如何在前后端分离项目中,使用Spring Security
繁依Fanyi 发表于 2024/10/22 23:25:59 2024/10/22
【摘要】 使用 WebSecurityConfigurationAdapter在前后端分离的架构中,通常使用 Token 进行认证和授权是一种常见的做法。Token 可以是 JSON Web Token(JWT),用于在客户端和服务器之间传递身份信息和访问控制信息。下面我将详细介绍如何在 Spring Boot 后端和 Vue 前端应用中使用 Token(JWT)来实现认证和授权。 后端(Sprin...
后端(Spring Boot + Spring Security + JWT)
1. 添加依赖
首先,确保在你的 Spring Boot 项目中添加相关依赖:
<!-- Spring Security -->
<dependency>
    <artifactId>spring-boot-starter-security</artifactId>
</dependency>
<!-- JWT -->
<dependency>
    <groupId>io.jsonwebtoken</groupId>
    <artifactId>jjwt</artifactId>
    <version>0.9.1</version>
</dependency>
2. 配置Spring Security和JWT
创建一个配置类来配置 Spring Security 和 JWT。
import com.fasterxml.jackson.databind.ObjectMapper;
import io.jsonwebtoken.Claims;
import io.jsonwebtoken.Jwts;
import io.jsonwebtoken.SignatureAlgorithm;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.beans.factory.annotation.Value;
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.http.HttpStatus;
import org.springframework.security.authentication.AuthenticationManager;
import org.springframework.security.config.annotation.authentication.builders.AuthenticationManagerBuilder;
import org.springframework.security.config.annotation.method.configuration.EnableGlobalMethodSecurity;
import org.springframework.security.config.annotation.web.builders.HttpSecurity;
import org.springframework.security.config.annotation.web.configuration.EnableWebSecurity;
import org.springframework.security.config.annotation.web.configuration.WebSecurityConfigurerAdapter;
import org.springframework.security.config.http.SessionCreationPolicy;
import org.springframework.security.core.userdetails.UserDetails;
import org.springframework.security.core.userdetails.UserDetailsService;
import org.springframework.security.crypto.password.PasswordEncoder;
import org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter;
import org.springframework.web.filter.OncePerRequestFilter;
import javax.servlet.FilterChain;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import java.io.IOException;
import java.util.Date;
import java.util.HashMap;
import java.util.Map;
import java.util.function.Function;
@Configuration
@EnableWebSecurity
@EnableGlobalMethodSecurity(prePostEnabled = true)
public class SecurityConfig extends WebSecurityConfigurerAdapter {
    @Autowired
    private UserDetailsService userDetailsService;
    @Autowired
    private JwtRequestFilter jwtRequestFilter;
    @Autowired
    private CustomAuthenticationEntryPoint customAuthenticationEntryPoint;
    @Autowired
    private CustomAccessDeniedHandler customAccessDeniedHandler;
    @Autowired
    public void configureGlobal(AuthenticationManagerBuilder auth) throws Exception {
        auth.userDetailsService(userDetailsService).passwordEncoder(passwordEncoder());
    @Override
    protected void configure(HttpSecurity http) throws Exception {
        http.csrf().disable()
            .authorizeRequests()
                .antMatchers("/api/public/**").permitAll() // 公开访问的API
                .anyRequest().authenticated()
            .and()
            .exceptionHandling()
                .authenticationEntryPoint(customAuthenticationEntryPoint)
                .accessDeniedHandler(customAccessDeniedHandler)
            .and()
            .sessionManagement()
                .sessionCreationPolicy(SessionCreationPolicy.STATELESS); // 禁用Spring Security的Session管理
        http.addFilterBefore(jwtRequestFilter, UsernamePasswordAuthenticationFilter.class);
    @Bean
    public PasswordEncoder passwordEncoder() {
        return new BCryptPasswordEncoder();
    @Bean
    public JwtTokenUtil jwtTokenUtil() {
        return new JwtTokenUtil();
    @Bean
    @Override
    public AuthenticationManager authenticationManagerBean() throws Exception {
        return super.authenticationManagerBean();
3. JWT Token Util 类
创建一个用于生成和验证 JWT 的工具类 JwtTokenUtil。
import org.springframework.stereotype.Component;
import java.io.Serializable;
@Component
public class JwtTokenUtil implements Serializable {
    @Value("${jwt.secret}")
    private String secret;
    @Value("${jwt.expiration}")
