CodeNavi自定义规则节点属性(基础节点)
yd_296685231 发表于 2024/06/27 10:56:02 2024/06/27
【摘要】 CodeNavi自定义规则的基础节点
节点
描述
示例
属性
名称
描述
值类型
示例
DSL 规则
annotation
注解
public class Test extends ArrayList {
@TheAnnotation(isOk = false, num = 3, str = Test.test1)
    public void functionWithAnnotation() {
name
名称
字符串
@TheAnnotation(isOk = false)
annotation ann where ann.name == "TheAnnotation";
annoMembers
注解的注解项
annomember节点集合
    ann.annoMembers contain am where
        am.name == "isOk";
annoMember
注解项
name
名称
字符串
        am.name == "str";
annoValue
注解项的具体值
literal、enumConstantAccess、fieldAcccess节点
        am.annoValue amv where and(
            amv is fieldAccess,
            amv.name == "test1"
recordDeclaration
类/接口声明
public class MyClass { }
public interface MyInterface { };
name
类名,包含包名
字符串
package com.huawei.secbrella.kirin.test.sourcefile.record;
public class TypeTest {
recordDeclaration rd where
    rd.name == "com.huawei.secbrella.kirin.test.sourcefile.record.TypeTest";
comments
注释
comment节点集合
// 注释
    rd.comments contain lineComment;
kind
类类型,可能是interface或class
字符串
    rd.kind == "class";
superTypes
所有直接和间接集成的父类和接口
recordDeclartion节点集合
class MyList extends ArrayList<String> {
class SecondMyList extends MyList {
    rd.superTypes contain sType where
        sType.name endWith "ArrayList";
directSuperTypes
直接集成的父类和接口
    rd.directSuperTypes contain sType where
definedFields
类中定义的所有字段
fieldDeclaration节点集合
class RecordDeclarationDemo extends Father { // 告警行
    private static int COUNT = 0;
    rd.definedFields.size() == 1;
definedConstructors
类中定义的所有构造方法
functionCall节点集合
    RecordDeclarationDemo() {}
    rd.definedConstructors.size() == 1;
definedMethods
类中定义的所有方法
functionCall节点集合
    public void recordDeclarationMethod01() {
    and(
        rd.definedMethods.size() == 1,
        rd.definedMethods contain fd where
            fd.name == "recordDeclarationMethod01"
anonymousInnerClassExpression
匿名内部类表达式
        new MemberClass() {  // 告警行
            @Override
            public void f() {
                int i = 0;
                System.out.println("aaaaa");
        }.f();
name
字符串
            @Override
            public void f() {
        }.f();
anonymousInnerClassExpression ac where and(
    ac.name == "MemberClass",
    ac.enclosingFunctionName == "main"
anonymousClassBody
任意节点集合
            @Override
            public void f() {
        }.f();
        ac.anonymousClassBody ab contain functionDeclaration;
arrayAccess
数组访问表达式
int a = arr[3];
log.info(arr2[1][3]);
arrayIndex
literal、任意access类节点、functionCall节点等
Integer[] arr = {0,1,2,3,4};
Integer i = arr[3];
arrayAccess aa where and(
    aa.arrayIndex is numLiteral,
    aa.arrayIndex.value == 3
base
variableAccess等任意access类节点、functionCall节点等
int a = arr[3];
arrayAccess arr where or(
    arr.base is variableAccess,
    arr.base is arrayAccess
rootBase
String[] a1 = arr[3];
String a2 = arr[1][3];
arrayAccess arr where arr.rootBase rb where and(
    rb is variableAccess,
    rb.name == "arr"
type
objectType节点
System.out.println(hello[1]);
    arr.type.name == "int";
arrayCreationExpression
数组创建表达式
int[] arr = new String[11];
dimensions
数组的维度集合
节点集合
String[] array = new String[10];
arrayCreationExpression ac where
    ac.dimensions.size() == 1;
dimensions[]
数组的维度
numLiteral、access类节点、functionCall节点等
String[] array = new String[10][a];
arrayCreationExpression ac where and(
    ac.dimensions.size() == 2,
    ac.dimensions[0] dm where and(
        dm is numLiteral,
        dm.value == 10
initArray
数组创建的初始化值
initArrayExpression
