K8s 集群高可用master节点Etcd挂掉如何恢复?
山河已无恙 发表于 2024/03/19 01:52:26 2024/03/19
【摘要】 写在前面很常见的集群运维场景,整理分享博文内容为 K8s 集群高可用 master 节点故障如何恢复的过程理解不足小伙伴帮忙指正 不必太纠结于当下,也不必太忧虑未来,当你经历过一些事情的时候,眼前的风景已经和从前不一样了。——村上春树遇到了什么问题今天做实验发现 ,集群其中一个 master 节点上的 etcd 和 apiserver 都挂掉了┌──[root@vms100.liruilon...
写在前面
  • 很常见的集群运维场景,整理分享
  • 博文内容为 K8s 集群高可用 master 节点故障如何恢复的过程
  • 理解不足小伙伴帮忙指正
遇到了什么问题
┌──[root@vms100.liruilongs.github.io]-[~]
└─$kubectl get nodes
NAME                          STATUS   ROLES           AGE    VERSION
vms100.liruilongs.github.io   Ready    control-plane   415d   v1.25.1
vms101.liruilongs.github.io   Ready    control-plane   415d   v1.25.1
vms102.liruilongs.github.io   Ready    control-plane   415d   v1.25.1
vms103.liruilongs.github.io   Ready    <none>          415d   v1.25.1
vms105.liruilongs.github.io   Ready    <none>          415d   v1.25.1
vms106.liruilongs.github.io   Ready    <none>          415d   v1.25.1
vms100.liruilongs.github.io 这个节点 上的 apiserver 和 etcd
└─$kubectl get pod -A -o wide | grep apiserver
kube-system          kube-apiserver-vms100.liruilongs.github.io            0/1     CrashLoopBackOff   1448 (3m23s ago)   415d   192.168.26.100   vms100.liruilongs.github.io   <none>           <none>
kube-system          kube-apiserver-vms101.liruilongs.github.io            1/1     Running            272 (3h18m ago)    415d   192.168.26.101   vms101.liruilongs.github.io   <none>           <none>
kube-system          kube-apiserver-vms102.liruilongs.github.io            1/1     Running            246 (3h18m ago)    415d   192.168.26.102   vms102.liruilongs.github.io   <none>           <none>
└─$kubectl get pod -A -o wide | grep etcd
kube-system          etcd-vms100.liruilongs.github.io                      0/1     CrashLoopBackOff   1244 (3m6s ago)    415d   192.168.26.100   vms100.liruilongs.github.io   <none>           <none>
kube-system          etcd-vms101.liruilongs.github.io                      1/1     Running            167 (3h18m ago)    415d   192.168.26.101   vms101.liruilongs.github.io   <none>           <none>
kube-system          etcd-vms102.liruilongs.github.io                      1/1     Running            173 (3h18m ago)    415d   192.168.26.102   vms102.liruilongs.github.io   <none>           <none>
查看 keepalived 对应的静态Pod运行正常
└─$kubectl get pod -A -o wide | grep keep
kube-system          keepalived-vms100.liruilongs.github.io                1/1     Running            63 (3h50m ago)    415d   192.168.26.100   vms100.liruilongs.github.io   <none>           <none>
kube-system          keepalived-vms101.liruilongs.github.io                1/1     Running            54 (3h51m ago)    415d   192.168.26.101   vms101.liruilongs.github.io   <none>           <none>
kube-system          keepalived-vms102.liruilongs.github.io                1/1     Running            60 (3h51m ago)    415d   192.168.26.102   vms102.liruilongs.github.io   <none>           <none>
所以可能是 etcd 数据不同步,或者什么原因 导致etcd 挂掉了。因为 每个 master 节点的 apiserver 只和 本节点的 etcd 进行 通信(每个 etcd 的写请求会转发到 etcd 的领导节点),etcd 挂掉,apiserver 无法提供能力,所以也会挂掉。
通过 etcdctl 可以发现 vms100.liruilongs.github.io 上的 etcd 彻底死掉了