    private long expiration;
    public String generateToken(UserDetails userDetails) {
        Map<String, Object> claims = new HashMap<>();
        return Jwts.builder()
                .setClaims(claims)
                .setSubject(userDetails.getUsername())
                .setIssuedAt(new Date(System.currentTimeMillis()))
                .setExpiration(new Date(System.currentTimeMillis() + expiration * 1000))
                .signWith(SignatureAlgorithm.HS512, secret)
                .compact();
    public String getUsernameFromToken(String token) {
        return getClaimFromToken(token, Claims::getSubject);
    public Date getExpirationDateFromToken(String token) {
        return getClaimFromToken(token, Claims::getExpiration);
    public <T> T getClaimFromToken(String token, Function<Claims, T> claimsResolver) {
        final Claims claims = getAllClaimsFromToken(token);
        return claimsResolver.apply(claims);
    private Claims getAllClaimsFromToken(String token) {
        return Jwts.parser().setSigningKey(secret).parseClaimsJws(token).getBody();
    public boolean validateToken(String token, UserDetails userDetails) {
        final String username = getUsernameFromToken(token);
        return (username.equals(userDetails.getUsername()) && !isTokenExpired(token));
    private boolean isTokenExpired(String token) {
        final Date expiration = getExpirationDateFromToken(token);
        return expiration.before(new Date());
4. JWT 请求过滤器
创建一个 JWT 请求过滤器来拦截和验证请求中的 JWT。
import org.springframework.security.authentication.UsernamePasswordAuthenticationToken;
import org.springframework.security.core.Authentication;
import org.springframework.security.core.context.SecurityContextHolder;
@Component
public class JwtRequestFilter extends OncePerRequestFilter {
    @Autowired
    private JwtTokenUtil jwtTokenUtil;
    @Autowired
    @Override
    protected void doFilterInternal(HttpServletRequest request, HttpServletResponse response, FilterChain chain)
            throws ServletException, IOException {
        final String authorizationHeader = request.getHeader("Authorization");
        String username = null;
        String jwt = null;
        if (authorizationHeader != null && authorizationHeader.startsWith("Bearer ")) {
            jwt = authorizationHeader.substring(7);
            username = jwtTokenUtil.getUsernameFromToken(jwt);
        if (username != null && SecurityContextHolder.getContext().getAuthentication() == null) {
            UserDetails userDetails = this.userDetailsService.loadUserByUsername(username);
            if (jwtTokenUtil.validateToken(jwt, userDetails)) {
                UsernamePasswordAuthenticationToken usernamePasswordAuthenticationToken = new UsernamePasswordAuthenticationToken(
                        userDetails, null, userDetails.getAuthorities());
                SecurityContextHolder.getContext().setAuthentication(usernamePasswordAuthenticationToken);
        chain.doFilter(request, response);
5. 登录和生成JWT
创建一个登录接口,验证用户身份并生成JWT返回给客户端。
import org.springframework.http.ResponseEntity;
import org.springframework.security.authentication.BadCredentialsException;
import org.springframework.security.authentication.DisabledException;
import org.springframework.web.bind.annotation.PostMapping;
import org.springframework.web.bind.annotation.RequestBody;
@RestController
public class JwtAuthenticationController {
    @Autowired
    private AuthenticationManager authenticationManager;
    @Autowired
    @Autowired
    @PostMapping(value = "/api/login")
    public ResponseEntity<?> createAuthenticationToken(@RequestBody JwtRequest authenticationRequest) throws Exception {
        authenticate(authenticationRequest.getUsername(), authenticationRequest.getPassword());
        final UserDetails userDetails = userDetailsService.loadUserByUsername(authenticationRequest.getUsername());
        final String token = jwtTokenUtil.generateToken(userDetails);
        return ResponseEntity.ok(new JwtResponse(token));
    private void authenticate(String username, String password) throws Exception {
        try {