String[] array2 = new String[]{"abc", "dec"};
    ac.initArray.elements contain ele where
        ele.value == "abc";
type
数组创建的类型
objectType节点
    ac.type.name == "java.lang.String";
initArrayExpression
初始化数组表达式
int[] arr = {1, 2, 4};
@Parameter(names = {"ok", "hello", "yes"})
elements
数组初始化包含的元素集合
节点集合
initArrayExpression ia where
    ia.elements.size() == 3;
elements[]
数组初始化的元素
literal类节点、变量类
new String[] {"ok", "ey"};
    ia.elements[0].value == "ok";
functionDeclaration
方法声明
public void fun() {
    System.out.println(" ");
name
方法名
字符串
public static void debugFirst() {
functionDeclaration fd where
    fd.name == "debugFirst";
isConstructor
是否构造函数
布尔值
public MyTest() {}
    fd.isConstructor == true;
hasBody
是否有方法体
布尔值
    fd.hasBody;
comments
方法的注释
comments节点
// 注释
public static String sayHello() {}
    fd.comments contain lineComment;
type
返回值的类型
objectType节点
        return "hello";
    fd.type.name == "java.lang.String";
functionUsages
调用了该方法的位置
functionCall节点集合
    public void debugSecond(int param) {
        FunctionTest.debugFirst();
functionDeclaration fd where and(
    fd.name == "debugFirst",
    fd.functionUsages contain fc where
        fc.enclosingFunctionName == "debugSecond"
callers
调用了该方法的位置所在方法声明
functionDeclaration节点集合
    fd.callers contain cc where cc.name == "debugSecond"
assignStatements
方法体中的所有assignStatement节点
assignStatement节点集合
public void functionCalls_first_argument() {            String s = "hello";
    StringBuilder sb = new StringBuilder("");
functionDeclaration fd where fd.assignStatements.size() == 2;
fieldAccesses
方法体中的所有fieldAccesses节点
fieldAccesses节点集合
public void fieldAccesses_boolean() {
        System.out.println(this.testFlag);
    fd.fieldAccesses contain fa where
        fa.name == "testFlag";
functionCalls
方法体中的所有functionCall节点
functionCall节点集合
public void assignStatements_function_call_to_variable() {
        boolean result = "hello".equals("no");
        System.out.println(result);
    fd.functionCalls contain fc where
        fc.name == "equals";
ifBlocks
方法体中的所有ifBlock节点
ifBlock节点集合
public void loopBlocks_for(boolean flag) {
        if (flag) {
            for (int i = 0; i < 10; i++) {
                System.out.println(i);
    fd.ifBlocks contain ib where
        ib contain forBlock;
loopBlocks
方法体中的所有loopBlock节点
loopBlock节点集合
public void loopBlocks_while(boolean flag) {
        int m = 10;
        while (m > 0) {
            m--;
    fd.loopBlocks contain ib where
        ib is whileBlock;
parameters
方法体中的所有parameterDeclaration节点
parameterDeclaration节点集合
public void loopBlocks_for(boolean flag) {}
    fd.parameters contain pa where
        pa.name == "flag";
returnStatements
方法体中的所有returnStatement节点
returnStatement节点集合
public int returnStatements_return_int(int m) {
        if (m > 10) {
            if (m < 100) {
                return randomInt();
        return 0;
    fd.returnStatements contain rs where
        rs in ifBlock;
variableAccesses
方法体中的所有variableAccess节点
variableAccess节点集合
        int m = 10;
        while (m > 0) {
            m--;
    fd.variableAccesses contain va where
        va.name == "m";
body
方法体
body语句块
        int m = 10;
        while (m > 0) {
            m--;
    fd.body contain assignStatement;
body.statementNum
方法体的语句数量
数值
public String functionCase() {
        Boolean result = validNull();
        return "";
    fd.body.statementNum == 2;
firstStatement
方法的第一个完整的语句
任意节点
        return "";
    fd.firstStatement contain variableDeclaration;
lastStatement
方法的最后一个完整的语句
