集群环境搭建&&网盘部署
winnerwhy 发表于 2024/09/26 09:11:05 2024/09/26
【摘要】 (1) 修改主机名并配置映射# hostnamectl set-hostname master# cat /etc/hosts127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4::1 localhost localhost.localdomain localhost6 l...
(1) 修改主机名并配置映射
# cat /etc/hosts
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
192.168.100.10 master
192.168.100.11 node
(2) 关闭SELinux和防火墙
# sed -i 's/SELINUX=enforcing/SELINUX=disabled/g' /etc/selinux/config
# setenforce 0
# systemctl stop firewalld.service
# systemctl disable firewalld.service
(3) 删除iptables防火墙规则
# iptables -F
# iptables -X
# iptables -Z
# /usr/sbin/iptables-save
(4) 配置yum源
@@master节点
# mkdir /opt/centos
# mount -o loop CentOS-7-x86_64-DVD-2009.iso /mnt/
mount: /dev/loop0 is write-protected, mounting read-only
# cp -rvf /mnt/* /opt/centos/
# umount /mnt
# mount -o loop kubernetes_v1.2.iso /mnt/
# umount /mnt
# rm -rf /etc/yum.repos.d/*
# cat /etc/yum.repos.d/local.repo
[centos]
name=centos
baseurl=file:///opt/centos
gpgcheck=0
enabled=1
[k8s]
name=k8s
baseurl=file:///opt/kubernetes-repo
gpgcheck=0
enabled=1
# yum install vsftpd vim -y
# vim /etc/vsftpd/vsftpd.conf
anon_root=/opt
# systemctl restart vsftpd && systemctl enable vsftpd
@@node节点
# cat /etc/yum.repos.d/ftp.repo
[centos]
name=centos
baseurl=ftp://master/centos
gpgcheck=0
enabled=1
[k8s]
name=k8s
baseurl=ftp://master/kubernetes-repo
gpgcheck=0
enabled=1
(5)  部署Harbor仓库
执行./k8s_harbor_install.sh
(6)  上传镜像
执行.//k8s_image_push.sh
(7)  部署Kubernetes集群
执行./k8s_master_install.sh
(8)  node节点加入集群
执行./k8s_node_install.sh
(9)  master节点
执行./k8s_project_install.sh
owncloud网盘
[root@master ~]# cat owncloud-pvc.yaml
apiVersion: v1
kind: PersistentVolume
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  capacity:
    storage: 5Gi
  hostPath:
    path: /data/owncloud
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 5Gi
[root@master ~]# kubectl apply -f  owncloud-pvc.yaml
[root@master ~]# cat owncloud-configmap.yaml
apiVersion: v1
kind: ConfigMap
metadata:
data:
  OWNCLOUD_ADMIN_USERNAME: “admin”
  OWNCLOUD_ADMIN_PASSWORD: “123456”
[root@master ~]# kubectl apply -f  owncloud-configmap.yaml
[root@master ~]# echo 123456 | base64
[root@master ~]# cat owncloud-secret.yaml
apiVersion: v1
kind: Secret
metadata:
type: Opaque
data:
  password: MTIzNDU2Cg==
[root@master ~]# kubectl apply -f  owncloud-secret.yaml
[root@master ~]# cat owncloud-deploy.yaml
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
  replicas: 1
  selector:
    matchLabels:
      app: owncloud
  template:
    metadata:
      labels:
        app: owncloud
    spec:
      containers:
      - name: owncloud
        image: 192.168.100.10/library/owncloud:latest
        imagePullPolicy: IfNotPresent
        envFrom:
        - configMapRef:
        env:
        - name: OWNCLOUD_DB_PASSWORD
          valueFrom:
            secretKeyRef:
              key: password
        ports:
        - containerPort: 80
        volumeMounts:
        - name: owncloud-pv
          mountPath: /var/www/html
      volumes:
      - name: owncloud-pv
        persistentVolumeClaim:
          claimName: owncloud-pvc
[root@master ~]# kubectl apply -f  owncloud-deploy.yaml
[root@master ~]# cat owncloud-svc.yaml
apiVersion: v1
kind: Service
metadata:
spec:
  selector:
    app: owncloud
  ports:
    - name: http
      port: 80
  type: NodePort
[root@master ~]#  kubectl apply -f .
[root@master ~]# kubectl get secrets
[root@master ~]# kubectl get pvc
[root@master ~]# kubectl get pod -owide