└─$ETCDCTL_API=3 etcdctl  --endpoints https://127.0.0.1:2379 \
 --cert="/etc/kubernetes/pki/etcd/server.crt" \
 --key="/etc/kubernetes/pki/etcd/server.key"  \
 --cacert="/etc/kubernetes/pki/etcd/ca.crt" \
 member list -w table
Error: dial tcp 127.0.0.1:2379: connect: connection refused
如何排查
这里我们换一个 etcd 节点 执行 命令
查看 etcd 集群成员
└─$ssh vms101.liruilongs.github.io
Last login: Sat Mar  2 09:52:01 2024 from 192.168.26.100
┌──[root@vms101.liruilongs.github.io]-[~]
|        ID        | STATUS  |            NAME             |         PEER ADDRS          |        CLIENT ADDRS         |
|  ee392e5273e89e2 | started | vms100.liruilongs.github.io | https://192.168.26.100:2380 | https://192.168.26.100:2379 |
| 70059e836d19883d | started | vms101.liruilongs.github.io | https://192.168.26.101:2380 | https://192.168.26.101:2379 |
| b8cb9f66c2e63b91 | started | vms102.liruilongs.github.io | https://192.168.26.102:2380 | https://192.168.26.102:2379 |
查看节点状态
   endpoint status --cluster  -w table
Failed to get the status of endpoint https://192.168.26.100:2379 (context deadline exceeded)
|          ENDPOINT           |        ID        | VERSION | DB SIZE | IS LEADER | RAFT TERM | RAFT INDEX |
| https://192.168.26.101:2379 | 70059e836d19883d |   3.5.4 |   88 MB |     false |       603 |   22208417 |
| https://192.168.26.102:2379 | b8cb9f66c2e63b91 |   3.5.4 |   88 MB |      true |       603 |   22208417 |
确定 ETCD 节点故障
 endpoint  health --cluster  -w table
https://192.168.26.101:2379 is healthy: successfully committed proposal: took = 3.753357ms
https://192.168.26.102:2379 is healthy: successfully committed proposal: took = 2.989943ms
https://192.168.26.100:2379 is unhealthy: failed to connect: dial tcp 192.168.26.100:2379: connect: connection refused
Error: unhealthy cluster
查看 etcd 的容器日志
└─$docker ps -a | grep etcd
0f2f98ebf8c3   a8a176a5d5d6                                        "etcd --advertise-cl…"   4 minutes ago   Exited (2) 4 minutes ago                  k8s_etcd_etcd-vms100.liruilongs.github.io_kube-system_e8c17bb99f9bd8119cdd769556041e18_1252
a4b39d16a753   registry.aliyuncs.com/google_containers/pause:3.8   "/pause"                 4 hours ago     Up 4 hours                                k8s_POD_etcd-vms100.liruilongs.github.io_kube-system_e8c17bb99f9bd8119cdd769556041e18_54
└─$docker logs 0f2f98ebf8c3
{"level":"info","ts":"2024-03-16T14:46:54.644Z","caller":"etcdmain/etcd.go:73","msg":"Running: ","args":["etcd","--advertise-client-urls=https://192.168.26.100:2379","--cert-file=/etc/kubernetes/pki/etcd/server.crt","--client-cert-auth=true","--data-dir=/var/lib/etcd","--experimental-initial-corrupt-check=true","--experimental-watch-progress-notify-interval=5s","--initial-advertise-peer-urls=https://192.168.26.100:2380","--initial-cluster=vms100.liruilongs.github.io=https://192.168.26.100:2380","--key-file=/etc/kubernetes/pki/etcd/server.key","--listen-client-urls=https://127.0.0.1:2379,https://192.168.26.100:2379","--listen-metrics-urls=http://127.0.0.1:2381","--listen-peer-urls=https://192.168.26.100:2380","--name=vms100.liruilongs.github.io","--peer-cert-file=/etc/kubernetes/pki/etcd/peer.crt","--peer-client-cert-auth=true","--peer-key-file=/etc/kubernetes/pki/etcd/peer.key","--peer-trusted-ca-file=/etc/kubernetes/pki/etcd/ca.crt","--snapshot-count=10000","--trusted-ca-file=/etc/kubernetes/pki/etcd/ca.crt"]}