任意节点
private boolean isNumeric(String str) {
        return false;
    fd.lastStatement contain returnStatement;
subMethods
所有重写了该方法的子类方法
functionDecalration节点集合
public class FatherDemo {
        public void fatherDemoMethod() { // 告警行
            System.out.println("father class");
        public void demoMethod() {
    public class SonDemo extends FatherDemo {
            System.out.println("Son class");
    and(
        fd.name == "fatherDemoMethod",
        fd.subMethods contain fd2 where
            fd2.name == "fatherDemoMethod"
superMethods
该方法重写的父类方法
    and(
        fd.superMethods contain fd2 where
paramDeclaration
参数声明,方法定义中的参数定义
public void fun(String name) {
    System.out.println(name);
name
参数的名字
字符串
paramDeclaration pa where pa.name == "name";
type
参数的类型
objectType节点
paramDeclaration pa where pa.type.name == "java.lang.String";
functionCall
方法调用
Objects.isNull(str);
String name = person.getName();
name
方法名
字符串
functionCall fc where
    fc.name == "isNull";
function
调用的方法
        return "";
    public Boolean validNull() {
        return false;
functionCall fc where fc.function fd where and(
    fd is functionDeclaration,
    fd.name == "validNull",
        rs.returnValue.value == false
possibleFunctions
调用的方法及其重写与被重写的方法,用于多态类创建对象时,声明类型为父类,实例化类型为子类型,调用对象方法时function属性应定位到子类的方法中,但实际会定位到父类方法中,用此属性规避这种问题导致的漏报
        Son sg = new GrandSon();
        sg.run();  //父类和子类都有这个方法
functionCall fc2 where and(
    fc2.base.name == "sg",
    fc2.possibleFuncs contain fun where and(
        fun.enclosingClass.name endWith "GrandSon",
        fun contain stringLiteral sl1 where
                sl1.value == "Grandson is running"
base
直接调用者
valueAccess类节点、functionCall节点等
MyRandom.aa();
functionCall fc where and(
    fc.name == "aa",
    fc.base.name == "MyRandom"
rootBase
根调用者
a().b().c();
functionCall fc where and(    fc.name == "c",    fc.rootBase is functionCall,    fc.rootBase.name == "a");
arguments
入参集合
valueAccess类节点、functionCall节点等的集合
sb.append(s.toUpperCase(Locale.ENGLISH));
functionCall fc where fc.arguments contain arg where
and(
     arg is functionCall,
     arg.name == "toUpperCase",
     arg.arguments contain fieldAccess
arguments[n]
第n个入参
add(a, b);
    fc.arguments[1].name == "b";
argument
函数入参
JSON.parseObject("{\"name\":\"A\"}", Demo.class);
name
参数名
字符串
argument arg where arg.name == "i";
argumentIndex
参数的index
数值
argument arg where arg.argumentIndex == 0;
argumentHolder
使用该参数的方法调用
functionCall节点
argument arg where arg.argumentHolder.name == "println";
methodReferenceExpression
方法引用表达式
List::stream
name
方法名
字符串
Supplier<Integer> size = list::size;
methodReferenceExpression mf where
mf.name == "size";
function
调用的方法
mf.function.name == "size";
type
方法返回值类型
objectType节点
mf.type.name == "int";
objectCreationExpression
对象创建表达式
new ArrayList();
name
方法名
字符串
new MethodRefTypeTest();
objectCreationExpression obc where
obc.name == "MethodRefTypeTest";
type
返回值类型
objectType节点
obc.type.name == "com.huawei.secbrella.kirin.test.sourcefile.methodRefType.MethodRefTypeTest";
function
调用的构造方法
public class MethodRefTypeTest {
    MethodRefTypeTest() {
    obc.function.name == "MethodRefTypeTest";
arguments
入参集合
new String("Hello");
obc.arguments.size() == 1;
arguments[n]
第n个入参
obc.arguments[0].value == "Hello";
assignStatement
赋值语句,同时也是二元表达式
a = 10;
lhs
赋值语句的左值
valueAccess类节点
a = 10;
assignStatement ass where ass.lhs.name == "a";
rhs
赋值语句的右值
literal类节点、valueAccess类节点、functionCall类节点
a = 10;
assignStatement ass where ass.rhs.value == 10;
binaryOperation
