java 动态添加Scheduled
8181暴风雪 发表于 2025/01/21 19:48:04 2025/01/21
【摘要】 在Java中,动态添加​​@Scheduled​​​任务通常涉及到Spring的​​TaskScheduler​​​接口和​​ScheduledExecutorService​​。以下是一个示例,展示了如何在运行时动态添加和删除定时任务。1. 创建Spring Boot项目首先,确保你的Spring Boot项目中已经添加了​​spring-boot-starter​​​和​​spring-...
1. 创建Spring Boot项目
首先,确保你的Spring Boot项目中已经添加了​​spring-boot-starter​​​和​​spring-boot-starter-web​​依赖。
2. 配置​​TaskScheduler​​
在Spring配置类中配置​​TaskScheduler​​:
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.scheduling.concurrent.ThreadPoolTaskScheduler;
@Configuration
public class SchedulerConfig {
    @Bean
    public ThreadPoolTaskScheduler taskScheduler() {
        ThreadPoolTaskScheduler scheduler = new ThreadPoolTaskScheduler();
        scheduler.setPoolSize(10);
        scheduler.setThreadNamePrefix("MyScheduler-");
        scheduler.setDaemon(true);
        return scheduler;
3. 创建动态任务管理器
创建一个类来管理动态添加和删除的任务:
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.scheduling.TaskScheduler;
import org.springframework.scheduling.support.CronTrigger;
import org.springframework.stereotype.Service;
import java.util.HashMap;
import java.util.Map;
import java.util.concurrent.ScheduledFuture;
@Service
public class DynamicTaskService {
    @Autowired
    private TaskScheduler taskScheduler;
    private final Map<String, ScheduledFuture<?>> scheduledTasks = new HashMap<>();
    public void addTask(String taskId, Runnable task, String cronExpression) {
        ScheduledFuture<?> future = taskScheduler.schedule(task, new CronTrigger(cronExpression));
        scheduledTasks.put(taskId, future);
    public void removeTask(String taskId) {
        ScheduledFuture<?> future = scheduledTasks.get(taskId);
        if (future != null) {
            future.cancel(true);
            scheduledTasks.remove(taskId);
4. 创建一个示例任务
创建一个简单的任务类:
import org.springframework.stereotype.Component;
@Component
public class SampleTask implements Runnable {
    private String taskId;
    public SampleTask(String taskId) {
        this.taskId = taskId;
    @Override
    public void run() {
        System.out.println("Executing task: " + taskId + " at " + System.currentTimeMillis());
5. 创建控制器来管理任务
创建一个REST控制器来动态添加和删除任务:
import org.springframework.web.bind.annotation.*;
@RestController
@RequestMapping("/tasks")
public class TaskController {
    @Autowired
    private DynamicTaskService dynamicTaskService;
    @PostMapping
    public String addTask(@RequestParam String taskId, @RequestParam String cronExpression) {
        SampleTask task = new SampleTask(taskId);
        dynamicTaskService.addTask(taskId, task, cronExpression);
        return "Task added: " + taskId;
    @DeleteMapping("/{taskId}")
    public String removeTask(@PathVariable String taskId) {
        dynamicTaskService.removeTask(taskId);
        return "Task removed: " + taskId;
6. 启动Spring Boot应用
启动你的Spring Boot应用,并使用HTTP请求来动态添加和删除任务。
示例请求
  • 添加任务:
curl -X POST "http://localhost:8080/tasks?taskId=myTask1&cronExpression=0/10 * * * * ?"
  • 删除任务:
curl -X DELETE "http://localhost:8080/tasks/myTask1"
关键点
  • ​​TaskScheduler​​​: 使用Spring的​​TaskScheduler​​接口来调度任务。
  • ​​CronTrigger​​​: 使用​​CronTrigger​​来定义任务的执行频率。
  • ​​ScheduledFuture​​​: 使用​​ScheduledFuture​​来管理任务的执行状态,并支持取消任务。
通过以上步骤,你可以在Spring Boot应用中动态地添加和删除定时任务,提供了灵活的任务管理能力。
