天局(NASA)在冰桥任务(IceBridge)之前使用大气透明计量(ATM)雷达收集的数据。该数据集提供了大气透明计量雷达观测到的冰盖表面高程和回波强度信息。这些数据对于研究极地冰盖的地形特征、冰盖厚度以及冰盖变化具有重要意义。研究人员和科学家可以利用这些数据来分析极地地区的冰盖演变过程,推动气候变化研究以及生态系统监测工作。
摘要
This data set contains spot elevation measurements of Arctic, Greenland, Antarctic, and Patagonia sea ice and ice surface acquired using the NASA Airborne Topographic Mapper (ATM) instrumentation.
Parameter(s):
GLACIER ELEVATION/ICE SHEET ELEVATION
Platform(s):
DHC-6, NASA DC-8, P-3A, P-3A ORION, P-3B
Sensor(s):
ATM
Data Format(s):
Binary, Binary
Temporal Coverage:
23 June 1993 to 30 October 2008
Temporal Resolution:
  • Varies
Spatial Resolution:
  • varies
  • varies
Spatial Reference System(s):
WGS 84
EPSG:4326
代码
!pip install leafmap
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data/raw/main/nasa_earth_data.tsv"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="BLATM1B",
    cloud_hosted=True,
    bounding_box=(-180.0, 60.0, 180.0, 90.0),
    temporal=("1993-06-23", "2008-10-30"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
网址推荐
 知识星球
知识星球 | 深度连接铁杆粉丝,运营高品质社群,知识变现的工具 (zsxq.com)https://wx.zsxq.com/group/48888525452428
机器学习
https://www.cbedai.net/xg
干旱监测平台
慧天干旱监测与预警-首页https://www.htdrought.com/