二元表达式,包括 +、-、*、/运算、=赋值运算等
a = 10;
a + b;
lhs
二元表达式的左值
int i = 1;
binaryOperation bo where bo.lhs.name == "i";
operator
二元表达式的操作符
字符串
while (i == 1)
binaryOperation bo where bo.operator == "==";
rhs
二元表达式的右值
a > b;
binaryOperation bo where bo.rhs.name == "b";
operands
二元表达的操作对象(左值和右值)
节点集合
a > b;
bo.operands contain op where
op.name == "a";
castExpression
强制类型转换
Son sonFromDad = (Son) dad;
castType
目标类型
node
ArrayList second = (ArrayList) list;
castExpression ce where
ce.castType.name == "java.util.ArrayList";
operand
操作对象
node
ce.operand.name == "list";
fieldDeclaration
字段定义(声明)
public static int count = 0;
private String name;
name
字段名
字符串
private int aes_key = 3;
fieldDeclaration fd where fd.name == "aes_key";
comments
注释
comment节点集合
// 注释
fieldDeclaration fd where fd.comments contain lineComment;
initializer
初始化值
任意节点
fieldDeclaration fd where fd.initializer.value == 3;
valueUsages
使用该字段的节点
public void test() {
        this.aes_key = 10;
fieldDeclaration fed where
fed.valueUsages contain va where
va in functionDeclaration fd where fd.name == "test";
fieldAccess
字段(成员变量)访问
System.out.println(Person.name);
name
字段名
字符串
Person.name
fieldAccess fa where fa.name == "name";
field
字段定义
fieldDeclaration节点
        this.aes_key = 10;
fieldAccess fa where fa.field.initializer.value == 3;
base
访问者
任意节点
Person.name
fieldAccess fa where fa.base.name == "Person";
enumDeclaration
枚举类声明
enum MyEnum {
name
枚举全类名
字符串
enum TheEnum {
    PUT, HEAD, DELETE;
enumDeclaration ed where ed.name == "com.huawei.secbrella.kirin.test.sourcefile.enumConstantTest.TheEnum";
definedFields
定义的所有字段
enum Planet {
    MERCURY(3.303e+23, 2.4397e6),
    VENUS(1, 6.0518e6),
    public static final double G = 6.67300E-11;
    private final double mass; // in kilograms
    private final double radius; // in meters
    ed.definedFields.size() == 3;
definedMethods
定义的所有方法
enum Planet {
    Planet(double mass, double radius) {
        this.mass = mass;
        this.radius = radius;
    ed.definedMethods.size() == 1;
enumConstants
定义的所有枚举常量
enumConstant节点集合
enum Planet {
    VENUS(1, 6.0518e6),
    EARTH(5.976e+24, 6.37814e7),
    MARS(6.421e+23, 3.3972e7),
enumDeclaration ed where ed.enumConstants.size() == 4;
enumConstantDeclaration
枚举常量声明, 枚举类中用逗号分隔的常量
public enum DayOfWeek {
        MONDAY, TUESDAY, WEDNESDAY
enum Planet {
    VENUS(1, 6.0518e6),
    EARTH(5.976e+24, 6.37814e7);
    public static final double G = 6.67300E-11; // 成员变量声明
name
枚举常量名
字符串
enumConstantDeclaration ed where ed.name == "Monday";
definedEnumConstantFields
枚举常量中定义的所有字段
fieldDeclaration节点的集合
enum Week3 { Monday, Tuesday, Wednesday, Thursday, Friday, Saturday { private String tmp = "test"; }}
enumConstantDeclaration ed where ed.definedEnumConstantFields.size() == 1;
definedEnumConstantMethods
枚举常量中定义的所有方法
functionDeclaration节点的集合
enum Week3 {
    Saturday {
    Sunday {
        public void work() {
            System.out.println("休息");
    ed.definedEnumConstantMethods contain fd where
        fd.name == "work";
enumConstantArguments
枚举常量中的入参
literal节点、valueAccess类节点、functionCall节点等的集合
enum Planet {
    NEPTUNE(1.024e+26, 2.4746e6);
        this.mass = mass;
ed.enumConstantArguments.size() == 2;
enumConstantAccess
枚举常量访问
public void fun(DayOfWeek n) {
System.out.println(DayOfWeek.MONDAY);
System.out.println(n.MONDAY);
name
枚举常量名
字符串
Planet.EARTH;
enumConstantAccess ea where ea.name == "EARTH";
enumConstant
访问的枚举常量所在声明
enumConstant节点
Planet.EARTH;
enumConstantAccess ea where ea.enumConstant.name == "EARTH";
base
访问者
