openGauss5.0.0极简版环境搭建(4)
datacloud 发表于 2024/08/07 20:08:58 2024/08/07
【摘要】 openGauss5.0.0极简版环境搭建(4):安装openGauss5.0.0极简版
1.set gloabal parameters
[root@openEuler2203 ~]# mkdir -p /opt/software/openGauss
[root@openEuler2203 ~]# touch /etc/profile.d/custom.sh
[root@openEuler2203 ~]# vim /etc/profile.d/custom.sh
在文末添加
export MY_HOSTNAME=openEuler2203             ## 主机名
export MY_HOSTIP=192.168.116.147             ## IP地址
export MY_SOFTWARE_DIRECTORY=/opt/software/openGauss  ## 软件包所在目录
export MY_XML=/opt/software/openGauss/clusterconfig.xml   ##集群配置XML文件
export OPENGAUSS_DOWNLOAD_URL= https://opengauss.obs.cn-south-1.myhuaweicloud.com/5.0.1/x86_openEuler_2203/openGauss-5.0.0-openEuler-64bit.tar.bz2 ##openGauss安装压缩包下载地址
[root@openEuler2203 ~]# source /etc/profile.d/custom.sh
[root@openEuler2203 ~]# hostnamectl set-hostname $MY_HOSTNAME
[root@openEuler2203 ~]# vim /etc/hosts
在文末添加
192.168.116.147  openEuler2203   #openGauss OM IP Hosts Mapping
后保存退出
[root@openEuler2203 ~]# cat /etc/hosts
127.0.0.1   localhost localhost.localdomain localhost4 locahost4.localdomain4
::1         localhost localhost.localdomain localhost6 locahost6.localdomain6
2.Disable firewalld service
[root@openEuler2203 ~]# systemctl disable firewalld.service #使防火墙服务失效
Removed /etc/systemd/system/multi-user.target.wants/firewalld.service.
Removed /etc/systemd/system/dbus-org.fedoraproject.FirewallD1.service.
[root@openEuler2203 ~]# systemctl stop firewalld.service #停止防火墙服务
[root@openEuler2203 ~]# systemctl status firewalld.service #查看防火墙状态
○ firewalld.service - firewalld - dynamic firewall daemon
     Loaded: loaded (/usr/lib/systemd/system/firewalld.service; disabled; vendor prese>
     Active: inactive (dead)
       Docs: man:firewalld(1)
Mar 27 19:24:28 openEuler2203 systemd[1]: Starting firewalld - dynamic firewall daemon>
Mar 27 19:24:28 openEuler2203 systemd[1]: Started firewalld - dynamic firewall daemon.
Mar 27 19:39:00 openEuler2203 systemd[1]: Stopping firewalld - dynamic firewall daemon>
Mar 27 19:39:01 openEuler2203 systemd[1]: firewalld.service: Deactivated successfully.
Mar 27 19:39:01 openEuler2203 systemd[1]: Stopped firewalld - dynamic firewall daemon.
lines 1-10/10 (END)
[1]+  Stopped                 systemctl status firewalld.service
3.Disable SELINUX
[root@openEuler2203 ~]# echo "SELINUX=disabled" >> /etc/selinux/config
[root@openEuler2203 ~]# cat /etc/selinux/config | grep "SELINUX=disabled"
SELINUX=disabled
[root@openEuler2203 ~]# reboot #重启系统
4.Configure encoding
[root@openEuler2203 ~]# echo "LANG=en_US.UTF-8" >> /etc/profile
或者
在文档末尾输入
LANG=en_US.UTF-8
5.Configure Timezone
[root@openEuler2203 ~]# date -R
Wed, 27 Mar 2024 19:52:08 +0800
[root@openEuler2203 ~]# hwclock
2024-03-27 19:52:30.992513+08:00
6.Close swap partition
[root@openEuler2203 ~]# swapoff -a
7.在各数据库节点上,关闭RemoveIPC
(1)修改/etc/systemd/logind.conf文件中的“RemoveIPC”值为“no”。
[root@openEuler2203 ~]# vim  /etc/systemd/logind.conf
RemoveIPC=no
#RuntimeDirectorySize=10%
#RuntimeDirectoryInodesMax=
RemoveIPC=no
#InhibitorsMax=8192
#SessionsMax=8192
(2)修改/usr/lib/systemd/system/systemd-logind.service文件中的“RemoveIPC”值为“no”
[root@openEuler2203 ~]# echo "RemoveIPC=no" >>
(3)重新加载配置参数
[root@openEuler2203 ~]# systemctl daemon-reload
[root@openEuler2203 ~]# systemctl restart systemd-logind
(4)检查修改是否生效
[root@openEuler2203 ~]# loginctl show-session | grep RemoveIPC
RemoveIPC=no
[root@openEuler2203 ~]# systemctl show systemd-logind | grep RemoveIPC
RemoveIPC=no
8.Configure SSH Service
[root@openEuler2203 ~]# echo "Banner none " >> /etc/ssh/sshd_config
[root@openEuler2203 ~]# echo "PermitRootLogin yes" >> /etc/ssh/sshd_config
或者
[root@openEuler2203 ~]# vim /etc/ssh/sshd_config
设置或输入
Banner none
PermitRootLogin yes
[root@openEuler2203 ~]# cat /etc/ssh/sshd_config
Banner none
PermitRootLogin yes
  1. 关闭HISTORY记录
[root@openEuler2203 ~]# echo "HISTSIZE=0 " >> /etc/profile
  1. 检查Python version
[root@openEuler2203 ~]# python3 --version
或者
[root@openEuler2203 ~]# python3 -V
Python 3.9.9
11.Configure sysctl.conf and performanc.sh
