为什么Mybatis-plus生成的id在k8s环境会发生重复
一颗小谷粒 发表于 2024/11/27 15:39:07 2024/11/27
【摘要】 数据库的业务id添加了唯一索引,当并发量上来时生产环境偶尔会出现此列的值重复问题,这是因为生成id时发成了重复现象,采取的是mybatis-plus的雪花算法策略,雪花算法这里就不细说了,大致由4部分组成时间戳、datacenterId、wokerId、自增序列。在mybatis-plus中 datacenterId和wokerId需要我们自己去设置,如果没有设置那么mybatis-plus...
在mybatis-plus中 datacenterId和wokerId需要我们自己去设置,如果没有设置那么mybatis-plus会自己去进行设值,下面来分析下mybatis-plus中完整的id生成过程
分析
服务启动时,会加载默认的 DefaultIdentifierGenerator,调用无参构造方法
public class DefaultIdentifierGenerator implements IdentifierGenerator {
    private final Sequence sequence;
    public DefaultIdentifierGenerator() {
        this.sequence = new Sequence(null);
    public DefaultIdentifierGenerator(InetAddress inetAddress) {
        this.sequence = new Sequence(inetAddress);
    public DefaultIdentifierGenerator(long workerId, long dataCenterId) {
        this.sequence = new Sequence(workerId, dataCenterId);
    public DefaultIdentifierGenerator(Sequence sequence) {
        this.sequence = sequence;
    @Override
    public Long nextId(Object entity) {
        return sequence.nextId();
接着会调用无参构造方法时构造了 Sequence,传入的InetAddress参数为null
 * 机器标识位数
private final long workerIdBits = 5L;
private final long datacenterIdBits = 5L;
private final long maxWorkerId = -1L ^ (-1L << workerIdBits);
private final long maxDatacenterId = -1L ^ (-1L << datacenterIdBits);
public Sequence(InetAddress inetAddress) {
    this.inetAddress = inetAddress;
    this.datacenterId = getDatacenterId(maxDatacenterId);
    this.workerId = getMaxWorkerId(datacenterId, maxWorkerId);
maxDatacenterId 和 maxWorkerId 固定为31,接着继续分析 getDatacenterId(maxDatacenterId)
protected long getDatacenterId(long maxDatacenterId) {
    long id = 0L;
    try {
        if (null == this.inetAddress) {
            this.inetAddress = InetAddress.getLocalHost();
        NetworkInterface network = NetworkInterface.getByInetAddress(this.inetAddress);
        if (null == network) {
            id = 1L;
            byte[] mac = network.getHardwareAddress();
            if (null != mac) {
                id = ((0x000000FF & (long) mac[mac.length - 2]) | (0x0000FF00 & (((long) mac[mac.length - 1]) << 8))) >> 6;
                id = id % (maxDatacenterId + 1);
    } catch (Exception e) {
        logger.warn(" getDatacenterId: " + e.getMessage());
    return id;
可以看出 getDatacenterId(maxDatacenterId) 返回的 datacenterId 就是mac地址,接着再继续分析 getMaxWorkerId(datacenterId, maxWorkerId)
protected long getMaxWorkerId(long datacenterId, long maxWorkerId) {
    StringBuilder mpid = new StringBuilder();
    mpid.append(datacenterId);
    String name = ManagementFactory.getRuntimeMXBean().getName();
    if (StringUtils.isNotBlank(name)) {
         * GET jvmPid
        mpid.append(name.split(StringPool.AT)[0]);
     * MAC + PID 的 hashcode 获取16个低位
    return (mpid.toString().hashCode() & 0xffff) % (maxWorkerId + 1);
可以看出 getMaxWorkerId(long datacenterId, long maxWorkerId) 返回的 workerId 是mac地址和进程id的结合
到这里初始化工作执行完毕,下面就是生成id的过程了
sequence.nextId()
 * 时间起始标记点,作为基准,一般取系统的最近时间(一旦确定不能变动)
private final long twepoch = 1288834974657L;
 * 机器标识位数
 * 毫秒内自增位
private final long sequenceBits = 12L;
private final long workerIdShift = sequenceBits;
private final long datacenterIdShift = sequenceBits + workerIdBits;
 * 时间戳左移动位
private final long timestampLeftShift = sequenceBits + workerIdBits + datacenterIdBits;
private final long sequenceMask = -1L ^ (-1L << sequenceBits);
private final long workerId;
 * 数据标识 ID 部分
private final long datacenterId;
 * 并发控制
private long sequence = 0L;
 * 上次生产 ID 时间戳
private long lastTimestamp = -1L;
 * IP 地址
private InetAddress inetAddress;
public synchronized long nextId() {
    //获取当前最新的时间
    long timestamp = timeGen();
    //闰秒
    if (timestamp < lastTimestamp) {
        long offset = lastTimestamp - timestamp;
        //如果误差时间范围在5内
        if (offset <= 5) {
            try {
                //等待误差时间的2倍
                wait(offset << 1);
                //重新在获取最新的时间
                //如果依旧还是小于记录的时间则抛出异常
                    throw new RuntimeException(String.format("Clock moved backwards.  Refusing to generate id for %d milliseconds", offset));
                throw new RuntimeException(e);
            //大于误差范围则抛出异常
    if (lastTimestamp == timestamp) {
        // 相同毫秒内,序列号自增
        sequence = (sequence + 1) & sequenceMask;
        if (sequence == 0) {
            // 同一毫秒的序列数已经达到最大
            timestamp = tilNextMillis(lastTimestamp);
        // 不同毫秒内,序列号置为 1 - 3 随机数
        sequence = ThreadLocalRandom.current().nextLong(1, 3);
    //将这次获得的最新时间记录下来,用于下次执行时对比
    lastTimestamp = timestamp;
    // 时间戳部分 | 数据中心部分 | 机器标识部分 | 序列号部分
    return ((timestamp - twepoch) << timestampLeftShift)
        | (datacenterId << datacenterIdShift)
        | (workerId << workerIdShift)
        | sequence;
可以看到生成的策略与时间戳、mac地址、进程id、自增序列有关。
看似美好但其实是有问题的,因为在k8s集群环境下,如果不是在同一个k8s环境中,mac地址有可能会重复,java服务进程id都为1,这就造成生成的id会可能重复
解决
所以需要借助第三方来解决redis或zookeeper,因为redis比zookeeper更常用,最终决定用redis来生成datacenterId和workerId
