GEE重大更新涉及每一个人:没有云端项目的将被限制使用GEE
此星光明 发表于 2024/07/23 17:22:41 2024/07/23
【摘要】 目录GEE官方原邮件What you need to knowWe’re here to help翻译后你需要做的申请延期界面申请延期的链接 网址推荐0代码在线构建地图应用机器学习GEE官方原邮件Hello Earth Engine User,We are writing to let you know about key updates for Earth Engine's noncomm...
目录
GEE官方原邮件
We’re here to help
翻译后
你需要做的
申请延期界面
申请延期的链接
 网址推荐
0代码在线构建地图应用
机器学习
GEE官方原邮件
We are writing to let you know about key updates for Earth Engine's noncommercial offerings starting September 16, 2024. These updates are time-sensitive and may require you to change how you access Earth Engine.
Please note that Earth Engine will continue to remain free for noncommercial use.
We have provided additional details below to guide you through these changes.
There are two important updates to Earth Engine's noncommercial offerings:
Since 2022, we've encouraged the use of Cloud projects, which enable you to leverage other Google Cloud tools to maximize your impact. Earth Engine users with a Cloud project are able to run custom machine learning models with Vertex AI and export large datasets to BigQuery, enabling solutions for complex use cases such as palm oil cultivation prediction and flood mapping. Cloud projects also enable a number of administrative capabilities, such as automated workflows and managed access and resources, allowing users to enable these solutions more efficiently and securely.
As part of this effort, please note the following changes to Earth Engine:
What you need to do
To ensure all Earth Engine users have a consistent experience and access to the growing set of Cloud features, follow the guidelines below:
  1. All Earth Engine usage must be linked to Cloud projects:
    • As of June 2024, all new Earth Engine access requires a Cloud project.
    • Starting September 16, 2024, we will be limiting quotas* for accounts without Cloud projects, and most new Earth Engine features will only be available to users of Cloud projects.
    • Starting November 13, 2024, all Earth Engine access will require a Cloud project.
    • Transition to Cloud projects: If you're not already using Cloud projects to access Earth Engine, you’ll need to follow the steps in the configuration guide by November 13, 2024 to ensure uninterrupted access to Earth Engine. We recommend starting as early as possible since you may need additional permissions from your organization’s Cloud administrator.
    • If you wish to retain your individual access (without a Cloud project) beyond November 13, 2024, please review your eligibility and apply for an extension.
We remain steadfast in our commitment to offer Earth Engine free of charge for noncommercial and research use. If you're using Earth Engine for free, please ensure that your usage is consistent with our noncommercial and research use policy. We will be reviewing noncommercial usage to ensure that it aligns with our policies.
Additional actions required
  1. Verify your noncommercial use:
We’re here to help
We understand these changes may require some adjustments, but please know that we are here to support you. If you have any questions or require further assistance, please contact Earth Engine Registration Support.
Thanks for choosing Earth Engine.
- The Earth Engine Team
*You'll still be able to make requests, but having fewer concurrent online/high-volume requests and concurrent batch tasks will limit your throughput. Learn more in our quota documentation.
翻译后
你好地球引擎用户,
我们写信是为了让您了解Earth Engine从2024年9月16日开始的非商业产品的关键更新。这些更新具有时间敏感性,可能需要您更改访问Earth Engine的方式。 请注意,Earth Engine将继续免费用于非商业用途。 我们在下面提供了更多详细信息来指导您完成这些更改。
你需要知道的 Earth Engine的非商业产品有两个重要更新: 所有Earth Engine的使用必须链接到云项目: 自2022年以来,我们鼓励使用云项目,使您能够利用其他Google Cloud工具来最大限度地发挥影响力。拥有云项目的Earth Engine用户能够使用Vertex AI运行自定义机器学习模型,并将大型数据集输出到BigQuery,从而为棕榈油种植预测和洪水绘图等复杂用例提供解决方案。云项目还支持多种管理功能,例如自动化工作流程以及托管访问和资源,使用户能够更高效、更安全地启用这些解决方案。
作为此工作的一部分,请注意Earth Engine的以下更改:
截至2024年6月,所有新的Earth Engine访问都需要云项目。
从2024年9月16日开始,我们将限制没有云项目的帐户的配额 *,大多数新的Earth Engine功能将仅对云项目的用户可用。
从2024年11月13日开始,所有Earth Engine访问都需要云项目。
你需要做的
为了确保所有Earth Engine用户拥有一致的体验并访问不断增长的云功能,请遵循以下指南: 过渡到云项目:如果您尚未使用云项目访问Earth Engine,则需要在2024年11月13日之前遵循配置指南中的步骤,以确保不间断地访问Earth Engine。
我们建议尽早开始,因为您可能需要您组织的云管理员的额外权限。 如果您希望在2024年11月13日之后保留您的个人访问权限(没有云项目),请审查您的资格并申请延期。
验证您的非商业用途: 我们仍然坚定地承诺免费提供Earth Engine用于非商业和研究用途。如果您免费使用Earth Engine,请确保您的使用符合我们的非商业和研究使用政策。我们将审查非商业用途,以确保其符合我们的政策。
需要采取的其他行动 审查非商业用途的资格要求,以验证您的非商业用途。 如果您没有资格获得非商业用途,请按照本指南注册付费使用项目。 我们是来帮 我们明白这些更改可能需要一些调整,但请知道我们是来支持您的。
如果您有任何问题或需要进一步帮助,请联系Earth Engine Registration Support。 感谢您选择地球引擎。
- 地球引擎团队 * 您仍然可以发出请求,但并发在线/大容量请求和并发批处理任务较少将限制您的吞吐量。请参阅我们的配额文档了解更多信息。
申请延期界面
申请延期的链接
https://docs.google.com/forms/d/e/1FAIpQLSeB9_UuLO9b4ehOBlEPmM1s5YqiybdrYn3_YFE5pIJrz8YehQ/viewform
 网址推荐
0代码在线构建地图应用
https://invite.mapmost.com/#/login?source_inviter=nClSZANO
机器学习
https://www.cbedai.net/xg