{"level":"info","ts":"2024-03-16T14:46:54.645Z","caller":"etcdmain/etcd.go:116","msg":"server has been already initialized","data-dir":"/var/lib/etcd","dir-type":"member"}
{"level":"info","ts":"2024-03-16T14:46:54.645Z","caller":"embed/etcd.go:131","msg":"configuring peer listeners","listen-peer-urls":["https://192.168.26.100:2380"]}
{"level":"info","ts":"2024-03-16T14:46:54.645Z","caller":"embed/etcd.go:479","msg":"starting with peer TLS","tls-info":"cert = /etc/kubernetes/pki/etcd/peer.crt, key = /etc/kubernetes/pki/etcd/peer.key, client-cert=, client-key=, trusted-ca = /etc/kubernetes/pki/etcd/ca.crt, client-cert-auth = true, crl-file = ","cipher-suites":[]}
{"level":"info","ts":"2024-03-16T14:46:54.645Z","caller":"embed/etcd.go:139","msg":"configuring client listeners","listen-client-urls":["https://127.0.0.1:2379","https://192.168.26.100:2379"]}
{"level":"info","ts":"2024-03-16T14:46:54.645Z","caller":"embed/etcd.go:308","msg":"starting an etcd server","etcd-version":"3.5.4","git-sha":"08407ff76","go-version":"go1.16.15","go-os":"linux","go-arch":"amd64","max-cpu-set":4,"max-cpu-available":4,"member-initialized":true,"name":"vms100.liruilongs.github.io","data-dir":"/var/lib/etcd","wal-dir":"","wal-dir-dedicated":"","member-dir":"/var/lib/etcd/member","force-new-cluster":false,"heartbeat-interval":"100ms","election-timeout":"1s","initial-election-tick-advance":true,"snapshot-count":10000,"snapshot-catchup-entries":5000,"initial-advertise-peer-urls":["https://192.168.26.100:2380"],"listen-peer-urls":["https://192.168.26.100:2380"],"advertise-client-urls":["https://192.168.26.100:2379"],"listen-client-urls":["https://127.0.0.1:2379","https://192.168.26.100:2379"],"listen-metrics-urls":["http://127.0.0.1:2381"],"cors":["*"],"host-whitelist":["*"],"initial-cluster":"","initial-cluster-state":"new","initial-cluster-token":"","quota-size-bytes":2147483648,"pre-vote":true,"initial-corrupt-check":true,"corrupt-check-time-interval":"0s","auto-compaction-mode":"periodic","auto-compaction-retention":"0s","auto-compaction-interval":"0s","discovery-url":"","discovery-proxy":"","downgrade-check-interval":"5s"}
panic: freepages: failed to get all reachable pages (page 7744: multiple references)
goroutine 109 [running]:
go.etcd.io/bbolt.(*DB).freepages.func2(0xc00009c480)
        /go/pkg/mod/go.etcd.io/bbolt@v1.3.6/db.go:1056 +0xe9
created by go.etcd.io/bbolt.(*DB).freepages
        /go/pkg/mod/go.etcd.io/bbolt@v1.3.6/db.go:1054 +0x1cd
如何解决
这里最快的办法是重新同步一下这个节点的数据,即把这个故障节点移出 集群,清理完故障节点旧数据在重新添加,操作步骤
  • 清理数据目录,移动静态Pod 的yaml 文件:停止故障节点服务,然后删除etcd数据目录。
  • 移除故障节点:使用member remove命令剔除错误节点,可以在健康的节点执行命令。
  • 添加节点:使用member add命令添加故障节点。
  • 重新启动:移动故障节点yaml文件,进行启动
注: 静态Pod 通过加载指定目录的 yaml 文件来调度,kubelet 会定时扫描,删除移动 yaml 文件,静态 Pod 会自动停止,同理。添加 yaml 文件会自动创建静态 Pod
移动静态Pod 的yaml 文件
