用dfs在带权树网络中统计可连接服务器对数目
Xxy_1008 发表于 2024/08/28 16:43:24 2024/08/28
【摘要】 深度优先搜索(Depth-First Search,简称 DFS)是一种用于遍历或搜索树或图的算法。其核心思想是尽可能深地访问节点,然后再回溯。DFS 可以用于解决许多计算机科学问题,如路径查找、连通分量、拓扑排序等。DFS 的基本概念DFS 可以用递归或迭代(借助栈)来实现。无论哪种实现方式,DFS 的基本步骤都是相同的:访问当前节点。标记当前节点为已访问。递归或迭代地访问当前节点的每一个...
DFS 的基本概念
  1. 访问当前节点。
  2. 标记当前节点为已访问。
  3. 递归或迭代地访问当前节点的每一个未访问的邻居节点。
DFS 的实现方法
递归实现
在递归实现中,函数会调用自身来实现深度优先的遍历。
def dfs_recursive(graph, start, visited=None):
    if visited is None:
        visited = set()
    visited.add(start)
    print(start)  # 访问节点
    for neighbor in graph[start]:
        if neighbor not in visited:
            dfs_recursive(graph, neighbor, visited)
# 示例用法
graph = {
    'A': ['B', 'C'],
    'B': ['A', 'D', 'E'],
    'C': ['A', 'F'],
    'D': ['B'],
    'E': ['B', 'F'],
    'F': ['C', 'E']
dfs_recursive(graph, 'A')
迭代实现
在迭代实现中,使用栈来模拟递归调用的过程。
def dfs_iterative(graph, start):
    visited = set()
    stack = [start]
    while stack:
        node = stack.pop()
        if node not in visited:
            visited.add(node)
            print(node)  # 访问节点
            # 将邻居节点压入栈中
            stack.extend(reversed(graph[node]))
# 示例用法
graph = {
    'A': ['B', 'C'],
    'C': ['A', 'F'],
    'D': ['B'],
    'E': ['B', 'F'],
    'F': ['C', 'E']
dfs_iterative(graph, 'A')
应用场景
1. 路径查找
DFS 可以用于在图中查找从起始节点到目标节点的路径。
def dfs_path(graph, start, goal, path=None):
    if path is None:
        path = [start]
    if start == goal:
        return path
        if neighbor not in path:
            new_path = dfs_path(graph, neighbor, goal, path + [neighbor])
            if new_path:
                return new_path
    return None
# 示例用法
graph = {
    'A': ['B', 'C'],
    'C': ['A', 'F'],
    'D': ['B'],
    'E': ['B', 'F'],
    'F': ['C', 'E']
print(dfs_path(graph, 'A', 'F'))  # 输出 ['A', 'C', 'F']
2. 检测连通分量
DFS 可以用于检测图中的连通分量,即图中的所有节点是否连通。
def connected_components(graph):
    visited = set()
    components = []
    for node in graph:
            component = []
            dfs_component(graph, node, visited, component)
            components.append(component)
    return components
def dfs_component(graph, node, visited, component):
    visited.add(node)
    component.append(node)
    for neighbor in graph[node]:
            dfs_component(graph, neighbor, visited, component)
# 示例用法
graph = {
    'A': ['B'],
    'B': ['A', 'D'],
    'C': ['E'],
    'D': ['B'],
    'E': ['C'],
    'F': []
print(connected_components(graph))  # 输出 [['A', 'B', 'D'], ['C', 'E'], ['F']]
时间复杂度和空间复杂度
  • 时间复杂度:DFS 的时间复杂度为 O(V + E),其中 V 是顶点的数量,E 是边的数量。每个节点和边都被访问一次。
