基于二维CS-SCHT变换和扩频方法的彩色图像水印嵌入和提取算法matlab仿真
简简单单做算法 发表于 2024/05/29 22:19:57 2024/05/29
【摘要】 1.算法运行效果图预览  2.算法运行软件版本matlab2022a 3.算法理论概述水印嵌入原理  水印提取原理: 将嵌入水印的图像再次进行二维CS-SCHT变换。 提取变换后的低频系数,并按照嵌入时的规则去除宿主图像内容的影响,恢复出水印信息 Wm′​。 4.部分核心程序% figure;% subplot(121);% imshow(Irgb)% subplot(122);% imsh...
1.算法运行效果图预览
2.算法运行软件版本
matlab2022a
3.算法理论概述
水印嵌入原理
水印提取原理:
4.部分核心程序
% figure;
% subplot(121);
% imshow(Irgb)
% subplot(122);
% imshow(I1)
%RGB转换为RGB2YUV
R   = double(Irgb(:,:,1));
G   = double(Irgb(:,:,2));
B   = double(Irgb(:,:,3));
Y   =  0.299*R + 0.587*G + 0.114*B;
U   = -0.147*R - 0.289*G + 0.436*B;
V   =  0.615*R - 0.515*G - 0.100*B;
YUV = cat(3, Y, U, V);
[I0,Marks1] = func_read_images(Y,I1);
I0          = imresize(I0,[512,512]);
%设置嵌入强度
Power       = 5;
%设置块的大小
Blksize     = 8;
RR          = 60;
CC          = 60;
%对水印进行置乱
Marks1s     = Arnold(Marks1,1,0);
% figure
% subplot(131);
% imshow(Irgb,[]);
% title('原始图像');
% subplot(132);
% imshow(Marks1,[]);
% title('水印');
% subplot(133);
% imshow(Marks1s,[]);
% title('置乱后水印');
%对图像进行处理
[Mwk_1st]       = func_wk_insert(I0,Marks1s,Power,Blksize,RR,CC);
Y               = imresize(Y,[512,512]);
U               = imresize(U,[512,512]);
V               = imresize(V,[512,512]);
Mwk_1stYUV2     = cat(3,Mwk_1st,U,V);
%YUV2RGB
RGB1        = zeros(size(Mwk_1stYUV2));
RGB1(:,:,1) = Mwk_1st + 1.14 * V;
RGB1(:,:,2) = Mwk_1st - 0.39 * U - 0.58 * V;
RGB1(:,:,3) = Mwk_1st + 2.03 * U;
RGB1n(:,:,1)=awgn(RGB1(:,:,1),SNRS(ij),'measured');
RGB1n(:,:,2)=awgn(RGB1(:,:,2),SNRS(ij),'measured');
RGB1n(:,:,3)=awgn(RGB1(:,:,3),SNRS(ij),'measured');
%水印提取
Rs   = double(RGB1n(:,:,1));
Gs   = double(RGB1n(:,:,2));
Bs   = double(RGB1n(:,:,3));
Ys   =  0.299*Rs + 0.587*Gs + 0.114*Bs;
Us   = -0.147*Rs - 0.289*Gs + 0.436*Bs;
Vs   =  0.615*Rs - 0.515*Gs - 0.100*Bs;
Mwk_1st2  = Ys(:,:,1);
Msg1      = func_wk_desert(real(Mwk_1st2),Blksize,RR,CC,4);
%对水印进行逆置乱
Msg1s     = Arnold(uint8(255*Msg1),1,1);
% figure
% subplot(231);
% imshow(Irgb,[]);
% title('原始图像');
% subplot(232);
% imshow(uint8(YUV));
% title('RGB转为YUV图片');
% subplot(233);
% imshow(Marks1);
% title('水印');
% subplot(234);
% imshow(uint8(RGB1));
% title('JPEG压缩攻击');
% subplot(236);
% imshow(Msg1s,[]);
% title('水印提取');
%水印提取,计算NC和PSNR
Marks1 = imresize(Marks1,[RR,CC]);
NC(ij,jk)     = func_nc(uint8(Marks1),uint8(Msg1s)) ;
end
end
figure;
plot(SNRS,mean(NC,2),'b-o');
xlabel('SNR');
ylabel('水印提取NC值');