└─$mv  /etc/kubernetes/manifests/{etcd.yaml,kube-apiserver.yaml}  /tmp/
删除etcd数据目录
└─$rm -rf /var/lib/etcd/*
确认节点 的 etcd 和 apiservier 都已经停止
kube-system          kube-apiserver-vms101.liruilongs.github.io            1/1     Running   272 (4h15m ago)   415d   192.168.26.101   vms101.liruilongs.github.io   <none>           <none>
kube-system          kube-apiserver-vms102.liruilongs.github.io            1/1     Running   246 (4h15m ago)   415d   192.168.26.102   vms102.liruilongs.github.io   <none>           <none>
kube-system          etcd-vms101.liruilongs.github.io                      1/1     Running   167 (4h15m ago)   415d   192.168.26.101   vms101.liruilongs.github.io   <none>           <none>
kube-system          etcd-vms102.liruilongs.github.io                      1/1     Running   173 (4h15m ago)   415d   192.168.26.102   vms102.liruilongs.github.io   <none>           <none>
获取故障节点 ID,下面的操作我们在健康的 etcd 节点执行,或者可以修改 --endpoints
└─$ETCDCTL_API=3 etcdctl  --endpoints https://192.168.26.101:2379  --cert="/etc/kubernetes/pki/etcd/server.crt"  --key="/etc/kubernetes/pki/etcd/server.key"  --cacert="/etc/kubernetes/pki/etcd/ca.crt" member list -w table
移除故障节点
└─$ETCDCTL_API=3 etcdctl  --endpoints https://127.0.0.1:2379  --cert="/etc/kubernetes/pki/etcd/server.crt"  --key="/etc/kubernetes/pki/etcd/server.key"  --cacert="/etc/kubernetes/pki/etcd/ca.crt"  member remove ee392e5273e89e2
Member  ee392e5273e89e2 removed from cluster 4816f346663d82a7
重新添加
└─$ETCDCTL_API=3 etcdctl  --endpoints https://127.0.0.1:2379  --cert="/etc/kubernetes/pki/etcd/server.crt"  --key="/etc/kubernetes/pki/etcd/server.key"  --cacert="/etc/kubernetes/pki/etcd/ca.crt"  member add vms100.liruilongs.github.io --peer-urls=https://192.168.26.100:2380
Member 456f71fdc1ad9917 added to cluster 4816f346663d82a7
ETCD_NAME="vms100.liruilongs.github.io"
ETCD_INITIAL_CLUSTER="vms100.liruilongs.github.io=https://192.168.26.100:2380,vms101.liruilongs.github.io=https://192.168.26.101:2380,vms102.liruilongs.github.io=https://192.168.26.102:2380"
ETCD_INITIAL_ADVERTISE_PEER_URLS="https://192.168.26.100:2380"
ETCD_INITIAL_CLUSTER_STATE="existing"
回到 100 节点机器,移动 Yaml 文件,恢复节点
└─$mv /tmp/{etcd.yaml,kube-apiserver.yaml} /etc/kubernetes/manifests/
确认 Pod 状态
kube-system          etcd-vms100.liruilongs.github.io                      1/1     Running   0                 16s    192.168.26.100   vms100.liruilongs.github.io   <none>           <none>
kube-system          etcd-vms101.liruilongs.github.io                      1/1     Running   167 (4h32m ago)   415d   192.168.26.101   vms101.liruilongs.github.io   <none>           <none>
kube-system          etcd-vms102.liruilongs.github.io                      1/1     Running   173 (4h32m ago)   415d   192.168.26.102   vms102.liruilongs.github.io   <none>           <none>
kube-system          kube-apiserver-vms100.liruilongs.github.io            1/1     Running   0                 24s    192.168.26.100   vms100.liruilongs.github.io   <none>           <none>
kube-system          kube-apiserver-vms101.liruilongs.github.io            1/1     Running   272 (4h32m ago)   415d   192.168.26.101   vms101.liruilongs.github.io   <none>           <none>
