基于GA遗传优化的CNN-LSTM的时间序列回归预测matlab仿真
简简单单做算法 发表于 2024/06/09 00:01:40 2024/06/09
【摘要】 1.算法运行效果图预览  2.算法运行软件版本matlab2022a 3.部分核心程序figureplot(Error2,'linewidth',2);grid onxlabel('迭代次数');ylabel('遗传算法优化过程');legend('Average fitness'); [V,I] = min(JJ);X = phen1(I,:); LR = ...
1.算法运行效果图预览
2.算法运行软件版本
matlab2022a
3.部分核心程序
figure
grid on
xlabel('迭代次数');
ylabel('遗传算法优化过程');
[V,I] = min(JJ);
X     = phen1(I,:);
LR             = X(1);
numHiddenUnits1 = floor(X(2))+1;% 定义隐藏层中LSTM单元的数量
numHiddenUnits2 = floor(X(3))+1;% 定义隐藏层中LSTM单元的数量
%CNN-GRU-ATT
layers = func_model2(Dim,numHiddenUnits1,numHiddenUnits2);
%训练
[Net,INFO] = trainNetwork(Nsp_train2, NTsp_train, layers, options);
IT  =[1:length(INFO.TrainingLoss)];
Accuracy=INFO.TrainingRMSE;
figure;
plot(IT(1:1:end),Accuracy(1:1:end));
xlabel('epoch');
ylabel('RMSE');
%数据预测
Dpre1 = predict(Net, Nsp_train2);
Dpre2 = predict(Net, Nsp_test2);
%归一化还原
T_sim1=Dpre1*Vmax2;
T_sim2=Dpre2*Vmax2;
%网络结构
analyzeNetwork(Net)
figure
subplot(211);
plot(1: Num1, Tat_train,'-bs',...
    'LineWidth',1,...
    'MarkerSize',6,...
    'MarkerEdgeColor','k',...
    'MarkerFaceColor',[0.9,0.0,0.0]);
hold on
plot(1: Num1, T_sim1,'g',...
    'LineWidth',2,...
    'MarkerSize',6,...
    'MarkerFaceColor',[0.9,0.9,0.0]);
legend('真实值', '预测值')
xlabel('预测样本')
ylabel('预测结果')
grid on
subplot(212);
plot(1: Num1, Tat_train-T_sim1','-bs',...
    'LineWidth',1,...
    'MarkerSize',6,...
xlabel('预测样本')
ylabel('预测误差')
grid on
ylim([-50,50]);
figure
subplot(211);
plot(1: Num2, Tat_test,'-bs',...
    'LineWidth',1,...
    'MarkerSize',6,...
hold on
plot(1: Num2, T_sim2,'g',...
    'LineWidth',2,...
    'MarkerSize',6,...
xlabel('测试样本')
ylabel('测试结果')
grid on
subplot(212);
plot(1: Num2, Tat_test-T_sim2','-bs',...
    'LineWidth',1,...
    'MarkerSize',6,...
xlabel('预测样本')
ylabel('预测误差')
grid on
ylim([-50,50]);
save R2.mat Num2 Tat_test T_sim2 IT Accuracy Error2
140
4.算法理论概述
       基于遗传算法(Genetic Algorithm, GA)优化的CNN-LSTM(卷积神经网络-长短时记忆网络)时间序列回归预测模型,是一种结合了进化计算与深度学习的先进预测方法,旨在提高对时间序列数据未来值预测的准确性和稳定性。这种方法通过GA优化CNN-LSTM模型的超参数,以实现对时间序列数据更高效的特征提取和模式学习。
4.1 遗传算法(GA)原理
       遗传算法是一种模拟自然界中生物进化过程的全局优化算法,通过“选择”、“交叉”(杂交)和“变异”等操作,逐步优化个体群体,寻找问题的最优解。在CNN-LSTM模型优化中,GA的目标是找到一组最佳超参数(如学习率、网络结构参数等),使得模型的预测性能指标(如均方误差、R²分数等)最优。
4.2 GA优化CNN-LSTM步骤
       CNN-LSTM模型结合了卷积神经网络(CNN)和长短时记忆网络(LSTM),以高效处理时间序列数据的特征提取和序列建模。
GA优化CNN-LSTM步骤
初始化:随机生成一组超参数个体(染色体),构成初始种群。
评估:对每个个体(一组超参数),训练对应的CNN-LSTM模型,并在验证集上评估性能。
选择:基于评估性能,选择优秀个体(如采用轮盘赌选择、锦标赛选择等策略)。
交叉:对选中个体进行交叉操作,生成新的个体(如单点交叉、均匀交叉)。
变异:以一定概率对个体的某些基因(超参数)进行变异(如突变率改变)。
重复:回到步骤2,直到达到预设的代数或满足停止条件。
