2024华为云开源开发者论坛项目抢鲜看|Kmesh: 监控指标和访问日志功能详解
云容器大未来 发表于 2024/11/27 10:23:31 2024/11/27
【摘要】 Kmesh 是内核原生Sidecarless服务网格数据平面。它借助 "eBPF "和 "可编程内核",将流量治理下沉到操作系统内核,大大的降低了服务网格的资源开销和网络延迟。本文将详细介绍Kmesh如何使用eBPF直接获取链接信息,并根据这些信息构建监控指标和访问日志?
通过eBPF,流量数据可以直接在内核中获取,并且能够使用 "bpf map"将数据传递到用户空间。Kmesh使用这些数据构建监控指标和访问日志。
▍如何获取原始数据
在内核中,可以直接获取socket携带的流量信息。
bpf_tcp_sock 中携带的数据如下:
struct bpf_tcp_sock {
 __u32 snd_cwnd;  /* Sending congestion window  */
 __u32 srtt_us;  /* smoothed round trip time << 3 in usecs */
 __u32 rtt_min;
 __u32 snd_ssthresh; /* Slow start size threshold  */
 __u32 rcv_nxt;  /* What we want to receive next  */
 __u32 snd_nxt;  /* Next sequence we send  */
 __u32 snd_una;  /* First byte we want an ack for */
 __u32 mss_cache; /* Cached effective mss, not including SACKS */
 __u32 ecn_flags; /* ECN status bits.   */
 __u32 rate_delivered; /* saved rate sample: packets delivered */
 __u32 rate_interval_us; /* saved rate sample: time elapsed */
 __u32 packets_out; /* Packets which are "in flight" */
 __u32 retrans_out; /* Retransmitted packets out  */
 __u32 total_retrans; /* Total retransmits for entire connection */
 __u32 segs_in;  /* RFC4898 tcpEStatsPerfSegsIn
     * total number of segments in.
 __u32 data_segs_in; /* RFC4898 tcpEStatsPerfDataSegsIn
     * total number of data segments in.
 __u32 segs_out;  /* RFC4898 tcpEStatsPerfSegsOut
     * The total number of segments sent.
 __u32 data_segs_out; /* RFC4898 tcpEStatsPerfDataSegsOut
     * total number of data segments sent.
 __u32 lost_out;  /* Lost packets   */
 __u32 sacked_out; /* SACK'd packets   */
 __u64 bytes_received; /* RFC4898 tcpEStatsAppHCThruOctetsReceived
     * sum(delta(rcv_nxt)), or how many bytes
     * were acked.
 __u64 bytes_acked; /* RFC4898 tcpEStatsAppHCThruOctetsAcked
     * sum(delta(snd_una)), or how many bytes
     * were acked.
 __u32 dsack_dups; /* RFC4898 tcpEStatsStackDSACKDups
     * total number of DSACK blocks received
 __u32 delivered; /* Total data packets delivered incl. rexmits */
 __u32 delivered_ce; /* Like the above but only ECE marked packets */
 __u32 icsk_retransmits; /* Number of unrecovered [RTO] timeouts */
注意: 上述数据并没完全用于监控指标和访问日志功能。Kmesh将在后续的开发中逐步补充这些指标。
现阶段使用的数据有:
struct tcp_probe_info {
    __u32 type;
    struct bpf_sock_tuple tuple;
    __u32 sent_bytes;
    __u32 received_bytes;
    __u32 conn_success;
    __u32 direction;
    __u64 duration; // ns
    __u64 close_ns;
    __u32 state; /* tcp state */
    __u32 protocol;
    __u32 rtt_min;
除了这些socket携带的数据外,Kmesh通过socket_storage在建立链接时存储临时数据。当链接关闭时,从之前存储的临时数据中获取链接持续时间等数据。
▍数据处理
Kmesh在内核中获取了来自链接的数据后,会通过ringbuf将数据传递给用户态。
Kmesh在用户态将ringbuf的数据解析之后,根据这些数据中携带的源服务和目标服务信息更新metricController中的缓存和构建metricLabels。
构建的metricLabels有workload粒度的也有service粒度的。但workload粒度的监控指标最多是集群中pod数量的平方,因此Kmesh提供一个启动开关,使用户能够按需启用监控指标功能和访问日志功能。
namespacedhost := ""
for k, portList := range dstWorkload.Services {