kube-system          kube-apiserver-vms102.liruilongs.github.io            1/1     Running   246 (4h32m ago)   415d   192.168.26.102   vms102.liruilongs.github.io   <none>           <none>
查看 etcd 集群状态
└─$ETCDCTL_API=3 etcdctl  --endpoints https://127.0.0.1:2379  --cert="/etc/kubernetes/pki/etcd/server.crt"  --key="/etc/kubernetes/pki/etcd/server.key"  --cacert="/etc/kubernetes/pki/etcd/ca.crt" member list -w table
| 54952f3b494c0286 | unstarted |                             | https://192.168.26.100:2380 |                             |
这里我们发现 新添加的节点状态不正常,一直是 unstarted
我们在 故障节点执行 etcd 命令。发现故障节点并没有添加到集群,而是作为一个单节点运行。
└─$ETCDCTL_API=3 etcdctl  --endpoints https://127.0.0.1:2379  --cert="/etc/kubernetes/pki/etcd/server.crt"  --key="/etc/kubernetes/pki/etcd/server.key"  --cacert="/etc/kubernetes/pki/etcd/ca.crt" endpoint status --cluster  -w table
| https://192.168.26.100:2379 | ee392e5273e89e2 |   3.5.4 |  815 kB |      true |         2 |       2261 |
也没有同步 当前集群的数据
└─$kubectl get pod -A -o wide  --server=https://vms100.liruilongs.github.io:6443
No resources found
遇到这种情况,大部分原因是 某个节点的 etcd配置文件的问题,我的这个问题是 故障节点的 etcd 配置文件,没有集群信息相关配置,所以这里把集群相关配置写入配置
原本的配置文件
└─$cat /etc/kubernetes/manifests/etcd.yaml
apiVersion: v1
kind: Pod
metadata:
  annotations:
    kubeadm.kubernetes.io/etcd.advertise-client-urls: https://192.168.26.100:2379
  creationTimestamp: null
  labels:
    component: etcd
    tier: control-plane
  namespace: kube-system
spec:
  containers:
  - command:
    - etcd
    - --advertise-client-urls=https://192.168.26.100:2379
    - --cert-file=/etc/kubernetes/pki/etcd/server.crt
    - --client-cert-auth=true
    - --data-dir=/var/lib/etcd
    - --experimental-initial-corrupt-check=true
    - --experimental-watch-progress-notify-interval=5s
    - --initial-advertise-peer-urls=https://192.168.26.100:2380
    - --initial-cluster=vms100.liruilongs.github.io=https://192.168.26.100:2380
    - --key-file=/etc/kubernetes/pki/etcd/server.key
    - --listen-client-urls=https://127.0.0.1:2379,https://192.168.26.100:2379
    - --listen-metrics-urls=http://127.0.0.1:2381
    - --listen-peer-urls=https://192.168.26.100:2380
    - --name=vms100.liruilongs.github.io
    - --peer-cert-file=/etc/kubernetes/pki/etcd/peer.crt
    - --peer-client-cert-auth=true
    - --peer-key-file=/etc/kubernetes/pki/etcd/peer.key
    - --peer-trusted-ca-file=/etc/kubernetes/pki/etcd/ca.crt
    - --snapshot-count=10000
    - --trusted-ca-file=/etc/kubernetes/pki/etcd/ca.crt
    image: registry.aliyuncs.com/google_containers/etcd:3.5.4-0
集群信息不全的,添加后的配置文件
apiVersion: v1
kind: Pod
metadata:
  annotations:
  labels:
    component: etcd
    tier: control-plane
spec:
  containers:
  - command:
    - etcd
    - --initial-cluster=vms100.liruilongs.github.io=https://192.168.26.100:2380,vms101.liruilongs.github.io=https://192.168.26.101:2380
    - --initial-cluster-state=existing
然后我们以上面相同的方式从新恢复一次,发现节点直接没有起来
kube-system          kube-apiserver-vms100.liruilongs.github.io            0/1     CrashLoopBackOff   1 (18s ago)       39s    192.168.26.100   vms100.liruilongs.github.io   <none>           <none>
