【Spring Boot】 SpringBoot自动装配-Condition
Ninja之路 发表于 2024/12/20 21:10:49 2024/12/20
【摘要】 @TOC 一、前言@Conditional注解在Spring4.0中引入,其主要作用就是判断条件是否满足,从而决定是否初始化并向容器注册Bean。 二、 定义 2.1 @Conditional@Conditional注解定义如下:其内部只有一个参数为Class对象数组,且必须继承自Condition接口,通过重写Condition接口的matches方法来判断是否需要加载Bean@Tar...
@TOC
一、前言
二、 定义
2.1 @Conditional
@Target({ElementType.TYPE, ElementType.METHOD})
@Retention(RetentionPolicy.RUNTIME)
@Documented
public @interface Conditional {
  Class<? extends Condition>[] value();
2.2 Condition
Condition接口定义如下:该接口为一个函数式接口,只有一个matches接口,形参为ConditionContext context, AnnotatedTypeMetadata metadata。ConditionContext定义如2.2.1,AnnotatedTypeMetadata见名知意,就是用来获取注解的元信息的
@FunctionalInterface
public interface Condition {
  boolean matches(ConditionContext context, AnnotatedTypeMetadata metadata);
2.2.1 ConditionContext
ConditionContext接口定义如下:通过查看源码可以知道,从这个类中可以获取很多有用的信息
public interface ConditionContext {
   * 返回Bean定义信息
   * Return the {@link BeanDefinitionRegistry} that will hold the bean definition
   * should the condition match.
   * @throws IllegalStateException if no registry is available (which is unusual:
   * only the case with a plain {@link ClassPathScanningCandidateComponentProvider})
  BeanDefinitionRegistry getRegistry();
   * 返回Bean工厂
   * Return the {@link ConfigurableListableBeanFactory} that will hold the bean
   * definition should the condition match, or {@code null} if the bean factory is
   * not available (or not downcastable to {@code ConfigurableListableBeanFactory}).
  @Nullable
  ConfigurableListableBeanFactory getBeanFactory();
   * 返回环境变量 比如在application.yaml中定义的信息
   * Return the {@link Environment} for which the current application is running.
  Environment getEnvironment();
   * 返回资源加载器
   * Return the {@link ResourceLoader} currently being used.
  ResourceLoader getResourceLoader();
   * 返回类加载器
   * Return the {@link ClassLoader} that should be used to load additional classes
   * (only {@code null} if even the system ClassLoader isn't accessible).
   * @see org.springframework.util.ClassUtils#forName(String, ClassLoader)
  @Nullable
  ClassLoader getClassLoader();
三、 使用说明
通过一个简单的小例子测试一下@Conditional是不是真的能实现Bean的条件化注入。
3.1 创建项目
首先我们创建一个SpringBoot项目
3.1.1 导入依赖
这里我们除了springboot依赖,再添加个lombok依赖
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.5.3</version>
        <relativePath/> <!-- lookup parent from repository -->
    </parent>
    <groupId>com.ldx</groupId>
    <artifactId>condition</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <name>condition</name>
    <description>Demo project for Spring Boot</description>
    <properties>
        <java.version>1.8</java.version>
    </properties>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter</artifactId>
        </dependency>
        <dependency>
            <groupId>org.projectlombok</groupId>
            <artifactId>lombok</artifactId>
            <version>1.18.12</version>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
            </plugin>
        </plugins>
    </build>
</project>
3.1.2 添加配置信息
在application.yaml 中加入配置信息
user:
  enable: false
3.1.3 创建User类
package com.ldx.condition;
import lombok.AllArgsConstructor;
import lombok.Data;
 * 用户信息
 * @author ludangxin
 * @date 2021/8/1
@Data
@AllArgsConstructor
public class User {
   private String name;
   private Integer age;
3.1.4 创建条件实现类
import org.springframework.context.annotation.Condition;
import org.springframework.context.annotation.ConditionContext;
import org.springframework.core.env.Environment;
import org.springframework.core.type.AnnotatedTypeMetadata;
 * 用户bean条件判断
 * @author ludangxin
 * @date 2021/8/1
public class UserCondition implements Condition {
   @Override
   public boolean matches(ConditionContext conditionContext, AnnotatedTypeMetadata annotatedTypeMetadata) {
      Environment environment = conditionContext.getEnvironment();
      // 获取property user.enable
