AMSR-E/Aqua 第 3 级全球每月地表土壤水分平均值和标准偏差
此星光明 发表于 2024/07/05 20:57:30 2024/07/05
【摘要】 ​AMSR-E/Aqua level 3 global monthly Surface Soil Moisture Averages V005 (AMSRE_AVRMO) at GES DISCGES DISC 的 AMSR-E/Aqua 第 3 级全球地表土壤水分月平均值 V005 (AMSRE_AVRMO)AMSR-E/Aqua level 3 global monthly Surfac...
AMSR-E/Aqua level 3 global monthly Surface Soil Moisture Standard Deviation V005 (AMSRE_STDMO) at GES DISC
GES DISC 的 AMSR-E/Aqua 第 3 级全球每月地表土壤水分标准偏差 V005 (AMSRE_STDMO)
简介
该数据集包含 1 乘 1 度网格单元的全球月度土壤湿度统计数据(标准偏差)。数据来源是 AMSR-E 每日土壤水分估算值(AE_Land3.002:AMSR-E/Aqua Daily L3 Surface Soil Moisture, Interpretive Parameters, QC EASE-Grids.第 2 版)。数据集涵盖的时间段为 2002-10-01 至 2011-09-30。
- **📊 数据集简介** 该数据集包含1x1度网格单元的全球月表面土壤湿度统计数据(标准偏差),数据来源为AMSR-E每日。[来源](https://monica.im/s/CuNBYiSw6n)
- **🌍 数据来源** 该数据集为AMSR-E/Aqua级别3全球月表面土壤湿度标准偏差V005(AMSRE_STDMO)在GES DISC的数据。数据包含全球月表面土壤湿度统计数据。[来源](https://monica.im/s/CuNBYiT4cr)
核心
Publisher NASA/GSFC/SED/ESD/GCDC/GESDISC
Contact Name PETER ROMANOV, PHD
Contact Email mailto:Peter.Romanov@noaa.gov
Bureau Code 026:00
Program Code 026:001
Public Access Level public
Geographic Coverage -180.0 -90.0 180.0 90.0
Temporal Applicability 2002-10-01T00:00:00Z/2011-09-30T23:59:59.999Z
Theme NEESPI NASA, geospatial
Language en-US
Homepage GES DISC
Issued 2009-03-10T00:00:00.000Z
Unique Identifier C1239898009-GES_DISC
Last Update 2011-09-30T00:00:00.000Z
共同核心扩展
citation NEESPI Data Center Project. 2002-07-01. AMSRE_STDMO. Version 005. AMSR-E/Aqua level 3 global monthly Surface Soil Moisture Standard Deviation V005. Greenbelt, MD, USA. AMSRE_STDMO. Archived by National Aeronautics and Space Administration, U.S. Government, Goddard Earth Sciences Data and Information Services Center (GES DISC). GES DISC. GES DISC. Digital Science Data.
creator NEESPI Data Center Project
data-presentation-form Digital Science Data
graphic-preview-description Sample image of AMSR-E global monthly soil moisture standard deviation at 1x1 degree, Jan 2010
graphic-preview-file https://docserver.gesdisc.eosdis.nasa.gov/public/project/Images/AMSRE_STDMO_005.png
issue-identification AMSRE_STDMO
release-place Greenbelt, MD, USA
series-name AMSRE_STDMO
代码
!pip install leafmap
!pip install pandas
!pip install folium
!pip install matplotlib
!pip install mapclassify
import pandas as pd
import leafmap
url = "https://github.com/opengeos/NASA-Earth-Data/raw/main/nasa_earth_data.tsv"
df = pd.read_csv(url, sep="\t")
df
leafmap.nasa_data_login()
results, gdf = leafmap.nasa_data_search(
    short_name="AMSRE_AVRMO",
    cloud_hosted=True,
    bounding_box=(-180, -90, 180, 90),
    temporal=("2002-10-01", "2011-09-30"),
    count=-1,  # use -1 to return all datasets
    return_gdf=True,
gdf.explore()
#leafmap.nasa_data_download(results[:5], out_dir="data")
引用
网址推荐
0代码在线构建地图应用
https://invite.mapmost.com/#/login?source_inviter=nClSZANO
机器学习
https://www.cbedai.net/xg