kube-system          kube-apiserver-vms101.liruilongs.github.io            1/1     Running            272 (5h29m ago)   415d   192.168.26.101   vms101.liruilongs.github.io   <none>           <none>
kube-system          kube-apiserver-vms102.liruilongs.github.io            1/1     Running            246 (5h29m ago)   415d   192.168.26.102   vms102.liruilongs.github.io   <none>           <none>
kube-system          etcd-vms100.liruilongs.github.io                      0/1     CrashLoopBackOff   3 (21s ago)       53s    192.168.26.100   vms100.liruilongs.github.io   <none>           <none>
kube-system          etcd-vms101.liruilongs.github.io                      1/1     Running            167 (5h29m ago)   415d   192.168.26.101   vms101.liruilongs.github.io   <none>           <none>
kube-system          etcd-vms102.liruilongs.github.io                      1/1     Running            173 (5h29m ago)   415d   192.168.26.102   vms102.liruilongs.github.io   <none>           <none>
查看日志
└─$kubectl logs etcd-vms100.liruilongs.github.io -n kube-system
{"level":"fatal","ts":"2024-03-16T16:25:19.981Z","caller":"etcdmain/etcd.go:204","msg":"discovery failed","error":"error validating peerURLs {ClusterID:4816f346663d82a7 Members:[&{ID:b8cb9f66c2e63b91 RaftAttributes:{PeerURLs:[https://192.168.26.102:2380] IsLearner:false} Attributes:{Name:vms102.liruilongs.github.io ClientURLs:[https://192.168.26.102:2379]}} &{ID:3fbbbed942c51f7b RaftAttributes:{PeerURLs:[https://192.168.26.100:2380] IsLearner:false} Attributes:{Name: ClientURLs:[]}} &{ID:70059e836d19883d RaftAttributes:{PeerURLs:[https://192.168.26.101:2380] IsLearner:false} Attributes:{Name:vms101.liruilongs.github.io ClientURLs:[https://192.168.26.101:2379]}}] RemovedMemberIDs:[]}: member count is unequal","stacktrace":"go.etcd.io/etcd/server/v3/etcdmain.startEtcdOrProxyV2\n\t/go/src/go.etcd.io/etcd/release/etcd/server/etcdmain/etcd.go:204\ngo.etcd.io/etcd/server/v3/etcdmain.Main\n\t/go/src/go.etcd.io/etcd/release/etcd/server/etcdmain/main.go:40\nmain.main\n\t/go/src/go.etcd.io/etcd/release/etcd/server/main.go:32\nruntime.main\n\t/go/gos/go1.16.15/src/runtime/proc.go:225"}
根据日志信息,可以看到有用的信息 RemovedMemberIDs:[]}: member count is unequal ,成员数量不相等,在分析日志
    "level": "info",
    "ts": "2024-03-16T16:25:19.961Z",
    "caller": "etcdmain/etcd.go:73",
    "msg": "Running: ",
    "args": [
        "etcd",
        "--initial-cluster=vms100.liruilongs.github.io=https://192.168.26.100:2380,vms101.liruilongs.github.io=https://192.168.26.101:2380",
        "--initial-cluster-state=existing",
    "level": "warn",
    "ts": "2024-03-16T16:25:19.981Z",
    "caller": "etcdmain/etcd.go:146",
    "msg": "failed to start etcd",
    "error": "error validating peerURLs {ClusterID:4816f346663d82a7 Members:[&{ID:b8cb9f66c2e63b91 RaftAttributes:{PeerURLs:[https://192.168.26.102:2380] IsLearner:false} Attributes:{Name:vms102.liruilongs.github.io ClientURLs:[https://192.168.26.102:2379]}} &{ID:3fbbbed942c51f7b RaftAttributes:{PeerURLs:[https://192.168.26.100:2380] IsLearner:false} Attributes:{Name: ClientURLs:[]}} &{ID:70059e836d19883d RaftAttributes:{PeerURLs:[https://192.168.26.101:2380] IsLearner:false} Attributes:{Name:vms101.liruilongs.github.io ClientURLs:[https://192.168.26.101:2379]}}] RemovedMemberIDs:[]}: member count is unequal"
