Java8-05
kwan的解忧杂货铺 发表于 2024/08/31 13:43:57 2024/08/31
【摘要】 1.抽取对象属性List<Integer> ids = taskRecordDOList.stream().map(TaskRecordDO::getId).collect(Collectors.toList()); 2.obj2objList<DayStoreSkuSizeInvSalDTO> dtos = sizeInvSalList.stream() ....
1.抽取对象属性
2.obj2obj
                .map(item -> {
                    DayStoreSkuSizeInvSalDTO dayStoreSkuSizeInvSalDTO = new DayStoreSkuSizeInvSalDTO();
                    BeanUtil.copyProperties(item, dayStoreSkuSizeInvSalDTO);
                    return dayStoreSkuSizeInvSalDTO;
                }).collect(Collectors.toList());
3.属性转 set
转set:
final Set<String> sizeCodes = sizeInvSalList.stream().map(DayStoreSkuSizeInvSalDO::getSizeCode).collect(Collectors.toSet());
筛选转set:
final List<String> genderName = pageQuery.getGenderName();
        if (CollectionUtils.isNotEmpty(genderName)) {
            tags = tags.stream().filter(t -> genderName.contains(t.getGenderName()))
4.list2list
Map<Object, List<Student>> mapGroup = list.stream().collect(Collectors.groupingBy(v ->             v.getName() + v.getAge()));
List<List<Student>> categorys = new ArrayList<>(mapGroup.values());
5.toMap 重复 key
Map<Date, TimeAxisDTO> collect6 = timeAxisDTOListB.stream().collect(Collectors.
  toMap(TimeAxisDTO::getPeriodSdate, timeAxisDTO -> timeAxisDTO, (key1, key2) -> key1));
6.array2List
 * 数组转list  Arrays.asList不能add
 * @author : kwan
 * @version : 1.0.0
 * @date : 2022/8/10 00:21
public class Basic_collection_10_Array2List_01 {
    String[] strArray = new String[2];
    List list = Arrays.asList(strArray);
    //对转换后的list插入一条数据
    list.add("1");
    System.out.println(list);
 * 数组转list
 * @author : kwan
 * @version : 1.0.0
public class Basic_collection_10_Array2List_02 {
        ArrayList<String> list = new ArrayList<String>(Arrays.asList(strArray));
        list.add("1");
 * 数组转list
 * @author : kwan
 * @version : 1.0.0
public class Basic_collection_10_Array2List_03 {
        ArrayList< String> arrayList = new ArrayList<String>(strArray.length);
        Collections.addAll(arrayList, strArray);
        arrayList.add("1");
        System.out.println(arrayList);
7.map2list
需要将 map 打平转为 list
  final List<StoreSkuInvSalDTO> sal = groupName_2_salDatas.values().stream()
                .flatMap(x -> x.getProducts().stream())
8.List&String&Set 互转
//list转string
String str= String.join("','", list);
//list转set
Set<String> set = new HashSet<>(skuList);
//set转list
List<String> list = new ArrayList<>(set);
9.arrays2str
默写关键点
  • mapToObj
  • collect
  • Collectors
int[] res = {1, 2, 3, 4, 5};
final String collect = Arrays.stream(res).mapToObj(String::valueOf).collect(Collectors.joining(""));
        System.out.println(collect);
//StringBuilder低效写法
StringBuilder sb = new StringBuilder();
for (int i : res) {
    sb.append(i);
String result1 = sb.toString().trim();
System.out.println(result1);
