Deeplabv3+昇腾适配推理验证任务心得
yd_231154117 发表于 2024/12/13 16:42:58 2024/12/13
【摘要】 首先查看任务计划书:https://onebox,huawei.com/#eSpaceGroupFile/1/46845/8932260,主要目的是将Deeplabv3+项目适配至华为的 Ascend(昇腾)处理器,确保其在这些硬件平台上的高效运行,即验证Deeplabv3能不能在 Ascend(昇腾)系统中运行。
首先查看任务计划书:https://bbs.huaweicloud.cn/blogs/439491主要目的是将Deeplabv3+项目适配至华为的 Ascend(昇腾)处理器,确保其在这些硬件平台上的高效运行,即验证模型能不能在 Ascend(昇腾)系统中运行。
验证过程
明确目的后开始熟悉项目,Deeplabv3+的github网址:https://github.com/qubvel-org/segmentation_models.pytorch
segmentation_models.pytorch的环境配置
1 资源清单
产品名称
NPU架构
CPU架构
操作系统
云堡垒机
Ascend 910B3
鲲鹏计算
Kunpeng-920
Huawei Cloud EulerOS 2.0 (aarch64)
2 验证流程
1、安装segmentation_models.pytorch依赖包
可在requirements文件夹require.txt下修改依赖包版本
efficientnet-pytorch==0.7.1
huggingface_hub==0.26.3
numpy==2.1.3
pillow==11.0.0
pretrainedmodels==0.7.4
six==1.16.0
timm==1.0.12
torch==2.5.1
torchvision==0.20.1
tqdm==4.67.1
默认没有安装opencv,需要安装python-opencv
2、安装SMP依赖项
Install SMP
make install_dev  # create .venv, install SMP in dev mode
Run tests and code checks
make fixup         # Ruff for formatting and lint checks
Update table with encoders
make table        # generate a table with encoders and print to stdout
3、安装onnxruntime
4、生成onnx模型文件并验证有效性
model = smp.DeepLabV3Plus("resnet34", encoder_weights="imagenet", classes=1)
model = model.eval()
# dynamic_axes is used to specify the variable length axes. it can be just batch size
dynamic_axes = {0: "batch_size", 2: "height", 3: "width"}
onnx_model_name = "DeepLabV3Plus_resnet34.onnx"
onnx_model = torch.onnx.export(
    model,  # model being run
    torch.randn(1, 3, 224, 224),  # model input
    onnx_model_name,  # where to save the model (can be a file or file-like object)
    export_params=True,  # store the trained parameter weights inside the model file
    opset_version=12,  # the ONNX version to export
    do_constant_folding=True,  # whether to execute constant folding for optimization
    input_names=["input"],  # the model's input names
    output_names=["output"],  # the model's output names
    dynamic_axes={  # variable length axes
        "input": dynamic_axes,
        "output": dynamic_axes,
onnx_model = onnx.load(onnx_model_name)
onnx.checker.check_model(onnx_model)
check_model没有报错日志即验证成功
"onnx test is ok!"
5、加载onnx验证CPU推理结果
sample = torch.randn(1,3, 512, 512)
img=np.expand_dims(sample)
img=np.array(img,dtype=np.float32)
batch,height,width,channel=img.shape
img=np.reshape(img,(batch,channel,height,width))
ort_session = onnxruntime.InferenceSession(
    onnx_model_name, providers=["CPUExecutionProvider"]
# compute ONNX Runtime output prediction
# ort_inputs = {"input": sample.numpy()}
ort_inputs = {"input": sample}
ort_outputs = ort_session.run(output_names=None, input_feed=ort_inputs)
ort_outputs
tensor([[[[-0.1246, -0.8691,  1.2468,  ...,  1.5282, -1.2732,  0.9794],
          [ 1.3723, -0.0419,  2.8774,  ...,  2.5053,  0.2462,  1.1938],
          [ 0.7045, -1.1840, -0.5846,  ...,  0.7469,  0.3499,  0.8009],
          [-0.8097,  0.1798,  0.3107,  ..., -1.2473,  1.5366, -0.3955],
          [-0.1176, -0.0104,  0.4736,  ...,  0.8608, -0.8950,  0.6830],
          [-1.6339, -1.4623,  0.6656,  ..., -0.6432, -2.3936, -0.6228]],
6、onnx转om模型推理
安装cann后利用如下代码进行转换
atc --model=deeplabv3_plus.onnx --framework=5 --output=deeplabv3_plus --soc_version=Ascend310 -- --input_shape="input:1,3,512,512"
转换成功后可以在服务器上进行om模型推理
加载模型设置大小为(1,3,512,512)维度的随机图像tensor进行推理
# 从文件加载离线模型数据
model_path = './model/deeplabv3_plus.om'
model = acllite_model(model_path)
# 根据构建好的模型输入数据进行模型推理
img=torch.randn(1,3,1024,1024)
result_list = model.execute([img])
#得到推理结果并且reshape成512*512,并且转换成uint8类型
result_img = result_list[0].reshape(512, 512)
result_img = result_img.astype('uint8')
result_img.shape
print(result_img)
打印result_img输出结果完成推理
tensor([[[[ 0.1919, -0.7563, -1.1512,  ...,  0.2721, -0.1220,  1.4461],
          [ 0.9982,  0.6150,  0.0191,  ..., -2.4493, -0.8513, -0.6102],
          [ 0.7011, -0.2566,  1.3187,  ..., -0.4520, -1.4002, -0.1832],
          [-0.6632, -0.7704,  0.8694,  ...,  0.9940,  0.7905, -0.2253],
          [-0.0981,  0.1034, -0.3128,  ..., -0.1130, -0.0628, -0.8793],
          [-0.9770, -0.6159, -0.6841,  ..., -0.2381,  1.0263, -0.2224]],
         [[ 0.1441,  1.7850,  0.7764,  ...,  0.2099, -0.3699,  0.8952],
          [ 0.3328,  0.8359,  2.3847,  ..., -2.0905,  0.2405, -0.2678],
          [ 0.4478,  0.4810, -0.3092,  ...,  0.8745, -1.2963,  0.6621],
          [ 0.1475,  0.2986, -0.8419,  ...,  0.0538,  0.0745,  0.5989],
          [ 1.1479,  0.3992, -1.0586,  ..., -1.3081,  1.4740, -1.3389],
          [-1.0331, -2.2473,  1.1847,  ..., -0.7303,  2.7132,  0.0633]],