    for _, port := range portList.Ports {
        if port.TargetPort == uint32(dstPort) {
            namespacedhost = k
            break
    if namespacedhost != "" {
        break
建立工作负载粒度的度量和服务粒度的度量metricLabels后,更新缓存。
每5秒钟,监控指标信息都会通过Prometheus API更新到Prometheus中。
在处理指标时,会一起生成访问日志。每次链接关闭时,都会将生成的Accesslog打印到Kmesh的日志中。
Kmesh监控指标功能和访问日志功能的整体架构图如下所示:
指标细节
现阶段Kmesh L4层监控的指标如下:
工作负载粒度:
Name Describe
kmesh_tcp_workload_connections_opened_total 源工作负载和目标工作负载之间总共建立了多少次链接
kmesh_tcp_workload_connections_closed_total 源工作负载和目标工作负载之间总共关闭了多少次链接
kmesh_tcp_workload_received_bytes_total 目标工作负载接收到了多少的数据
kmesh_tcp_workload_sent_bytes_total 源工作负载发送了多少的数据
kmesh_tcp_workload_conntections_failed_total 源工作负载和目标工作负载之间建立链接失败了多少次
服务粒度:
Name Describe
kmesh_tcp_connections_opened_total 源工作负载和目标服务之间总共建立了多少次链接
kmesh_tcp_connections_closed_total 源工作负载和目标服务之间总共关闭了多少次链接
kmesh_tcp_received_bytes_total 目标服务接收到了多少的数据
kmesh_tcp_sent_bytes_total 源工作负载发送了多少的数据
kmesh_tcp_conntections_failed_total 源工作负载和目标服务之间建立链接失败了多少次
监控指标例子:
kmesh_tcp_workload_received_bytes_total{connection_security_policy="mutual_tls",destination_app="httpbin",destination_canonical_revision="v1",destination_canonical_service="httpbin",destination_cluster="Kubernetes",destination_pod_address="10.244.0.11",destination_pod_name="httpbin-5c5944c58c-v9mlk",destination_pod_namespace="default",destination_principal="-",destination_version="v1",destination_workload="httpbin",destination_workload_namespace="default",reporter="destination",request_protocol="tcp",response_flags="-",source_app="sleep",source_canonical_revision="latest",source_canonical_service="sleep",source_cluster="Kubernetes",source_principal="-",source_version="latest",source_workload="sleep",source_workload_namespace="default"} 231
也能够通过prometheus dashboard查看监控指标。具体步骤参考Kmesh可观测性文档。
现阶段Kmesh访问日志展示的字段如下:
Name Describe
src.addr 请求的源地址和端口
src.workload 源工作负载名称
src.namespace 源工作负载所在的namespace
dst.addr 请求的目标地址和端口
dst.service 目标服务的域名
dst.workload 目标工作负载的名称
dst.namespace 目标工作负载的命名空间
direction 流量流向,OUTBOUND表示从节点流出,INBOUND表示从流入节点
sent_bytes 本次链接发送的数据量
received_bytes 本次链接接收的数据量
duration 本次链接的持续时间
Accesslog Result:
accesslog: 2024-09-14 08:19:26.552709932 +0000 UTC
src.addr=10.244.0.17:51842, src.workload=prometheus-5fb7f6f8d8-h9cts, src.namespace=istio-system,
dst.addr=10.244.0.13:9080, dst.service=productpage.echo-1-27855.svc.cluster.local, dst.workload=productpage-v1-8499c849b9-bz9t9, dst.namespace=echo-1-27855, direction=INBOUND, sent_bytes=5, received_bytes=292, duration=2.733902ms
▍Summary
Kmesh直接从套接字获取流量数据,并将其作为ringbuf传递到用户空间,以生成监控指标和访问日志。
避免在用户空间拦截流量并以本地方式获取指标。定期批量更新用户空间中的指标,避免在大流量时增加网络延迟。
随后,我们还将开发跟踪功能,以补充 Kmesh 的可观测能力。
欢迎感兴趣的同学加入Kmesh开源社区!
Kmesh GitHub: https://github.com/kmesh-net/kmesh
Kmesh Website: https://kmesh.net/
12月7日,Kmesh技术专家将在2024华为云开源开发者论坛上带来《服务网格的未来:Kmesh的设计思想与演进方向》技术分享及重磅发布!添加小助手k8s2222,报名领票参会!