任意节点
Planet.EARTH;
enumConstantAccess ea where ea.base.name == "Planet";
exceptionBlock
异常捕捉代码块,包括tryBlock、catchBlock、finallyBlock
try {
    int num = 1/0;
} catch (Exception e) {
    throw new RuntimeException(e);
} finally {
    System.out.println("finally");
tryBlock
try语句块
tryBlock节点
try {
    int num = 1/0;
} finally {
exceptionBlock eb where
eb.tryBlock contain variableDeclaration;
catchBlocks
所有的catch语句块
catchBlock节点的集合
try {
    int num = 1/0;
} finally {
eb.catchBlocks contain cb where cb contain throwStatement;
finallyBlock
finally语句块
finallyBlock节点
try {
    int num = 1/0;
} finally {
    eb.finallyBlock contain functionCall fc where
        fc.name == "println";
tryBlock
try语句块
try { }
_
try语句块
tryBlock节点
try {
    int num = 1/0;
} finally {
tryBlock tb where
tb contain variableDeclaration;
catchBlock
catch语句块
try {
int num = 1/0;
System.out.println(e);
parameters
node list
try {
    int num = 1/0;
catchBlock cb where
    cb.parameters contain p where
        p.name == "e";
finallyBlock
finally代码块
finally {
_
finally语句块
finallyBlock节点
try {
    int num = 1/0;
} finally {
finallyBlock fb where
    fb contain functionCall fc where
tryWithResources
tryWithResources异常捕捉代码块
try (Statement stmt = con.createStatement()) {
            System.out.println("try-with-resources block");
        } catch (SQLException e1) {
        } catch (Exception e2) {
            System.out.println(e2);
tryBlock
try语句块
tryBlock节点
tryWithResources eb where
catchBlocks
所有的catch语句块
catchBlock节点的集合
finallyBlock
finally语句块
finallyBlock节点
} finally {
resources
任意节点
若干statements节点的集合
tryWithResources twr where
    twr.resources contain re where
        re contain functionCall fc where
                    fc.name == "createStatement";
throwStatement
throw语句,异常抛出语句
try {
throw new Exception();
operand
node
throwStatement tr where
tr.operand is objectCreationExpression;
forBlock
for循环代码块
for (int i = 0; i < list.size(); i++) {
initialization
变量初始化
variableDeclaration、 variableAccess节点
forBlock fb where fb.initialization.name == "i";
condition
循环条件
binaryOperation
forBlock fb where fb.condition.rhs is functionCall;
iteration
迭代操作
unaryOperation节点
forBlock fb where fb.iteration.operator == "++";
body
循环体
body语句块
i++;
forBlock fb where
fb.body contain variableAccess vs where
vs.name == "i";
body.statementNum
body语句块的语句数量
数值
i++;
forBlock fb where
fb.body.statementNum == 1;
firstStatement
forBlock的第一条语句
任意节点
i++;
forBlock fb where
fb.firstStatement contain unaryOperation;
lastStatement
forBlock的最后一条语句
任意节点
for (int j1 = 1; j1 < 50 && k1 < 50; j1++, k1++) {
System.out.println(j1);
k1++;
forBlock fb where
fb.lastStatement contain unaryOperation;
forEachBlock
forEach循环代码块
for (Integer integer : list) {
variable
循环变量
variableDeclaration节点
for (String str : list) {
System.out.println(str);
forEachBlock fb where and(
fb.variable is variableDeclaration,
fb.variable.name == "str"
iterable
被循环的变量
任意节点
fb.iterable.name == "list";
body
循环体
body语句块
fb.body contain functionCall;
body.statementNum
body语句块的语句数量
数值
firstStatement
forEachBlock的第一条语句
任意节点
lastStatement
forEachBlock的最后一条语句
任意节点
System.out.print(’ ‘);
fb.lastStatement contain functionCall;
whileBlock
while循环语句块
while() {
condition
循环条件
任意节点
while(i > list.size()) {
i++;
whileBlock wb where
wb.condition contain binaryOperation bo where
bo.lhs.name == "i";
body
循环体
body语句块
while(i > list.size()) { i++;}
whileBlock wb where wb.body contain unaryOperation;
body.statementNum
body语句块的语句数量
数值
i++;
whileBlock wb where
wb.body.statementNum == 2;
