ModelBox-AI应用开发:动物分割【玩转华为云】
阳光大猫 发表于 2024/06/07 06:13:50 2024/06/07
【摘要】 本章我们介绍了如何使用ModelBox开发一个动物图片分割的AI应用,我们只需要准备模型文件以及简单的配置即可创建一个HTTP服务。同时我们可以了解到LinkNet网络的基本结构、数据处理和模型训练方法,以及对应的推理应用逻辑。
一、准备环境
ModelBox端云协同AI开发套件(Windows)环境准备【视频教程】
二、应用开发
1. 创建工程
在ModelBox sdk目录下使用create.bat创建animal_seg工程
(tensorflow) PS D:\modelbox-win10-x64-1.5.3> .\create.bat -t server -n animal_seg
(tensorflow) D:\modelbox-win10-x64-1.5.3>set BASE_PATH=D:\modelbox-win10-x64-1.5.3\
(tensorflow) D:\modelbox-win10-x64-1.5.3>set PATH=D:\modelbox-win10-x64-1.5.3\\python-embed;C:\Users\yanso\miniconda3\envs\tensorflow\lib\site-packages\pywin32_system32;C:\Users\yanso\miniconda3\envs\tensorflow;C:\Users\yanso\miniconda3\envs\tensorflow\Library\mingw-w64\bin;C:\Users\yanso\miniconda3\envs\tensorflow\Library\usr\bin;C:\Users\yanso\miniconda3\envs\tensorflow\Library\bin;C:\Users\yanso\miniconda3\envs\tensorflow\Scripts;C:\Users\yanso\miniconda3\envs\tensorflow\bin;C:\Users\yanso\miniconda3\condabin;C:\Windows\System32\HWAudioDriverLibs;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\Git\cmd;C:\Users\yanso\miniconda3;C:\Users\yanso\miniconda3\Scripts;C:\Users\yanso\miniconda3\Library\bin;.;C:\Program Files\Git LFS;C:\Users\yanso\AppData\Local\Microsoft\WindowsApps;.;C:\Users\yanso\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\yanso\miniconda3\envs\tensorflow\lib\site-packages\pywin32_system32;C:\Users\yanso\miniconda3;C:\Users\yanso\miniconda3\Library\mingw-w64\bin;C:\Users\yanso\miniconda3\Library\usr\bin;C:\Users\yanso\miniconda3\Library\bin;C:\Users\yanso\miniconda3\Scripts;C:\Users\yanso\miniconda3\bin;C:\Users\yanso\miniconda3\condabin;C:\Windows\System32\HWAudioDriverLibs;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\Git\cmd;C:\Users\yanso\miniconda3;C:\Users\yanso\miniconda3\Scripts;C:\Users\yanso\miniconda3\Library\bin;.;C:\Program Files\Git LFS;C:\Users\yanso\AppData\Local\Microsoft\WindowsApps;.;C:\Users\yanso\AppData\Local\Programs\Microsoft VS Code\bin;C:\Windows\System32\HWAudioDriverLibs;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\Git\cmd;C:\Users\yanso\miniconda3;C:\Users\yanso\miniconda3\Scripts;C:\Users\yanso\miniconda3\Library\bin;.;C:\Program Files\Git LFS;C:\Users\yanso\AppData\Local\Microsoft\WindowsApps;.;C:\Users\yanso\AppData\Local\Programs\Microsoft VS Code\bin
(tensorflow) D:\modelbox-win10-x64-1.5.3>set PYTHONPATH=
(tensorflow) D:\modelbox-win10-x64-1.5.3>set PYTHONHOME=
(tensorflow) D:\modelbox-win10-x64-1.5.3>python.exe -u D:\modelbox-win10-x64-1.5.3\\create.py -t server -n animal_seg
sdk version is modelbox-win10-x64-1.5.3
dos2unix: converting file D:\modelbox-win10-x64-1.5.3\workspace\animal_seg/graph\animal_seg.toml to Unix format...
dos2unix: converting file D:\modelbox-win10-x64-1.5.3\workspace\animal_seg/graph\modelbox.conf to Unix format...
dos2unix: converting file D:\modelbox-win10-x64-1.5.3\workspace\animal_seg/bin\mock_task.toml to Unix format...
