HCCDP-wordpress
yd_60545498 发表于 2024/06/16 22:42:12 2024/06/16
【摘要】 参考https://support.huaweicloud.cn/utiltg-obs/obs_11_0006.htmlobsutil 介绍obsutil 是一款用于访问管理华为云对象存储服务(Object Storage Service,OBS)的命令行工具,您可以使用该工具对OBS进行常用的配置管理操作,如创建桶、上传文件/文件夹、下载文件/文件夹、删除文件/文件夹等。对于熟悉命令行程...
#!/bin/bash
# 数据库,Wordpress 初始密码定义 /root/INIT_PASSWORD
INIT_ID="admin"
INIT_PASSWORD=$(date +%s | sha256sum | base64 | head -c 10)
echo $INIT_PASSWORD > /root/INIT_PASSWORD
# 安装PHP 8
#添加第三方源
sudo yum install -y https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
sudo yum install -y https://rpms.remirepo.net/enterprise/remi-release-7.rpm
#启用php 8
sudo yum -y install yum-utils
sudo yum-config-manager --disable 'remi-php*'
sudo yum-config-manager --enable remi-php80
yum install -y php php-bcmath php-cli php-common php-devel php-fpm php-gd php-intl php-ldap php-mbstring php-mysqlnd php-odbc php-pdo php-pear php-pecl-xmlrpc php-pecl-zip php-process php-snmp php-soap php-sodium php-xml
# 安装所需的包
#yum update -y
yum install -y httpd mariadb-server expect
chown -R apache:apache /var/www
chmod 2775 /var/www
find /var/www -type d -exec sudo chmod 2775 {} \;
find /var/www -type f -exec sudo chmod 0664 {} \;
systemctl start httpd
systemctl enable httpd
systemctl start mariadb
systemctl enable mariadb
# 数据库密码重置 ============================
/usr/bin/mysqladmin -u root password "$INIT_PASSWORD"
SECURE_MYSQL=$(expect -c "
set timeout 10
spawn mysql_secure_installation
expect \"Enter current password for root (enter for none):\"
send \"$INIT_PASSWORD\r\"
expect \"Change the root password?\"
send \"y\r\"
expect \"New password\"
expect \"Re-enter new password\"
expect \"Remove anonymous users?\"
send \"y\r\"
expect \"Disallow root login remotely?\"
send \"y\r\"
expect \"Remove test database and access to it?\"
send \"y\r\"
expect \"Reload privilege tables now?\"
send \"y\r\"
expect eof
echo "$SECURE_MYSQL"
# Mysql 设置:创建 Wordpress 数据库,创建用户/密码
mysql -u root -p$INIT_PASSWORD mysql -e "\
CREATE DATABASE wordpress;
GRANT ALL PRIVILEGES ON *.* TO '$INIT_ID'@'localhost' IDENTIFIED BY '$INIT_PASSWORD' WITH GRANT OPTION;
GRANT ALL PRIVILEGES ON *.* TO '$INIT_ID'@'%'  IDENTIFIED BY '$INIT_PASSWORD' WITH GRANT OPTION;
FLUSH PRIVILEGES;\
# 安装 Wordpress
mkdir -p /var/www/
pushd /var/www/
wget https://wordpress.org/latest.tar.gz
tar -xzf latest.tar.gz
rm -f latest.tar.gz
chown -R apache:apache wordpress
mv html{,_old}
mv wordpress html
popd
MYIP=$(curl -s whatismyip.akamai.com)
curl -s --data "dbname=wordpress&uname=$INIT_ID&pwd=$INIT_PASSWORD&dbhost=localhost&prefix=wp_&submit=Submit" \
http://$MYIP/wp-admin/setup-config.php?step=2
curl -s --data "weblog_title=Wordpress+QuickStart&user_name=$INIT_ID&admin_password=$INIT_PASSWORD& \
admin_password2=$INIT_PASSWORD&admin_email=admin%40example.com&blog_public=1&Submit=Install+WordPress" \
http://$MYIP/wp-admin/install.php?step=2
# 结束:请通过以下 IP 地址进行访问以确认
echo http://$MYIP
echo ID : $INIT_ID
echo PW : $INIT_PASSWORD