firstStatement
whileBlock的第一条语句
任意节点
i++;
whileBlock wb where
wb.firstStatement contain unaryOperation;
lastStatement
whileBlock的最后一条语句
任意节点
i++;
whileBlock wb where
wb.lastStatement contain functionCall;
doWhileBlock
do…while语句块
do {
} while ();
condition
循环条件
任意节点
do {
i++;
} while (i < 10);
doWhileBlock wb where
bo.lhs.name == "i";
body
循环体
body语句块
do {
i++;
} while (i < 10);
body.statementNum
body语句块的语句数量
数值
do {
i++;
System.out.print(i);
} while (i < 10);
whileBlock wb where
firstStatement
forBlock的第一条语句
任意节点
do {
i++;
} while (i < 10);
lastStatement
forBlock的最后一条语句
任意节点
do {
i++;
} while (i < 10);
loopBlock
循环语句块,包括forBlock, forEachBlock, doWhileBlock, whileBlock
for() {};
while() {};
condition
循环条件
任意节点
i++;
whileBlock wb where
bo.lhs.name == "i";
body
循环体
body语句块
i++;
whileBlock wb where
body.statementNum
body语句块的语句数量
数值
i++;
whileBlock wb where
firstStatement
loopBlock的第一条语句
任意节点
i++;
whileBlock wb where
lastStatement
loopBlock的最后一条语句
任意节点
i++;
whileBlock wb where
ifBlock
if语句块
if(num > 10) {
condition
if条件
binaryOperation节点
if (m > 10) {
System.out.println("m > 10");
System.out.println("m <= 10");
ifBlock ib where
ib.condition contain binaryOperation bo where
bo.operator == ">";
thenBlock
if条件为true执行的语句
block语句块
if (m > 10) {
ifBlock ib where
ib.thenBlock contain stringLiteral ss where
ss.value == "m > 10";
elseBlock
if条件为false执行的语句
block语句块
if (m > 10) {
ifBlock ib where
ib.elseBlock contain stringLiteral ss where
ss.value == "m <= 10";
thenBlock
then语句块,if 条件成立后执行
if(num > 10) {
do();
_
if条件为true执行的语句
block语句块
if (m > 10) {
thenBlock tb where
tb contain stringLiteral ss where
elseBlock
else语句块
else {
_
if条件为false执行的语句
block语句块
if (m > 10) {
elseBlock eb where
eb contain stringLiteral ss where
importDeclaration
import声明
import com.huawei.java….
name
import的类名
字符串
import static java.lang.String.valueOf;
importDeclaration im where
im.name == "java.lang.String.valueOf";
isStatic
import是否为静态
布尔值
im.isStatic;
instanceofExpression
类型判断表达式
if(father instanceof Father) {
lhs
左值
任意节点
instanceofExpression ie where
ie.lhs.name == "father";
rhs
右值,类型值
全类名常量
list instanceof List
ie.rhs.name == "java.util.List";
lambdaExpression
lambda表达式
list.forEach(integer -> {
if (integer == 1) {
System.out.println("单数");
parameters
参数
paramDeclaration节点
    if (integer == 1) {
lambdaExpression le where
le.parameters contain p where p.name == "integer";
body
方法体
block语句块
    if (integer == 1) {
le.body contain variableAccess va where va.name == "integer";
body.statementNum
body语句块的语句数量
数值
    if (integer == 1) {
le.body.statementNum == 1;
firstStatement
lambdaExpression的第一条语句
任意节点
    if (integer == 2) {
le.firstStatement contain ifBlock;
lastStatement
lambdaExpression的最后一条语句
任意节点
    if (integer == 3) {
     System.out.print("双数");
    le.lastStatement contain functionCall fc where
        fc.name == "print";
literal
常量,包括字符串、布尔、数字常量
Constant appeared in source code
value
常量值
字符串、数值、布尔值等
int a = 1;
literal ll where ll.value == 1;
stringLiteral
字符串常量
System.out.println("aaa");
length
字符串长度
数值
stringLiteral l where l.length == 3;
value
字符串值
字符串
stringLiteral l where l.value == "aaa";
boolLiteral
布尔常量
System.out.println(true);
value
布尔值
布尔值
boolLiteral l where l.value == true;
numLiteral
数字常量
System.out.println(1);
value
数值
数值
numLiteral l where l.value == 1;
returnStatement
return语句
return a;
returnValue
返回值
任意节点
return a;
returnStatement rs where rs.returnValue.name == "a";
breakStatement
break语句
break;
_
_
_
break;
breakStatement;
continueStatement
continue语句