            authenticationManager.authenticate(new UsernamePasswordAuthenticationToken(username, password));
        } catch (DisabledException e) {
            throw new Exception("USER_DISABLED", e);
        } catch (BadCredentialsException e) {
            throw new Exception("INVALID_CREDENTIALS", e);
前端(Vue)
在前端Vue应用中,你需要处理JWT的存储和使用。
1. 登录请求
在Vue组件中实现用户登录请求,获取JWT并存储到LocalStorage。
// 简化的登录方法示例
login(username, password) {
    return axios.post('/api/login', { username, password })
        .then(response => {
            if (response.data && response.data.token) {
                // 将JWT Token保存到LocalStorage中
                localStorage.setItem('jwtToken', response.data.token);
            return response.data;
2. JWT Token的存储和使用
在Vue应用中,通常将JWT Token存储在LocalStorage中,并在每次请求时将Token添加到请求的Header中,以便后端验证用户的身份和权限。
// 设置全局的axios默认请求头,添加Authorization字段
axios.defaults.headers.common['Authorization'] = 'Bearer ' + localStorage.getItem('jwtToken');
// 示例:获取用户信息的方法
getUserInfo() {
    return axios.get('/api/userinfo')
        .then(response => {
// 示例:注销方法
logout() {
    localStorage.removeItem('jwtToken'); // 清除本地存储的JWT Token
    // 可以选择发送注销请求到后端,使后端的Token失效
3. 路由守卫和权限控制
使用Vue Router的导航守卫(路由守卫),根据用户的登录状态和权限信息控制页面的访问。
import Vue from 'vue'
import Router from 'vue-router'
import Home from './views/Home.vue'
import AdminPanel from './views/AdminPanel.vue'
import Login from './views/Login.vue'
Vue.use(Router)
const router = new Router({
    routes: [
            path: '/',
            component: Home,
            meta: { requiresAuth: true } // 需要登录才能访问的页面
            path: '/admin',
            component: AdminPanel,
            meta: { requiresAuth: true, requiresAdmin: true } // 需要管理员权限才能访问的页面
            path: '/login',
            component: Login
router.beforeEach((to, from, next) => {
    const jwtToken = localStorage.getItem('jwtToken');
    if (to.matched.some(record => record.meta.requiresAuth)) {
        if (!jwtToken) {
            next('/login'); // 没有登录,跳转到登录页面
            // 验证Token是否过期等逻辑可以根据实际需求添加
            next();
        next(); // 不需要登录的页面直接放行
export default router;
4. 处理Token过期和刷新
在使用JWT时,需要处理Token过期的情况,一般的做法是在前端捕获HTTP请求返回的401状态码(未授权),然后根据情况重新获取新的Token。
// 示例:处理HTTP请求返回的401状态码
axios.interceptors.response.use(
    response => {
        return response;
    error => {
        if (error.response.status === 401) {
            // 清除本地存储的Token
            // 跳转到登录页面或者重新获取新的Token等操作
            // 可以根据实际情况进行处理
        return Promise.reject(error);
使用 SecurityFilterChain
在最新版本的 Spring Security 中,WebSecurityConfigurerAdapter 已经被弃用。取而代之的是新的配置方式,直接通过配置类和 SecurityFilterChain Bean 来配置安全性。下面是如何在不使用 WebSecurityConfigurerAdapter 的情况下配置 Spring Security 和 JWT 认证。
1. 添加依赖
<dependency>
</dependency>
<!-- JWT -->
<dependency>
</dependency>
2. 配置 Spring Security 和 JWT
不使用 WebSecurityConfigurerAdapter 的情况下,可以使用 SecurityConfigurer 和 SecurityFilterChain 进行配置。
import org.springframework.security.config.annotation.authentication.configuration.AuthenticationConfiguration;
import org.springframework.security.config.annotation.web.configurers.AbstractHttpConfigurer;
import org.springframework.security.crypto.bcrypt.BCryptPasswordEncoder;
import org.springframework.security.web.SecurityFilterChain;
@Configuration
@EnableWebSecurity
public class SecurityConfig {
    private final JwtRequestFilter jwtRequestFilter;
    private final CustomAuthenticationEntryPoint customAuthenticationEntryPoint;
    private final CustomAccessDeniedHandler customAccessDeniedHandler;
    public SecurityConfig(JwtRequestFilter jwtRequestFilter,
                          CustomAuthenticationEntryPoint customAuthenticationEntryPoint,
                          CustomAccessDeniedHandler customAccessDeniedHandler) {
        this.jwtRequestFilter = jwtRequestFilter;
        this.customAuthenticationEntryPoint = customAuthenticationEntryPoint;
        this.customAccessDeniedHandler = customAccessDeniedHandler;
    @Bean
    public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
        http.csrf(AbstractHttpConfigurer::disable)
            .authorizeRequests(authorizeRequests ->
