gaussdb运维常用语句
yd_261177225 发表于 2024/04/23 11:52:40 2024/04/23
【摘要】 说明:部分语句截取至华为官方文档:https://support.huaweicloud.cn/gaussdb/index.html 用户相关创建用户并授权create user u1 password 'awdrg@123!'; alter user u1 with dbadmin auditadmin poladmin;锁定/解锁用户alter user u1 account LOCK...
用户相关
创建用户并授权
锁定/解锁用户
alter user u1 account LOCK/UNLOCK;
查看指定用户已使用的会话连接数
select count(*) from dv_sessions where username='xxx';
查看所有用户已使用的会话连接数
select count(*) from dv_sessions;
查询指定用户的最大连接数
select rolname,rolconnlimit from pg_roles where rolname='user';
创建防篡改用户
create schema ledger with blockchain;
数据库相关
创建数据库
create database d1;
创建数据库并指定所有者
create database d1 owner u1;
重命名数据库
alter database d1 rename to db1;
查询指定数据库的最大连接数
select datname,datconnlimit from pg_database where datname='db';
表相关
以下示例部分引用华为官方文档
创建表
create table t1 ORIENTATION=row/column DISTRIBUTE BY HASH/REPLICATION/RANGE/LIST
创建分区表
create table t1 create table p_test ( a int,b int,c int,d int ) partition by range(b) ( partition p1 values less than (10), partition p2 values less than (20), partition p3 values less than (30), partition p4 values less than maxvalue );
create table p_test ( a int,b int,c int,d int )with (orientation = column) distribute by hash(a) partition by hash(b) ( partition p1, partition p2 );
CREATE TABLE test_list (col1 int, col2 int) partition by list(col1) ( partition p1 values (2000), partition p2 values (3000), partition p3 values (4000), partition p4 values (5000) );
创建加密表
CREATE TABLE creditcard_info (id_number int, name text encrypted with (column_encryption_key = ImgCEK, encryption_type = DETERMINISTIC), credit_card varchar(19) encrypted with (column_encryption_key = ImgCEK1, encryption_type = DETERMINISTIC)); NOTICE: The 'DISTRIBUTE BY' clause is not specified. Using 'id_number' as the distribution column by default. HINT: Please use 'DISTRIBUTE BY' clause to specify suitable data distribution column. CREATE TABLE
修改表
添加列
ALTER TABLE tpcds.warehouse_t19 ADD W_GOODS_CATEGORY varchar(30);
添加列及约束
ALTER TABLE tpcds.warehouse_t19 ADD CONSTRAINT W_CONSTR_KEY4 CHECK (W_STATE IS NOT NULL);
修改字段类型
ALTER TABLE tpcds.warehouse_t19 ALTER COLUMN W_GOODS_CATEGORY TYPE varchar(80), ALTER COLUMN W_STREET_NAME TYPE varchar(100);
给一个已存在字段添加非空约束。
ALTER TABLE tpcds.warehouse_t19 ALTER COLUMN W_GOODS_CATEGORY SET NOT NULL;
移除已存在字段的非空约束。
ALTER TABLE tpcds.warehouse_t19 ALTER COLUMN W_GOODS_CATEGORY DROP NOT NULL;
将表移动到另一个表空间。
ALTER TABLE tpcds.warehouse_t19 SET TABLESPACE PG_DEFAULT;
将表移动到另一个模式中。
gaussdb=# ALTER TABLE tpcds.warehouse_t19 SET SCHEMA joe;
重命名已存在的表。
ALTER TABLE joe.warehouse_t19 RENAME TO warehouse_t23;
从表中删除一个字段。
ALTER TABLE joe.warehouse_t23 DROP COLUMN W_STREET_NAME;
删除表空间。
DROP TABLE tpcds.warehouse_t1;
获取表的模式名和表名
select schemaname ,tablename from pg_tables where tablename='test';
select table_schema ,table_name from information_schema.tables where table_name ='test';
select pn.nspname,pc.relname from pg_class pc , pg_namespace pn where pc.relnamespace=pn.oid and pc.relname='test';
获取指定表所在的节点名称
select node_name from pgxc_node where oid in ( select unnest(nodeoids) from pgxc_class where pcrelid ='test'::regclass );
获取指定表的所在的节点名字和表在节点上的数据数量
SELECT b.node_name, a.cnt FROM (SELECT xc_node_id,count(*) AS cnt FROM p_test GROUP BY xc_node_id) a pgxc_node b WHERE a.xc_node_id=b.node_id ORDER BY a.cnt desc;
获取指定表的owner
select c.relname,r.rolname as owner from pg_class c join pg_roles r on c.relowner=r.oid where relname='t1';
select schemaname,tablename tab,tableowner from pg_tables where tablename='t1';
索引相关
创建索引
create index idx1 on t1(l1,l2) where (l1=xx and l2 > xxx)
禁用索引
alter index idx1 unusable;
重建索引
alter index idx1 rebuild;
重命名索引
alter index idx1 rename to idx2;
权限相关
获取某个用户的表级权限
select table_schema,table_name,grantee,privilege_type from information_schema.table_privileges where grantee='user1';
获取对某表有权限的用户信息
select grantee,privilege_type from information_schema.table_privileges where table_name='table1';