continue;
_
_
_
continue;
continueStatement;
staticBlock
静态语句块
class A {
_
_
block语句块
static {
int n = 5;
staticBlock sb where sb contain variableDeclaration;
switchBlock
Switch语句块
switch (n) {
case 1:
do();
selector
switch语句的判断条件
任意节点
switch (m) {
switchBlock swb where
swb.selector.name == "m";
caseStatement
case语句块
switch (m) {
case 12:
System.out.println("hello");
break;
default:
System.out.println("default value");
break;
_
_
caseStatement节点
switch (m) {
    case 12:
        break;
    default:
         break;
caseStatement cs where cs contain literal;
defaultStatement
default语句块
switch (m) {
case 12:
break;
default:
break;
_
_
defaultStatement节点
switch (m) {
    case 12:
        break;
    default:
         break;
switchBlock swb where swb contain defaultStatement;
synchronizedBlock
同步代码块
synchronized(i){
do();
lock
锁
任意节点
synchronized (i1) {
synchronizedBlock sy where
sy.lock contain variableAccess va where
va.name == "i1";
body
执行语句
block语句块
synchronized (i2) {
sy.body contain functionCall fc where
body.statementNum
body语句块的语句数量
数值
synchronized (i2) { System.out.println("hello");}
synchronizedBlock sb where sb.body.statementNum == 1;
firstStatement
synchronizedBlock的第一条语句
任意节点
synchronized (i) {
    i++;
sb.firstStatement contain unaryOperation;
lastStatement
synchronizedBlock的最后一条语句
任意节点
synchronized (i) {
    i++;
sb.lastStatement contain functionCall;
ternaryOperation
条件表达式/三目运算
res = 2 > 2 ? true : false;
condition
三目运算的判断条件
binaryOperation
boolean res = num > 1 ? true : false;
ternaryOperation tp where
tp.condition.lhs.name == "num";
thenExpression
三目运算条件为真的操作
任意节点
tp.thenExpression contain literal ll where
ll.value == true;
elseExpression
三目运算条件为假的操作
任意节点
String str = num > 1 ? "true" : "false";
tp.elseExpression contain literal ll where
ll.value == "false";
unaryOperation
一元表达式
a++;
--b;
isPrefix
是否运算符前置
布尔值
a++;
unaryOperation uo where uo.isPrefix == false;
operand
操作对象
任意节点
i++;
unaryOperation uo where uo.operand.name == "i";
operator
运算符
字符串
i++;
unaryOperation uo where uo.operator == "++";
variableAccess
变量访问
int a = arr[3];
log.info(a);
name
变量名
字符串
int a = arr[3];
log.info(a);
variableAccess va where va.name == "a";
variable
被访问的变量的定义
variableDeclaration
int a = arr[3];
log.info(a);
variableAccess va where va.variable.name == "a";
variableDeclaration
变量声明
int a = arr[3];
int b;
log.info(a);
name
变量名
字符串
int a = arr[3];
variableDeclaration vd where vd.name == "a";
initializer
初始化值
任意节点
int a = arr[3];
variableDeclaration vd where vd.initializer is arrayAccess;
valueUsages
使用该变量的所有位置
任意节点
int a = arr[3];
log.info(a);
    vd.valueUsages contain vu where
        vu in functionCall;
comment
注释,包括行注释、块注释、javaDoc注释
// xxx
/* xxx */
/** xxx */
content
注释的内容
字符串
// function declaration
public void getInstance(String des) {}
comment cm where cm.content match ".*";
commentedNode
被注释的节点
节点
lineComment cm where cm.commentedNode is functionDeclaration;
lineComment
行注释
// 注释
content
注释的内容
字符串
comment cm where cm.content match ".*function.*";
commentedNode
被注释的节点
节点
blockComment
块注释
/* 注释 */
content
注释的内容
字符串
/* block comment */
blockComment bc where bc.content contain "block comment";
commentedNode
被注释的节点
节点
/* block comment */
int a = 2;
blockComment bc where bc.commentedNode contain variableDeclaration;
javadocComment
javadoc注释
注释
content
注释的内容
字符串
* 功能描述
* @since 2023-03-20
public class EncryptCommon {}
javadocComment jd where jd.content contain "@since";
commentedNode
被注释的节点
节点
* 功能描述
* @since 2023-03-20
    jd.commentedNode is recordDeclaration;