                authorizeRequests.antMatchers("/api/public/**").permitAll()
                                 .anyRequest().authenticated())
            .exceptionHandling(exceptionHandling ->
                exceptionHandling.authenticationEntryPoint(customAuthenticationEntryPoint)
                                 .accessDeniedHandler(customAccessDeniedHandler))
            .sessionManagement(sessionManagement ->
                sessionManagement.sessionCreationPolicy(SessionCreationPolicy.STATELESS))
        return http.build();
    @Bean
    @Bean
    public AuthenticationManager authenticationManager(AuthenticationConfiguration authenticationConfiguration) throws Exception {
        return authenticationConfiguration.getAuthenticationManager();
3. JWT Token Util 类
@Component
                .setClaims(claims)
                .compact();
4. JWT 请求过滤器
@Component
    @Autowired
    @Autowired
    @Override
        String jwt = null;
5. 登录和生成 JWT
创建一个登录接口,验证用户身份并生成 JWT 返回给客户端。
@RestController
    @Autowired
    @Autowired
    @Autowired
        try {
前端(Vue)
在前端 Vue 应用中,你需要处理 JWT 的存储和使用。
1. 登录请求
在 Vue 组件中实现用户登录请求,获取 JWT 并存储到 LocalStorage。
// 登录方法
        .then(response => {
                // 将 JWT Token 保存到 LocalStorage 中
2. JWT Token 的存储和使用
在 Vue 应用中,通常将 JWT Token 存储在 LocalStorage 中,并在每次请求时将 Token 添加到请求的 Header 中,以便后端验证用户的身份和权限。
// 设置全局的 axios 默认请求头,添加 Authorization 字段
```javascript
// 示例:获取用户信息的方法
getUserInfo() {
        .then(response => {
// 示例:注销方法
logout() {
3. 路由守卫和权限控制
使用 Vue Router 的导航守卫(路由守卫),根据用户的登录状态和权限信息控制页面的访问。
Vue.use(Router)
    routes: [
            path: '/',
            component: Home,
            path: '/admin',
            path: '/login',
            component: Login
        if (!jwtToken) {
            next();
4. 处理Token过期和刷新
    response => {
        return response;
    error => {
            // 清除本地存储的Token
            // 可以根据实际情况进行处理
新的配置方式主要区别在于 Spring Security 中不再使用 WebSecurityConfigurerAdapter 进行配置,而是通过 SecurityFilterChain 和其他配置类来实现同样的功能。下面详细介绍它们的区别和新的配置方法。
新旧版对比
旧版(使用 WebSecurityConfigurerAdapter)
旧版配置通常使用一个继承 WebSecurityConfigurerAdapter 的类来进行安全配置。
@EnableWebSecurity
    @Override
            .and()
            .and()
            .sessionManagement().sessionCreationPolicy(SessionCreationPolicy.STATELESS);
        // 添加 JWT 过滤器
        http.addFilterBefore(jwtRequestFilter(), UsernamePasswordAuthenticationFilter.class);
    @Bean
    // 定义 JWT 过滤器
    @Bean
    public JwtRequestFilter jwtRequestFilter() {
        return new JwtRequestFilter();
新版(使用 SecurityFilterChain)
新版配置不再使用 WebSecurityConfigurerAdapter,而是通过定义 SecurityFilterChain Bean 来配置安全性。
新版配置示例
1. SecurityConfig.java
@Configuration
@EnableWebSecurity
    @Bean
    @Bean
    @Bean
2. 其他相关配置和组件
  • JwtTokenUtil:处理 JWT 生成和验证的工具类。
  • JwtRequestFilter:JWT 过滤器,用于在请求到达时验证 JWT。
JwtTokenUtil.java
@Component
                .setClaims(claims)
                .compact();
JwtRequestFilter.java
@Component
    @Autowired
    @Autowired
    @Override
        String jwt = null;
新旧版区别总结
  1. 配置类的结构:
    • 旧版:通过继承 WebSecurityConfigurerAdapter,重写 configure(HttpSecurity http) 方法进行配置。
    • 新版:通过定义 SecurityFilterChain Bean,直接配置 HttpSecurity。
  2. 认证管理器:
    • 旧版:直接在 WebSecurityConfigurerAdapter 中配置。
    • 新版:通过 AuthenticationConfiguration 获取 AuthenticationManager。
  3. 注入过滤器:
    • 旧版:使用 http.addFilterBefore(jwtRequestFilter(), UsernamePasswordAuthenticationFilter.class)。
    • 新版:使用 http.addFilterBefore(jwtRequestFilter, UsernamePasswordAuthenticationFilter.class)。
迁移步骤
  1. 删除 WebSecurityConfigurerAdapter:
    • 删除继承自 WebSecurityConfigurerAdapter 的类。
  2. 定义 SecurityFilterChain Bean:
    • 新建一个配置类,定义 SecurityFilterChain Bean,配置 HttpSecurity。
  3. 调整其他配置:
    • 根据新方式调整 AuthenticationManager 和其他相关配置。
通过以上步骤,你可以从旧版的 WebSecurityConfigurerAdapter 配置迁移到新版的 SecurityFilterChain 配置,同时保持应用的安全性和功能。
大致流程
  1. 引入依赖:确保引入 Spring Security 和 JWT 相关的依赖。
  2. 配置安全性:使用 Java 配置类(如 SecurityConfig)来设置 HTTP 安全性、CSRF、会话管理等。
  3. 实现 JWT 相关逻辑:创建工具类和过滤器来处理 JWT 的生成、解析和验证。
  4. 自定义异常处理:编写自定义的认证入口点和访问拒绝处理器。
  5. 实现用户服务:实现 UserDetailsService 接口,加载用户信息。
  6. 编写控制器:创建登录和注册接口,处理用户认证和注册请求。
  7. 测试与验证:启动应用程序,使用工具测试各个接口,确保功能正常。