success: create animal_seg in D:\modelbox-win10-x64-1.5.3\workspace
create.bat工具的参数中,-t表示所创建实例的类型,包括server(ModelBox工程)、python(Python功能单元)、c++(C++功能单元)、infer(推理功能单元)等;-n表示所创建实例的名称,开发者自行命名。
2. 创建推理功能单元
在ModelBox sdk目录下使用create.bat创建linknet_infer推理功能单元
(tensorflow) PS D:\modelbox-win10-x64-1.5.3> .\create.bat -t infer -n linknet_infer -p animal_seg
(tensorflow) D:\modelbox-win10-x64-1.5.3>python.exe -u D:\modelbox-win10-x64-1.5.3\\create.py -t infer -n linknet_infer -p animal_seg
success: create infer linknet_infer in D:\modelbox-win10-x64-1.5.3\workspace\animal_seg/model/linknet_infer
create.bat工具使用时,-t infer 即表示创建的是推理功能单元;-n xxx_infer 表示创建的功能单元名称为xxx_infer;-p animal_seg 表示所创建的功能单元属于animal_seg应用。
a. 下载转换好的模型
运行此Notebook下载转换好的ONNX格式模型
b. 修改模型配置文件
模型和配置文件保持在同级目录下
# Copyright (C) 2020 Huawei Technologies Co., Ltd. All rights reserved.
[base]
name = "linknet_infer"
device = "cpu"
version = "1.0.0"
description = "your description"
entry = "./linknet.onnx"  # model file path, use relative path
type = "inference"
virtual_type = "onnx" # inference engine type: win10 now only support onnx
group_type = "Inference"  # flowunit group attribution, do not change
# Input ports description
[input]
[input.input1]  # input port number, Format is input.input[N]
name = "Input"  # input port name
type = "float"  # input port data type ,e.g. float or uint8
device = "cpu"  # input buffer type: cpu, win10 now copy input from cpu
# Output ports description
[output]
[output.output1] # output port number, Format is output.output[N]
name = "Output"  # output port name
type = "float"   # output port data type ,e.g. float or uint8
3. 创建后处理功能单元
在ModelBox sdk目录下使用create.bat创建linknet_post后处理功能单元
(tensorflow) PS D:\modelbox-win10-x64-1.5.3> .\create.bat -t python -n linknet_post -p animal_seg
(tensorflow) D:\modelbox-win10-x64-1.5.3>python.exe -u D:\modelbox-win10-x64-1.5.3\\create.py -t python -n linknet_post -p animal_seg
success: create python linknet_post in D:\modelbox-win10-x64-1.5.3\workspace\animal_seg/etc/flowunit/linknet_post
a. 修改配置文件
# Copyright (c) Huawei Technologies Co., Ltd. 2022. All rights reserved.
# Basic config
[base]
name = "linknet_post" # The FlowUnit name
device = "cpu" # The flowunit runs on cpu
version = "1.0.0" # The version of the flowunit
type = "python" # Fixed value, do not change
description = "description" # The description of the flowunit
entry = "linknet_post@linknet_postFlowUnit" # Python flowunit entry function
group_type = "Generic"  # flowunit group attribution, change as Input/Output/Image/Generic ...
# Flowunit Type
stream = false # Whether the flowunit is a stream flowunit
condition = false # Whether the flowunit is a condition flowunit
collapse = false # Whether the flowunit is a collapse flowunit
collapse_all = false # Whether the flowunit will collapse all the data
expand = false #  Whether the flowunit is a expand flowunit
# The default Flowunit config
[config]
net_h = 256
net_w = 256
[input]
[input.input1] # Input port number, the format is input.input[N]
name = "in_feat" # Input port name
type = "float" # Input port type
[output]
[output.output1] # Output port number, the format is output.output[N]
name = "out_data" # Output port name
type = "string" # Output port type
b. 修改逻辑代码
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import _flowunit as modelbox
import numpy as np
import json
import cv2
class linknet_postFlowUnit(modelbox.FlowUnit):
    # Derived from modelbox.FlowUnit
    def __init__(self):
        super().__init__()
    def open(self, config):
        # Open the flowunit to obtain configuration information
        self.params = {}
        self.params['net_h'] = config.get_int('net_h')
        self.params['net_w'] = config.get_int('net_w')
        return modelbox.Status.StatusCode.STATUS_SUCCESS
    def process(self, data_context):
        # Process the data
        in_feat = data_context.input("in_feat")
        out_data = data_context.output("out_data")