[root@openEuler2203 ~]# sysctl -w kernel.sem="250 85000 250 330"
kernel.sem = 250 85000 250 330
12.openGauss software download
[root@openEuler2203 ~]# cd $MY_SOFTWARE_DIRECTORY
[root@openEuler2203 openGauss]# wget $OPENGAUSS_DOWNLOAD_URL
--2024-03-27 21:46:48--  https://opengauss.obs.cn-south-1.myhuaweicloud.com/5.0.1/x86_openEuler_2203/openGauss-5.0.1-openEuler-64bit.tar.bz2 ##需先注册并登录opnGuass.org网站
Resolving opengauss.obs.cn-south-1.myhuaweicloud.com (opengauss.obs.cn-south-1.myhuaweicloud.com)... 122.9.127.163, 122.9.127.162
Connecting to opengauss.obs.cn-south-1.myhuaweicloud.com (opengauss.obs.cn-south-1.myhuaweicloud.com)|122.9.127.163|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 100889548 (96M) [application/x-bzip2]
Saving to: ‘openGauss-5.0.1-openEuler-64bit.tar.bz2’
openGauss-5.0.1-openE 100%[========================>]  96.21M  31.0MB/s    in 3.1s
2024-03-27 21:46:52 (31.0 MB/s) - ‘openGauss-5.0.1-openEuler-64bit.tar.bz2’ saved [100889548/100889548]
13.Uncompress openGauss Package and Modify directory permissions
[root@openEuler2203 openGauss]# ls
[root@openEuler2203 openGauss]# tar -jxvf  openGauss-5.0.0-openEuler-64bit.tar.bz2
/bin/
./bin/kdb5_util
./bin/klist
./simpleInstall/README.md
./simpleInstall/school.sql
./simpleInstall/install.sh
./version.cfg
[root@openEuler2203 openGauss]# rm -f openGauss-5.0.1-openEuler-64bit.tar.bz2
[root@openEuler2203 openGauss]# chown -R ouser:dbGroup /opt/software/openGauss/
[root@openEuler2203 openGauss]# chmod -R 755 $MY_SOFTWARE_DIRECTORY
或者
[root@openEuler2203 openGauss]# chmod g=rwx -R  $MY_SOFTWARE_DIRECTORY
[root@openEuler2203 openGauss]# chmod o=r-x -R  $MY_SOFTWARE_DIRECTORY
bin  include  lib                                      share          version.cfg
etc  jre      openGauss-5.0.0-openEuler-64bit.tar.bz2  simpleInstall
[root@openEuler2203 openGauss]# ls -l /opt/software/openGauss
total 32
drwxrwxr-x. 2 ouser dbGroup 4096 Dec 15 20:01 bin
drwxrwxr-x. 3 ouser dbGroup 4096 Dec 15 20:01 etc
drwxrwxr-x. 3 ouser dbGroup 4096 Dec 15 20:01 include
drwxrwxr-x. 4 ouser dbGroup 4096 Dec 15 20:01 jre
drwxrwxr-x. 5 ouser dbGroup 4096 Dec 15 20:01 lib
drwxrwxr-x. 5 ouser dbGroup 4096 Dec 15 20:01 share
drwxrwxr-x. 2 ouser dbGroup 4096 Dec 15 20:01 simpleInstall
-rwxrwxr-x. 1 ouser dbGroup   32 Dec 15 20:01 version.cfg
14.execute openGauss install
(1)install
[root@openEuler2203 openGauss]#su - ouser
[ouser@openEuler2203 ~]$ cd $MY_SOFTWARE_DIRECTORY
[ouser@openEuler2203 openGauss]$ ls
bin  etc  include  jre  lib  share  simpleInstall  version.cfg
[ouser@openEuler2203 openGauss]$ cd simpleInstall
[ouser@openEuler2203 simpleInstall]$ ls
finance.sql  install.sh  README.md  school.sql
sh install.sh
[ouser@openEuler2203 simpleInstall]$ sh install.sh -w "Mar152024@" -p 5432 &&source ~/.bashrc
[step 1]: check parameter
[step 2]: check install env and os setting
[step 3]: change_gausshome_owner
[step 4]: set environment variables
[2024-03-27 22:05:26.129][2589][][gs_ctl]:  done
[2024-03-27 22:05:26.129][2589][][gs_ctl]: server started (/opt/software/openGauss/data/single_node)
import sql file
Would you like to create a demo database (yes/no)? yes
Load demoDB [school,finance] success.
[complete successfully]: You can start or stop the database server using:
    gs_ctl start|stop|restart -D $GAUSSHOME/data/single_node -Z single_node
(2) 安装执行完成后,使用ps和gs_ctl查看进程是否正常
[ouser@openEuler2203 simpleInstall]$ ps ux | grep gaussdb
ouser       2592  2.1 10.2 5864372 777648 ?      Ssl  22:05   0:03 /opt/software/openGauss/bin/gaussdb -D /opt/software/openGauss/data/single_node
ouser       2868  0.0  0.0  22096  2348 pts/0    S+   22:08   0:00 grep --color=auto gaussdb
(3)查询数据库节点信息
[ouser@openEuler2203 simpleInstall]$ gs_ctl query -D /opt/software/openGauss/data/single_node
HA state:
        local_role                     : Normal
        static_connections             : 0
        db_state                       : Normal
        detail_information             : Normal
 Senders info:
No information
 Receiver info:
No information