    "level": "fatal",
    "caller": "etcdmain/etcd.go:204",
    "msg": "discovery failed",
    "error": "error validating peerURLs {ClusterID:4816f346663d82a7 Members:[&{ID:b8cb9f66c2e63b91 RaftAttributes:{PeerURLs:[https://192.168.26.102:2380] IsLearner:false} Attributes:{Name:vms102.liruilongs.github.io ClientURLs:[https://192.168.26.102:2379]}} &{ID:3fbbbed942c51f7b RaftAttributes:{PeerURLs:[https://192.168.26.100:2380] IsLearner:false} Attributes:{Name: ClientURLs:[]}} &{ID:70059e836d19883d RaftAttributes:{PeerURLs:[https://192.168.26.101:2380] IsLearner:false} Attributes:{Name:vms101.liruilongs.github.io ClientURLs:[https://192.168.26.101:2379]}}] RemovedMemberIDs:[]}: member count is unequal",
    "stacktrace": "go.etcd.io/etcd/server/v3/etcdmain.startEtcdOrProxyV2\n\t/go/src/go.etcd.io/etcd/release/etcd/server/etcdmain/etcd.go:204\ngo.etcd.io/etcd/server/v3/etcdmain.Main\n\t/go/src/go.etcd.io/etcd/release/etcd/server/etcdmain/main.go:40\nmain.main\n\t/go/src/go.etcd.io/etcd/release/etcd/server/main.go:32\nruntime.main\n\t/go/gos/go1.16.15/src/runtime/proc.go:225"
可以看到它提示 可能错误与 vms102.liruilongs.github.io 节点相关
然后我们看一下 vms102.liruilongs.github.io 的配置文件
┌──[root@vms102.liruilongs.github.io]-[~]
apiVersion: v1
kind: Pod
metadata:
  annotations:
    kubeadm.kubernetes.io/etcd.advertise-client-urls: https://192.168.26.102:2379
  labels:
    component: etcd
    tier: control-plane
spec:
  containers:
  - command:
    - etcd
    - --advertise-client-urls=https://192.168.26.102:2379
    - --initial-advertise-peer-urls=https://192.168.26.102:2380
    - --initial-cluster=vms100.liruilongs.github.io=https://192.168.26.100:2380,vms102.liruilongs.github.io=https://192.168.26.102:2380,vms101.liruilongs.github.io=https://192.168.26.101:2380
    - --listen-client-urls=https://127.0.0.1:2379,https://192.168.26.102:2379
    - --listen-peer-urls=https://192.168.26.102:2380
    - --name=vms102.liruilongs.github.io
通过配置文件比对,可以发现,之前配置的故障节点的配置任然有问题,少了一个vms102.liruilongs.github.io=https://192.168.26.102:2380节点信息。
"--initial-cluster=vms100.liruilongs.github.io=https://192.168.26.100:2380,vms102.liruilongs.github.io=https://192.168.26.102:2380,vms101.liruilongs.github.io=https://192.168.26.101:2380"
修改完配置,按照上面相同的流程重新恢复节点, 节点恢复
通过 etcdctl 命令检查
| ac5f6045dbe477b3 | started | vms100.liruilongs.github.io | https://192.168.26.100:2380 | https://192.168.26.100:2379 |
| https://192.168.26.101:2379 | 70059e836d19883d |   3.5.4 |   88 MB |     false |       603 |   22227327 |
| https://192.168.26.100:2379 | ac5f6045dbe477b3 |   3.5.4 |   88 MB |     false |       603 |   22227327 |
| https://192.168.26.102:2379 | b8cb9f66c2e63b91 |   3.5.4 |   88 MB |      true |       603 |   22227327 |
故障节点恢复,在实际的操作中,添加完节点,我们需要确认故障节点的配置文件是否是正确的配置文件
© 2018-2024 liruilonger@gmail.com, All rights reserved. 保持署名-非商用-相同方式共享(CC BY-NC-SA 4.0)