        # linknet_post process code.
        # Remove the following code and add your own code here.
        for buffer_feat in in_feat:
            feat_data = np.array(buffer_feat.as_object(), copy=False)
            result = {"det_result": str(feat_data.tolist())}
            result_str = json.dumps(result)
            out_buffer = modelbox.Buffer(self.get_bind_device(), result_str)
            out_data.push_back(out_buffer)
    def close(self):
        # Close the flowunit
        return modelbox.Status()
    def data_pre(self, data_context):
        # Before streaming data starts
    def data_post(self, data_context):
        # After streaming data ends
    def data_group_pre(self, data_context):
        # Before all streaming data starts
    def data_group_post(self, data_context):
        # After all streaming data ends
4. 修改流程图
animal_seg工程graph目录下存放流程图,默认的流程图animal_seg.toml与工程同名,其内容为(以Windows版ModelBox为例):
[driver]
dir = ["${HILENS_APP_ROOT}/etc/flowunit",
"${HILENS_APP_ROOT}/etc/flowunit/cpp",
"${HILENS_APP_ROOT}/model",
"${HILENS_MB_SDK_PATH}/flowunit"]
skip-default = true
[profile]
profile=false
trace=false
dir="${HILENS_DATA_DIR}/mb_profile"
[graph]
format = "graphviz"
graphconf = """digraph animal_seg {
    node [shape=Mrecord]
    queue_size = 4
    batch_size = 1
    input1[type=input,flowunit=input,device=cpu,deviceid=0]
    httpserver_sync_receive[type=flowunit, flowunit=httpserver_sync_receive_v2, device=cpu, deviceid=0, time_out_ms=5000, endpoint="http://0.0.0.0:8083/v1/animal_seg", max_requests=100]
    image_decoder[type=flowunit, flowunit=image_decoder, device=cpu, key="image_base64", queue_size=4]
    image_resize[type=flowunit, flowunit=resize, device=cpu, deviceid=0, image_width=256, image_height=256]
    normalize[type=flowunit, flowunit=normalize, device=cpu, deviceid=0, standard_deviation_inverse="0.003921568627450,0.003921568627450,0.003921568627450"]
    linknet_infer[type=flowunit, flowunit=linknet_infer, device=cpu, deviceid=0, batch_size=1]
    linknet_post[type=flowunit, flowunit=linknet_post, device=cpu, deviceid=0]
    httpserver_sync_reply[type=flowunit, flowunit=httpserver_sync_reply_v2, device=cpu, deviceid=0]
    input1:input -> httpserver_sync_receive:in_url
    httpserver_sync_receive:out_request_info -> image_decoder:in_encoded_image
    image_decoder:out_image -> image_resize:in_image
    image_resize:out_image -> normalize:in_data
    normalize:out_data -> linknet_infer:Input
    linknet_infer:Output -> linknet_post:in_feat
    linknet_post:out_data -> httpserver_sync_reply:in_reply_info
[flow]
desc = "animal_seg run in modelbox-win10-x64"
 5. 准备动物图片和测试脚本
a. 动物图片
b. 测试脚本
animal_seg工程data目录下存放测试脚本test_http.py
import os
import cv2
import json
import base64
import http.client
import numpy as np
class HttpConfig:
    '''http调用的参数配置'''
    def __init__(self, host_ip, port, url, img_base64_str):
        self.hostIP = host_ip
        self.Port = port
        self.httpMethod = "POST"
        self.requstURL = url
        self.headerdata = {
            "Content-Type": "application/json"
        self.test_data = {
            "image_base64": img_base64_str
        self.body = json.dumps(self.test_data)
def read_image(img_path):
    '''读取图片数据并转为base64编码的字符串'''
    img_data = cv2.imread(img_path)
    img_str = cv2.imencode('.jpg', img_data)[1].tobytes()
    img_bin = base64.b64encode(img_str)
    img_base64_str = str(img_bin, encoding='utf8')
    return img_data, img_base64_str
def decode_result_str(result_str):
    try:
        result = json.loads(json.loads(result_str)['det_result'])
        mask = np.array(list(result)).reshape(256, 256, 3)
    except Exception as ex:
        print(str(ex))
        return []
    else:
        return np.argmax(mask, axis=-1)
def test_image(img_path, ip, port, url):
    '''单张图片测试'''
    img_data, img_base64_str = read_image(img_path)
    http_config = HttpConfig(ip, port, url, img_base64_str)
    conn = http.client.HTTPConnection(host=http_config.hostIP, port=http_config.Port)