  • 空间复杂度:在最坏情况下,递归实现的空间复杂度为 O(V),因需要存储递归调用栈。如果使用迭代实现,空间复杂度为 O(V),因需要存储栈或队列。
Sum up:
DFS 是一种非常有用的图遍历算法,适用于多种场景。通过递归或迭代来实现 DFS,可以解决路径查找、连通分量检测等问题。理解 DFS 的基本原理和实现方法,是学习更复杂图算法的基础。
 在带权树网络中统计可连接服务器对数目[中等]
题目:
给你一棵无根带权树,树中总共有 n 个节点,分别表示 n 个服务器,服务器从 0 到 n - 1 编号。同时给你一个数组 edges ,其中 edges[i] = [ai, bi, weighti] 表示节点 ai 和 bi 之间有一条双向边,边的权值为 weighti 。再给你一个整数 signalSpeed 。
如果两个服务器 a ,b 和 c 满足以下条件,那么我们称服务器 a 和 b 是通过服务器 c 可连接的 :
  • a < b ,a != c 且 b != c 。
  • 从 c 到 a 的距离是可以被 signalSpeed 整除的。
  • 从 c 到 b 的距离是可以被 signalSpeed 整除的。
  • 从 c 到 b 的路径与从 c 到 a 的路径没有任何公共边。
请你返回一个长度为 n 的整数数组 count ,其中 count[i] 表示通过服务器 i 可连接 的服务器对的 数目 。
示例 1:
输入:edges = [[0,1,1],[1,2,5],[2,3,13],[3,4,9],[4,5,2]], signalSpeed = 1
输出:[0,4,6,6,4,0]
解释:由于 signalSpeed 等于 1 ,count[c] 等于所有从 c 开始且没有公共边的路径对数目。
在输入图中,count[c] 等于服务器 c 左边服务器数目乘以右边服务器数目。
示例 2:
输入:edges = [[0,6,3],[6,5,3],[0,3,1],[3,2,7],[3,1,6],[3,4,2]], signalSpeed = 3
输出:[2,0,0,0,0,0,2]
解释:通过服务器 0 ,有 2 个可连接服务器对(4, 5) 和 (4, 6) 。
通过服务器 6 ,有 2 个可连接服务器对 (4, 5) 和 (0, 5) 。
所有服务器对都必须通过服务器 0 或 6 才可连接,所以其他服务器对应的可连接服务器对数目都为 0 。
提示:
  • 2 <= n <= 1000
  • edges.length == n - 1
  • edges[i].length == 3
  • 0 <= ai, bi < n
  • edges[i] = [ai, bi, weighti]
  • 1 <= weighti <= 106
  • 1 <= signalSpeed <= 106
  • 输入保证 edges 构成一棵合法的树。
题目分析:
        大致可以看出来这道题考察的是dfs+枚举 ,把每一个节点所连接的节点和权重加到一个列表里面储存,然后依次遍历这些节点,计算符合题意的解,加入到结果列表里面,返回结果即可。但是刚开始没有思路,不知从何下手,访问了题解区才完成代码实现。
代码实现:
class Solution:
    def countPairsOfConnectableServers(self, edges: List[List[int]], signalSpeed: int) -> List[int]:
        def dfs(a: int, fa: int, ws: int) -> int:
            cnt = 0 if ws % signalSpeed else 1
            for b, w in g[a]:
                if b != fa:
                    cnt += dfs(b, a, ws + w)
            return cnt
        n = len(edges) + 1
        g = [[] for _ in range(n)]
        for a, b, w in edges:
            g[a].append((b, w))
            g[b].append((a, w))
        ans = [0] * n
        for a in range(n):
            s = 0
            for b, w in g[a]:
                t = dfs(b, a, w)
                ans[a] += s * t
                s += t
        return ans
总结:
        这段代码实现了一个计算可连接服务器对数的算法。具体来说,该算法通过深度优先搜索(DFS)计算树中每对连接的服务器节点之间可传输信号的数量。
        首先,在 countPairsOfConnectableServers 方法中,定义了一个内部的 DFS 函数 dfs,用来计算从节点 a 出发,传输信号速度为 ws 时,与相邻服务器节点的连接对数量。
        然后,初始化变量 n 为服务器节点数量加一,初始化空列表 g 用来存储图的邻接表。接着,将输入的边信息 edges 添加到邻接表 g 中。
        继续,初始化长度为 n 的全零列表 ans 用来存储每个节点的连接对数。然后对每个节点 a 进行遍历,计算与相邻节点 b 的连接对数量,并将结果存储在 ans 中。
        最后,返回 ans,即每个节点的连接对数的列表。