      String property = environment.getProperty("user.enable");
      // 如果user.enable的值等于true 那么返回值为true,反之为false
      return "true".equals(property);
3.1.5 修改启动类
import lombok.extern.slf4j.Slf4j;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
import org.springframework.context.ConfigurableApplicationContext;
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Conditional;
@Slf4j
@SpringBootApplication
public class ConditionApplication {
      ConfigurableApplicationContext applicationContext = SpringApplication.run(ConditionApplication.class, args);
      // 获取类型为User类的Bean
      User user = applicationContext.getBean(User.class);
      log.info("user bean === {}", user);
   * 注入User类型的Bean
   @Bean
   @Conditional(UserCondition.class)
   public User getUser(){
      return new User("张三",18);
3.2 测试
3.2.1 当user.enable=false
报错找不到可用的User类型的Bean
  .   ____          _            __ _ _
 /\\ / ___'_ __ _ _(_)_ __  __ _ \ \ \ \
( ( )\___ | '_ | '_| | '_ \/ _` | \ \ \ \
 \\/  ___)| |_)| | | | | || (_| |  ) ) ) )
  '  |____| .__|_| |_|_| |_\__, | / / / /
 =========|_|==============|___/=/_/_/_/
 :: Spring Boot ::                (v2.5.3)
Exception in thread "main" org.springframework.beans.factory.NoSuchBeanDefinitionException: No qualifying bean of type 'com.ldx.condition.User' available
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBean(DefaultListableBeanFactory.java:351)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBean(DefaultListableBeanFactory.java:342)
	at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1172)
	at com.ldx.condition.ConditionApplication.main(ConditionApplication.java:16)
Process finished with exit code 1
3.2.2 当user.enable=true
正常输出UserBean实例信息
  .   ____          _            __ _ _
com.ldx.condition.ConditionApplication   : user bean === User(name=张三, age=18)
3.3 小结
上面的例子通过使用@Conditional和Condition接口,实现了spring bean的条件化注入。
好处:
  1. 可以实现某些配置的开关功能,如上面的例子,我们可以将UserBean换成开启缓存的配置,当property的值为true时,我们才开启缓存的配置
  2. 当有多个同名的bean时,如何抉择的问题。
  3. 实现自动化的装载。如判断当前classpath中有mysql的驱动类时(说明我们当前的系统需要使用mysql),我们就自动的读取application.yaml中的mysql配置,实现自动装载;当没有驱动时,就不加载。
四、改进
从上面的使用说明中我们了解到了条件注解的大概使用方法,但是代码中还是有很多硬编码的问题。比如:UserCondition中的property的key包括value都是硬编码,其实我们可以通过再扩展一个注解来实现动态的判断和绑定。
4.1 创建注解
import java.lang.annotation.*;
 * 自定义条件属性注解
 * <p>
 *   当配置的property name对应的值 与设置的 value值相等时,则注入bean
 * @author ludangxin
 * @date 2021/8/1
@Documented
// 指定condition的实现类
@Conditional({UserCondition.class})
public @interface MyConditionOnProperty {
   // 配置信息的key
   String name();
   // 配置信息key对应的值
   String value();
4.2 修改UserCondition
import java.util.Map;
 * 用户bean条件判断
 * @author ludangxin
 * @date 2021/8/1
   @Override
      // 获取自定义的注解
      Map<String, Object> annotationAttributes = annotatedTypeMetadata.getAnnotationAttributes("com.ldx.condition.MyConditionOnProperty");
      // 获取在注解中指定的name的property的值 如:user.enable的值
      String property = environment.getProperty(annotationAttributes.get("name").toString());
      // 获取预期的值
      String value = annotationAttributes.get("value").toString();
      return value.equals(property);
测试后,结果符合预期。
其实在spring中已经内置了许多常用的条件注解,其中我们刚实现的就在内置的注解中已经实现了,如下。
五、 Spring内置条件注解
注解 说明
  • @ConditionalOnSingleCandidate 当给定类型的bean存在并且指定为Primary的给定类型存在时,返回true
  • @ConditionalOnMissingBean 当给定的类型、类名、注解、昵称在beanFactory中不存在时返回true.各类型间是or的关系
  • @ConditionalOnBean 与上面相反,要求bean存
  • @ConditionalOnMissingClass 当给定的类名在类路径上不存在时返回true,各类型间是and的关系
  • @ConditionalOnClass 与上面相反,要求类存在
  • @ConditionalOnCloudPlatform 当所配置的CloudPlatform为激活时返回true
  • @ConditionalOnExpression spel表达式执行为true
  • @ConditionalOnJava 运行时的java版本号是否包含给定的版本号.如果包含,返回匹配,否则,返回不匹配
  • @ConditionalOnProperty 要求配置属性匹配条件 @ConditionalOnJndi 给定的jndi的Location必须存在一个.否则,返回不匹配
  • @ConditionalOnNotWebApplication web环境不存在时
  • @ConditionalOnWebApplication web环境存在时
  • @ConditionalOnResource 要求制定的资源存在