    conn.request(method=http_config.httpMethod, url=http_config.requstURL,
                 body=http_config.body, headers=http_config.headerdata)
    response = conn.getresponse().read().decode()
    mask = decode_result_str(response).astype(np.float32)
    height, width = img_data.shape[:2]
    mask = cv2.resize(mask, (width, height))
    mask_0 = np.where(mask==0, 255, np.zeros(mask.shape))
    mask_0 = mask_0.reshape(height, width, 1)
    mask_2 = np.where(mask==2, 255, np.zeros(mask.shape))
    mask_2 = mask_2.reshape(height, width, 1)
    mask = np.concatenate((mask_0, mask_2, mask_0), axis=-1).astype(np.uint8)
    image = cv2.addWeighted(img_data, 1, mask, 0.5, 0)
    cv2.imwrite('./result-' + os.path.basename(img_path), image)
if __name__ == "__main__":
    port = 8083
    ip = "127.0.0.1"
    url = "/v1/animal_seg"
    img_path = "test.jpg"
三、运行应用
 在animal_seg工程目录下执行.\bin\main.bat运行应用:
(tensorflow) PS D:\modelbox-win10-x64-1.5.3> cd D:\modelbox-win10-x64-1.5.3\workspace\animal_seg
(tensorflow) PS D:\modelbox-win10-x64-1.5.3\workspace\animal_seg> .\bin\main.bat
(tensorflow) D:\modelbox-win10-x64-1.5.3\workspace\animal_seg>set PATH=D:/modelbox-win10-x64-1.5.3/workspace/animal_seg/bin/../../../python-embed;D:/modelbox-win10-x64-1.5.3/workspace/animal_seg/bin/../../../modelbox-win10-x64/bin;D:/modelbox-win10-x64-1.5.3/workspace/animal_seg/bin/../dependence/lib;C:\Users\yanso\miniconda3\envs\tensorflow\lib\site-packages\pywin32_system32;C:\Users\yanso\miniconda3\envs\tensorflow;C:\Users\yanso\miniconda3\envs\tensorflow\Library\mingw-w64\bin;C:\Users\yanso\miniconda3\envs\tensorflow\Library\usr\bin;C:\Users\yanso\miniconda3\envs\tensorflow\Library\bin;C:\Users\yanso\miniconda3\envs\tensorflow\Scripts;C:\Users\yanso\miniconda3\envs\tensorflow\bin;C:\Users\yanso\miniconda3\condabin;C:\Windows\System32\HWAudioDriverLibs;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\Git\cmd;C:\Users\yanso\miniconda3;C:\Users\yanso\miniconda3\Scripts;C:\Users\yanso\miniconda3\Library\bin;.;C:\Program Files\Git LFS;C:\Users\yanso\AppData\Local\Microsoft\WindowsApps;.;C:\Users\yanso\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\yanso\miniconda3\envs\tensorflow\lib\site-packages\pywin32_system32;C:\Users\yanso\miniconda3;C:\Users\yanso\miniconda3\Library\mingw-w64\bin;C:\Users\yanso\miniconda3\Library\usr\bin;C:\Users\yanso\miniconda3\Library\bin;C:\Users\yanso\miniconda3\Scripts;C:\Users\yanso\miniconda3\bin;C:\Users\yanso\miniconda3\condabin;C:\Windows\System32\HWAudioDriverLibs;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\Git\cmd;C:\Users\yanso\miniconda3;C:\Users\yanso\miniconda3\Scripts;C:\Users\yanso\miniconda3\Library\bin;.;C:\Program Files\Git LFS;C:\Users\yanso\AppData\Local\Microsoft\WindowsApps;.;C:\Users\yanso\AppData\Local\Programs\Microsoft VS Code\bin;C:\Windows\System32\HWAudioDriverLibs;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Users\Administrator\AppData\Local\Microsoft\WindowsApps;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\Git\cmd;C:\Users\yanso\miniconda3;C:\Users\yanso\miniconda3\Scripts;C:\Users\yanso\miniconda3\Library\bin;.;C:\Program Files\Git LFS;C:\Users\yanso\AppData\Local\Microsoft\WindowsApps;.;C:\Users\yanso\AppData\Local\Programs\Microsoft VS Code\bin
(tensorflow) D:\modelbox-win10-x64-1.5.3\workspace\animal_seg>modelbox.exe -c D:/modelbox-win10-x64-1.5.3/workspace/animal_seg/bin/../graph/modelbox.conf
[2024-06-07 06:07:44,657][ WARN][    iva_config.cc:143 ] update vas url failed. Fault, no vas projectid or iva endpoint
open log file D:/modelbox-win10-x64-1.5.3/workspace/animal_seg/bin/../hilens_data_dir/log/modelbox.log failed, No error
input dims is:1,256,256,3,
output dims is:1,256,256,3,
HTTP服务启动后可以在另一个终端进行请求测试,进入animal_seg工程目录data文件夹中使用test_http.py脚本发起HTTP请求进行测试:
(tensorflow) PS D:\modelbox-win10-x64-1.5.3> cd D:\modelbox-win10-x64-1.5.3\workspace\animal_seg\data
(tensorflow) PS D:\modelbox-win10-x64-1.5.3\workspace\animal_seg\data> python .\test_http.py
分割后的图片保存在animal_seg工程目录下的data文件夹中
四、小结
